05-15-2015, 06:51 | #1 (permalink) |
No Life Poster Join Date: Oct 2010 Location: colombo
Member: 1418524 Status: Offline Thanks Meter: 186 | P768g Writing u-boot...Failed! -------------------------------------------------------------------------------- Platform: LG Infineon Connection mode: OMAP Selected model: P768g Opening "LGP768gAT-00-V10a-AMX-XXX-DEC-17-2012+0_AP.oct"...OK Please, disconnect cable, reconnect battery, connect P999 cable (with 910k resistor) Initializing device...OK Writing Firmware... Connecting to modem CPU...OK Sending preloader...OK Sending loader...OK Initializing flash...OK Writing psi.fls...OK Writing slb.fls...OK Writing AENEAS_FW.fls...OK Writing L6260_SIC.fls...OK Writing L6260_SIC-CDS.fls...OK Connecting to application CPU...OK Erasing gpt1...OK Writing gpt1...OK Erasing u-boot... u-boot not erased. Trying to skip. Writing u-boot...Failed! -------------------------------------------------------------------------------- Platform: LG Infineon Connection mode: OMAP Selected model: P768g Please, disconnect cable, reconnect battery, connect P999 cable (with 910k resistor) Connecting...OK Sending preloader...OK Sending loader...OK Opening "LGP768gAT-00-V10a-AMX-XXX-DEC-17-2012+0_AP.oct"...OK Initializing device...OK Writing Firmware... Connecting to application CPU...OK Erasing gpt1... gpt1 not erased. Trying to skip. Writing gpt1...Failed! |
05-15-2015, 11:23 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Software can't erase and write u-boot section. Most likely, device has HW problems (problems with eMMC flash chip). Try to perform the Repair operation again: connect the cable directly to motherboard USB port, don't use any USB hubs or PCI USB cards. Try to connect the device to another motherboard USB ports. Try on another PC. If the problem is the same, this is HW problem. |
05-15-2015, 15:40 | #5 (permalink) |
Freak Poster Join Date: Jun 2008
Member: 785465 Status: Offline Thanks Meter: 7 | Octopus, team, I'm not an expert but, I have a P769 with the same phone, and is the second one that octoplus box kill, because all phones before use octoplus turn on. next time I will use the normal way, I have octoplus to make everything easier but that is not easy, this one has a problem that said encrypting or something like that, so i flash with octoplus and same error as OP. more likely is a error in the software. please check it. |
