02-16-2018, 22:07 | #5011 (permalink) |
No Life Poster Join Date: Mar 2011 Location: dominican republic Age: 45
Member: 1537078 Status: Offline Sonork: celular center Thanks Meter: 573 | LG VS835 Reset FRP successfully done using VS500 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM45 Selected model: VS500 Please, put the phone into download mode manually (Power phone OFF (reconnect battery), press and hold "Vol+" button and connect the cable (or P999 cable)). Reading info... Model ID: VS835 Incompatible model ID! IMEI: 355866-07-231851-7 Android version: Battery level: 50% SW Version: VS83512A Mode: Emergency Initializing flash...OK SW version: VS83512A_06 Android version: 6.0.1 LAF Version: 1.1 Product ID: CT69S161124003156 IMEI: 355866-07-xxxxxx-7 Target operator: VZW Hardware: rev_10 Reading partitions...OK Resetting FRP Lock...Failed! Error code: WHU8CHON7C Reading partitions...OK Resetting FRP Lock... Step 1...Failed! Error code: 726167756C Reading partitions...OK Resetting FRP Lock...OK Resetting FRP lock successfully completed! If the phone hang on logo or is restarting afetr performing the operation, please re-flash it using the same or higher version of firmware Performed by 2.7.9.1 Software version. Last edited by Octopus box; 02-17-2018 at 12:34. |
The Following User Says Thank You to chipscell25 For This Useful Post: |
02-17-2018, 07:02 | #5012 (permalink) |
Freak Poster Join Date: Jul 2016
Member: 2604648 Status: Offline Thanks Meter: 346 | LG-LS450 Unlock successfully dOne Code: Welcome to Octoplus/Octopus Box LG Software version 2.7.9 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM66 Selected model: LS450 Reading info... IMEI: 350305-26-000000-* Android version: 6.0.1 Battery level: 67% SW Version: LS450ZV5 Mode: Emergency Initializing flash...OK SW version: LS450ZV8_04 Android version: 6.0.1 LAF Version: 1.1 Product ID: CB41S170209004433 IMEI: 356848-07-856***-* Target operator: SPR Hardware: rev_10 Reading partitions...OK Reading Carrier...OK Unlocking...OK Writing Carrier...OK Phone successfully unlocked! Performed by 2.7.9 Software version. Last edited by Octopus box; 02-17-2018 at 12:31. |
The Following User Says Thank You to buffer2k11 For This Useful Post: |
02-17-2018, 20:43 | #5013 (permalink) |
Freak Poster Join Date: Aug 2010 Location: Egypt Age: 40
Member: 1382969 Status: Offline Sonork: 100.1679189 Thanks Meter: 30 | M250N successfully unlocked Welcome to Octoplus/Octopus Box LG Software version 2.7.9 -------------------------------------------------------------------------------- Checking data...OK Platform: LG MTK Selected port: COM3 Selected baudrate: 921600 Selected model: M250N Selected USB connection type Please, disconnect cable, reconnect battery, connect P999 cable (with 910k resistor) or Reconnect battery, press and hold "Vol+" for 10 seconds and connect Micro USB cable. Phone found at port COM40 Port is not active! Performed by 2.7.9 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG MTK Selected port: COM3 Selected baudrate: 921600 Selected model: M250N Selected USB connection type Please, disconnect cable, reconnect battery, connect P999 cable (with 910k resistor) or Reconnect battery, press and hold "Vol+" for 10 seconds and connect Micro USB cable. Phone found at port COM40 Mode: Emergency Initializing flash...OK Model ID: LG-M250n SW version: LGM250nAT-01-V10h-EUR-XX-AUG-14-2017+0 LAF Version: 1.1 Product ID: CT01S170209001873 IMEI: Target operator: GLOBAL Hardware: rev_10 Battery level: 50% Reading partitions...OK Checking security... Checking security passed! -------------------------------------------------------------------------------- IMEI: 354945-08-125400-3 Bluetooth address: A8:B8:6EF:41:18 Wi-Fi MAC address: A8:B8:6E:39:BD:E4 SPC: 000000 -------------------------------------------------------------------------------- Reading security area...OK Backup saved to "M250N_35************_17-02-2018_21-41-23.EEP" Unlocking... Writing security area... LAF Error: 80000121. Trying second method...OK Phone successfully unlocked! Performed by 2.7.9 Software version. Last edited by Octopus box; 02-18-2018 at 14:33. |
The Following User Says Thank You to pharaohpeter For This Useful Post: |
02-17-2018, 20:50 | #5014 (permalink) |
Member: 1537078 Status: Offline Sonork: celular center Thanks Meter: 573 | LS676 Reset FRP successfully done Welcome to Octoplus/Octopus Box LG Software version 2.7.9.1 -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM45 Selected model: LS676 Reading info... IMEI: 350305-26-000000-4 Android version: 6.0.1 Battery level: 68% SW Version: LS676ZV3 Mode: Emergency Initializing flash...OK SW version: LS676ZV5_06 Android version: 6.0.1 LAF Version: 1.1 Product ID: HD58S170110001497 IMEI: 357269-08-011835-9 Target operator: SPR Hardware: rev_11 Performed by 2.7.9.1 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM45 Selected model: LS676 Please, put the phone into download mode manually (Power phone OFF (reconnect battery), press and hold "Vol+" button and connect the cable (or P999 cable)). Reading info... IMEI: 350305-26-000000-4 Android version: 6.0.1 Battery level: 68% SW Version: LS676ZV3 Mode: Emergency Initializing flash...OK SW version: LS676ZV5_06 Android version: 6.0.1 LAF Version: 1.1 Product ID: HD58S170110001497 IMEI: 357269-08-xxxxxx-9 Target operator: SPR Hardware: rev_11 Reading partitions...OK Resetting FRP Lock...Failed! Reading partitions...OK Resetting FRP Lock... Step 1...OK Step 2...OK Step 3...OK Resetting FRP lock successfully completed! Performed by 2.7.9.1 Software version. Last edited by Octopus box; 02-18-2018 at 14:34. |
02-20-2018, 14:59 | #5015 (permalink) |
Banned Join Date: Oct 2017 Location: pakistan kpk mansehra Age: 26
Member: 2765424 Status: Offline Thanks Meter: 1,039 | Lg ls996 frp reset done LG LS996 FRP RESET DONE Code: Welcome to Octoplus/Octopus Box LG Software version 2.7.9 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM495 Selected model: LS996 Please, put the phone into download mode manually (Power phone OFF (reconnect battery), press and hold "Vol+" button and connect the cable (or P999 cable)). Reading info... IMEI: 350305-26-000000-4 Android version: 5.1.1 Battery level: 57% SW Version: LS996ZV9 Mode: Emergency Initializing flash...OK SW version: LS996ZV9_02 Android version: 5.1.1 LAF Version: 1.1 Product ID: PT01S150323005361 IMEI: 352596-06-215234-4 Target operator: SPR Hardware: rev_10 Reading partitions...OK Resetting FRP Lock... Resetting FRP lock successfully completed! Performed by 2.7.9 Software version. |
The Following User Says Thank You to taimur-ahmad For This Useful Post: |
02-21-2018, 12:13 | #5016 (permalink) |
No Life Poster Join Date: Jul 2009 Location: CHENNAI
Member: 1079392 Status: Offline Thanks Meter: 444 | LG H791 (Nexus 5x) Reset FRP success Code: Welcome to Octoplus/Octopus Box LG Software version 2.7.6 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM78 Selected model: H791 Please, put the phone into download mode manually (Power phone OFF, press and hold "Vol+" button and connect the cable). Reading info...Failed! Port busyFailed! Could not detect mode! Performed by 2.7.6 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM78 Selected model: H791 Please, put the phone into download mode manually (Power phone OFF, press and hold "Vol+" button and connect the cable). Reading info...Failed! Port busyFailed! Could not detect mode! Performed by 2.7.6 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM21 Selected model: H791 Please, put the phone into download mode manually (Power phone OFF, press and hold "Vol+" button and connect the cable). Reading info... IMEI: 353627-07-721437-0 Android version: Battery level: 51% SW Version: LGH791AT-00-V10k-NXS-XXX-NOV-1 Mode: Emergency Initializing flash...OK SW version: LGH791AT-00-V10k-NXS-XXX-NOV-12-2015-32G-MMB29K- USER+0 Android version: 6.0 LAF Version: 1.2 Product ID: PT02S160202003285 IMEI: 353627-07-721437-0 Target operator: GOOGLE Hardware: After performing Reset FRP operation the phone may stuck on logo. To fix this problem You shall reflash the phone with the latest firmare. Perform Reset FRP operation at your own risk. Continue? Reading partitions...OK Resetting FRP Lock...OK Resetting FRP lock successfully completed! Performed by 2.7.6 Software version. Last edited by Octopus box; 02-21-2018 at 12:23. |
The Following User Says Thank You to mmurugan1978 For This Useful Post: |
02-22-2018, 06:34 | #5017 (permalink) | |||
Freak Poster Join Date: Jul 2016 Age: 29
Member: 2602390 Status: Offline Thanks Meter: 106 | REset FRp Lg LS755 Done.......OCTOpluS Quote:
[/url] Ajmobilesshop.. ......................Iftikhar Ahmed.... Last edited by Octopus box; 02-22-2018 at 06:44. | |||
The Following User Says Thank You to ajmobilesshop For This Useful Post: |
02-22-2018, 18:08 | #5018 (permalink) |
Member: 1537078 Status: Offline Sonork: celular center Thanks Meter: 573 | D631 Reset Screen Lock Successfully done Welcome to Octoplus/Octopus Box LG Software version 2.7.9.1 -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM45 Selected model: D631 Reading info... Model ID: LG-D631 IMEI: 014087-00-171930-2 Android version: 5.0.2 Battery level: 92% SW Version: D63120h Mode: Emergency Initializing flash...OK SW version: LGD631AT-00-V20h-310-410-AUG-24-2015+0 Android version: 5.0.2 LAF Version: 1.1 Product ID: CT65S140912003543 IMEI: 014087-00-171930-2 Target operator: ATT Hardware: rev_10 Performed by 2.7.9.1 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM45 Selected model: D631 Please, put the phone into download mode manually (Power phone OFF (reconnect battery), press and hold "Vol+" button and connect the cable (or P999 cable)). Reading info... Model ID: LG-D631 IMEI: 014087-00-171930-2 Android version: 5.0.2 Battery level: 92% SW Version: D63120h Mode: Emergency Initializing flash...OK SW version: LGD631AT-00-V20h-310-410-AUG-24-2015+0 Android version: 5.0.2 LAF Version: 1.1 Product ID: CT65S140912003543 IMEI: 014087-xx-xxxxxxx-2 Target operator: ATT Hardware: rev_10 Resetting Screen Lock...OK Resetting screen lock successfully completed! Performed by 2.7.9.1 Software version. Last edited by Octopus box; 02-22-2018 at 18:15. |
02-23-2018, 17:20 | #5019 (permalink) |
No Life Poster Join Date: Dec 2005 Location: NEAR YOU
Member: 205427 Status: Offline Sonork: 100.1580937 Thanks Meter: 1,162 | LG TP450 (TMB Unlock App) Unlocked !!! Superb Update .. Checking data...OK Platform: LG Qualcomm Selected port: COM73 Selected model: TP450 Reading info... Model ID: LG-TP450 IMEI: xxxxxxxxxxx Android version: 7.0 Battery level: 15% SW Version: TP45010d Mode: Normal Firmware compiled date: Jul 27 2017 Firmware compiled time: 05:00:00 Firmware released date: Oct 11 2017 Firmware released time: 22:12:34 SW Version: MPSS.TA.2.3.c4-00026-8940_GEN_PACK-1 IMEI: 357016-08-022128-1 SPC: 000000 Checking root access... Initializing ADB...OK Waiting for phone...OK Phone is already rooted. -------------------------------------------------------------------------------- Connecting to server...OK Octopus smart card is present. Checking smart card...OK Username: xxxxxx Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Your balance: 115 credits. To perform "Unlock" operation you need to have 115 credits. Sending exploit...OK Executing exploit...OK Sending data to server...OK Calculating. Please Wait...OK Unlocking... Phone successfully unlocked! Rebooting phone... Performed by 2.8.0 Software version. Last edited by Octopus box; 02-24-2018 at 09:13. |
The Following User Says Thank You to zeel_zeel For This Useful Post: |
02-23-2018, 18:23 | #5020 (permalink) |
Member: 1537078 Status: Offline Sonork: celular center Thanks Meter: 573 | LS980 successfully unlocked Welcome to Octoplus/Octopus Box LG Software version 2.8.0 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM45 Selected model: LS980 Please, put the phone into download mode manually (Power phone OFF (reconnect battery), press and hold "Vol+" button and connect the cable (or P999 cable)). Reading info... Mode: Emergency Initializing flash...OK SW version: LS980ZVI_07 Android version: 5.0.2 LAF Version: 1.1 Product ID: YE03S131115002705 IMEI: 990002-xx-xxxxxx-7 Target operator: SPR Hardware: rev_10 Resetting Screen Lock...OK Resetting screen lock successfully completed! Performed by 2.8.0 Software version. Last edited by Octopus box; 02-24-2018 at 09:03. |
02-23-2018, 18:28 | #5021 (permalink) |
Member: 1537078 Status: Offline Sonork: celular center Thanks Meter: 573 | VS986 successfully unlocked Welcome to Octoplus/Octopus Box LG Software version 2.8.0 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM45 Selected model: VS986 Please, put the phone into download mode manually (Power phone OFF (reconnect battery), press and hold "Vol+" button and connect the cable (or P999 cable)). Reading info... Model ID: VS986 IMEI: 352898-07-031721-0 Android version: 6.0 Battery level: 13% SW Version: VS98626A Mode: Emergency Initializing flash...OK SW version: VS98626A_00 Android version: 6.0 LAF Version: 1.1 Product ID: YE05S160603001959 IMEI: 352898-xx-xxxxxx-0 Target operator: VZW Hardware: rev_10 Reading partitions...OK Resetting FRP Lock... Resetting FRP lock successfully completed! Performed by 2.8.0 Software version. Last edited by Octopus box; 02-24-2018 at 09:05. |
02-23-2018, 19:46 | #5022 (permalink) |
No Life Poster Join Date: Jan 2017 Location: Jamaica
Member: 2673816 Status: Offline Thanks Meter: 612 | LG G5 H831 android 7.0 unlock done Welcome to Octoplus/Octopus Box LG Software version 2.7.9 Checking data...OK Platform: LG Qualcomm Selected port: COM760 Selected model: H831 Reading info... Model ID: LG-H831 IMEI: 35XXXX-XX-XXXXXX-X Android version: 7.0 Battery level: 96% SW Version: H83120b Mode: Normal Firmware compiled date: Feb 22 2017 Firmware compiled time: 23:00:00 Firmware released date: Mar 9 2017 Firmware released time: 11:51:00 SW Version: MPSS.TH.2.0.c1.4-00047-M8996FAAAANAZM-1.88674.1 IMEI: 35XX43-XX-4XX73X-7 Bluetooth address: D0:13:FD:E6:46:9E Wi-Fi MAC address: D0:13:FD:53:E6:E1 SPC: 000000 Unlocking... Write security backup function doesn't work for this device with latest firmware versions. If you'll encounter any problem during Unlock operation - you won't be able to restore the phone to it's initial state, so proceed at your own risk. Continue? Skip Read/Write QCN Switching to Download mode...OK Initializing flash...OK Reading partitions...OK Reading security area...OK Backup saved to "H831_35XXXXXXXXXXXXX_23-02-2018_12-26-08.SEC" Writing security area...OK Switching to Normal mode... Found model LGH831AT* ÿh GQ at port COM760 Phone successfully unlocked! Rebooting phone... Performed by 2.7.9 Software version. Last edited by Octopus box; 02-24-2018 at 09:10. |
The Following User Says Thank You to ThePhoneTechDoc For This Useful Post: |
02-23-2018, 19:51 | #5023 (permalink) |
Member: 1537078 Status: Offline Sonork: celular center Thanks Meter: 573 | LS676 successfully unlocked Welcome to Octoplus/Octopus Box LG Software version 2.8.0 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM847 Selected model: LS676 Reading info... IMEI: 358784-07-620992-0 Android version: 6.0.1 Battery level: 53% SW Version: LS676ZV6 Mode: Emergency Initializing flash...OK SW version: LS676ZV6_02 Android version: 6.0.1 LAF Version: 1.1 Product ID: HD58S161115003033 IMEI: 358784-xx-xxxxxx-0 Target operator: SPR Hardware: rev_11 Reading partitions...OK Reading Carrier...OK Unlocking...OK Writing Carrier...OK Phone successfully unlocked! Performed by 2.8.0 Software version. Last edited by Octopus box; 02-24-2018 at 09:06. |
02-23-2018, 20:28 | #5024 (permalink) |
No Life Poster Join Date: May 2011 Location: tropical island
Member: 1568769 Status: Offline Sonork: 161.1167 Thanks Meter: 208 | m210 unlock done :) Code: Welcome to Octoplus/Octopus Box LG Software version 2.8.0 -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM423 Selected model: M210 Reading info... Model ID: LG-M210 IMEI: 353661-08-818158-3 Android version: 7.0 Battery level: 64% SW Version: M21010s Mode: Normal Performed by 2.8.0 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM423 Selected model: M210 Reading info... Model ID: LG-M210 IMEI: 353661-08-818158-3 Android version: 7.0 Battery level: 77% SW Version: M21010s Trying to enable Diagnostics ports... Found model LGM210AT: ÿh at port COM423 Checking root access... Initializing ADB...OK ADB Server was found. Trying to kill... Waiting for phone...Failed! Please, reconnect phone, enable USB debugging, and try again. To enable USB debugging, please perform the following steps: 1. Disconnect cable 2. Install LG Android ADB drivers 3. Go to "Settings" -> "About phone" -> "Software information" 4. Click on Build number 5 times 5. Enable "Settings" -> "Developer options" -> "USB debugging" option 6. Connect the cable and check, whether ADB interface has appeared in PC Device Manager. Performed by 2.8.0 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM423 Selected model: M210 Reading info... Model ID: LG-M210 IMEI: 353661-08-818158-3 Android version: 7.0 Battery level: 78% SW Version: M21010s Mode: Normal Firmware compiled date: May 27 2017 Firmware compiled time: 13:00:00 Firmware released date: Oct 19 2017 Firmware released time: 16:21:56 SW Version: MPSS.JO.2.0.c1.2-00031-8937_GENNS_PACK-1 IMEI: 353661-08-818158-3 SPC: 000000 Checking root access... Initializing ADB...OK Waiting for phone...OK Phone is not rooted. Please, root the phone manually! Performed by 2.8.0 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM423 Selected model: M210 Reading info... Model ID: LG-M210 IMEI: 353661-08-818158-3 Android version: 7.0 Battery level: 78% SW Version: M21010s Mode: Normal Firmware compiled date: May 27 2017 Firmware compiled time: 13:00:00 Firmware released date: Oct 19 2017 Firmware released time: 16:21:56 SW Version: MPSS.JO.2.0.c1.2-00031-8937_GENNS_PACK-1 IMEI: 353661-08-818158-3 SPC: 000000 Checking root access... Initializing ADB...OK Waiting for phone...OK Phone is already rooted. -------------------------------------------------------------------------------- Connecting to server...OK Octopus smart card is present. Checking smart card...OK Username: Authorizing...Failed! Performed by 2.8.0 Software version. -------------------------------------------------------------------------------- Connecting to server ...OK Username: headszone19 Authorizing...OK Checking balance...OK Your balance: 115 credits. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM423 Selected model: M210 Reading info... Model ID: LG-M210 IMEI: 353661-08-818158-3 Android version: 7.0 Battery level: 83% SW Version: M21010s Mode: Normal Firmware compiled date: May 27 2017 Firmware compiled time: 13:00:00 Firmware released date: Oct 19 2017 Firmware released time: 16:21:56 SW Version: MPSS.JO.2.0.c1.2-00031-8937_GENNS_PACK-1 IMEI: 353661-08-818158-3 SPC: 000000 Checking root access... Initializing ADB...OK Waiting for phone...OK Phone is already rooted. -------------------------------------------------------------------------------- Connecting to server...OK Octopus smart card is present. Checking smart card...OK Username: headszone19 Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Your balance: 115 credits. To perform "Unlock" operation you need to have 115 credits. Sending exploit...OK Executing exploit...OK Sending data to server...OK Calculating. Please Wait...OK Unlocking... Phone successfully unlocked! Rebooting phone... Performed by 2.8.0 Software version. Last edited by Octopus box; 02-24-2018 at 09:16. |
The Following User Says Thank You to headszone1 For This Useful Post: |
02-24-2018, 00:35 | #5025 (permalink) |
No Life Poster Join Date: Nov 2004 Location: Dominican Republic Age: 49
Member: 92317 Status: Offline Sonork: 100.1591991 Thanks Meter: 223 | MS210 successfully unlocked Code: Welcome to Octoplus/Octopus Box LG Software version 2.8.0 -------------------------------------------------------------------------------- Connecting to server ...OK Username: 01xxxxxxx Authorizing...OK Checking balance...OK Your balance: 355 credits. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM1 Selected model: MS210 Reading info... Could not detect mode! Performed by 2.8.0 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM1447 Selected model: MS210 Reading info... Model ID: LGMS210 IMEI: 353191-09-287465-0 Android version: 7.0 Battery level: 88% SW Version: MS21010i Mode: Normal Firmware compiled date: Nov 07 2016 Firmware compiled time: 02:00:00 Firmware released date: Apr 7 2017 Firmware released time: 09:25:36 SW Version: MPSS.JO.2.0.c1.2-00006-8937_GENNS_PACK-1 IMEI: 353191-09-287465-0 SPC: 000000 Checking root access... Initializing ADB...OK ADB Server was found. Trying to kill... Waiting for phone...Failed! Please, reconnect phone, enable USB debugging, and try again. To enable USB debugging, please perform the following steps: 1. Disconnect cable 2. Install LG Android ADB drivers 3. Go to "Settings" -> "About phone" -> "Software information" 4. Click on Build number 5 times 5. Enable "Settings" -> "Developer options" -> "USB debugging" option 6. Connect the cable and check, whether ADB interface has appeared in PC Device Manager. Performed by 2.8.0 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM1447 Selected model: MS210 Reading info... Model ID: LGMS210 IMEI: 353191-09-287465-0 Android version: 7.0 Battery level: 88% SW Version: MS21010i Mode: Normal Firmware compiled date: Nov 07 2016 Firmware compiled time: 02:00:00 Firmware released date: Apr 7 2017 Firmware released time: 09:25:36 SW Version: MPSS.JO.2.0.c1.2-00006-8937_GENNS_PACK-1 IMEI: 353191-09-287465-0 SPC: 000000 Checking root access... Initializing ADB...OK Waiting for phone...OK Phone is already rooted. -------------------------------------------------------------------------------- Connecting to server...OK Octopus smart card is present. Checking smart card...OK Username: 0100000A1F Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Your balance: 355 credits. To perform "Unlock" operation you need to have 115 credits. Sending exploit...OK Executing exploit...OK Sending data to server...OK Calculating. Please Wait...OK Unlocking... Phone successfully unlocked! Rebooting phone... Performed by 2.8.0 Software version. Last edited by Octopus box; 02-24-2018 at 09:17. |
The Following User Says Thank You to cdmagsm03 For This Useful Post: |
Post here successfully unlocked a2 phones | 3lsheikh | SETool2 | 10 | 03-04-2011 02:48 |
Successfully Unlock Z240 Phone Freeze | jhepoy_org | UST Pro II | 13 | 12-02-2009 06:03 |
Successfully unlock BB5 phones with bb5king | Mjabbar | BB5KING | 0 | 11-29-2008 14:13 |
Successfully unlock BB5 phones with bb5king | Mjabbar | BB5KING | 2 | 11-26-2008 11:54 |
PB2 - Successfully unlocked LG phones CU/KU ... | DOUHAL | PolarBox 3 | 72 | 11-05-2008 18:21 |
