06-26-2014, 14:00 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. What is the state of your device exactly? What is the firmware version in the phone? To write firmware, You should use the special P999 cable with 910 kOhm resistor inside, not standard Micro USB cable! Connect the device directly to PC motherboard USB port, don't use any USB hubs or USB PCI extention card, this is important. Connect only to PC motherboard USB port. Try to write firmware on another PC. If the problem is the same - check HW, this can be HW problem. |
06-27-2014, 04:47 | #3 (permalink) | |
Crazy Poster Join Date: May 2014
Member: 2178225 Status: Offline Sonork: 100.1638479 Thanks Meter: 4 | Quote:
sir pls help me sir my phone connect for the pc but application cpu error | |
06-27-2014, 06:20 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Do You use the special cable? Try to write firmware on another PC. If the problem is the same - most likely, this is HW problem. |
