01-22-2018, 19:16 | #1 (permalink) |
No Life Poster Join Date: Jan 2009 Location: cameroon
Member: 953931 Status: Offline Sonork: 1652252 Thanks Meter: 897 | Please help me solve this [Answered] Server greeting: "Card updates server v.2.2" Searching installed cards... Found card with s/n 01026C69 The card is not valid card. Found card with s/n 00046E6E Selected card: 0000046E6E Updates count: 21 Updates limit: 31 Activations: - LG - FULL (ver 2.5) - Samsung - NO - JTAG - NO - FRP - NO Creating secure connection... Requesting firmware... Writing card firmware... Failed! Error at cmd #3 Last edited by Octopus box; 01-23-2018 at 08:14. |
01-23-2018, 08:11 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Hello. Disconnect all other devices from PC, take out smart card from the Box, clean the card's contacts, then try to update card firmware again. Also try to put card into an external card reader (dongle) or into another box (use the box as a card reader) and re-update card. Write here the result. Connect Box/card reader directly to PC motherboard USB port, it is better don't use USB hubs. |
01-23-2018, 10:56 | #4 (permalink) |
Member: 953931 Status: Offline Sonork: 1652252 Thanks Meter: 897 | Searching for server... Server greeting: "Card updates server v.2.2" Searching installed cards... Found card with s/n 00046E6E Selected card: 0000046E6E Updates count: 31 Updates limit: 31 Activations: - LG - FULL (ver 2.5) - Samsung - NO - JTAG - NO - FRP - NO Creating secure connection... The number of updates has exceeded the maximum value! Could not create secure connection! |
01-23-2018, 12:18 | #6 (permalink) |
Member: 953931 Status: Offline Sonork: 1652252 Thanks Meter: 897 | Searching for server... Server greeting: "Card updates server v.2.2" Searching installed cards... Found card with s/n 00046E6E Selected card: 0000046E6E Updates count: 31 Updates limit: 34 Activations: - LG - FULL (ver 2.5) - Samsung - NO - JTAG - NO - FRP - NO Creating secure connection... [0000.2]Exception: ''$ [0000]Exception: RichEdit line insertion error Requesting firmware... Writing card firmware... Failed! Error at cmd #4 |
01-23-2018, 12:43 | #7 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Your card doesn't answer to Software's commands. This can be the problem with used card reader or problem with card. Try to use another external card reader. Also try to re-update card on another PC. If the problem is still the same, most likely, card is damaged. |
