11-21-2014, 12:27 | #2853 (permalink) |
No Life Poster Join Date: Jul 2004 Location: Ukraine Age: 44
Member: 75408 Status: Offline Thanks Meter: 1,190 | Flashing LG U8120: Code: Welcome to Octoplus/Octopus Box LG Software version 1.7.5 -------------------------------------------------------------------------------- Platform: LG SEMC Selected port: COM3 Selected baudrate: 921600 Selected model: U8120 Use Testpoint/Jumper: No -------------------------------------------------------------------------------- Please reconnect battery and press "Power ON" Phone found Chip ID: 01030071 Hardware CID: 17 Mcert: A1_LG_AS_CUSTOMER Phone authorization: BROWN Sending preloader...OK Sending start loader...OK Sending main loader...OK CERTLOADER: 040318 1450 LLECXC1325413_CERTLOADER R3J Flash ID: 890D Flash type: Intel RD38F4050L0YT IMEI: 353290-00-683385-9 Sending flash preloader...OK Opening "U8120_V104_RUSS.oct"...OK Sending main loader...OK Writing Firmware... Converting "U8120_phone_wcdma_4mbram_russ.ssw"...OK Writing "U8120_phone_wcdma_4mbram_russ.ssw"...OK Converting "drive_c_russ.ssw"...OK Writing "drive_c_russ.ssw"...OK Converting "drive_media_russ.ssw"...OK Writing "drive_media_russ.ssw"...OK Converting "FS_Rec_Italy_russ.ssw"...OK Writing "FS_Rec_Italy_russ.ssw"...OKOK Disconnected. |
11-21-2014, 12:29 | #2854 (permalink) |
Member: 75408 Status: Offline Thanks Meter: 1,190 | Unlocking LG U8120: Code: Platform: LG SEMC Selected port: COM3 Selected baudrate: 921600 Selected model: U8120 Use Testpoint/Jumper: No -------------------------------------------------------------------------------- Please reconnect battery and press "Power ON" Phone found Chip ID: 01030071 Hardware CID: 17 Mcert: A1_LG_AS_CUSTOMER Phone authorization: BROWN Sending preloader...OK Sending start loader...OK Sending main loader...OK CERTLOADER: 040318 1450 LLECXC1325413_CERTLOADER R3J Flash ID: 890D Flash type: Intel RD38F4050L0YT IMEI: 353290-00-683385-9 Sending flash preloader...OK Sending production loader...OK Unlocking...OK -------------------------------------------------------------------------------- All codes are set to: 56014436 To finish unlock procedure do next: - Insert SIM Card, power on phone and enter 2945#*88110# - Enter 56014436 Disconnected. |
11-24-2014, 15:46 | #2855 (permalink) | |
No Life Poster Join Date: May 2006 Location: The_Colombian_Team !
Member: 278939 Status: Offline Sonork: 100.1593095 Thanks Meter: 382 | Repair IMEI LG D855P Done Quote:
11-24-2014, 19:21 | #2856 (permalink) |
Freak Poster Join Date: Jul 2013 Location: OMAN UAE
Member: 1982525 Status: Offline Sonork: 100.1619259 Thanks Meter: 45 | Docomo L705iX Tested ---------------------------------------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM47 Selected model: L705iX Phone not detected. Please try again. ---------------------------------------------------------------------------------------------------------------- To perform this operation you need: 1. Disconnect cable from phone 2. Type #17320508*# 3. Go to "Port Settng" and select "QCT mode" 4. Go to "Diag Setting" and select "USB Set for Diag" 5. Connect cable to phone and press "Read info" ---------------------------------------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM47 Selected model: L705iX Mode: Normal Phone model: L705iX SW Version: L705iX-MSM409510-V10c-MAR-17-2009-DCM-JP IMEI: 358393-01-113RRR-4 Bluetooth adress: 0D:47:4D:7E:BB:01 Firmware compiled date: Jun 28 2007 Firmware compiled time: 18:00:00 Firmware released date: Mar 17 2009 Firmware released time: 11:52:22 ---------------------------------------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM47 Selected model: L705iX Mode: Normal Phone model: L705iX SW Version: L705iX-MSM409510-V10c-MAR-17-2009-DCM-JP IMEI: 358393-01-113RRR-4 Bluetooth adress: 0D:47:4D:7E:BB:01 Unlocking... Prepairing loader...OK Sending loader...OK Writing security area... Phone succesfully unlocked! Rebooting phone... |
11-26-2014, 16:15 | #2857 (permalink) |
Insane Poster Join Date: Jun 2012 Age: 27
Member: 1768772 Status: Offline Thanks Meter: 13 | Factory Reset T375 -------------------------------------------------------------------------------- Platform: LG Infineon Selected port: COM6 Selected model: T300 This action requires COM cable! Phone and phone lights should be powered ON Reseting...OK |
The Following User Says Thank You to paulo henryck For This Useful Post: |
11-26-2014, 19:44 | #2858 (permalink) |
Member: 1768772 Status: Offline Thanks Meter: 13 | Unlock Gs107 Platform: LG Infineon Selected port: COM6 Selected baudrate: 921600 Selected model: GS107 Please, disconnect battery and connect cable... Phone found. Sending preloader...OK Sending loader...OK Reading info. Please wait... Flash ID: EC000626 Flash type: Samsung IMEI: 353696-04-571528-9 Reading security area...OK Backup saved to "GS107-353696045715289_26-11-2014_15-41-19.eep" Writing security area...OK Phone successfully unlocked! |
11-27-2014, 15:50 | #2859 (permalink) |
Product Supporter Join Date: Jul 2011 Location: ISLAMIC & INDIA WITH MIRACLE T Age: 37
Member: 1617868 Status: Offline Sonork: 100.1625996 Thanks Meter: 2,028 | Lg c105 hang logo solvede (flashing) Last edited by Octopus box; 12-02-2014 at 14:51. |
The Following User Says Thank You to .::THE ROCK::. For This Useful Post: |
11-27-2014, 19:34 | #2860 (permalink) |
No Life Poster Join Date: Jan 2009 Location: cameroon
Member: 953931 Status: Offline Sonork: 1652252 Thanks Meter: 897 | lg E610 Flasing done Code: -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM17 Selected model: E610 Reading info...OK Mode: Emergency Model ID: BS/LGE610/8D Opening "LGE610vAT-01-V20c-219-10-MAY-18-2013+0.oct"...OK Checking partition...OK Write BootLoaders: No Writing AMSS...OK Writing Boot Image...OK Writing Boot logo...OK Writing Recovery Image...OK Writing Persist...OK Writing System...OK Finalizing...OK Writing firmware done! To finish the operation please power on phone and wait 3 minutes |
The Following User Says Thank You to fokal2008 For This Useful Post: |
11-27-2014, 19:36 | #2861 (permalink) |
Member: 953931 Status: Offline Sonork: 1652252 Thanks Meter: 897 | Lg E900 Flasing done Code: Platform: LG Qualcomm Selected port: COM22 Selected model: E900 Phone model: E900 Mode: Emergency Opening "LG-E900AT-01-V10g-208-01-OCT-19-2010+0.oct"...OK Writing Firmware... -------------------------------------------------------------------------------- Please, make sure the phone's battery is fully charged. Disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Qualcomm-based devices). You should not run any other programs or attach new devices to your computer during the flashing! Please, follow these simple precautions to avoid damaging your phone. -------------------------------------------------------------------------------- Checking partition...OK Writing APPS boot...OK Writing APPS...OK Writing DSP1...OK Writing AMSS...OK Writing Windows Mobile...OK Writing Firmware done! To finish the operation please power on phone and wait 3 minutes |
11-29-2014, 12:47 | #2862 (permalink) |
Member: 1768772 Status: Offline Thanks Meter: 13 | -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM8 Selected model: E405 Reading info...OK Mode: Emergency Model ID: BS/E405/7D Opening "V10F_00_E405.oct"...OK Checking partition...OK Write BootLoaders: Yes Checking BCPL status...OK BCPL status: 1 Unlocking BCPL...OK BCPE status: 0 Writing QCSBL_CFG...OK Writing QCSBL...OK Writing OEMSBL...OK Writing AMSS...OK Writing EMMCBOOT...OK Writing Boot Image...OK Writing Recovery Image...OK Writing Persist...OK Writing System...OK Finalizing...OK Writing firmware done! To finish the operation please power on phone and wait 3 minutes |
12-02-2014, 14:38 | #2863 (permalink) |
No Life Poster Join Date: Nov 2007 Location: Romania,Sinaia
Member: 637351 Status: Offline Thanks Meter: 167 | lg e730 Resetting screen lock successfully Code: Platform: LG Qualcomm Selected port: COM80 Selected model: E730 Reading info...OK Mode: Normal Model ID: E730 Firmware compiled date: Aug 10 2011 Firmware compiled time: 13:00:00 Firmware released date: Jan 14 2013 Firmware released time: 17:27:51 SW Version: E730-M8X55-V10j-JAN-15-2013-XX IMEI: 358103-04-09xxxx-x Bluetooth address: F0:1C:13:8B:30:52 Wi-Fi MAC address: F0:1C:13:0E:A3:74 Switching to Download mode...OK To avoid damaging your phone, please, follow these simple precautions: Use a clean PC (without any installed drivers and software for BlackBerry phones, modem Dashboard software, Phone PC suites software). Please, make sure the phone's battery is fully charged. You should not run any other programs or attach new devices to your computer during this operation! Sending loader...OK Resetting Screen Lock... This process can take about 15 minutes. Please, wait... Resetting screen lock successfully completed! Rebooting phone... |
12-02-2014, 16:46 | #2864 (permalink) |
No Life Poster Join Date: Jan 2008 Location: PAKISTAN KARACHI Age: 44
Member: 686395 Status: Offline Sonork: 100.1608345 Thanks Meter: 3,822 | Lg ls995 one click unlock LG LS995 ONE CLICK UNLOCK Code: Welcome to Octoplus/Octopus Box LG Software version 1.7.6 -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM140 Selected model: LS995 Reading info...OK Mode: Normal Model ID: LS995ZV7:ÿh°( Firmware compiled date: Mar 04 2014 Firmware compiled time: 23:00:00 Firmware released date: Jun 12 2014 Firmware released time: 20:12:58 SW Version: M8974A-AAAANAZM-2.0.20049 IMEI: 990003-56-023726-1 SPC: 831940 MEID: 99000356023726 Mobile ESN: 80C5BA4D SSD_A: 91CC64BFDEFF7EB2 SSD_B: 73E74163C6E9F735 AKEY: 16001958615661734420 OTKSL: 816018 NAM Name: Sprint MDN: 718-593-7091 User Lock Code: 8022 SID/NID: 4139 / 65535 MCC: 310 MNC: 00 MIN1: 3507032 MIN2: 347 Unlocking... Initializing ADB...OK Waiting for phone...OK Checking root access... Phone is not rooted. Sending exploit...OK Checking root access... Phone is already rooted. Root access garanted! Sending network config...OK Setting options...OK Phone successfully unlocked! Rebooting phone... To complete the operation, please make Factory Reset (Go to "Settings" -> "General" -> "Backup & reset" -> "Factory data reset", press "Reset phone" and "Erase everything" buttons). |
Post here successfully unlocked a2 phones | 3lsheikh | SETool2 | 10 | 03-04-2011 02:48 |
Successfully Unlock Z240 Phone Freeze | jhepoy_org | UST Pro II | 13 | 12-02-2009 06:03 |
Successfully unlock BB5 phones with bb5king | Mjabbar | BB5KING | 0 | 11-29-2008 14:13 |
Successfully unlock BB5 phones with bb5king | Mjabbar | BB5KING | 2 | 11-26-2008 11:54 |
PB2 - Successfully unlocked LG phones CU/KU ... | DOUHAL | PolarBox 3 | 72 | 11-05-2008 18:21 |
