09-15-2014, 08:59 | #1 (permalink) |
No Life Poster Join Date: Aug 2003 Location: Mars Age: 40
Member: 38084 Status: Offline Thanks Meter: 115 | P920 blank imei Please, disconnect battery and connect P999 cable (with 910k resistor). Initializing device...OK Writing Firmware... Connecting to modem CPU...OK Sending preloader...Failed! |
09-15-2014, 09:13 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Connect the device via P999 cable (with 910k resistor) directly to PC motherboard USB port, don't use any USB hubs or PCI USB extension cards, this is important and try to write firmware again. Try to connect the phone to different PC motherboard USB ports. Try to make Repair EEPROM also. Try on another PC. If the problem is still the same - most likely, this is HW problem. |
