03-05-2015, 04:45 | #1 (permalink) |
Freak Poster Join Date: Nov 2012 Location: Imus,Cavite
Member: 1844172 Status: Offline Sonork: 100.1620999 Thanks Meter: 49 | P768 write firmware failed... -------------------------------------------------------------------------------- Platform: LG Infineon Connection mode: OMAP Selected model: P768 Opening "LGP768fAT-00-V10a-724-05-OCT-15-2012_AP.oct"...OK Please, disconnect cable, reconnect battery, connect P999 cable (with 910k resistor) Initializing device...OK Writing Firmware... Connecting to modem CPU...OK Sending preloader...OK Sending loader...OK Initializing flash...OK Writing psi.fls...OK Writing slb.fls...OK Writing AENEAS_FW.fls...OK Writing L6260_SIC.fls...OK Writing L6260_SIC-CDS.fls...OK Connecting to application CPU...OK Erasing gpt1...OK Writing gpt1...OK Erasing u-boot... u-boot not erased. Trying to skip. Writing u-boot...Failed! |
03-05-2015, 07:07 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | What cable do You use exactly? You should use the special LG P999 cable (with 910k resistor inside), not standart Micro USB cable. Also say, what is the problem with your device exactly? What is the state of the phone? What is the firmware version in the phone? Why do You want to write firmware? Install the latest Software version (Software), connect the phone directly to PC motherboard USB port (don't use any USB hubs, this is important) and try to write firmware again. |
03-05-2015, 08:51 | #3 (permalink) |
Member: 1844172 Status: Offline Sonork: 100.1620999 Thanks Meter: 49 | the problem is lg logo then off i use Micro USB cable with 910k resistor directly to PC motherboard USB port status of phone now the same lg logo.. |
03-05-2015, 09:01 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Most likely, your device has HW issues (problems with phone's flash chip). Anyway, try to write other firmwares. If the problem is the same - check HW. |
03-05-2015, 09:17 | #5 (permalink) |
Member: 1844172 Status: Offline Sonork: 100.1620999 Thanks Meter: 49 | same problem i Install the latest Software version Welcome to Octoplus/Octopus Box LG Software version 1.8.6 -------------------------------------------------------------------------------- Platform: LG Infineon Connection mode: OMAP Selected model: P768 Opening "LGP768fAT-00-V10a-724-05-OCT-15-2012_AP.oct"...OK Please, disconnect cable, reconnect battery, connect P999 cable (with 910k resistor) Initializing device...OK Writing Firmware... Connecting to modem CPU...OK Sending preloader...OK Sending loader...OK Initializing flash...OK Writing psi.fls...OK Writing slb.fls...OK Writing AENEAS_FW.fls...OK Writing L6260_SIC.fls...OK Writing L6260_SIC-CDS.fls...OK Connecting to application CPU...OK Erasing gpt1...OK Writing gpt1...OK Erasing u-boot... u-boot not erased. Trying to skip. Writing u-boot...Failed! |
