10-28-2015, 13:41 | #3316 (permalink) |
No Life Poster Join Date: Sep 2006 Location: Dhaka Bangladesh Age: 33
Member: 348877 Status: Offline Sonork: 1601289 Thanks Meter: 1,178 | Welcome to Octoplus/Octopus Box LG Software version 2.0.8 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM8 Selected model: D850 Reading info... Model ID: LG-D850 IMEI: 014065-00-023729-4 Android version: 5.0.1 Battery level: 67% Mode: Normal Firmware compiled date: Dec 05 2014 Firmware compiled time: 03:00:00 Firmware released date: Jan 16 2015 Firmware released time: 13:48:41 SW Version: MPSS.DI.2.0.1.c1.13-00050-M8974AAAAANPZM-1 IMEI: 014065-00-023729-4 SPC: 000000 Unlocking... Reading QCN... Send SPC...OK Reading Mobile Property...OK Reading Feature Mask...OK Reading Roaming List 0...OK Reading NV_Numbered Items...OK Reading NV_Numbered SIM1 Items...OK Reading NV_Numbered SIM2 Items...OK Reading NV Items...OK Reading EFS...OK Reading Provisioning Items...OK Reading QCN done! Backup saved to "D850_014065000237294_28-10-2015_12-15-04.qcn" Switching to Download mode...OK Initializing flash...OK Reading partition...OK Reading security area...OK Backup saved to "D850_014065000237294_28-10-2015_12-31-05.SEC" Writing security area...OK Switching to Normal mode... Trying to enable Diagnostics ports... Initializing ADB...OK ADB Server was found. Trying to kill... Waiting for phone... Please, reconnect phone, enable USB debugging, and try again. To enable USB debugging, please perform the following steps: 1. Disconnect cable 2. Install LG Android ADB drivers 3. Go to "Settings" -> "About phone" -> "Software information" 4. Click on Build number 5 times 5. Enable "Settings" -> "Developer options" -> "USB debugging" option 6. Connect the cable and check, whether ADB interface has appeared in PC Device Manager. Please perform the following steps: 1. Disconnect cable 2. Put phone into Normal mode manually 3. Press "Ok" button Trying to enable Diagnostics ports... Initializing ADB...OK ADB Server was found. Trying to kill... Waiting for phone...OK Diagnostics ports are enbled! Switching to Serial Port... Found model LG-D850 at port COM8 Send SPC...OK Writing QCN... Writing NV_Numbered Items...OK Writing NV_Numbered SIM1 Items...OK Writing NV_Numbered SIM2 Items...OK Writing QCN done! Phone successfully unlocked! To complete the operation, please make Factory Reset (Go to "Settings" -> "General" -> "Backup & reset" -> "Factory data reset", press "Reset phone" and "Erase everything" buttons). |
10-28-2015, 15:26 | #3317 (permalink) |
Member: 348877 Status: Offline Sonork: 1601289 Thanks Meter: 1,178 | LG P760 Flash done... Welcome to Octoplus/Octopus Box LG Software version 2.0.8 -------------------------------------------------------------------------------- Platform: LG Infineon Connection mode: OMAP Selected model: P760 Opening "LGP760AT-00-V10a-EUR-XXX-SEP-16-2012+0_AP.oct"...OK Please, disconnect cable, reconnect battery, connect P999 cable (with 910k resistor) Initializing device...OK Writing Firmware... Connecting to modem CPU...OK Sending preloader...OK Sending loader...OK Initializing flash...OK Writing psi.fls...OK Writing slb.fls...OK Writing AENEAS_FW.fls...OK Writing L6260_SIC.fls...OK Writing L6260_SIC-CDS.fls...OK Connecting to application CPU...OK Erasing gpt1...OK Writing gpt1...OK Erasing u-boot...OK Writing u-boot...OK Erasing boot...OK Writing boot...OK Erasing recovery...OK Writing recovery...OK Erasing misc...OK Writing misc...OK Erasing reserved...OK Writing reserved...OK Erasing system...OK Writing system...OK Erasing persist...OK Writing persist...OK Erasing gpt2...OK Writing gpt2...OK Writing firmware done! Disconnected. |
10-31-2015, 10:47 | #3318 (permalink) |
No Life Poster Join Date: Dec 2004 Location: Amoude-syria Age: 49
Member: 98928 Status: Offline Thanks Meter: 464 | LG G2 D802 reseting user code ok no data lose all is ok HER IS THE LOG: Code: Platform: LG Qualcomm Selected port: COM349 Selected model: D802 Please, put the phone into download mode manually (Power phone OFF, press and hold "Vol+" button and connect the cable). Reading info... Mode: Emergency Initializing flash...OK SW version: LGD802AT-00-V20b-CIS-XX-APR-23-2014+0 LAF Version: 1.0 Product ID: SM08S140617002670 IMEI: 865787-01-450739-2 Target operator: OPEN Hardware: rev_10 Resetting Screen Lock... Resetting screen lock successfully completed! |
11-01-2015, 12:31 | #3319 (permalink) |
No Life Poster Join Date: Nov 2007 Location: Romania,Sinaia
Member: 637351 Status: Offline Thanks Meter: 167 | LG T385b Unlock Done Code: Platform: LG Infineon Selected port: USB Selected model: T385B Disconnect battery and connect USB cable to phone...OK Sending preloader...OK Sending loader...OK Initializing flash...OK Flash ID: ADBA Flash Vendor: Hynix Reading info... IMEI: 353626-05-0xxxxx-x Bluetooth address: E8:92:A4:15:D1:1B Firmware version: V10a Locks: Network Lock Unlocking... Reading EEPROM...OK Backup saved to "T385B_3536260508xxxxx_01-11-2015_12-22-39.EEP" Reading security area...OK Writing security area... Writing EEPROM...OK Phone successfully unlocked! |
11-02-2015, 11:48 | #3321 (permalink) |
Member: 348877 Status: Offline Sonork: 1601289 Thanks Meter: 1,178 | LG MS323 Direct Unlock done.. Welcome to Octoplus/Octopus Box LG Software version 2.0.8 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM15 Selected model: MS323 Reading info... Model ID: LGMS323 IMEI: 014038-00-377285-6 Android version: 4.4.2 Battery level: 77% Mode: Normal Firmware compiled date: Feb 12 2014 Firmware compiled time: 05:00:00 Firmware released date: Aug 25 2014 Firmware released time: 21:44:37 SW Version: M8610B-AAAANAZM-1.0.6038 IMEI: 014038-00-377285-6 SPC: 000000 Unlocking... Skip Read/Write QCN Switching to Download mode...OK Initializing flash...OK Reading partition...OK Reading security area...OK Backup saved to "MS323_014038003772856_02-11-2015_10-13-56.SEC" Writing security area...OK Switching to Normal mode... Found model WX_PROJE at port COM15 Phone successfully unlocked! To complete the operation, please make Factory Reset (Go to "Settings" -> "General" -> "Backup & reset" -> "Factory data reset", press "Reset phone" and "Erase everything" buttons). |
11-04-2015, 23:55 | #3324 (permalink) |
No Life Poster Join Date: May 2010 Location: South America Age: 41
Member: 1308889 Status: Offline Sonork: 100.1608156 Thanks Meter: 266 | successfully unlocked LG P700 Checking data...OK Platform: LG Qualcomm Selected port: COM91 Selected model: P700 Reading info...OK Mode: Normal Model ID: P700 Firmware compiled date: Feb 22 2013 Firmware compiled time: 00:00:00 Firmware released date: Aug 13 2013 Firmware released time: 18:13:55 SW Version: P700-M7227A-V20f-AUG-13-2013-XX IMEI: 355332-05-384022-7 Bluetooth address: 986:F7:48:18:51 Wi-Fi MAC address: 10:68:3F:E9:17:2B Switching to Download mode...OK Unlocking... Searching security area...OK Reading security area...OK Backup saved to "P700_355332053840227_04-11-2015_17-42-49.SEC" Analyzing security...OK IMEI: 355332-05-384022-7 Bluetooth address: 986:F7:48:18:51 Writing security area...OK Switching to Normal mode... Please perform the following steps: 1. Disconnect cable 2. Put phone into Normal mode manually 3. Press "Ok" button Found model P700 at port COM91 Finalizing...OK Rebooting phone...OK Phone successfully unlocked! Rebooting phone... |
11-06-2015, 18:51 | #3325 (permalink) |
No Life Poster Join Date: Oct 2011 Location: online
Member: 1680232 Status: Offline Sonork: 100.1611221 Thanks Meter: 227 | Checking data...OK Platform: LG Qualcomm Selected port: COM43 Selected model: MS500 Reading info... Model ID: LGMS500-00-MS50012b-TMO-US-MAR-24-20140 IMEI: Android version: Battery level: 48% Mode: Normal Firmware compiled date: Mar 24 2014 Firmware compiled time: 20:58:37 Firmware released date: Mar 24 2014 Firmware released time: 20:58:37 SW Version: LGMS500Z00 IMEI: 013758-00-236002-0 SPC: 000000 Unlocking... Initializing ADB...OK ADB Server was found. Trying to kill... Waiting for phone...OK Checking root access... Initializing ADB...OK Waiting for phone...OK Phone is already rooted. Reading QCN... Send SPC...OK Reading Mobile Property...OK Reading Feature Mask...OK Reading Roaming List 0...OK Reading NV_Numbered Items...OK Reading NV_Numbered SIM1 Items...OK Reading NV_Numbered SIM2 Items...OK Reading NV Items...OK Reading EFS...OK Reading Provisioning Items...OK Reading QCN done! Backup saved to "MS500_013758002360020_06-11-2015_12-28-29.qcn" Reading partition...OK Reading security area...OK Backup saved to "MS500_013758002360020_06-11-2015_12-41-05.SEC" Analyzing security...OK Rebooting phone... Found model LGMS500Z: ÿd at port COM43 Send SPC...OK Writing QCN... Writing EFS...OK Writing NV_Numbered Items...OK Writing NV_Numbered SIM1 Items...OK Writing NV_Numbered SIM2 Items...OK Writing Provisioning Items...OK Writing QCN done! Phone successfully unlocked! Rebooting phone... |
11-08-2015, 11:12 | #3326 (permalink) |
No Life Poster Join Date: Apr 2009 Location: The Great India
Member: 1004995 Status: Offline Thanks Meter: 230 | D 340 SUCCESSFULY FLASHED. Welcome to Octoplus/Octopus Box LG Software version 2.0.6 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM11 Selected model: D380 Reading info... Model ID: LG-D380 IMEI: Android version: 4.4.2 Battery level: 41% Mode: Normal Firmware compiled date: Apr 08 2014 Firmware compiled time: 01:00:00 Firmware released date: Aug 28 2014 Firmware released time: 21:12:40 SW Version: M8610B-AAAANAZM-1.0.6047 IMEI: 354106-06-150937-5 IMEI B: 354106-06-150938-3 SPC: 000000 Opening "D38010d_00.oct"...OK Switching to Download mode...OK Initializing flash...OK Setting options...OK Reading partition...OK Formating USERDATA...OK Writing PrimaryGPT...OK Writing modem...OK Writing sbl1...OK Writing rpm...OK Writing tz...OK Writing sdi...OK Writing aboot...OK Writing rpmb...OK Writing tzb...OK Writing abootb...OK Writing persist...OK Writing laf...OK Writing boot...OK Writing recovery...OK Writing factory...OK Writing sbl1b...OK Writing cust...OK Writing system...OK Writing BackupGPT...OK Reading partition...OK Formating RCT...OK Formating MPT...OK Finalizing...OK Writing firmware done! |
11-10-2015, 09:24 | #3327 (permalink) |
No Life Poster Join Date: Oct 2005 Location: Pakistan
Member: 192810 Status: Offline Sonork: Some people NEED change Thanks Meter: 860 | Lg F180K Flashing Done Code: Welcome to Octoplus/Octopus Box LG Software version 2.0.8 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM58 Selected model: F180K Searching Diagnostic Ports...OK Reading info... Model ID: LGF180KAT-00-F180K20i-KT-KR-MAR-06-20130 IMEI: Android version: Battery level: 51% Mode: Emergency Model ID: BS/J1KT/1 SW version: LGF180KAT-00-V20i-KT-KR-MAR-06-2013+0 Product ID: PT02S121227003246 IMEI: 354281-05-128317-2 Opening "LGF180KAT-00-V20g-KT-KR-FEB-07-2013+0_2.oct"...OK Initializing flash...OK Reading partition...OK Writing PrimaryGPT...OK Reading partition...OK Formating userdata...OK Formating cache...OK Writing modem...Failed! -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM58 Selected model: F180K Searching Diagnostic Ports...OK Reading info... Model ID: LGF180KAT-00-F180K20i-KT-KR-MAR-06-20130 IMEI: Android version: Battery level: 51% Mode: Normal Firmware compiled date: Dec 04 2012 Firmware compiled time: 18:00:00 Firmware released date: Mar 5 2013 Firmware released time: 12:45:16 SW Version: Bluetooth address: 15:01:82:45:3A:08 Wi-Fi MAC address: 00:00:00:00:00:00 -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM7 Selected model: F180K Searching Diagnostic Ports...OK Reading info... Could not detect mode! -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM7 Selected model: F180K Searching Diagnostic Ports...OK Reading info... Could not detect mode! -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM58 Selected model: F180K Searching Diagnostic Ports...OK Reading info... Model ID: LGF180KAT-00-F180K20i-KT-KR-MAR-06-20130 IMEI: Android version: Battery level: 51% Mode: Emergency Model ID: BS/J1KT/1 SW version: LGF180KAT-00-V20i-KT-KR-MAR-06-2013+0 Product ID: PT02S121227003246 IMEI: 354281-05-128317-2 Opening "LGF180KAT-00-V20g-KT-KR-FEB-07-2013+0_2.oct"...OK Initializing flash...OK Reading partition...OK Writing PrimaryGPT...OK Reading partition...OK Formating userdata...OK Formating cache...OK Writing modem...OK Writing sbl1...OK Writing sbl2...OK Writing sbl3...OK Writing aboot...OK Writing rpm...OK Writing boot...OK Writing tz...OK Writing system...OK Writing userdata...OK Writing persist...OK Writing recovery...OK Writing BackupGPT...OK Finalizing...OK Writing firmware done! |
11-10-2015, 15:25 | #3328 (permalink) |
Member: 348877 Status: Offline Sonork: 1601289 Thanks Meter: 1,178 | LG P875 Flash done... Welcome to Octoplus/Octopus Box LG Software version 2.0.8 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM15 Selected model: P875 Reading info... Model ID: LGP875AT-00-P87510b-EUR-XX-JUL-09-20130 IMEI: Android version: Battery level: 54% Mode: Normal Firmware compiled date: Jul 9 2013 Firmware compiled time: 10:56:18 Firmware released date: Jul 9 2013 Firmware released time: 10:56:18 SW Version: P875 IMEI: 356226-05-022633-2 SPC: 000000 Opening "P87510e.oct"...OK Switching to Download mode...OK Initializing flash...OK Testing connection...OK Writing PrimaryGPT...OK Writing modem...OK Writing sbl1...OK Writing sbl2...OK Writing sbl3...OK Writing aboot...OK Writing rpm...OK Writing boot...OK Writing tz...OK Writing system...OK Writing userdata...OK Writing persist...OK Writing cache...OK Writing recovery...OK Writing cust...OK Writing BackupGPT...OK Finalizing...OK Writing firmware done! |
11-10-2015, 15:48 | #3329 (permalink) |
Member: 348877 Status: Offline Sonork: 1601289 Thanks Meter: 1,178 | LG E440 Firmware write done.. Welcome to Octoplus/Octopus Box LG Software version 2.0.8 -------------------------------------------------------------------------------- Checking data...OK Platform: LG MTK Selected port: COM88 Selected baudrate: 115200 Selected model: E440 Selected USB connection type Please, disconnect battery and connect cable...OK Phone found. CPU name: MT6575 CPU revision: 8A00.CB00.E201.0000 Setting power state...OK Prepairing loader...OK Sending loader...OK Synchronizing with loader... Loader version: 3.2.132 Detecting flash chip...OK Detecting EMMC flash chip...OK Reading info...OK Opening "BIN_LGE440AT-00-V10c-AME-XX-OCT-09-2013+0.oct"... Writing Firmware... Formating filesystem...OK Unlocking Bootloader...OK Writing FILE_INFO...OK Writing MBR...OK Checking partition...OK Writing EBR1...OK Writing EBR2...OK Writing EBR3...OK Writing UBOOT...OK Writing BOOTIMG...OK Writing RECOVERY...OK Writing SEC_RO...OK Writing LOGO...OK Writing PERSIST...OK Writing CUST...OK Writing ANDROID...OK Writing CACHE...OK Writing USRDATA...OK Checking partition...OK Writing __NODL...OK Finalizing...OK Writing firmware done! |
Post here successfully unlocked a2 phones | 3lsheikh | SETool2 | 10 | 03-04-2011 02:48 |
Successfully Unlock Z240 Phone Freeze | jhepoy_org | UST Pro II | 13 | 12-02-2009 06:03 |
Successfully unlock BB5 phones with bb5king | Mjabbar | BB5KING | 0 | 11-29-2008 14:13 |
Successfully unlock BB5 phones with bb5king | Mjabbar | BB5KING | 2 | 11-26-2008 11:54 |
PB2 - Successfully unlocked LG phones CU/KU ... | DOUHAL | PolarBox 3 | 72 | 11-05-2008 18:21 |
