07-08-2016, 16:45
#1 (permalink)
Join Date: Apr 2009 Location: Salvador - BA - Brazil Age: 37
Member: 1010981
Sonork: 100.1614537 Thanks Meter: 47 | Repair imei H736P (dual sim) MANY ERROS: I cant repair imei for this phone. Anyone can help-me?
Log file: Quote:
8/7/2016 12:24:40 > Welcome to Octoplus/Octopus Box LG Software version 2.3.5
8/7/2016 12:25:57 > --------------------------------------------------------------------------------
8/7/2016 12:25:57 > Checking data...8/7/2016 12:25:58 > OK
8/7/2016 12:25:58 > Platform: LG Qualcomm
8/7/2016 12:25:58 > Selected port: COM101
8/7/2016 12:25:58 > Selected model: H736P
8/7/2016 12:25:58 > Reading info...
8/7/2016 12:26:00 > Model ID: LG-H736P
8/7/2016 12:26:00 > IMEI: 352622-07-128439-7
8/7/2016 12:26:00 > Android version: 6.0
8/7/2016 12:26:00 > Battery level: 85%
8/7/2016 12:26:10 > Mode: Normal
8/7/2016 12:26:10 > Fixing IMEI...
8/7/2016 12:26:10 > New IMEI A: 350411-23-413999-1
8/7/2016 12:26:10 > New IMEI B: 350144-23-413999-8
8/7/2016 12:26:12 > Skip Read/Write QCN
8/7/2016 12:26:12 > Do you want to create security backup?
8/7/2016 12:26:16 > Writing security area...8/7/2016 12:26:19 > Failed!
8/7/2016 12:26:19 > Performed by 2.3.5 software version.
8/7/2016 12:26:23 > --------------------------------------------------------------------------------
8/7/2016 12:26:23 > Checking data...8/7/2016 12:26:24 > OK
8/7/2016 12:26:24 > Platform: LG Qualcomm
8/7/2016 12:26:24 > Selected port: COM101
8/7/2016 12:26:24 > Selected model: H736P
8/7/2016 12:26:24 > Reading info...
8/7/2016 12:26:26 > Model ID: LG-H736P
8/7/2016 12:26:26 > IMEI: 352622-07-128439-7
8/7/2016 12:26:26 > Android version: 6.0
8/7/2016 12:26:26 > Battery level: 85%
8/7/2016 12:26:36 > Mode: Normal
8/7/2016 12:26:36 > Fixing IMEI...
8/7/2016 12:26:36 > New IMEI A: 350411-23-413999-1
8/7/2016 12:26:36 > New IMEI B: 350144-23-413999-8
8/7/2016 12:26:38 > Skip Read/Write QCN
8/7/2016 12:26:38 > Do you want to create security backup?
8/7/2016 12:26:42 > Switching to Download mode...8/7/2016 12:27:07 > OK
8/7/2016 12:27:07 > Initializing flash...8/7/2016 12:27:09 > OK
8/7/2016 12:27:09 > Reading partitions...8/7/2016 12:27:11 > OK
8/7/2016 12:27:11 > Reading security area...8/7/2016 12:27:12 > OK
8/7/2016 12:27:12 > Backup saved to "H736P_352622071284397_08-07-2016_12-26-42.SEC"
8/7/2016 12:27:12 > Switching to Normal mode...
8/7/2016 12:28:57 > Trying to enable Diagnostics ports...
8/7/2016 12:28:57 > Initializing ADB...8/7/2016 12:28:58 > OK
8/7/2016 12:28:58 > Waiting for phone...8/7/2016 12:29:01 > OK
8/7/2016 12:29:03 > Diagnostics ports are enbled!
8/7/2016 12:29:03 > Switching to Serial Port...
8/7/2016 12:29:33 > Failed!
8/7/2016 12:29:33 > Trying to enable Diagnostics ports...
8/7/2016 12:29:33 > Checking root access...
8/7/2016 12:29:34 > Phone is not rooted.
8/7/2016 12:29:35 > Please, root the phone manually!
8/7/2016 12:29:35 > Please perform the following steps:
1. Disconnect cable
2. Put phone into Normal mode manually
3. Press "Ok" button
8/7/2016 12:31:41 > Trying to enable Diagnostics ports...
8/7/2016 12:31:41 > Failed!
8/7/2016 12:31:43 > Writing security area...
8/7/2016 12:31:43 > Performed by 2.3.5 software version.
8/7/2016 12:31:47 > --------------------------------------------------------------------------------
8/7/2016 12:31:47 > Checking data...8/7/2016 12:31:49 > OK
8/7/2016 12:31:49 > Platform: LG Qualcomm
8/7/2016 12:31:49 > Selected port: COM101
8/7/2016 12:31:49 > Selected model: H736P
8/7/2016 12:31:49 > Reading info...
8/7/2016 12:31:51 > Model ID: LG-H736P
8/7/2016 12:31:51 > IMEI: 352622-07-128439-7
8/7/2016 12:31:51 > Android version: 6.0
8/7/2016 12:31:51 > Battery level: 85%
8/7/2016 12:32:00 > Mode: Normal
8/7/2016 12:32:00 > Fixing IMEI...
8/7/2016 12:32:00 > New IMEI A: 350411-23-413999-1
8/7/2016 12:32:00 > New IMEI B: 350144-23-413999-8
8/7/2016 12:32:02 > Skip Read/Write QCN
8/7/2016 12:32:02 > Do you want to create security backup?
8/7/2016 12:32:13 > Switching to Download mode...8/7/2016 12:32:39 > OK
8/7/2016 12:32:39 > Initializing flash...8/7/2016 12:32:40 > OK
8/7/2016 12:32:41 > Reading partitions...8/7/2016 12:32:43 > OK
8/7/2016 12:32:43 > Reading security area...8/7/2016 12:32:44 > OK
8/7/2016 12:32:44 > Backup saved to "H736P_352622071284397_08-07-2016_12-32-13.SEC"
8/7/2016 12:32:44 > Switching to Normal mode...
8/7/2016 12:33:40 > Trying to enable Diagnostics ports...
8/7/2016 12:33:40 > Initializing ADB...8/7/2016 12:33:41 > OK
8/7/2016 12:33:41 > Waiting for phone...
8/7/2016 12:33:41 > Please, reconnect phone, enable USB debugging, and try again.
8/7/2016 12:33:41 > To enable USB debugging, please perform the following steps:
1. Disconnect cable
2. Install LG Android ADB drivers
3. Go to "Settings" -> "About phone" -> "Software information"
4. Click on Build number 5 times
5. Enable "Settings" -> "Developer options" -> "USB debugging" option
6. Connect the cable and check, whether ADB interface has appeared in PC Device Manager.8/7/2016 12:33:44 > OK
8/7/2016 12:33:45 > Diagnostics ports are enbled!
8/7/2016 12:33:45 > Switching to Serial Port...
8/7/2016 12:34:15 > Failed!
8/7/2016 12:34:15 > Trying to enable Diagnostics ports...
8/7/2016 12:34:15 > Checking root access...
8/7/2016 12:34:16 > Phone is not rooted.
8/7/2016 12:34:17 > Please, root the phone manually!
8/7/2016 12:34:17 > Please perform the following steps:
1. Disconnect cable
8/7/2016 12:34:23 > Trying to enable Diagnostics ports...
8/7/2016 12:34:24 > Diagnostics ports are enbled!
8/7/2016 12:34:24 > Switching to Serial Port...
8/7/2016 12:34:54 > Failed!
8/7/2016 12:34:54 > Trying to enable Diagnostics ports...
8/7/2016 12:34:54 > Checking root access...
8/7/2016 12:34:55 > Phone is not rooted.
8/7/2016 12:34:56 > Please, root the phone manually!
8/7/2016 12:34:56 > Performed by 2.3.5 software version.
8/7/2016 12:35:32 > --------------------------------------------------------------------------------
8/7/2016 12:35:32 > Checking data...8/7/2016 12:35:34 > OK
8/7/2016 12:35:34 > Platform: LG Qualcomm
8/7/2016 12:35:34 > Selected port: COM101
8/7/2016 12:35:34 > Selected model: H736P
8/7/2016 12:35:34 > Reading info...
8/7/2016 12:35:36 > Model ID: LG-H736P
8/7/2016 12:35:36 > IMEI: 352622-07-128439-7
8/7/2016 12:35:36 > Android version: 6.0
8/7/2016 12:35:36 > Battery level: 85%
8/7/2016 12:35:46 > Mode: Normal
8/7/2016 12:35:46 > Selecting input file...8/7/2016 12:36:03 > OK
8/7/2016 12:36:03 > Source file: "H736_QCN_02-10-2015_10-32-56.qcn"
8/7/2016 12:36:03 > Do You want to write IMEI from QCN file
or to leave current IMEI?
8/7/2016 12:36:04 > Write IMEI from QCN file!
8/7/2016 12:36:05 > Send SPC...8/7/2016 12:36:14 > OK
8/7/2016 12:36:14 > Writing QCN...
8/7/2016 12:36:17 > Could not read phone ESN!
8/7/2016 12:36:17 > Writing EFS...
8/7/2016 12:36:24 > Warning: /nv/item_files/rfnv/00020085 not wrote.
8/7/2016 12:36:33 > Warning: /nv/item_files/rfnv/00020086 not wrote.
8/7/2016 12:36:42 > Warning: /nv/item_files/rfnv/00020089 not wrote.
8/7/2016 12:36:48 > Warning: /nv/item_files/rfnv/00020090 not wrote.
8/7/2016 12:36:55 > Warning: /nv/item_files/rfnv/00020095 not wrote.
8/7/2016 12:36:58 > Warning: /nv/item_files/rfnv/00020099 not wrote.
8/7/2016 12:36:58 > Warning: /nv/item_files/rfnv/00020100 not wrote.
8/7/2016 12:36:58 > Warning: /nv/item_files/rfnv/00020101 not wrote.
8/7/2016 12:36:58 > Warning: /nv/item_files/rfnv/00020102 not wrote.
8/7/2016 12:36:58 > Warning: /nv/item_files/rfnv/00020103 not wrote.
8/7/2016 12:36:58 > Warning: /nv/item_files/rfnv/00020104 not wrote.
8/7/2016 12:36:58 > Warning: /nv/item_files/rfnv/00020105 not wrote.
8/7/2016 12:36:58 > Warning: /nv/item_files/rfnv/00020106 not wrote.
8/7/2016 12:36:58 > Warning: /nv/item_files/rfnv/00020107 not wrote.
8/7/2016 12:36:58 > Warning: /nv/item_files/rfnv/00020108 not wrote.
8/7/2016 12:36:58 > Warning: /nv/item_files/rfnv/00020109 not wrote.
8/7/2016 12:36:58 > Warning: /nv/item_files/rfnv/00020110 not wrote.
8/7/2016 12:36:58 > Warning: /nv/item_files/rfnv/00020120 not wrote.
8/7/2016 12:36:58 > Warning: /nv/item_files/rfnv/00020121 not wrote.
8/7/2016 12:36:58 > Warning: /nv/item_files/rfnv/00020122 not wrote.
8/7/2016 12:36:58 > Warning: /nv/item_files/rfnv/00020128 not wrote.
8/7/2016 12:36:58 > Warning: /nv/item_files/rfnv/00020132 not wrote.
8/7/2016 12:36:58 > Warning: /nv/item_files/rfnv/00020133 not wrote.
8/7/2016 12:36:58 > Warning: /nv/item_files/rfnv/00020135 not wrote.
8/7/2016 12:36:59 > Warning: /nv/item_files/rfnv/00020144 not wrote.
8/7/2016 12:36:59 > Warning: /nv/item_files/rfnv/00020145 not wrote.
8/7/2016 12:36:59 > Warning: /nv/item_files/rfnv/00020148 not wrote.
8/7/2016 12:36:59 > Warning: /nv/item_files/rfnv/00020149 not wrote.
8/7/2016 12:36:59 > Warning: /nv/item_files/rfnv/00020154 not wrote.
8/7/2016 12:36:59 > Warning: /nv/item_files/rfnv/00020158 not wrote.
8/7/2016 12:36:59 > Warning: /nv/item_files/rfnv/00020159 not wrote.
8/7/2016 12:36:59 > Warning: /nv/item_files/rfnv/00020160 not wrote.
8/7/2016 12:36:59 > Warning: /nv/item_files/rfnv/00020161 not wrote.
8/7/2016 12:36:59 > Warning: /nv/item_files/rfnv/00020162 not wrote.
8/7/2016 12:36:59 > Warning: /nv/item_files/rfnv/00020163 not wrote.
8/7/2016 12:36:59 > Warning: /nv/item_files/rfnv/00020164 not wrote.
8/7/2016 12:36:59 > Warning: /nv/item_files/rfnv/00020165 not wrote.
8/7/2016 12:36:59 > Warning: /nv/item_files/rfnv/00020166 not wrote.
8/7/2016 12:36:59 > Warning: /nv/item_files/rfnv/00020167 not wrote.
8/7/2016 12:36:59 > Warning: /nv/item_files/rfnv/00020168 not wrote.
8/7/2016 12:36:59 > Warning: /nv/item_files/rfnv/00020169 not wrote.
8/7/2016 12:36:59 > Warning: /nv/item_files/rfnv/00020179 not wrote.
8/7/2016 12:36:59 > Warning: /nv/item_files/rfnv/00020180 not wrote.
8/7/2016 12:36:59 > Warning: /nv/item_files/rfnv/00020181 not wrote.
8/7/2016 12:36:59 > Warning: /nv/item_files/rfnv/00020187 not wrote.
8/7/2016 12:36:59 > Warning: /nv/item_files/rfnv/00020191 not wrote.
8/7/2016 12:36:59 > Warning: /nv/item_files/rfnv/00020192 not wrote.
8/7/2016 12:36:59 > Warning: /nv/item_files/rfnv/00020194 not wrote.
8/7/2016 12:36:59 > Warning: /nv/item_files/rfnv/00020207 not wrote.
8/7/2016 12:36:59 > Warning: /nv/item_files/rfnv/00020208 not wrote.
8/7/2016 12:36:59 > Warning: /nv/item_files/rfnv/00020209 not wrote.
8/7/2016 12:36:59 > Warning: /nv/item_files/rfnv/00020210 not wrote.
8/7/2016 12:36:59 > Warning: /nv/item_files/rfnv/00020213 not wrote.
8/7/2016 12:36:59 > Warning: /nv/item_files/rfnv/00020215 not wrote.
8/7/2016 12:36:59 > Warning: /nv/item_files/rfnv/00020216 not wrote.
8/7/2016 12:36:59 > Warning: /nv/item_files/rfnv/00020219 not wrote.
8/7/2016 12:36:59 > Warning: /nv/item_files/rfnv/00020220 not wrote.
8/7/2016 12:36:59 > Warning: /nv/item_files/rfnv/00020223 not wrote.
8/7/2016 12:36:59 > Warning: /nv/item_files/rfnv/00020224 not wrote.
8/7/2016 12:36:59 > Warning: /nv/item_files/rfnv/00020229 not wrote.
8/7/2016 12:36:59 > Warning: /nv/item_files/rfnv/00020233 not wrote.
8/7/2016 12:36:59 > Warning: /nv/item_files/rfnv/00020234 not wrote.
8/7/2016 12:36:59 > Warning: /nv/item_files/rfnv/00020235 not wrote.
8/7/2016 12:36:59 > Warning: /nv/item_files/rfnv/00020236 not wrote.
8/7/2016 12:36:59 > Warning: /nv/item_files/rfnv/00020237 not wrote.
8/7/2016 12:36:59 > Warning: /nv/item_files/rfnv/00020238 not wrote.
8/7/2016 12:36:59 > Warning: /nv/item_files/rfnv/00020239 not wrote.
8/7/2016 12:36:59 > Warning: /nv/item_files/rfnv/00020240 not wrote.
8/7/2016 12:36:59 > Warning: /nv/item_files/rfnv/00020241 not wrote.
8/7/2016 12:36:59 > Warning: /nv/item_files/rfnv/00020242 not wrote.
8/7/2016 12:36:59 > Warning: /nv/item_files/rfnv/00020243 not wrote.
8/7/2016 12:36:59 > Warning: /nv/item_files/rfnv/00020244 not wrote.
8/7/2016 12:36:59 > Warning: /nv/item_files/rfnv/00020254 not wrote.
8/7/2016 12:36:59 > Warning: /nv/item_files/rfnv/00020255 not wrote.
8/7/2016 12:36:59 > Warning: /nv/item_files/rfnv/00020262 not wrote.
8/7/2016 12:36:59 > Warning: /nv/item_files/rfnv/00020274 not wrote.
8/7/2016 12:36:59 > Warning: /nv/item_files/rfnv/00020275 not wrote.
8/7/2016 12:36:59 > Warning: /nv/item_files/rfnv/00020278 not wrote.
8/7/2016 12:36:59 > Warning: /nv/item_files/rfnv/00020279 not wrote.
8/7/2016 12:36:59 > Warning: /nv/item_files/rfnv/00020284 not wrote.
8/7/2016 12:36:59 > Warning: /nv/item_files/rfnv/00020288 not wrote.
8/7/2016 12:36:59 > Warning: /nv/item_files/rfnv/00020289 not wrote.
8/7/2016 12:36:59 > Warning: /nv/item_files/rfnv/00020290 not wrote.
8/7/2016 12:36:59 > Warning: /nv/item_files/rfnv/00020291 not wrote.
8/7/2016 12:36:59 > Warning: /nv/item_files/rfnv/00020292 not wrote.
8/7/2016 12:36:59 > Warning: /nv/item_files/rfnv/00020293 not wrote.
8/7/2016 12:36:59 > Warning: /nv/item_files/rfnv/00020294 not wrote.
8/7/2016 12:36:59 > Warning: /nv/item_files/rfnv/00020295 not wrote.
8/7/2016 12:36:59 > Warning: /nv/item_files/rfnv/00020296 not wrote.
8/7/2016 12:36:59 > Warning: /nv/item_files/rfnv/00020297 not wrote.
8/7/2016 12:36:59 > Warning: /nv/item_files/rfnv/00020298 not wrote.
8/7/2016 12:36:59 > Warning: /nv/item_files/rfnv/00020299 not wrote.
8/7/2016 12:36:59 > Warning: /nv/item_files/rfnv/00020309 not wrote.
8/7/2016 12:36:59 > Warning: /nv/item_files/rfnv/00020310 not wrote.
8/7/2016 12:36:59 > Warning: /nv/item_files/rfnv/00020311 not wrote.
8/7/2016 12:36:59 > Warning: /nv/item_files/rfnv/00020317 not wrote.
8/7/2016 12:36:59 > Warning: /nv/item_files/rfnv/00020321 not wrote.
8/7/2016 12:36:59 > Warning: /nv/item_files/rfnv/00020322 not wrote.
8/7/2016 12:36:59 > Warning: /nv/item_files/rfnv/00020324 not wrote.
8/7/2016 12:36:59 > Warning: /nv/item_files/rfnv/00020457 not wrote.
8/7/2016 12:36:59 > Warning: /nv/item_files/rfnv/00020458 not wrote.
8/7/2016 12:36:59 > Warning: /nv/item_files/rfnv/00020459 not wrote.
8/7/2016 12:36:59 > Warning: /nv/item_files/rfnv/00020462 not wrote.
8/7/2016 12:36:59 > Warning: /nv/item_files/rfnv/00020463 not wrote.
8/7/2016 12:36:59 > Warning: /nv/item_files/rfnv/00020464 not wrote.
8/7/2016 12:36:59 > Warning: /nv/item_files/rfnv/00020465 not wrote.
8/7/2016 12:36:59 > Warning: /nv/item_files/rfnv/00020466 not wrote.
8/7/2016 12:36:59 > Warning: /nv/item_files/rfnv/00020467 not wrote.
8/7/2016 12:36:59 > Warning: /nv/item_files/rfnv/00020468 not wrote.
8/7/2016 12:36:59 > Warning: /nv/item_files/rfnv/00020469 not wrote.
8/7/2016 12:36:59 > Warning: /nv/item_files/rfnv/00020470 not wrote.
8/7/2016 12:36:59 > Warning: /nv/item_files/rfnv/00020475 not wrote.
8/7/2016 12:36:59 > Warning: /nv/item_files/rfnv/00020476 not wrote.
8/7/2016 12:36:59 > Warning: /nv/item_files/rfnv/00020477 not wrote.
8/7/2016 12:36:59 > Warning: /nv/item_files/rfnv/00020480 not wrote.
8/7/2016 12:36:59 > Warning: /nv/item_files/rfnv/00020531 not wrote.
8/7/2016 12:36:59 > Warning: /nv/item_files/rfnv/00020532 not wrote.
8/7/2016 12:36:59 > Warning: /nv/item_files/rfnv/00020533 not wrote.
8/7/2016 12:36:59 > Warning: /nv/item_files/rfnv/00020536 not wrote.
8/7/2016 12:36:59 > Warning: /nv/item_files/rfnv/00020537 not wrote.
8/7/2016 12:36:59 > Warning: /nv/item_files/rfnv/00020538 not wrote.
8/7/2016 12:36:59 > Warning: /nv/item_files/rfnv/00020539 not wrote.
8/7/2016 12:36:59 > Warning: /nv/item_files/rfnv/00020540 not wrote.
8/7/2016 12:36:59 > Warning: /nv/item_files/rfnv/00020541 not wrote.
8/7/2016 12:36:59 > Warning: /nv/item_files/rfnv/00020542 not wrote.
8/7/2016 12:36:59 > Warning: /nv/item_files/rfnv/00020543 not wrote.
8/7/2016 12:36:59 > Warning: /nv/item_files/rfnv/00020544 not wrote.
8/7/2016 12:36:59 > Warning: /nv/item_files/rfnv/00020549 not wrote.
8/7/2016 12:36:59 > Warning: /nv/item_files/rfnv/00020550 not wrote.
8/7/2016 12:36:59 > Warning: /nv/item_files/rfnv/00020551 not wrote.
8/7/2016 12:36:59 > Warning: /nv/item_files/rfnv/00020552 not wrote.
8/7/2016 12:36:59 > Warning: /nv/item_files/rfnv/00020554 not wrote.
8/7/2016 12:36:59 > Warning: /nv/item_files/rfnv/00020612 not wrote.
8/7/2016 12:36:59 > Warning: /nv/item_files/rfnv/00020613 not wrote.
8/7/2016 12:36:59 > Warning: /nv/item_files/rfnv/00020614 not wrote.
8/7/2016 12:36:59 > Warning: /nv/item_files/rfnv/00020615 not wrote.
8/7/2016 12:36:59 > Warning: /nv/item_files/rfnv/00020616 not wrote.
8/7/2016 12:36:59 > Warning: /nv/item_files/rfnv/00020617 not wrote.
8/7/2016 12:36:59 > Warning: /nv/item_files/rfnv/00020785 not wrote.
8/7/2016 12:36:59 > Warning: /nv/item_files/rfnv/00020790 not wrote.
8/7/2016 12:36:59 > Warning: /nv/item_files/rfnv/00020791 not wrote.
8/7/2016 12:36:59 > Warning: /nv/item_files/rfnv/00020794 not wrote.
8/7/2016 12:37:00 > Warning: /nv/item_files/rfnv/00020795 not wrote.
8/7/2016 12:37:00 > Warning: /nv/item_files/rfnv/00020800 not wrote.
8/7/2016 12:37:00 > Warning: /nv/item_files/rfnv/00020804 not wrote.
8/7/2016 12:37:00 > Warning: /nv/item_files/rfnv/00020805 not wrote.
8/7/2016 12:37:00 > Warning: /nv/item_files/rfnv/00020806 not wrote.
8/7/2016 12:37:00 > Warning: /nv/item_files/rfnv/00020807 not wrote.
8/7/2016 12:37:00 > Warning: /nv/item_files/rfnv/00020808 not wrote.
8/7/2016 12:37:00 > Warning: /nv/item_files/rfnv/00020809 not wrote.
8/7/2016 12:37:00 > Warning: /nv/item_files/rfnv/00020810 not wrote.
8/7/2016 12:37:00 > Warning: /nv/item_files/rfnv/00020811 not wrote.
8/7/2016 12:37:00 > Warning: /nv/item_files/rfnv/00020812 not wrote.
8/7/2016 12:37:00 > Warning: /nv/item_files/rfnv/00020813 not wrote.
8/7/2016 12:37:00 > Warning: /nv/item_files/rfnv/00020814 not wrote.
8/7/2016 12:37:00 > Warning: /nv/item_files/rfnv/00020815 not wrote.
8/7/2016 12:37:00 > Warning: /nv/item_files/rfnv/00020825 not wrote.
8/7/2016 12:37:00 > Warning: /nv/item_files/rfnv/00020826 not wrote.
8/7/2016 12:37:00 > Warning: /nv/item_files/rfnv/00020833 not wrote.
8/7/2016 12:37:00 > Warning: /nv/item_files/rfnv/00020848 not wrote.
8/7/2016 12:37:00 > Warning: /nv/item_files/rfnv/00020849 not wrote.
8/7/2016 12:37:00 > Warning: /nv/item_files/rfnv/00020852 not wrote.
8/7/2016 12:37:00 > Warning: /nv/item_files/rfnv/00020853 not wrote.
8/7/2016 12:37:00 > Warning: /nv/item_files/rfnv/00020858 not wrote.
8/7/2016 12:37:00 > Warning: /nv/item_files/rfnv/00020862 not wrote.
8/7/2016 12:37:00 > Warning: /nv/item_files/rfnv/00020863 not wrote.
8/7/2016 12:37:00 > Warning: /nv/item_files/rfnv/00020864 not wrote.
8/7/2016 12:37:00 > Warning: /nv/item_files/rfnv/00020865 not wrote.
8/7/2016 12:37:00 > Warning: /nv/item_files/rfnv/00020866 not wrote.
8/7/2016 12:37:00 > Warning: /nv/item_files/rfnv/00020867 not wrote.
8/7/2016 12:37:00 > Warning: /nv/item_files/rfnv/00020868 not wrote.
8/7/2016 12:37:00 > Warning: /nv/item_files/rfnv/00020869 not wrote.
8/7/2016 12:37:00 > Warning: /nv/item_files/rfnv/00020870 not wrote.
8/7/2016 12:37:00 > Warning: /nv/item_files/rfnv/00020871 not wrote.
8/7/2016 12:37:00 > Warning: /nv/item_files/rfnv/00020872 not wrote.
8/7/2016 12:37:00 > Warning: /nv/item_files/rfnv/00020873 not wrote.
8/7/2016 12:37:00 > Warning: /nv/item_files/rfnv/00020883 not wrote.
8/7/2016 12:37:00 > Warning: /nv/item_files/rfnv/00020884 not wrote.
8/7/2016 12:37:00 > Warning: /nv/item_files/rfnv/00020885 not wrote.
8/7/2016 12:37:00 > Warning: /nv/item_files/rfnv/00020891 not wrote.
8/7/2016 12:37:00 > Warning: /nv/item_files/rfnv/00020895 not wrote.
8/7/2016 12:37:00 > Warning: /nv/item_files/rfnv/00020896 not wrote.
8/7/2016 12:37:00 > Warning: /nv/item_files/rfnv/00020898 not wrote.
8/7/2016 12:37:00 > Warning: /nv/item_files/rfnv/00020912 not wrote.
8/7/2016 12:37:00 > Warning: /nv/item_files/rfnv/00020913 not wrote.
8/7/2016 12:37:00 > Warning: /nv/item_files/rfnv/00020914 not wrote.
8/7/2016 12:37:00 > Warning: /nv/item_files/rfnv/00020915 not wrote.
8/7/2016 12:37:00 > Warning: /nv/item_files/rfnv/00020916 not wrote.
8/7/2016 12:37:00 > Warning: /nv/item_files/rfnv/00020917 not wrote.
8/7/2016 12:37:00 > Warning: /nv/item_files/rfnv/00020918 not wrote.
8/7/2016 12:37:00 > Warning: /nv/item_files/rfnv/00020919 not wrote.
8/7/2016 12:37:00 > Warning: /nv/item_files/rfnv/00020920 not wrote.
8/7/2016 12:37:00 > Warning: /nv/item_files/rfnv/00020921 not wrote.
8/7/2016 12:37:00 > Warning: /nv/item_files/rfnv/00020922 not wrote.
8/7/2016 12:37:00 > Warning: /nv/item_files/rfnv/00020923 not wrote.
8/7/2016 12:37:00 > Warning: /nv/item_files/rfnv/00020924 not wrote.
8/7/2016 12:37:00 > Warning: /nv/item_files/rfnv/00020925 not wrote.
8/7/2016 12:37:00 > Warning: /nv/item_files/rfnv/00020926 not wrote.
8/7/2016 12:37:00 > Warning: /nv/item_files/rfnv/00020927 not wrote.
8/7/2016 12:37:00 > Warning: /nv/item_files/rfnv/00020928 not wrote.
8/7/2016 12:37:00 > Warning: /nv/item_files/rfnv/00020929 not wrote.
8/7/2016 12:37:00 > Warning: /nv/item_files/rfnv/00020930 not wrote.
8/7/2016 12:37:00 > Warning: /nv/item_files/rfnv/00020931 not wrote.
8/7/2016 12:37:00 > Warning: /nv/item_files/rfnv/00020932 not wrote.
8/7/2016 12:37:00 > Warning: /nv/item_files/rfnv/00020933 not wrote.
8/7/2016 12:37:00 > Warning: /nv/item_files/rfnv/00020934 not wrote.
8/7/2016 12:37:00 > Warning: /nv/item_files/rfnv/00020935 not wrote.
8/7/2016 12:37:00 > Warning: /nv/item_files/rfnv/00020936 not wrote.
8/7/2016 12:37:00 > Warning: /nv/item_files/rfnv/00020937 not wrote.
8/7/2016 12:37:00 > Warning: /nv/item_files/rfnv/00020938 not wrote.
8/7/2016 12:37:00 > Warning: /nv/item_files/rfnv/00020939 not wrote.
8/7/2016 12:37:00 > Warning: /nv/item_files/rfnv/00020940 not wrote.
8/7/2016 12:37:00 > Warning: /nv/item_files/rfnv/00020941 not wrote.
8/7/2016 12:37:00 > Warning: /nv/item_files/rfnv/00020962 not wrote.
8/7/2016 12:37:00 > Warning: /nv/item_files/rfnv/00020963 not wrote.
8/7/2016 12:37:00 > Warning: /nv/item_files/rfnv/00020964 not wrote.
8/7/2016 12:37:00 > Warning: /nv/item_files/rfnv/00020965 not wrote.
8/7/2016 12:37:00 > Warning: /nv/item_files/rfnv/00020966 not wrote.
8/7/2016 12:37:00 > Warning: /nv/item_files/rfnv/00020967 not wrote.
8/7/2016 12:37:00 > Warning: /nv/item_files/rfnv/00020968 not wrote.
8/7/2016 12:37:00 > Warning: /nv/item_files/rfnv/00020969 not wrote.
8/7/2016 12:37:00 > Warning: /nv/item_files/rfnv/00020970 not wrote.
8/7/2016 12:37:00 > Warning: /nv/item_files/rfnv/00020971 not wrote.
8/7/2016 12:37:00 > Warning: /nv/item_files/rfnv/00022131 not wrote.
8/7/2016 12:37:00 > Warning: /nv/item_files/rfnv/00022982 not wrote.
8/7/2016 12:37:00 > Warning: /nv/item_files/rfnv/00023387 not wrote.
8/7/2016 12:37:00 > Warning: /nv/item_files/rfnv/00023764 not wrote.
8/7/2016 12:37:00 > Warning: /nv/item_files/rfnv/00024198 not wrote.
8/7/2016 12:37:00 > Warning: /nv/item_files/rfnv/00024202 not wrote.
8/7/2016 12:37:00 > Warning: /nv/item_files/rfnv/00024226 not wrote.
8/7/2016 12:37:00 > Warning: /nv/item_files/rfnv/00024227 not wrote.
8/7/2016 12:37:00 > Warning: /nv/item_files/rfnv/00024228 not wrote.
8/7/2016 12:37:00 > Warning: /nv/item_files/rfnv/00024229 not wrote.
8/7/2016 12:37:00 > Warning: /nv/item_files/rfnv/00024230 not wrote.
8/7/2016 12:37:00 > Warning: /nv/item_files/rfnv/00024232 not wrote.
8/7/2016 12:37:00 > Warning: /nv/item_files/rfnv/00024233 not wrote.
8/7/2016 12:37:00 > Warning: /nv/item_files/rfnv/00024240 not wrote.
8/7/2016 12:37:00 > Warning: /nv/item_files/rfnv/00024243 not wrote.
8/7/2016 12:37:00 > Warning: /nv/item_files/rfnv/00024250 not wrote.
8/7/2016 12:37:00 > Warning: /nv/item_files/rfnv/00024252 not wrote.
8/7/2016 12:37:00 > Warning: /nv/item_files/rfnv/00024253 not wrote.
8/7/2016 12:37:00 > Warning: /nv/item_files/rfnv/00024255 not wrote.
8/7/2016 12:37:00 > Warning: /nv/item_files/rfnv/00024256 not wrote.
8/7/2016 12:37:00 > Warning: /nv/item_files/rfnv/00024583 not wrote.
8/7/2016 12:37:00 > Warning: /nv/item_files/rfnv/00024584 not wrote.
8/7/2016 12:37:00 > Warning: /nv/item_files/rfnv/00024586 not wrote.
8/7/2016 12:37:00 > Warning: /nv/item_files/rfnv/00024587 not wrote.
8/7/2016 12:37:00 > Warning: /nv/item_files/rfnv/00024590 not wrote.
8/7/2016 12:37:00 > Warning: /nv/item_files/rfnv/00024591 not wrote.
8/7/2016 12:37:00 > Warning: /nv/item_files/rfnv/00024593 not wrote.
8/7/2016 12:37:00 > Warning: /nv/item_files/rfnv/00024594 not wrote.
8/7/2016 12:37:00 > Warning: /nv/item_files/rfnv/00024606 not wrote.
8/7/2016 12:37:00 > Warning: /nv/item_files/rfnv/00024607 not wrote.
8/7/2016 12:37:00 > Warning: /nv/item_files/rfnv/00024609 not wrote.
8/7/2016 12:37:00 > Warning: /nv/item_files/rfnv/00024610 not wrote.
8/7/2016 12:37:00 > Warning: /nv/item_files/rfnv/00024932 not wrote.
8/7/2016 12:37:00 > Warning: /nv/item_files/rfnv/00024933 not wrote.
8/7/2016 12:37:00 > Warning: /nv/item_files/rfnv/00024934 not wrote.
8/7/2016 12:37:00 > Warning: /nv/item_files/rfnv/00024935 not wrote.
8/7/2016 12:37:00 > Warning: /nv/item_files/rfnv/00024936 not wrote.
8/7/2016 12:37:01 > Warning: /nv/item_files/rfnv/00024938 not wrote.
8/7/2016 12:37:01 > Warning: /nv/item_files/rfnv/00024939 not wrote.
8/7/2016 12:37:01 > Warning: /nv/item_files/rfnv/00024946 not wrote.
8/7/2016 12:37:01 > Warning: /nv/item_files/rfnv/00024949 not wrote.
8/7/2016 12:37:01 > Warning: /nv/item_files/rfnv/00024961 not wrote.
8/7/2016 12:37:01 > Warning: /nv/item_files/rfnv/00024962 not wrote.
8/7/2016 12:37:01 > Warning: /nv/item_files/rfnv/00024964 not wrote.
8/7/2016 12:37:01 > Warning: /nv/item_files/rfnv/00024965 not wrote.
8/7/2016 12:37:01 > Warning: /nv/item_files/rfnv/00024966 not wrote.
8/7/2016 12:37:01 > Warning: /nv/item_files/rfnv/00024967 not wrote.
8/7/2016 12:37:01 > Warning: /nv/item_files/rfnv/00024972 not wrote.
8/7/2016 12:37:01 > Warning: /nv/item_files/rfnv/00024973 not wrote.
8/7/2016 12:37:01 > Warning: /nv/item_files/rfnv/00024974 not wrote.
8/7/2016 12:37:01 > Warning: /nv/item_files/rfnv/00024975 not wrote.
8/7/2016 12:37:01 > Warning: /nv/item_files/rfnv/00024980 not wrote.
8/7/2016 12:37:01 > Warning: /nv/item_files/rfnv/00024981 not wrote.
8/7/2016 12:37:01 > Warning: /nv/item_files/rfnv/00024982 not wrote.
8/7/2016 12:37:01 > Warning: /nv/item_files/rfnv/00024983 not wrote.
8/7/2016 12:37:01 > Warning: /nv/item_files/rfnv/00024996 not wrote.
8/7/2016 12:37:01 > Warning: /nv/item_files/rfnv/00024997 not wrote.
8/7/2016 12:37:01 > Warning: /nv/item_files/rfnv/00024998 not wrote.
8/7/2016 12:37:01 > Warning: /nv/item_files/rfnv/00024999 not wrote.
8/7/2016 12:37:01 > Warning: /nv/item_files/rfnv/00025004 not wrote.
8/7/2016 12:37:01 > Warning: /nv/item_files/rfnv/00025005 not wrote.
8/7/2016 12:37:01 > Warning: /nv/item_files/rfnv/00025006 not wrote.
8/7/2016 12:37:01 > Warning: /nv/item_files/rfnv/00025007 not wrote.
8/7/2016 12:37:01 > Warning: /nv/item_files/rfnv/00025020 not wrote.
8/7/2016 12:37:01 > Warning: /nv/item_files/rfnv/00025021 not wrote.
8/7/2016 12:37:01 > Warning: /nv/item_files/rfnv/00025022 not wrote.
8/7/2016 12:37:01 > Warning: /nv/item_files/rfnv/00025023 not wrote.
8/7/2016 12:37:01 > Warning: /nv/item_files/rfnv/00025036 not wrote.
8/7/2016 12:37:01 > Warning: /nv/item_files/rfnv/00025037 not wrote.
8/7/2016 12:37:01 > Warning: /nv/item_files/rfnv/00025038 not wrote.
8/7/2016 12:37:01 > Warning: /nv/item_files/rfnv/00025039 not wrote.
8/7/2016 12:37:01 > Warning: /nv/item_files/rfnv/00025044 not wrote.
8/7/2016 12:37:01 > Warning: /nv/item_files/rfnv/00025045 not wrote.
8/7/2016 12:37:01 > Warning: /nv/item_files/rfnv/00025046 not wrote.
8/7/2016 12:37:01 > Warning: /nv/item_files/rfnv/00025047 not wrote.
8/7/2016 12:37:01 > Warning: /nv/item_files/rfnv/00025052 not wrote.
8/7/2016 12:37:01 > Warning: /nv/item_files/rfnv/00025053 not wrote.
8/7/2016 12:37:01 > Warning: /nv/item_files/rfnv/00025054 not wrote.
8/7/2016 12:37:01 > Warning: /nv/item_files/rfnv/00025055 not wrote.
8/7/2016 12:37:01 > Warning: /nv/item_files/rfnv/00025060 not wrote.
8/7/2016 12:37:01 > Warning: /nv/item_files/rfnv/00025061 not wrote.
8/7/2016 12:37:01 > Warning: /nv/item_files/rfnv/00025062 not wrote.
8/7/2016 12:37:01 > Warning: /nv/item_files/rfnv/00025063 not wrote.
8/7/2016 12:37:01 > Warning: /nv/item_files/rfnv/00025068 not wrote.
8/7/2016 12:37:01 > Warning: /nv/item_files/rfnv/00025069 not wrote.
8/7/2016 12:37:01 > Warning: /nv/item_files/rfnv/00025070 not wrote.
8/7/2016 12:37:01 > Warning: /nv/item_files/rfnv/00025071 not wrote.
8/7/2016 12:37:01 > Warning: /nv/item_files/rfnv/00025076 not wrote.
8/7/2016 12:37:01 > Warning: /nv/item_files/rfnv/00025077 not wrote.
8/7/2016 12:37:01 > Warning: /nv/item_files/rfnv/00025078 not wrote.
8/7/2016 12:37:01 > Warning: /nv/item_files/rfnv/00025079 not wrote.
8/7/2016 12:37:01 > Warning: /nv/item_files/rfnv/00025084 not wrote.
8/7/2016 12:37:01 > Warning: /nv/item_files/rfnv/00025085 not wrote.
8/7/2016 12:37:01 > Warning: /nv/item_files/rfnv/00025086 not wrote.
8/7/2016 12:37:01 > Warning: /nv/item_files/rfnv/00025087 not wrote.
8/7/2016 12:37:01 > Warning: /nv/item_files/rfnv/00025100 not wrote.
8/7/2016 12:37:01 > Warning: /nv/item_files/rfnv/00025101 not wrote.
8/7/2016 12:37:01 > Warning: /nv/item_files/rfnv/00025102 not wrote.
8/7/2016 12:37:01 > Warning: /nv/item_files/rfnv/00025103 not wrote.
8/7/2016 12:37:01 > Warning: /nv/item_files/rfnv/00025116 not wrote.
8/7/2016 12:37:01 > Warning: /nv/item_files/rfnv/00025117 not wrote.
8/7/2016 12:37:01 > Warning: /nv/item_files/rfnv/00025118 not wrote.
8/7/2016 12:37:01 > Warning: /nv/item_files/rfnv/00025119 not wrote.
8/7/2016 12:37:01 > Warning: /nv/item_files/rfnv/00025426 not wrote.
8/7/2016 12:37:01 > Warning: /nv/item_files/rfnv/00025427 not wrote.
8/7/2016 12:37:01 > Warning: /nv/item_files/rfnv/00025428 not wrote.
8/7/2016 12:37:01 > Warning: /nv/item_files/rfnv/00025429 not wrote.
8/7/2016 12:37:01 > Warning: /nv/item_files/rfnv/00025434 not wrote.
8/7/2016 12:37:01 > Warning: /nv/item_files/rfnv/00025436 not wrote.
8/7/2016 12:37:01 > Warning: /nv/item_files/rfnv/00025438 not wrote.
8/7/2016 12:37:01 > Warning: /nv/item_files/rfnv/00025439 not wrote.
8/7/2016 12:37:01 > Warning: /nv/item_files/rfnv/00025441 not wrote.
8/7/2016 12:37:01 > Warning: /nv/item_files/rfnv/00025454 not wrote.
8/7/2016 12:37:01 > Warning: /nv/item_files/rfnv/00025458 not wrote.
8/7/2016 12:37:01 > Warning: /nv/item_files/rfnv/00025459 not wrote.
8/7/2016 12:37:01 > Warning: /nv/item_files/rfnv/00025460 not wrote.
8/7/2016 12:37:01 > Warning: /nv/item_files/rfnv/00025461 not wrote.
8/7/2016 12:37:01 > Warning: /nv/item_files/rfnv/00025462 not wrote.
8/7/2016 12:37:01 > Warning: /nv/item_files/rfnv/00025463 not wrote.
8/7/2016 12:37:01 > Warning: /nv/item_files/rfnv/00025464 not wrote.
8/7/2016 12:37:01 > Warning: /nv/item_files/rfnv/00025465 not wrote.
8/7/2016 12:37:01 > Warning: /nv/item_files/rfnv/00025466 not wrote.
8/7/2016 12:37:01 > Warning: /nv/item_files/rfnv/00025467 not wrote.
8/7/2016 12:37:01 > Warning: /nv/item_files/rfnv/00025468 not wrote.
8/7/2016 12:37:01 > Warning: /nv/item_files/rfnv/00025471 not wrote.
8/7/2016 12:37:01 > Warning: /nv/item_files/rfnv/00025472 not wrote.
8/7/2016 12:37:01 > Warning: /nv/item_files/rfnv/00025481 not wrote.
8/7/2016 12:37:01 > Warning: /nv/item_files/rfnv/00025486 not wrote.
8/7/2016 12:37:01 > Warning: /nv/item_files/rfnv/00025576 not wrote.
8/7/2016 12:37:01 > Warning: /nv/item_files/rfnv/00025577 not wrote.
8/7/2016 12:37:01 > Warning: /nv/item_files/rfnv/00025578 not wrote.
8/7/2016 12:37:01 > Warning: /nv/item_files/rfnv/00025579 not wrote.
8/7/2016 12:37:01 > Warning: /nv/item_files/rfnv/00025617 not wrote.
8/7/2016 12:37:01 > Warning: /nv/item_files/rfnv/00025618 not wrote.
8/7/2016 12:37:01 > Warning: /nv/item_files/rfnv/00025619 not wrote.
8/7/2016 12:37:01 > Warning: /nv/item_files/rfnv/00025620 not wrote.
8/7/2016 12:37:01 > Warning: /nv/item_files/rfnv/00025621 not wrote.
8/7/2016 12:37:01 > Warning: /nv/item_files/rfnv/00025624 not wrote.
8/7/2016 12:37:01 > Warning: /nv/item_files/rfnv/00025625 not wrote.
8/7/2016 12:37:01 > Warning: /nv/item_files/rfnv/00025626 not wrote.
8/7/2016 12:37:01 > Warning: /nv/item_files/rfnv/00025627 not wrote.
8/7/2016 12:37:01 > Warning: /nv/item_files/rfnv/00025628 not wrote.
8/7/2016 12:37:01 > Warning: /nv/item_files/rfnv/00025631 not wrote.
8/7/2016 12:37:02 > Warning: /nv/item_files/rfnv/00025632 not wrote.
8/7/2016 12:37:02 > Warning: /nv/item_files/rfnv/00025633 not wrote.
8/7/2016 12:37:02 > Warning: /nv/item_files/rfnv/00025634 not wrote.
8/7/2016 12:37:02 > Warning: /nv/item_files/rfnv/00025635 not wrote.
8/7/2016 12:37:02 > Warning: /nv/item_files/rfnv/00025637 not wrote.
8/7/2016 12:37:02 > Warning: /nv/item_files/rfnv/00025638 not wrote.
8/7/2016 12:37:02 > Warning: /nv/item_files/rfnv/00025642 not wrote.
8/7/2016 12:37:02 > Warning: /nv/item_files/rfnv/00025647 not wrote.
8/7/2016 12:37:02 > Warning: /nv/item_files/rfnv/00025650 not wrote.
8/7/2016 12:37:02 > Warning: /nv/item_files/rfnv/00025655 not wrote.
8/7/2016 12:37:02 > Warning: /nv/item_files/rfnv/00025656 not wrote.
8/7/2016 12:37:02 > Warning: /nv/item_files/rfnv/00025658 not wrote.
8/7/2016 12:37:02 > Warning: /nv/item_files/rfnv/00025675 not wrote.
8/7/2016 12:37:02 > Warning: /nv/item_files/rfnv/00025676 not wrote.
8/7/2016 12:37:02 > Warning: /nv/item_files/rfnv/00025677 not wrote.
8/7/2016 12:37:02 > Warning: /nv/item_files/rfnv/00025678 not wrote.
8/7/2016 12:37:02 > Warning: /nv/item_files/rfnv/00025679 not wrote.
8/7/2016 12:37:02 > Warning: /nv/item_files/rfnv/00025681 not wrote.
8/7/2016 12:37:02 > Warning: /nv/item_files/rfnv/00025682 not wrote.
8/7/2016 12:37:02 > Warning: /nv/item_files/rfnv/00025691 not wrote.
8/7/2016 12:37:02 > Warning: /nv/item_files/rfnv/00025694 not wrote.
8/7/2016 12:37:02 > Warning: /nv/item_files/rfnv/00025702 not wrote.
8/7/2016 12:37:02 > Warning: /nv/item_files/rfnv/00025756 not wrote.
8/7/2016 12:37:02 > Warning: /nv/item_files/rfnv/00025758 not wrote.
8/7/2016 12:37:02 > Warning: /nv/item_files/rfnv/00025759 not wrote.
8/7/2016 12:37:02 > Warning: /nv/item_files/rfnv/00025761 not wrote.
8/7/2016 12:37:02 > Warning: /nv/item_files/rfnv/00027112 not wrote.
8/7/2016 12:37:02 > Warning: /nv/item_files/rfnv/00027113 not wrote.
8/7/2016 12:37:02 > Warning: /nv/item_files/rfnv/00027114 not wrote.
8/7/2016 12:37:02 > Warning: /nv/item_files/rfnv/00027152 not wrote.
8/7/2016 12:37:02 > Warning: /nv/item_files/rfnv/00027153 not wrote.
8/7/2016 12:37:02 > Warning: /nv/item_files/rfnv/00027500 not wrote.
8/7/2016 12:37:02 > Warning: /nv/item_files/rfnv/00027501 not wrote.
8/7/2016 12:37:02 > Warning: /nv/item_files/rfnv/00027502 not wrote.
8/7/2016 12:37:02 > Warning: /nv/item_files/rfnv/00027503 not wrote.
8/7/2016 12:37:02 > Warning: /nv/item_files/rfnv/00027508 not wrote.
8/7/2016 12:37:02 > Warning: /nv/item_files/rfnv/00027509 not wrote.
8/7/2016 12:37:02 > Warning: /nv/item_files/rfnv/00027510 not wrote.
8/7/2016 12:37:02 > Warning: /nv/item_files/rfnv/00027511 not wrote.
8/7/2016 12:37:02 > Warning: /nv/item_files/rfnv/00027998 not wrote.
8/7/2016 12:37:02 > Warning: /nv/item_files/rfnv/00027999 not wrote.
8/7/2016 12:37:02 > Warning: /nv/item_files/rfnv/00028000 not wrote.
8/7/2016 12:37:02 > Warning: /nv/item_files/rfnv/00028001 not wrote.
8/7/2016 12:37:02 > Warning: /pdp_profiles/profile_init_flag not wrote.
8/7/2016 12:37:02 > Warning: /pdp_profiles/Subs1/profile1 not wrote.
8/7/2016 12:37:02 > Warning: /pdp_profiles/Subs2/profile1 not wrote.8/7/2016 12:37:02 > OK
8/7/2016 12:37:02 > Writing NV_Numbered Items...8/7/2016 12:37:02 > Failed!
8/7/2016 12:37:02 > Error code: ZXLCALSZXD
8/7/2016 12:37:02 > Performed by 2.3.5 software version.
