08-22-2016, 12:36 | #1 (permalink) |
No Life Poster Join Date: Oct 2005 Location: georgia tbilisi
Member: 194939 Status: Offline Sonork: 100.168.25.6 Thanks Meter: 623 | sistem hung seel log Welcome to Octoplus/Octopus Box LG Software version 2.3.1 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM61 Selected model: P700 Reading info...OK Mode: Emergency Model ID: BS/P700/7D Opening "LGP700AT-00-v20d-BAL.oct"...OK Checking partition...OK Write BootLoaders: No Writing AMSS...OK Writing Boot Image...OK Writing Boot logo...OK Writing Recovery Image...OK Writing Persist...OK Writing System...OK Finalizing...OK Writing firmware done! To finish the operation please power on phone and wait 3 minutes Performed by 2.3.1 software version. on up version like 2.3.7 2.3.9 when press write firmware my windows is hungin and cant do anything only reset help please tell me is it my windows problemm? if windows problemm why is working ok on v 2.3.1? br p.s my windows is working with any gsm programms,boxes,dongles without problemm |
08-22-2016, 13:07 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. We will check where can be the problem and will inform You about possible solution. |
08-26-2016, 14:35 | #3 (permalink) |
Member: 194939 Status: Offline Sonork: 100.168.25.6 Thanks Meter: 623 | now another bug with ls990 when press write firmware button(phone is connected via emergecy mode) -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM16 Selected model: LS990 Reading info...Failed! Port busy Initializing ADB...OK Waiting for phone... Please, reconnect phone, enable USB debugging, and try again. To enable USB debugging, please perform the following steps: 1. Disconnect cable 2. Install LG Android ADB drivers 3. Go to "Settings" -> "About phone" -> "Software information" 4. Click on Build number 5 times 5. Enable "Settings" -> "Developer options" -> "USB debugging" option 6. Connect the cable and check, whether ADB interface has appeared in PC Device Manager. Performed by 2.3.9 software version. why soft is initialithisn adb when need write firmware? solve please Last edited by Octopus box; 08-26-2016 at 14:48. |
08-26-2016, 14:54 | #4 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | There can be 2 reasons for this problem: 1. You don't have necessary installed on your PC. 2. Other Software on your PC blocks connection with the phone: Quote:
1. Install the latest Software version. 2. Install necessary drivers: http://octopusbox.com/files/drivers/..._ver_3.8.1.rar, http://octoplusbox.com/files/drivers...dADBDriver.exe 3. Restart PC. 4. Close all third party Software (Android managers, modem dashboards, etc.) 5. Switch the phone to Emergency Mode (use USB port of PC motherboard for connection). 6. Repeat "Write Firmware" operation. | |
