10-31-2014, 00:15 | #1 (permalink) |
Junior Member Join Date: Jun 2014
Member: 2212741 Status: Offline Thanks Meter: 0 | repair imei lg G3 d850 fail [Solved] Initializing flash...OK Reading partition...Fail Last edited by Octopus box; 11-06-2014 at 07:22. |
10-31-2014, 07:18 | #3 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | @ tomnguyen77777 Hello. Try to perform the operation by using test Software version, that we have sent You to your PM. Connect the device directly to PC motherboard USB port, don't use any USB hubs or PCI USB extention cards, this is important. Try to repeat the operation on another PC. |
11-02-2014, 08:09 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | @ icellphonez Hello. What do You mean exactly under "files to d850 imei repair"? What is the problem with Repair IMEI? What is the IMEI in your device now exactly? To Repair IMEI, do the next: 1. Remove SD and SIM cards from the phone. 2. Connect powered on phone to PC via Micro USB cable. 3. Install necessary driver. 4. Enter correct IMEI. 5. Click "IMEI fix" button. 6. Follow software instructions (prompts). 7. Post here full Software log with all of these actions. Note: To connect the phone in Normal Mode, do the next: Go to "Settings -> Networks -> Tethering & Networks -> Turn on "USB tethering". |
11-05-2014, 14:55 | #8 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Connect the device directly to PC motherboard USB port, don't use any USB hubs or PCI USB extention cards, this is important. Try to repeat the operation on another PC. Post here full Software log. |
