10-06-2015, 10:38 | #1 (permalink) |
No Life Poster Join Date: Jul 2009 Location: Los Angeles, CA
Member: 1081371 Status: Offline Thanks Meter: 720 | Repair IMEI LG G4 "TMobile/AT&T" Since i have not seen any box support for the LG G4 "Tmobile/ATT" Here is my way of IMEI repair for the LG G4 without a box! Since we are going to be using "adb shell" to wipe the IMEI, you will need to Root your device go to this link [ROOT] TMO/VZW/ATT/SPRINT/INTL Root your LG … | LG G4 | XDA Forums Follow the steps carefully! and give a thanks to "thecubed" for Root method! Make sure you make a back up of your QCN before trying this you will need this at the end! You will need "QPST" after installing it enable "diag mode" from your device plug into your computer Open up "QPST Configuration" go to "Ports" and "add New Port" and you will se your Serail Port highlight it and press "OK" still with in "QPST Configuration" go to "Start Clients" and go to "software download" you will go to "Backup" and "Browse" to where you want to save your "QCN Backup!" Close "QPST" and open up "Command prompt window" with in your "adb folder" Send these commands.. adb devices "your device should pop up"... adb shell su "make sure you grant access" dd if=/dev/zero of=/dev/block/mmcblk0p24 "first command" dd if=/dev/zero of=/dev/block/mmcblk0p25 "Second command' dd if=/dev/zero of=/dev/block/mmcblk0p26 "third command" and reboot your device .... Open up again "QPST Configuration" add again your "Lg serial port" go to "software download" and "restore" your "QCN" and "Browse" your "QCN" that you backed up ealier!.. and finally you can use either "EFS Pro/CDMA workshop(paid version)/DFS Tool" and write your IMEI! reboot DONE!... NOTE: if you still having issues trying to connect to the phone send this command with in "adb shell" echo 1 > /sys/devices/platform/lg_diag_cmd/diag_enable If you still need help send me a msg and I will try to help you .... |
The Following 9 Users Say Thank You to jusmejose For This Useful Post: |
10-09-2015, 03:51 | #3 (permalink) |
No Life Poster Join Date: Oct 2014 Location: Guatemala
Member: 2273678 Status: Offline Thanks Meter: 293 | Bro, this thread is under rated....it deserves A LOT more attention and credit!!!! Just did an LG Stylo today!! WORKS 100% Wait a sec.....I think I know why it's so quite over here now Thanks bro once again!! Beast!!!! Last edited by F_X; 10-09-2015 at 04:00. |
The Following User Says Thank You to F_X For This Useful Post: |
10-12-2015, 18:37 | #9 (permalink) |
Member: 1081371 Status: Offline Thanks Meter: 720 | Open up "EFS professional" select "Qualcomm tools" select your Serail port of your device ... under "Secure Ops" Check "IMEI" input your IMEI .. reboot... --------- DFS tool Open up "DFS Tool" Select your port.. Write your IMEI under "Programming" reboot... |
10-12-2015, 21:27 | #11 (permalink) |
Member: 1081371 Status: Offline Thanks Meter: 720 | Sorry for the late reply but yes it will work for "att and tmobile" for "sprint and verzion" i personally use "cdma workshop" paid version .... i will be updating for other new LG devices "stylo,leon" i should be buying those devices this week ... |
