Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Octopus/Octoplus > Octopus LG/Octoplus LG
Old 11-14-2012, 17:53   #2161 (permalink)
..::Rizwan::..'s Avatar
Member: 777415
Sonork: 1589702
Thanks Meter: 1,420
LG KP 500 Unlock Done
Welcome to Octopus Box LG Software version 2.2.9
Platform: LG Infineon
Selected port: COM3
Selected baudrate: 921600
Selected model: KP500
Please reconnect battery, press and hold power button...Canceled!
Disconnected.
Selected port: USB
Disconnect battery and connect USB cable to phone...
Reading info. Please wait...
IMEI: 352153-03-374552-3
Unlocking...
Reading security area...
Backup saved to
"KP500-352153033745523_14-11-2012_08-45-20.eep"
Writing security area...
Phone successfully unlocked!
The Following User Says Thank You to ..::Rizwan::.. For This Useful Post:
Old 11-15-2012, 13:42   #2162 (permalink)
trenac's Avatar
Member: 1246981
Sonork: 100.1590424
Thanks Meter: 240
p500 direct unlock
Platform: LG Qualcomm
Selected port: COM55
Selected model: P500
Reading info...OK
Mode: Normal
Model ID: P500
Firmware compiled date: Sep 02 2010
Firmware compiled time: 14:00:00
Firmware released date: Feb 22 2011
Firmware released time: 12:04:57
SW Version: P500-M76XX-V10h-FEB-23-2011-XX
IMEI: 354043-04-789427-6
Bluetooth address: B0:89:91:62:52:C0
Unlocking...
Switching to Download mode...OK
To avoid damaging your phone, please, follow these simple precautions:
Use a clean PC (without any installed drivers and software for
BlackBerry phones, modem Dashboard software, Phone PC suites
software).
Please, make sure the phone's battery is fully charged.
You should not run any other programs or attach new devices to your
computer during this operation!
Sending loader...OK
Reading security area...OK
Backup saved to "P500_354043047894276_15-11-2012_13-37-45.SEC"
Writing security area...OK
Rebooting phone...
The Following User Says Thank You to trenac For This Useful Post:
Old 11-15-2012, 21:12   #2163 (permalink)
sirnavid2010's Avatar
Member: 777729
Sonork: 100.1616470
Thanks Meter: 804
Welcome to Octopus Box LG Software version 2.3.0
Selected port: COM42
Selected model: E510
Reading info...OK
Mode: Emergency
Model ID: BS/E510/7D
Opening "BIN_LGE510AT-00-V10b-ARB-XX-JUN-04-2012+0.oct"...OK
Checking partition...OK
Write BootLoaders: Yes
Writing QCSBL header...OK
Writing QCSBL...OK
Writing OEMSBL...OK
Writing AMSS...OK
Writing APPS boot loader...OK
Writing Boot image...OK
Writing System...OK
Writing Recovery image...OK
Writing Splash image...OK
Finalizing...OK
Writing firmware done!
To finish the operation please power on phone and wait 3 minutes
The Following User Says Thank You to sirnavid2010 For This Useful Post:
Old 11-16-2012, 07:11   #2164 (permalink)
Member: 474934
Sonork: 100.1619723
Thanks Meter: 12
E400 reflash done
Selected port: COM261
Selected model: E400
Reading info...OK
Mode: Normal
Model ID: E400
Firmware compiled date: Nov 17 2011
Firmware compiled time: 22:00:00
Firmware released date: Jul 19 2012
Firmware released time: 11:45:11
SW Version: E0_EU-M7225A-V10f-JUL-19-2012-XX
IMEI: 353016-05-812061-8
Bluetooth address: A8:16:B2:CE:0C:34
Opening "LGE400AT-00-V10f-EUR-XXX-MAR-31-2012+0.oct"...OK
Write BootLoaders: No
Writing AMSS...OK
Writing Boot Image...OK
Writing Recovery Image...OK
Writing Persist...OK
Writing System...OK
Finalizing...OK
The Following User Says Thank You to vital_888 For This Useful Post:
Old 11-16-2012, 07:29   #2165 (permalink)
Member: 474934
Sonork: 100.1619723
Thanks Meter: 12
A230 reflash done
Selected port: USB
Selected model: A230
Disconnect battery and connect USB cable to phone...OK
Sending preloader...OK
Sending loader...OK
Initializing flash...OK
Flash ID: ADB1
Flash Vendor: Hynix
Reading info...
IMEI A: 358821-04-034935-6
IMEI B: 358821-04-034936-4
Bluetooth address: A8:92:2C:E5:A2:CB
Firmware version: V10a
Locks: none
Opening "LGA230AT-00-V10a-CIS-XXX-JUN-09-2011+0.oct"...OK
Reading EEPROM...OK
Backup saved to "A230_358821040349356_16-11-2012_12-21-45.EEP"
Writing Firmware...OK
Writing EEPROM...OK
Disconnected.
The Following 2 Users Say Thank You to vital_888 For This Useful Post:
Old 11-16-2012, 11:28   #2166 (permalink)
Member: 151368
Thanks Meter: 62
Selected port: COM14
Selected baudrate: 460800
Selected model: A100
Please reconnect battery...
Phone found.
Sending loader...OK
Flash ID: F8001632
Flash type: Fidelix
IMEI: 356861-04-461797-0
Reading codes. Please wait...
Unlock code: 7590 9334 3085 9803
To finish the operation, please perform the following steps:
1. Insert the original SIM card and type 2945#*20001#
2. Go to menu>Settings>Security>SIMLOCK and enter the code.
The Following 2 Users Say Thank You to Drunya_L For This Useful Post:
Old 11-18-2012, 09:35   #2167 (permalink)
Member: 350201
Thanks Meter: 51
P930 Flash Ok !
Welcome to Octopus Box LG Software version 2.3.1
Connecting to server octopus-server0.no-ip.biz:82...OK
Authorizing...OK
Selected port: COM5
Selected model: P930
Reading info...Failed!
Could not detect mode.
Selected port: COM5
Selected port: COM617
Reading info...OK
Mode: Emergency
Model ID: BS/P930/7D
Opening "LGP930AT-01-V20c-310-410-JUN-25-2012+0_2.oct"...OK
Writing MODEM...OK
Writing SBL1...OK
Writing SBL2...OK
Writing EXT...OK
Writing RPM...OK
Writing SBL3...OK
Writing ABOOT...OK
Writing BOOT...OK
Writing TZ...OK
Writing PERSIST...OK
Writing RECOVERY...OK
Writing MDM...OK
Writing TOMBSTONES...OK
Writing SYSTEM...OK
Writing CACHE...OK
Finalizing...OK
The Following User Says Thank You to taki7610 For This Useful Post:
Old 11-19-2012, 06:46   #2168 (permalink)
parengBok's Avatar
Member: 696820
Sonork: 100.1640853
Thanks Meter: 241
LG-T505 Security Code.. Done via flashing..
Procedure:
1.Infineon Tab
2. Select = T505
3. Connect (usb mode )without battery
4. Load Firmware
5. Tick write flash..
Selected port: USB
Selected model: T505
Sending loader...OK
Flash ID: ADBA
Flash Vendor: Hynix
Reading info...
IMEI: 357348-04-107464-4
Bluetooth address: 70:05:14:93:B8:F6
Locks: none
Opening "T505AT-01-V10a-214-03-APR-29-2011+0.oct"...OK
Reading EEPROM...OK
Backup saved to "T505_357348041074644_19-11-2012_10-54-24.EEP"
Writing EEPROM...OK
Disconnected.
Old 11-19-2012, 06:49   #2169 (permalink)
parengBok's Avatar
Member: 696820
Sonork: 100.1640853
Thanks Meter: 241
Lg-T505 Security Code.. done via flashing..
Selected port: USB
Sending loader...OK
Flash ID: ADBA
Flash Vendor: Hynix
Reading info...
Locks: none
Reading EEPROM...OK
Writing EEPROM...OK
Disconnected.
Uploaded with ImageShack.us
Old 11-22-2012, 05:34   #2170 (permalink)
Member: 350201
Thanks Meter: 51
SamSung i9300 repair EFS ok !
- My nhận banh t le
To connect SC-02B phone you have to perform the following steps:
1. Disconnect USB cable from phone.
2. Go to Menu->Settings->Applications->Development.
3. Turn on "USB Debugging" option.
4. When the message appears press "Yes".
5. Connect USB cable to the phone.
6. Press "Read Info" in Octopus Samsung software.
To connect GT-I9300 phone you have to perform the following steps:
2. Go to Menu->Settings->Developer options.
4. When message is appear press "Yes".
5. Connect usb cable to phone.
6. Go to dial window.
7. Enter *#9090# number.
8. Set speed to 115200.
9. Reboot phone.
10. Press "Read Info" in Octopus Samsung software.
Platform: Samsung Android
Selected port: COM362
Selected model: GT-I9300
Port is busy
To put GT-I9300 phone into download mode you have to perform the following steps:
1. Reconnect phone battery.
2. Press and hold "Volume - " + "Home" + "Power" buttons.
3. When phone turns on press "Volume+" button.
Repairing EFS...
Searching for a phone. Please wait...
Phone found.
EFS Repair successfully
Old 11-23-2012, 09:41   #2171 (permalink)
hanif007's Avatar
Member: 665441
Sonork: 100.1670531
Thanks Meter: 601
Selected port: USB
Selected model: GD510
Phone not respond!
Reconnecting in safe mode...
Please reconnect USB cable...
This mode only supports firmware writing.
Please use COM Cable for unlocking.
Opening "GD510AT-00-V10a-202-01-NOV-09-2009+4.oct"...OK
Writing Firmware...
Writing Firmware done!
Disconnected.
Old 11-23-2012, 10:00   #2172 (permalink)
hanif007's Avatar
Member: 665441
Sonork: 100.1670531
Thanks Meter: 601
Gd510
Selected port: USB
Phone not respond!
Writing Firmware...
Disconnected.
The Following 2 Users Say Thank You to hanif007 For This Useful Post:
Old 11-24-2012, 16:39   #2173 (permalink)
trenac's Avatar
Member: 1246981
Sonork: 100.1590424
Thanks Meter: 240
p 350 direct unlock ok
11/24/2012 4:30:29 PM > Selected port: COM57
11/24/2012 4:30:29 PM > Selected model: P350
11/24/2012 4:30:29 PM > Reading info...11/24/2012 4:30:29 PM > OK
11/24/2012 4:30:29 PM > Mode: Normal
11/24/2012 4:30:29 PM > Model ID: P350
11/24/2012 4:30:29 PM > Firmware compiled date: Oct 26 2010
11/24/2012 4:30:29 PM > Firmware compiled time: 14:00:00
11/24/2012 4:30:29 PM > Firmware released date: Sep 26 2011
11/24/2012 4:30:29 PM > Firmware released time: 12:56:51
11/24/2012 4:30:29 PM > SW Version: P350-M76XX-V10e-SEP-28-2011-XX
11/24/2012 4:30:29 PM > IMEI: 358304-04-594986-8
11/24/2012 4:30:29 PM > Bluetooth address: F8:0C:F3:47:BB:5F
11/24/2012 4:30:29 PM > Unlocking...
11/24/2012 4:30:29 PM > Switching to Download mode...11/24/2012 4:30:33 PM > OK
11/24/2012 4:30:33 PM > To avoid damaging your phone, please, follow these simple precautions:
Use a clean PC (without any installed drivers and software for BlackBerry phones, modem Dashboard software, Phone PC suites software).
You should not run any other programs or attach new devices to your computer during this operation!
11/24/2012 4:30:36 PM > Sending loader...11/24/2012 4:30:52 PM > OK
11/24/2012 4:30:52 PM > Reading security area...11/24/2012 4:30:52 PM > OK
11/24/2012 4:30:52 PM > Backup saved to "P350_358304045949868_24-11-2012_16-30-52.SEC"
11/24/2012 4:30:52 PM > Writing security area...11/24/2012 4:30:53 PM > OK
11/24/2012 4:30:53 PM > Phone successfully unlocked!
11/24/2012 4:30:53 PM > Rebooting phone...
Old 11-25-2012, 07:17   #2174 (permalink)
SANGURAN_BOX's Avatar
Member: 739429
Sonork: FIND TO GOOGLES
Thanks Meter: 85
Selected port: COM59
Selected model: L04C
Mode: Normal
Phone model: L04C
SW Version: L04C-M76XX-V10d-FEB-15-2011-XX
IMEI: 354079-04-041309-4
Bluetooth address: B0:89:91:3C:78:AC
Firmware compiled date: Oct 13 2010
Firmware compiled time: 21:00:00
Firmware released date: Feb 15 2011
Firmware released time: 12:42:09
Mode: Normal
Phone model: L04C
Checking security...OK
Unlocking...OK
Rebooting phone...
The Following User Says Thank You to SANGURAN_BOX For This Useful Post:
Old 11-25-2012, 07:17   #2175 (permalink)
Member: 739429
Thanks Meter: 85
Mode: Normal
Phone model: L04C
Mode: Normal
Phone model: L04C
Unlocking...OK
Rebooting phone...
Post here successfully unlocked a2 phones 3lsheikh SETool2 10 03-04-2011 02:48
Successfully Unlock Z240 Phone Freeze jhepoy_org UST Pro II 13 12-02-2009 06:03
Successfully unlock BB5 phones with bb5king Mjabbar BB5KING 0 11-29-2008 14:13
Successfully unlock BB5 phones with bb5king Mjabbar BB5KING 2 11-26-2008 11:54
PB2 - Successfully unlocked LG phones CU/KU ... DOUHAL PolarBox 3 72 11-05-2008 18:21
Page generated in 0.34364 seconds with 9 queries
