03-24-2015, 21:41 | #1 (permalink) |
Junior Member Join Date: Jun 2014
Member: 2210735 Status: Offline Thanks Meter: 1 | problem with d820 error code Error code: ZXLCALSZXD [Solved] -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM33 Selected model: D820 Reading info... Initializing ADB...OK ADB Server was found. Trying to kill... Waiting for phone...OK Model ID: Nexus 5 Firmware version: Kernel version: 3.4.0-gd59db4e Android version: 4.4.4 Hardware: ARMv7 After perform Repair IMEI operation, 3G/4G network will be unavailable! Initializing ADB...OK Waiting for phone...OK Switching to Fastboot mode...OK Unlocking Bootloader... Bootloader is unlocked. Writing Bootloader...OK Please, wait while the phone will turn on and press "Ok" button. Trying to enable Diagnostics ports... Initializing ADB...OK ADB Server was found. Trying to kill... Waiting for phone...OK Checking root access... Phone is already rooted. Diagnostics ports are enbled! Switching to Serial Port... Found model AAAAANAZ*ÿh°G at port COM32 Reading info...OK Mode: Normal Model ID: AAAAANAZ*ÿh°G Firmware compiled date: Mar 12 2014 Firmware compiled time: 20:00:00 Firmware released date: Jun 4 2014 Firmware released time: 17:04:20 SW Version: M8974A-2.0.50.1.16 Fixing IMEI... New IMEI: 900326-58-421111-4 Reading NVM...OK Backup saved to "D820_Bad_24-03-2015_14-52-01.NVM" Reading EFS...OK Backup saved to "D820_Bad_24-03-2015_14-53-32.EFS" Switching to Download mode...OK Initializing flash...OK Reading partition...OK Reading security area...OK Backup saved to "D820_Bad_24-03-2015_14-54-05.SEC" Writing security area...OK Switching to Normal mode... Please perform the following steps: 1. Wait while the phone will turn on 2. Reboot the phone 3. Enable "USB debugging" Mode 4. Connect the cable and check, whether ADB interface has appeared in PC Device Manager 5. Press "Ok" button. Initializing ADB...OK ADB Server was found. Trying to kill... Waiting for phone...OK Switching to Fastboot mode...OK Unlocking Bootloader... Select "Yes" on phone screen and press "Power" button. Please perform the following steps: 1. Wait while the phone will turn on 2. Reboot the phone 3. Enable "USB debugging" Mode 4. Connect the cable and check, whether ADB interface has appeared in PC Device Manager 5. Press "Ok" button. Initializing ADB...OK ADB Server was found. Trying to kill... Waiting for phone...OK Switching to Fastboot mode...OK Bootloader is unlocked. Writing Bootloader...OK Please, wait while the phone will turn on and press "Ok" button. Trying to enable Diagnostics ports... Initializing ADB...OK ADB Server was found. Trying to kill... Waiting for phone...OK Checking root access... Phone is already rooted. Diagnostics ports are enbled! Switching to Serial Port... Found model AAAAANAZ*ÿh°G at port COM32 Checking data...OK Writing NVM...Failed! Error code: ZXLCALSZXD Last edited by Octopus box; 03-27-2015 at 06:55. |
03-24-2015, 22:03 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Install latest Software version (Software) and repeat "Repair IMEI" operation. Post here full Software log of the operation. |
03-27-2015, 00:18 | #3 (permalink) |
Member: 2210735 Status: Offline Thanks Meter: 1 | it workied with the old version Welcome to Octoplus/Octopus Box LG Software version 1.6.6 -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM45 Selected model: D820 Reading info...Failed! Port busyFailed! Could not detect mode! -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM45 Selected model: D820 Reading info...Failed! Port busyFailed! Could not detect mode! -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM45 Selected model: D820 Reading info...Failed! Port busyFailed! Could not detect mode! -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM33 Selected model: D820 Reading info... Initializing ADB...OK ADB Server was found. Trying to kill... Waiting for phone...OK Model ID: Nexus 5 Firmware version: Kernel version: 3.4.0-gd59db4e Android version: 4.4.4 Hardware: ARMv7 -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM33 Selected model: D820 Reading info... Initializing ADB...OK Waiting for phone...OK Model ID: Nexus 5 Firmware version: Kernel version: 3.4.0-gd59db4e Android version: 4.4.4 Hardware: ARMv7 After perform Repair IMEI operation, 3G/4G network will be unavailable! Initializing ADB...OK Waiting for phone...OK Switching to Fastboot mode...OK Unlocking Bootloader... Bootloader is unlocked. Writing Bootloader...OK Please, wait while the phone will turn on and press "Ok" button. Trying to enable Diagnostics ports... Initializing ADB...OK ADB Server was found. Trying to kill... Waiting for phone...OK Checking root access... Phone is already rooted. Diagnostics ports are enbled! Switching to Serial Port... Found model AAAAANAZ*ÿh°G at port COM32 Reading info...OK Mode: Normal Model ID: AAAAANAZ*ÿh°G Firmware compiled date: Mar 12 2014 Firmware compiled time: 20:00:00 Firmware released date: Jun 4 2014 Firmware released time: 17:04:20 SW Version: M8974A-2.0.50.1.16 Fixing IMEI... New IMEI: 900325-15-899999-7 Reading NVM...OK Backup saved to "D820_Bad_26-03-2015_18-00-09.NVM" Reading EFS...OK Backup saved to "D820_Bad_26-03-2015_18-02-31.EFS" Switching to Download mode...OK Initializing flash...OK Reading partition...OK Reading security area...OK Backup saved to "D820_Bad_26-03-2015_18-03-03.SEC" Writing security area...OK Switching to Normal mode... Please perform the following steps: 1. Wait while the phone will turn on 2. Reboot the phone 3. Enable "USB debugging" Mode 4. Connect the cable and check, whether ADB interface has appeared in PC Device Manager 5. Press "Ok" button. Initializing ADB...OK ADB Server was found. Trying to kill... Waiting for phone...OK Switching to Fastboot mode...OK Unlocking Bootloader... Select "Yes" on phone screen and press "Power" button. Please perform the following steps: 1. Wait while the phone will turn on 2. Reboot the phone 3. Enable "USB debugging" Mode 4. Connect the cable and check, whether ADB interface has appeared in PC Device Manager 5. Press "Ok" button. Initializing ADB...OK ADB Server was found. Trying to kill... Waiting for phone...OK Switching to Fastboot mode...OK Bootloader is unlocked. Writing Bootloader...OK Please, wait while the phone will turn on and press "Ok" button. Trying to enable Diagnostics ports... Initializing ADB...OK ADB Server was found. Trying to kill... Waiting for phone...OK Checking root access... Phone is already rooted. Diagnostics ports are enbled! Switching to Serial Port... Found model AAAAANAZ*ÿh°G at port COM32 Checking data...OK Writing NVM...OK NVM succesfully repaired. Writing EFS...OK IMEI successfully fixed! To complete the operation, please make Factory Reset (Go to "Settings" -> "General" -> "Backup & reset" -> "Factory data reset", press "Reset phone" and "Erase everything" buttons). |
