Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Octopus/Octoplus > Octopus LG/Octoplus LG
Old 08-14-2012, 13:47   #2056 (permalink)
Moderator
...:::::NP™:::::...'s Avatar
Member: 1162626
Sonork: 100.1591727 QQ:2337938173
Thanks Meter: 9,882
Successful Flash Repair LG A170
Platform: LG Infineon
Selected port: COM13
Selected baudrate: 921600
Selected model: A170
Please, disconnect battery and connect cable...
Phone found.
Sending preloader...OK
Sending loader...OK
Reading info. Please wait...
Flash ID: 20002888
Flash type: ST
IMEI: 350305-26-000000-1
Opening "LGA170AT-00-V10c-EUR-XXX-MAY-24-2011+0.oct"...OK
Erasing. Please wait...OK
Writing Firmware...OK
Writing Firmware done!
Disconnected.
The Following User Says Thank You to ...:::::NP™:::::... For This Useful Post:
Old 08-15-2012, 13:47   #2057 (permalink)
Nadoui's Avatar
Member: 1202782
Sonork: 100.1608261
Thanks Meter: 634
Welcome to Octopus Box LG Software version 2.1.7
Selected port: USB
Selected model: KS360
Disconnect battery and connect USB cable to phone...
Reading info...
IMEI: 352074-03-154752-3
Reading codes. Please wait...
Unlock code: 4982 4870
To finish the operation, please perform the following steps:
1. Insert the original SIM card or Motorola Test card and type 2945#*
71001#
2. Enter code.
Old 08-15-2012, 13:52   #2058 (permalink)
Nadoui's Avatar
Member: 1202782
Sonork: 100.1608261
Thanks Meter: 634
Selected port: USB
Selected model: KP500
IMEI: 357920-02-953321-1
Unlock code: 4327 2156
1. Insert the original SIM card and type 2945#*71001#
2. Go to menu>Settings>Security>SIMLOCK and enter the code.
Unlocking...
Reading security area...
Backup saved to
"KP500-357920029533211_15-08-2012_13-49-59.eep"
Writing security area...
Phone successfully unlocked!
Old 08-15-2012, 18:32   #2059 (permalink)
Nadoui's Avatar
Member: 1202782
Sonork: 100.1608261
Thanks Meter: 634
Platform: LG Qualcomm
Selected port: COM210
http://www.lg.com/fr/telephones-mobiles/lg-E900
Mode: Normal
Phone model: LG-E900
SW Version: LG-E900_V10g_Final-OCT-19-2010-2250-7004
IMEI: 354042-04-123049-5
Bluetooth address: 5C:173:4B:F4:8C
Checking security...OK
Unlocking...
To perform this operation you need:
1. Disconnect cable and reconnect the battery
2. Press and hold "Camera" + "Vol-" + "Power ON" keys
3. Connect cable and repeat the operation
Selected model: E900
Phone model: E900
Mode: Emergency
Unlocking...
Sending loader...OK
Reading security area...OK
Backup saved to "E900-_15-08-2012_18-24-50.sec"
Writing security area...OK
Rebooting phone...
Old 08-16-2012, 11:38   #2060 (permalink)
sirnavid2010's Avatar
Member: 777729
Sonork: 100.1616470
Thanks Meter: 804
Welcome to Octopus Box LG Software version 2.2.0
Selected port: COM6
Selected baudrate: 460800
Selected model: KG275
Please reconnect battery...
Phone found.
Sending loader...OK
Flash ID: 01001A01
Flash type: AMD/Spansion
IMEI: 350604-10-145772-4
Selecting output file...
Reading EEPROM into file "KG275-350604101457724.EEP"...
Reading EEPROM done!
Opening "KG275P16-ARB-V10j-XXX-XX-JAN 24 2008.oct"...OK
Disconnected.
Old 08-17-2012, 18:39   #2061 (permalink)
fredinho's Avatar
Member: 975275
Sonork: 100.1607001
Thanks Meter: 216
Welcome to Octopus Box Samsung software version 1.5.6
To connect SGH-T989 phone you have to perform the following steps:
1. Disconnect USB cable from phone.
2. Go to Menu->Settings->Applications->Development.
3. Turn on "USB Debugging" option.
4. When message is appear press "Yes".
5. Go to dial window.
6. Enter "*#7284#" number.
7. Set "USB" radio button to "Modem" value.
8. Close window.
9. Go to dial window.
10. Enter "*#9090#" number.
11. Set "Diag config" to "USB" value.
12. Restart phone.
13. Press "Read Info" in Octopus Samsung software.
Platform: Samsung Android
Selected port: COM148
Selected model: SGH-T989
Phone was not found on the selected port!
Searching for USB diagnostic port...
Connecting to phone on COM159
Mode: Normal
Phone model: SGH-T989
Phone IMEI: 359605-04-595965-0
SW Version: T989UVLDE/T989UVLDE
HW Version: REV0.1
Selected port: COM159
Mode: Normal
HW Version: REV0.1
Unlocking phone...
Switching to emergency mode...
Deactivating MSL failed
Phone unlocking was canceled
Mode: Normal
HW Version: REV0.1
Mode: Normal
HW Version: REV0.1
Unlocking phone...
Phone found
Deactivating MSL...
MSL deactivate successfully
Disconect phone and type *#9090# select USB mode.
Type *#7284# and select Modem.
Reboot phone and connect switched On phone to USB cable.
Searching for phone. Please wait...
Incorrect IMEI
HW Version: None
Found phone on COM159
Phone is successfully unlocked
Old 08-22-2012, 17:40   #2062 (permalink)
td_mobile_2007's Avatar
Member: 1647504
Thanks Meter: 214
11:47 AM : one LG KP500 flash ok
8/22/2012 11:47:17 AM > Platform: LG Infineon
8/22/2012 11:47:17 AM > Selected port: USB
8/22/2012 11:47:17 AM > Selected model: KP500
8/22/2012 11:47:17 AM > Disconnect battery and connect USB cable to phone...
8/22/2012 11:47:21 AM > Reading info. Please wait...
8/22/2012 11:47:22 AM > IMEI: 357920-02-386618-7
8/22/2012 11:47:35 AM > Disconnected.
8/22/2012 11:47:38 AM > --------------------------------------------------------------------------------
8/22/2012 11:47:38 AM > Platform: LG Infineon
8/22/2012 11:47:38 AM > Selected port: USB
8/22/2012 11:47:38 AM > Selected model: KP500
8/22/2012 11:47:38 AM > Disconnect battery and connect USB cable to phone...
8/22/2012 11:47:47 AM > Reading info. Please wait...
8/22/2012 11:47:48 AM > IMEI: 357920-02-386618-7
8/22/2012 11:47:49 AM > Selecting output file...
8/22/2012 11:47:54 AM > Reading EEPROM into file "KP500-357920023866187.EEP"...
8/22/2012 11:47:55 AM > Reading EEPROM done!
8/22/2012 11:48:32 AM > Opening "KP500AT-00-V10n-CIS-XXX-DEC-17-2008.oct"...8/22/2012 11:48:32 AM > OK
8/22/2012 11:48:32 AM > Writing Firmware...
8/22/2012 12:09:52 PM > Writing Firmware done!
8/22/2012 12:09:52 PM > Disconnected.
3:13 PM : one LG KP500 flash ok
Log file "C:\Program Files\GsmServer\Octopus_LG\LOG\22-08-2012_15-13-23.log" created.
8/22/2012 3:13:30 PM > Welcome to Octopus Box LG Software version 2.2.1
8/22/2012 3:13:52 PM > --------------------------------------------------------------------------------
8/22/2012 3:13:52 PM > Platform: LG Infineon
8/22/2012 3:13:52 PM > Selected port: USB
8/22/2012 3:13:52 PM > Selected model: KP500
8/22/2012 3:13:52 PM > Disconnect battery and connect USB cable to phone...
8/22/2012 3:14:02 PM > Reading info. Please wait...
8/22/2012 3:14:03 PM > IMEI: 352701-03-807569-0
8/22/2012 3:14:05 PM > Selecting output file...
8/22/2012 3:14:07 PM > Reading EEPROM into file "KP500-352701038075690.EEP"...
8/22/2012 3:14:08 PM > Reading EEPROM done!
8/22/2012 3:14:19 PM > Opening "KP500AT-00-V10n-CIS-XXX-DEC-17-2008.oct"...8/22/2012 3:14:19 PM > OK
8/22/2012 3:14:19 PM > Writing Firmware...
8/22/2012 3:35:51 PM > Writing Firmware done!
8/22/2012 3:35:51 PM > Disconnected.
Thanks Octopus Box Team
Old 08-23-2012, 16:29   #2063 (permalink)
Member: 1293050
Sonork: 100.1625975
Thanks Meter: 664
Log file "D:\Program Files\GsmServer\Octopus_LG\LOG\22-08-2012_13-18-36.log" created.
22.08.2012 13:18:41 > Welcome to Octopus Box LG Software version 2.0.6
22.08.2012 13:19:03 > --------------------------------------------------------------------------------
22.08.2012 13:19:03 > Platform: LG Infineon
22.08.2012 13:19:03 > Selected port: COM21
22.08.2012 13:19:03 > Selected model: A100
22.08.2012 13:19:03 > This action requires COM cable!
22.08.2012 13:19:03 > Phone and phone lights should be powered ON
22.08.2012 13:19:03 > Reseting...22.08.2012 13:19:05 > OK
Old 08-23-2012, 16:29   #2064 (permalink)
Member: 1293050
Sonork: 100.1625975
Thanks Meter: 664
Log file "D:\Program Files\GsmServer\Octopus_LG\LOG\21-08-2012_15-36-07.log" created.
21.08.2012 15:36:13 > Welcome to Octopus Box LG Software version 2.0.6
21.08.2012 15:36:32 > --------------------------------------------------------------------------------
21.08.2012 15:36:32 > Platform: LG Qualcomm
21.08.2012 15:36:32 > Selected port: COM86
21.08.2012 15:36:32 > Selected model: SH400
21.08.2012 15:36:33 > Mode: Normal
21.08.2012 15:36:33 > Phone model: SW400809
21.08.2012 15:36:33 > SW Version: M6281A-KLUZ-4.0.9530T
21.08.2012 15:36:33 > IMEI: 354247-02-256518-7
21.08.2012 15:36:33 > Firmware compiled date: Jan 07 2008
21.08.2012 15:36:33 > Firmware compiled time: 19:00:00
21.08.2012 15:36:33 > Firmware released date: Oct 02 2008
21.08.2012 15:36:33 > Firmware released time: 11:02:32
21.08.2012 15:36:34 > --------------------------------------------------------------------------------
21.08.2012 15:36:34 > Platform: LG Qualcomm
21.08.2012 15:36:34 > Selected port: COM86
21.08.2012 15:36:34 > Selected model: SH400
21.08.2012 15:36:34 > Mode: Normal
21.08.2012 15:36:34 > Phone model: SW400809
21.08.2012 15:36:34 > SW Version: M6281A-KLUZ-4.0.9530T
21.08.2012 15:36:34 > IMEI: 354247-02-256518-7
21.08.2012 15:36:34 > Checking security...21.08.2012 15:36:36 > OK
21.08.2012 15:36:36 > Prepairing loader...21.08.2012 15:36:39 > OK
21.08.2012 15:36:39 > Sending loader...21.08.2012 15:36:39 > OK
21.08.2012 15:36:39 > Searching signatures...
21.08.2012 15:36:39 > Signature #1...21.08.2012 15:36:40 > OK, not patched
21.08.2012 15:36:40 > Patching...
21.08.2012 15:36:40 > Signature #1...21.08.2012 15:36:41 > OK
21.08.2012 15:36:41 > Phone successfully unlocked!
21.08.2012 15:36:41 > Rebooting phone...
Old 08-23-2012, 17:26   #2065 (permalink)
Member: 1558521
Sonork: 100.1623313
Thanks Meter: 11
Samsung C3303K unlock ok
Old 08-25-2012, 02:12   #2066 (permalink)
Bruno Rafael's Avatar
Member: 700706
Sonork: 100.1590381
Thanks Meter: 206
kf700 witch rj45 ( ke500)
Selected port: COM18
Selected model: KF700Q
Mode: Normal
Phone model: KF700Q
SW Version: KF700Q-MSM6280-V10a-JUN-27-2008-XX
IMEI: 355265-02-000400-8
Bluetooth address: 00:1F:E3:3A:7A:70
Fixing IMEI...
New IMEI: 358265-02-000433-6
Prepairing loader...OK
Sending loader...OK
Backup saved to "KF700Q-355265020004008_24-08-2012_21-03-04.sec"
Erasing security area...OK
IMEI successfully fixed!
Rebooting phone..
Old 08-25-2012, 06:13   #2067 (permalink)
Member: 1199921
Thanks Meter: 36
L2- E 405 successfully unlocked
Thanks to Octopus Box
Welcome to Octopus Box LG Software version 2.2.2
Selected port: COM157
Selected model: E405
Reading info...OK
Mode: Normal
Model ID: E405
Firmware compiled date: Apr 02 2012
Firmware compiled time: 06:00:00
Firmware released date: Jul 4 2012
Firmware released time: 12:01:26
SW Version: E1_ESA-M7225A-V10b-JUL-04-2012-XX
IMEI: 353111-xxxxxxxxxxx
Bluetooth address: A8:16:B2:A6:07:2A
Reading info...OK
Mode: Normal
Model ID: E405
Switching to Download mode...OK
Unlocking...
To avoid damaging your phone, please, follow these simple precautions:
Use a clean PC (without any installed drivers and software for BlackBerry phones, modem Dashboard software, Phone PC suites software).
Please, make sure the phone's battery is fully charged.
You should not run any other programs or attach new devices to your computer during this operation!
Sending loader...
Failed!
Reading info...Failed!
Port busy
Reading info...OK
Mode: Emergency
Model ID: BS/E405f/7D
Reading info...OK
Mode: Emergency
Unlocking...
Searching security area...OK
Backup saved to "E405_25-08-2012_11-09-55.SEC"
Analyzing security...OK
IMEI B: 353111-xxxxxxx
Switching to Normal mode...OK
Found model E405 at port COM157
Finalizing...OK
Rebooting phone...OK
Rebooting phone...
The Following User Says Thank You to Sonasalg For This Useful Post:
Old 08-27-2012, 09:47   #2068 (permalink)
Member: 1199921
Thanks Meter: 36
LG E612 unlock successfully
LG E612 unlock successfully,
Thanks to OPTUS box
Selected port: COM131
Selected model: E615
Reading info...OK
Mode: Normal
Model ID: LGE612
Firmware compiled date: Apr 19 2012
Firmware released date: Jun 27 2012
Firmware released time: 13:02:52
SW Version: LGE612AT-00-V10b-505-02-JUN-26-2012+0
IMEI: 352397-xxxxxxxxx
Bluetooth address: A8:16:B2:B0:1B:9B
Selected model: E612
Reading info...OK
Mode: Normal
Model ID: LGE612
IMEI: 352397-xxxxxxxxxx0
Unlocking...
Sending loader...
Failed!
Reading info...OK
Mode: Emergency
Model ID: BS/LGE612/7D
Unlocking...
Backup saved to "E612_27-08-2012_15-57-25.SEC"
IMEI: 352397-xxxxxxxxx-0
Found model LGE612 at port COM131
Finalizing...OK
Rebooting phone...
Old 08-28-2012, 23:06   #2069 (permalink)
fredinho's Avatar
Member: 975275
Sonork: 100.1607001
Thanks Meter: 216
Selected model: A180
Phone found.
Sending loader...OK
Flash ID: F8001632
Flash type: Fidelix
IMEI: 357600-04-873852-6
Backup saved to "A180-357600048738526_28-08-2012_11-18-03.eep"
Disconnected.
Phone found.
Sending loader...OK
Flash ID: F8001632
Flash type: Fidelix
IMEI: 357600-04-873857-5
Backup saved to "A180-357600048738575_28-08-2012_11-19-57.eep"
Old 08-30-2012, 09:13   #2070 (permalink)
Dilip_Nath's Avatar
Member: 387110
Sonork: 100.1590892
Thanks Meter: 598
KF750 flashing done
Platform: LG SEMC
Selected model: KF750
Use Testpoint/Jumper: No
For correct working the battery must be fully charged!
Please reconnect battery and then connect USB cable
Starting...
Phone found!
Chip ID: 0xC9000401FFFFFFFF
Chipset: DB3150
BootROM mode detected
Sending ACC preloader...OK
Sending APP preloader...OK
CID: 54
IMEI: 353359-02-768696-6
Color: Red
Sending ACC production loader...OK
Sending APP production loader...OK
Opening "BIN-KF750-00-V10a-234-15-MAY-08-2008+8.oct"...OK
Writing "KF750_cxc000000_U350_PHONE_MCP_NAND_B26
_commercial.ssw"...OK
Writing "KF750
_CXC_FS_CABS_LP_NAND_commercial_VDF_GB.ssw"...OK
Writing "KF750
_CXC_LGPXO_SYS_CABS_LP_NAND_commercial.ssw"...OK
Disconnected.
The Following User Says Thank You to Dilip_Nath For This Useful Post:
Post here successfully unlocked a2 phones 3lsheikh SETool2 10 03-04-2011 02:48
Successfully Unlock Z240 Phone Freeze jhepoy_org UST Pro II 13 12-02-2009 06:03
Successfully unlock BB5 phones with bb5king Mjabbar BB5KING 0 11-29-2008 14:13
Successfully unlock BB5 phones with bb5king Mjabbar BB5KING 2 11-26-2008 11:54
PB2 - Successfully unlocked LG phones CU/KU ... DOUHAL PolarBox 3 72 11-05-2008 18:21
Page generated in 0.49292 seconds with 9 queries
