11-29-2014, 11:24 | #1 (permalink) |
Freak Poster Join Date: Oct 2013
Member: 2056468 Status: Offline Thanks Meter: 11 | repair imei p970 place the log : Welcome to Octoplus/Octopus Box LG Software version 1.7.5 -------------------------------------------------------------------------------- Platform: LG Infineon Connection mode: Modem Selected model: P970 Please, power phone ON, connect P990 cable (with 56k resistor), type 3845#*970#, go to "AP CP USB Switching" and click "CP Reset" (or "CP Image download")...OK Sending preloader...OK Sending loader...OK Reading info...Failed! Certificate load error Disconnected. Please, reboot the phone manually. -------------------------------------------------------------------------------- Platform: LG Infineon Connection mode: OMAP Selected model: P970 Opening "P970AT-00-V10a-260-01-MAY-03-2011+0.oct"... Please, disconnect battery and connect P999 cable (with 910k resistor).Canceled! -------------------------------------------------------------------------------- Platform: LG Infineon Connection mode: OMAP Selected model: P970 Opening "P970AT-00-V10a-260-01-MAY-03-2011+0.oct"... Please, disconnect battery and connect P999 cable (with 910k resistor).OK Initializing device...OK Writing Firmware... Connecting to modem CPU...Failed! -------------------------------------------------------------------------------- Platform: LG Infineon Connection mode: OMAP Selected model: P970 Opening "P970AT-00-V10a-260-01-MAY-03-2011+0.oct"... Please, disconnect battery and connect P999 cable (with 910k resistor).OK Initializing device...OK Writing Firmware... Connecting to modem CPU...OK Sending preloader...OK Sending loader...OK Initializing flash...Failed! |
11-29-2014, 11:34 | #2 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Hello. What is the state of your device exactly? What is the problem with it? What is the baseband and IMEI in the phone exactly? To write firmware You should use the special LG P999 cable with 910k resistor inside (not P990 cable with 56 kOhm resistor), connect the device directly to PC motherboard USB port, don't use any USB hubs or PCI USB extention cards, this is important. Try to use another cable. Try to write firmware on another PC. If the problem is still the same - most likely, this is HW problem. To Repair IMEI, power phone ON, connect the phone via P990 cable (with 56k resistor) directly to PC motherboard USB port, type 3845#*970#, go to "AP CP USB Switching" and click "CP Reset" (or "CP Image download"). Try to perform the operation on another PC. If there is the same error: Quote:
11-29-2014, 11:44 | #3 (permalink) |
Member: 2056468 Status: Offline Thanks Meter: 11 | ok I have the right and the power cable with variable resistance usb - 56k - 130k - 910K . the baseband and XMM6160 . the problem and imei empty digitand * # 06 # .comunque now I have a reset of the device and then try on another pc |
11-29-2014, 11:54 | #4 (permalink) |
Member: 2056468 Status: Offline Thanks Meter: 11 | I now by another erroe on dial dispositvo Welcome to Octoplus/Octopus Box LG Software version 1.7.6 -------------------------------------------------------------------------------- Platform: LG Infineon Connection mode: OMAP Selected model: P970 Opening "P970AT-00-V10a-260-01-MAY-03-2011+0.oct"... Please, disconnect battery and connect P999 cable (with 910k resistor).OK Initializing device...OK Writing Firmware... Connecting to modem CPU...OK Sending preloader...OK Sending loader...OK Initializing flash...Failed! -------------------------------------------------------------------------------- Platform: LG Infineon Connection mode: Modem Selected model: P970 Please, power phone ON, connect P990 cable (with 56k resistor), type 3845#*970#, go to "AP CP USB Switching" and click "CP Reset" (or "CP Image download")...OK Sending preloader...OK Sending loader...OK Reading info...Failed! An error has been occured during reading. Disconnected. Please, reboot the phone manually. -------------------------------------------------------------------------------- Platform: LG Infineon Connection mode: Modem Selected model: P970 Please, power phone ON, connect P990 cable (with 56k resistor), type 3845#*970#, go to "AP CP USB Switching" and click "CP Reset" (or "CP Image download")...OK Sending preloader...OK Sending loader...OK Reading info...Failed! An error has been occured during reading. Disconnected. Please, reboot the phone manually. -------------------------------------------------------------------------------- Platform: LG Infineon Connection mode: Modem Selected model: P970 Please, power phone ON, connect P990 cable (with 56k resistor), type 3845#*970#, go to "AP CP USB Switching" and click "CP Reset" (or "CP Image download")...OK Sending preloader...OK Sending loader...OK Reading info...Failed! An error has been occured during reading. |
