11-23-2014, 08:07 | #1 (permalink) |
No Life Poster Join Date: Apr 2008 Location: PROTECTED BY 308
Member: 750001 Status: Offline Sonork: 100.1641021 Thanks Meter: 1,269 | Strange problem Lg E612 logs Welcome to Octoplus/Octopus Box LG Software version 1.7.1 Connecting to server support.octoplusbox.com:82...OK Authorizing...OK -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM1 Selected model: E612 Reading info...Failed! Could not detect mode. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM155 Selected model: E612 Reading info...OK Mode: Emergency Model ID: BS/LGE612/7D Opening "LGE612AT-00-V10a-AME-XXX-JUL-05-2012+0.oct"...OK Checking partition...OK Write BootLoaders: No Writing AMSS...OK Writing Boot Image...OK Writing Boot logo...OK Writing Recovery Image...OK Writing Persist...OK Writing System...OK Finalizing...OK Writing firmware done! To finish the operation please power on phone and wait 3 minutes now its taking 9008 port pls help me Last edited by Octopus box; 11-23-2014 at 08:23. |
11-23-2014, 08:31 | #2 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. As I see from your Software log, You have writen firmware without phone's boot loaders: Quote:
1. Fully charge phone's battery by using external charger. 2. Put the phone into Emergency/Download Mode manually (disconnect the cable, reconnect the battery, press and hold "Vol-" + "Vol+" buttons and connect the cable). 3. Select (mark) option "Write boot loaders" in the Software. 4. Write firmware. Note: If it is not possible to write firmware or during firmware writing occures error, you need to put manualy phone into Emergency Mode, this is important. Also note: Please, make sure the phone's battery is fully charged. Disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Qualcomm-based devices). You should not run any other programs or attach new devices to your computer during the flashing! Please, follow these simple precautions to avoid damaging your phone. If the phone doesn't go into Emergency Mode, You need to repair phone's boot loaders by using Jtag tool and then re-flash. | |
