11-17-2016, 19:36 | #1 (permalink) |
Freak Poster Join Date: Aug 2008 Location: Santiago de Cuba, CUBA
Member: 836938 Status: Offline Thanks Meter: 18 | Reset FRP fail whith this new version in H790 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM119 Selected model: H790 Please, put the phone into download mode manually (Power phone OFF, press and hold "Vol+" button and connect the cable). Reading info... Model ID: LGH790 IMEI: 353626-07-xxxxxx-8 Android version: Battery level: 2% SW Version: LGH790AT-00-V10f-NXS-XXX-OCT-0 Mode: Emergency Initializing flash...OK SW version: LGH790AT-00-V10f-NXS-XXX-OCT-03-2015-16G-MDA89E- US Android version: 6.0 LAF Version: 1.2 Product ID: SM06S151001000456 IMEI: 353626-07-xxxxxx-8 Target operator: GOOGLE Hardware: After performing Reset FRP operation the phone may stuck on logo. To fix this problem You shall reflash the phone with the latest firmare. Perform Reset FRP operation at your own risk. Continue? Reading partitions...OK Resetting FRP Lock...OK Resetting screen lock successfully completed! Performed by 2.5.0 Software version. |
11-18-2016, 09:41 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Hello. Please, explain your problem more detail? Does FRP is still present on your device? What is the exact state of your device? |
11-18-2016, 16:03 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Most likely, your device firmware was upgraded to Android 7.x.x version (current firmware versions for this device with Android 7 version are detected as Android 6 from Download Mode, so it not possible to detect real version from Download Mode), and this not allows to perform Reset FRP via currently supported method. We research new solution for Android 7.x.x for this device. Also, if phone's data are not important for You, You can try to make "Reset FRP" again and then make "Factory Reset": 1. Power off the phone. 2. Press and hold "Vol-" and "Power" buttons until the phone will not enter in Bootloader Mode. 3. Select recovery Mode (Vol-, Vol+) and press "Power" button - the decumbent (lying) robot-android should appears. 4. Press "Power" and "Vol+" shortly. 6. Select "Wipe data/factory reset". |
11-18-2016, 17:11 | #5 (permalink) | |
Member: 836938 Status: Offline Thanks Meter: 18 | Quote:
Yes sr, when i turn on the phones says me that the device is enrolled in the android beta programs. I do the hard reset but the FRP is still in the device. Please any suggest???. Thanks for all | |
11-18-2016, 17:46 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Unfortunately, no other suggesstions. We research the solution. As soon as it will be ready, we will released it. |
