01-14-2017, 21:05 | #1 (permalink) |
Insane Poster Join Date: Nov 2013 Location: Havana,Cuba
Member: 2063322 Status: Offline Thanks Meter: 26 | Please Help frp remove H830 failed [Solved] -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM64 Selected model: H840 Please, put the phone into download mode manually (Power phone OFF, press and hold "Vol+" button and connect the cable (or P990 cable)). Reading info... Model ID: LG-H830 Incompatible model ID! Please, select correct model! Performed by 2.5.3 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM46 Selected model: H830 Please, put the phone into download mode manually (Power phone OFF, press and hold "Vol+" button and connect the cable). Reading info...Failed! Port busy Performed by 2.5.3 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM64 Selected model: H830 Please, put the phone into download mode manually (Power phone OFF, press and hold "Vol+" button and connect the cable). Reading info... Mode: Emergency Initializing flash...OK SW version: LGH830AT-01-V20a-310-260-NOV-07-2016-ARB01+0 Android version: 7.0 LAF Version: 1.1 Product ID: PT01S160601000527 IMEI: 356729-07-217671-6 Target operator: TMO Hardware: rev_10 Reading partitions...OK Resetting FRP Lock...Failed! LAF Error: 80000019. Reset FRP operation is currently not supported for your phone's firmware. Performed by 2.5.3 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM64 Selected model: H830 Please, put the phone into download mode manually (Power phone OFF, press and hold "Vol+" button and connect the cable). Reading info... Model ID: LG-H830 IMEI: Android version: 7.0 Battery level: 24% SW Version: H83020a Mode: Emergency Initializing flash...OK SW version: LGH830AT-01-V20a-310-260-NOV-07-2016-ARB01+0 Android version: 7.0 LAF Version: 1.1 Product ID: PT01S160601000527 IMEI: 356729-07-217671-6 Target operator: TMO Hardware: rev_10 Reading partitions...OK Resetting FRP Lock...Failed! Error code: KLQWHCKASD Performed by 2.5.3 Software version. Last edited by Octopus box; 03-15-2017 at 09:02. |
01-16-2017, 08:44 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Please install the latest Software version, then repeat "Reset FRP" operation again. Post here the result. Last edited by Octopus box; 01-16-2017 at 08:53. |
03-14-2017, 21:30 | #3 (permalink) |
No Life Poster Join Date: Nov 2005 Location: Sindhu Desh Age: 36
Member: 199814 Status: Offline Thanks Meter: 1,960 | Checking data...OK Platform: LG Qualcomm Selected port: COM149 Selected model: H830 Please, put the phone into download mode manually (Power phone OFF, press and hold "Vol+" button and connect the cable). Reading info... Model ID: LG-H830 IMEI: 358829-07-093607-5 Android version: 6.0.1 Battery level: 25% SW Version: H83010i Mode: Normal Switching to Download mode...OK Initializing flash...OK Reading partitions...OK Resetting FRP Lock... Resetting FRP lock successfully completed! Performed by 2.6.0 Software version. seems to be done thanks |
The Following User Says Thank You to asadnow2k For This Useful Post: |
