12-26-2014, 18:41 | #1 (permalink) |
Freak Poster Join Date: Feb 2009
Member: 975562 Status: Offline Thanks Meter: 46 | please fix this error or how? Welcome to Octoplus/Octopus Box LG Software version 1.8.0 -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM34 Selected model: D820 Reading info...Failed! Could not detect mode! -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM34 Selected model: D820 Reading info...OK Mode: Fastboot Model ID: hammerhead D820(H) 32GB Device serial number: 03fc8ad313ad2a1e Hardware: rev_11 Bootloader lock state: unlocked -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM34 Selected model: D820 Reading info...OK Mode: Fastboot Model ID: hammerhead D820(H) 32GB Device serial number: 03fc8ad313ad2a1e Hardware: rev_11 Bootloader lock state: unlocked Fixing IMEI... New IMEI: 358239-05-420028-4 Switching to Normal mode... Please perform the following steps: 1. Wait while the phone will turn on 2. Reboot the phone 3. Enable "USB debugging" Mode 4. Connect the cable and check, whether ADB interface has appeared in PC Device Manager 5. Press "Ok" button. Initializing ADB...OK ADB Server was found. Trying to kill... Waiting for phone...Failed! More than one device, connected via ADB, were found. Please disconnect all devices from PC and connect only the device You want to work with. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM34 Selected model: D820 Reading info...OK Mode: Fastboot Model ID: hammerhead D820(H) 32GB Device serial number: 03fc8ad313ad2a1e Hardware: rev_11 Bootloader lock state: unlocked Fixing IMEI... New IMEI: 358239-05-420028-4 Switching to Normal mode... Please perform the following steps: 1. Wait while the phone will turn on 2. Reboot the phone 3. Enable "USB debugging" Mode 4. Connect the cable and check, whether ADB interface has appeared in PC Device Manager 5. Press "Ok" button. Initializing ADB...OK Waiting for phone...OK Switching to Fastboot mode...OK Unlocking Bootloader... Bootloader is unlocked. Writing Bootloader...OK Please, wait while the phone will turn on and press "Ok" button. Trying to enable Diagnostics ports... Initializing ADB...OK Waiting for phone... Please, reconnect phone, enable USB debugging, and try again. To enable USB debugging, please perform the following steps: 1. Disconnect cable 2. Install LG Android ADB drivers 3. Go to "Settings" -> "About phone" -> "Software information" 4. Click on Build number 5 times 5. Enable "Settings" -> "Developer options" -> "USB debugging" option 6. Connect the cable and check, whether ADB interface has appeared in PC Device Manager.Failed! Please, reconnect phone, enable USB debugging, and try again. To enable USB debugging, please perform the following steps: 1. Disconnect cable 2. Install LG Android ADB drivers 3. Go to "Settings" -> "About phone" -> "Software information" 4. Click on Build number 5 times 5. Enable "Settings" -> "Developer options" -> "USB debugging" option 6. Connect the cable and check, whether ADB interface has appeared in PC Device Manager.Failed! -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM34 Selected model: D820 Reading info...OK Mode: Fastboot Model ID: hammerhead D820(H) 32GB Device serial number: 03fc8ad313ad2a1e Hardware: rev_11 Bootloader lock state: unlocked Fixing IMEI... New IMEI: 358239-05-420028-4 Switching to Normal mode... Please perform the following steps: 1. Wait while the phone will turn on 2. Reboot the phone 3. Enable "USB debugging" Mode 4. Connect the cable and check, whether ADB interface has appeared in PC Device Manager 5. Press "Ok" button. Initializing ADB...OK Waiting for phone...OK Switching to Fastboot mode...OK Unlocking Bootloader... Bootloader is unlocked. Writing Bootloader...OK Please, wait while the phone will turn on and press "Ok" button. Trying to enable Diagnostics ports... Initializing ADB...OK Waiting for phone...OK Checking root access... Phone is already rooted. Diagnostics ports are enbled! Switching to Serial Port... Failed! |
12-26-2014, 18:51 | #3 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Hello. "Write Firmware" is currently not Supported for D820 phone. What version of Android has the phone at the moment? |
12-26-2014, 19:19 | #5 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Unfortunately "Repair IMEI" operation is not adapted for D820 phones with Android 5.0 firmware. On your own risk You can try to re-flash the phone with Nexus Root Toolkit, or in the way described here: https://developers.google.com/android/nexus/images |
