Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Octopus/Octoplus > Octopus LG/Octoplus LG
Old 03-06-2014, 12:29   #2566 (permalink)
Nadoui's Avatar
Member: 1202782
Sonork: 100.1608261
Thanks Meter: 634
Welcome to Octoplus/Octopus Box LG Software version 1.4.5
Platform: LG Infineon
Selected port: USB
Selected model: T385
Disconnect battery and connect USB cable to phone...OK
Sending preloader...OK
Sending loader...OK
Initializing flash...OK
Flash ID: ADBA
Flash Vendor: Hynix
Reading info...
IMEI: 352325-05-357997-0
Bluetooth address: A8:16:B2:3D:38:2F
Firmware version: V10a
Locks: none
Unlocking...
Reading EEPROM...OK
Backup saved to "T385_352325053579970_06-03-2014_13-25-11.EEP"
Writing EEPROM...OK
Phone successfully unlocked!
Old 03-06-2014, 15:25   #2567 (permalink)
Moderator
...:::::NP:::::...'s Avatar
Member: 1162626
Sonork: 100.1591727 QQ:2337938173
Thanks Meter: 9,761
LG GD330 Flash Repair Done
Welcome to Octoplus/Octopus Box LG Software version 1.4.6
Platform: LG Texas Instruments
Selected port: USB
Selected baudrate: 921600
Selected model: GD330
Phone found.
Sending loader...OK
Release power button.
Flash ID: ECA1
Flash type: Samsung
Reading info. Please wait...
IMEI: 358978-03-510274-3
Repair mode: Yes
Opening "GD330AT-00-V10a-334-030-APR-21-2009+0.oct"...OK
Erasing...OK
Writing Total BIN...OK
Bro:- Palash Ahammad
Old 03-10-2014, 05:52   #2568 (permalink)
Member: 1861077
Thanks Meter: 76
Lg nexus 4 - imei repair
I have never worked with LG phones before in my life, neither have I repaired or rooted, but LG OCTOPUS make it very simple. Only problem I faced, and I am not sure if others are familiar or not, that to start out this process I was not sure that the process must be started from Download Mode, and then let this tool do its magic. Obviously the phone must be rooted. I spend few hrs wondering why I can't see serial port, etc in device manager when all the people here have been able to connect using serial port. I even contact the support team, but before they respond I figure it out.
Platform: LG Qualcomm
Selected port: COM1616
Selected model: E960
Reading info...OK
Mode: Emergency
Model ID: BS/J1A/1 (LG-E960)
SW version: LGE960AT-00-V10e-NXS-XX-JUL-29-2013-JWR66V-USER+0
Product ID: PT04S131030003055
IMEI: 355136-05-782XXXX-X
Switching to Normal mode...
Initializing ADB...OK
Waiting for phone...OK
Trying to enable Diagnostics ports...
Checking root access...
Phone is already rooted.
Diagnostics ports are enbled!
Switching to Serial Port...
Found model ACEFWMAZ* d at port COM1630
Fixing IMEI...
New IMEI: 355136-05-22XXXX-X
Reading NVM...OK
Backup saved to "E960_35513605782XXXX_10-03-2014_00-43-28.NVM"
Found port COM1629
Switching to Download mode...OK
Reading partition...OK
Reading security area...OK
Backup saved to "E960_35513605782XXXX_10-03-2014_00-56-09.SEC"
Analyzing security...OK
Checking data...OK
Writing NVM...OK
NVM succesfully repaired.
IMEI successfully fixed!
Please, reboot the phone manually.
Old 03-12-2014, 11:23   #2569 (permalink)
indergsm's Avatar
Member: 1788939
Sonork: 100.1625853
Thanks Meter: 228
LG E617g Unlock Done!
BR,
Inder
Old 03-12-2014, 13:08   #2570 (permalink)
Moderator
Member: 1162626
Thanks Meter: 9,761
LG GT540 Patten Lock Remove By Factory Reset
Selected port: COM148
Selected model: GT540
Mode: Normal
Phone model: GT540
SW Version: GT540-M76XX-V20b-DEC-15-2010-XX
IMEI: 355614-04-212466-8
Bluetooth address: B0:89:91:02:12:06
Firmware compiled date: Apr 14 2010
Firmware compiled time: 02:00:00
Firmware released date: Dec 15 2010
Firmware released time: 09:13:03
Reseting...OK
Old 03-12-2014, 13:27   #2571 (permalink)
F-Buzz's Avatar
Member: 730337
Thanks Meter: 65
E450 write firmware done
Old 03-12-2014, 13:47   #2572 (permalink)
sirnavid2010's Avatar
Member: 777729
Sonork: 100.1616470
Thanks Meter: 799
Welcome to Octoplus/Octopus Box LG Software version 1.4.7
Connection mode: OMAP
Selected model: P970
Opening "BIN_LGP970AT-00-V30b-AME-XXX-JAN-22-2013+0_AP.oct"...
Please, disconnect battery and connect P999 cable (with 910k
resistor).OK
Initializing device...OK
Writing Firmware...
Connecting to modem CPU...OK
Sending preloader...Failed!
resistor).OK
Writing Firmware...
Sending loader...OK
Writing psi.fls...OK
Writing slb.fls...OK
Writing AENEAS_FW.fls...OK
Writing R375_SIC.fls...OK
Connecting to application CPU...Failed!
resistor).OK
Writing Firmware...
Connecting to modem CPU...Failed!
resistor).OK
Writing Firmware...
Sending loader...OK
resistor).OK
Writing Firmware...
Sending loader...OK
Connecting to application CPU...OK
Writing Partition #0...OK
Writing Partition #1...OK
Writing Partition #2...OK
Writing Partition #3...OK
Writing Partition #4...OK
Writing Partition #5...OK
Writing Partition #6...OK
Writing Partition #7...OK
Writing Partition #8...OK
Writing Partition #9...OK
Writing Partition #10...OK
Writing Partition #11...OK
Writing Partition #12...OK
Writing Partition #13...OK
Writing firmware done!
Rebooting phone...
Disconnected.
Old 03-12-2014, 13:47   #2573 (permalink)
Member: 777729
Sonork: 100.1616470
Thanks Meter: 799
resistor).OK
Writing Firmware...
Sending loader...OK
Rebooting phone...
Disconnected.
Old 03-12-2014, 16:50   #2574 (permalink)
Member: 248790
Thanks Meter: 43
d958 imei repair unlock
Selected port: COM81
Selected model: D958
Reading info...OK
Mode: Normal
Model ID: D958
Firmware compiled date: Oct 10 2013
Firmware compiled time: 16:00:00
Firmware released date: Jan 22 2014
Firmware released time: 11:07:52
SW Version: M8974A-AAAANAZM-1.0.190061
IMEI: xxxxxxxxxxxx
Fixing IMEI...
New IMEI: xxxxxxxxxxxxxx
Reading NVM...OK
Backup saved to " D958_xxxxxxxxxxxxxx_12-03-2014_16-58-35.NVM"
Backup saved to " D958_xxxxxxxxxxxxxx_12-03-2014_17-03-25.SEC"
Writing security area...OK
Found model D958 at port COM81
Checking data...OK
Writing NVM...OK
To complete the operation, please make Factory Reset (Go to "Settings" ->
"General" -> "Backup & reset" -> "Factory data reset", press "Reset
phone" and "Erase everything" buttons).
Old 03-12-2014, 20:29   #2575 (permalink)
Member: 1797183
Thanks Meter: 28
firmware D960 Successfully
Selected port: COM105
Reading info...OK
Mode: Emergency
SW version: LGE960AT-00-V10d-NXS-XX-FEB-16-2013-JDQ39-USER+0
Product ID: BS11S130309002862
IMEI: 355136-05-432094-3
Opening "LGE960AT-00-V10d-NXS-XX-JAN-31-2013-JOP40G-USER+
0.oct"...OK
Writing PrimaryGPT...OK
Formating userdata...OK
Writing modem...OK
Writing sbl1...OK
Writing sbl2...OK
Writing sbl3...OK
Writing tz...OK
Writing boot...OK
Writing recovery...OK
Writing rpm...OK
Writing aboot...OK
Writing sbl2b...OK
Writing sbl3b...OK
Writing abootb...OK
Writing rpmb...OK
Writing tzb...OK
Writing persist...OK
Writing system...OK
Writing cache...OK
Writing BackupGPT...OK
Finalizing...OK
Old 03-13-2014, 14:51   #2576 (permalink)
Member: 453916
Sonork: 100.1620840
Thanks Meter: 226
Selected port: COM21
Selected model: D801
Reading info...OK
Mode: Normal
Model ID: D801
Firmware compiled date: Jul 26 2013
Firmware compiled time: 23:00:00
Firmware released date: Nov 26 2013
Firmware released time: 20:20:51
SW Version: M8974A-AAAANAZM-1.0.190034
IMEI: 013703-00-266937-6
Unlocking...
Reading NVM...OK
Backup saved to "D801_013703002669376_13-03-2014_17-07-41.NVM"
Backup saved to "D801_013703002669376_13-03-2014_17-11-46.SEC"
Found model D801 at port COM21
Checking data...OK
Repairing NVM...OK
To complete the operation, please make Factory Reset (Go to "Settings" -> "General" -> "Backup & reset" -> "Factory data reset", press "Reset phone" and "Erase everything" buttons).
The Following User Says Thank You to chris2007 For This Useful Post:
Old 03-13-2014, 21:44   #2577 (permalink)
netmobile's Avatar
Member: 746276
Sonork: 100.1609752
Thanks Meter: 650
Optimus L9 (MS769) locked to MetroPCS.
The Following User Says Thank You to netmobile For This Useful Post:
Old 03-15-2014, 14:21   #2578 (permalink)
trenac's Avatar
Member: 1246981
Sonork: 100.1590424
Thanks Meter: 236
p700 unlock done
Selected port: COM45
Selected model: P700
Reading info...OK
Mode: Normal
Model ID: P700
Firmware compiled date: Mar 05 2012
Firmware compiled time: 07:00:00
Firmware released date: Aug 25 2012
Firmware released time: 12:26:32
SW Version: P700-M7227A-V10i-AUG-25-2012-XX
IMEI: 352248-05-522998-2
Bluetooth address: E8:92:A4:B8:E8:4A
Wi-Fi MAC address: A8:16:B2:75:70:47
Unlocking...
To avoid damaging your phone, please, follow these simple precautions:
Use a clean PC (without any installed drivers and software for BlackBerry
phones, modem Dashboard software, Phone PC suites software).
Please, make sure the phone's battery is fully charged.
You should not run any other programs or attach new devices to your
computer during this operation!
Sending loader...
Searching security area...OK
Backup saved to "P700_15-03-2014_14-18-14.SEC"
Found model P700 at port COM45
Finalizing...OK
Rebooting phone...OK
Rebooting phone...
The Following User Says Thank You to trenac For This Useful Post:
Old 03-16-2014, 10:26   #2579 (permalink)
Islombek1991's Avatar
Member: 1922302
Sonork: 100.1638015
Thanks Meter: 21
Welcome to Octoplus/Octopus Box LG Software version 1.3.5
Platform: LG MTK
Selected port: COM1
Selected model: A155
Please, disconnect battery and connect cable...OK
Phone found.
Setting power state...OK
Prepairing loader...OK
Sending loader...OK
Synchronizing with loader...OK
Detecting NOR flash chip...OK
Detecting NAND flash chip...OK
Reading info...OK
IMEI A: Bad
IMEI B: Bad
Bluetooth address: Unknown
NOR flash chip: Intel
NOR size: 32 Mb
Opening "LGA155AT-00-V10d-CIS-XXX-APR-06-2011+0.oct"...OK
Writing Firmware...OK
The Following User Says Thank You to Islombek1991 For This Useful Post:
Old 03-16-2014, 17:07   #2580 (permalink)
mr.omphonx's Avatar
Member: 714648
Sonork: 1609640
Thanks Meter: 897
REPAIR BOOT P765 WITHOUT JTAG DONE WITH OCTOPUS
16/03/2014 22:51:40 > Connection mode: OMAP
16/03/2014 22:51:40 > Selected model: P765
16/03/2014 22:51:40 > Please, disconnect cable, reconnect battery, connect P999 cable (with 910k resistor)
16/03/2014 22:52:37 > Connecting...16/03/2014 22:52:37 > OK
16/03/2014 22:52:37 > Sending preloader...16/03/2014 22:52:43 > OK
16/03/2014 22:52:43 > Sending loader...16/03/2014 22:52:43 > OK
16/03/2014 22:52:51 > Opening "LGP765AT-00-V20b-IDN-JUL-26-2013+0_AP.oct"...16/03/2014 22:52:51 > OK
16/03/2014 22:52:51 > Initializing device...16/03/2014 22:52:52 > OK
16/03/2014 22:52:52 > Writing Firmware...
16/03/2014 22:52:52 > Connecting to application CPU...16/03/2014 22:52:52 > OK
16/03/2014 22:52:52 > Erasing gpt1...16/03/2014 22:52:52 > OK
16/03/2014 22:52:53 > Writing gpt1...16/03/2014 22:52:54 > OK
16/03/2014 22:52:54 > Erasing u-boot...16/03/2014 22:52:54 > OK
16/03/2014 22:52:54 > Writing u-boot...16/03/2014 22:52:55 > OK
16/03/2014 22:52:55 > Erasing boot...16/03/2014 22:52:55 > OK
16/03/2014 22:52:55 > Writing boot...16/03/2014 22:53:12 > OK
16/03/2014 22:53:12 > Erasing recovery...16/03/2014 22:53:12 > OK
16/03/2014 22:53:12 > Writing recovery...16/03/2014 22:53:30 > OK
16/03/2014 22:53:31 > Erasing misc...16/03/2014 22:53:31 > OK
16/03/2014 22:53:31 > Writing misc...16/03/2014 22:53:32 > OK
16/03/2014 22:53:32 > Erasing reserved...16/03/2014 22:53:32 > OK
16/03/2014 22:53:32 > Writing reserved...16/03/2014 22:53:33 > OK
16/03/2014 22:53:33 > Erasing system...16/03/2014 22:53:34 > OK
16/03/2014 22:53:34 > Writing system...16/03/2014 22:54:48 > OK
16/03/2014 22:54:49 > Repairing boot done.
16/03/2014 22:54:49 > Please, write any firmware from support.
The Following User Says Thank You to mr.omphonx For This Useful Post:
Post here successfully unlocked a2 phones 3lsheikh SETool2 10 03-04-2011 01:48
Successfully Unlock Z240 Phone Freeze jhepoy_org UST Pro II 13 12-02-2009 05:03
Successfully unlock BB5 phones with bb5king Mjabbar BB5KING 0 11-29-2008 13:13
Successfully unlock BB5 phones with bb5king Mjabbar BB5KING 2 11-26-2008 10:54
PB2 - Successfully unlocked LG phones CU/KU ... DOUHAL PolarBox 3 72 11-05-2008 17:21
Page generated in 0.55686 seconds with 9 queries
