Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Octopus/Octoplus > Octopus LG/Octoplus LG
Old 06-02-2010, 20:42   #361 (permalink)
69eyes's Avatar
Member: 942693
Sonork: 1592619
Thanks Meter: 2,201
KP570Q UNLOCK DONE!
The Following 2 Users Say Thank You to 69eyes For This Useful Post:
Old 06-02-2010, 20:44   #362 (permalink)
69eyes's Avatar
Member: 942693
Sonork: 1592619
Thanks Meter: 2,201
ANOTHER KP570Q UNLOCK DONE!
Old 06-03-2010, 14:57   #363 (permalink)
Member: 733209
Sonork: 1001620525
Thanks Meter: 426
CU575 UNLOCK DONE
The Following 2 Users Say Thank You to hung phong For This Useful Post:
Old 06-04-2010, 00:58   #364 (permalink)
69eyes's Avatar
Member: 942693
Sonork: 1592619
Thanks Meter: 2,201
Old 06-04-2010, 01:02   #365 (permalink)
69eyes's Avatar
Member: 942693
Sonork: 1592619
Thanks Meter: 2,201
KP151Q UNLOCK DONE!
The Following 4 Users Say Thank You to 69eyes For This Useful Post:
Old 06-04-2010, 01:09   #366 (permalink)
69eyes's Avatar
Member: 942693
Sonork: 1592619
Thanks Meter: 2,201
"YELLOW SCREEN & Unavailable Wallpaper file" Full Repair with Octopus Box Only with Direct Unlock!
The Following 3 Users Say Thank You to 69eyes For This Useful Post:
Old 06-05-2010, 13:41   #367 (permalink)
MR PROTEC's Avatar
Member: 86655
Thanks Meter: 385
kp107 unlock tested
Platform: LG Infineon
Selected port: COM34
Selected baudrate: 921600
Selected model: KP107
Please reconnect battery...
Phone found.
Sending preloader...OK
Sending loader...OK
Reading info. Please wait...
Flash ID: 01001A01
Flash type: AMD
IMEI: 358306-02-520021-x
Reading codes. Please wait...
Unlock code: 7998 1491
To finish the operation, please perform the following steps:
1. Insert the original SIM card and type 2945#*20001#
2.Go to menu>Settings>Security>SIMLOCK and enter the code.
The Following 3 Users Say Thank You to MR PROTEC For This Useful Post:
Old 06-06-2010, 14:22   #368 (permalink)
sirnavid2010's Avatar
Member: 777729
Sonork: 100.1616470
Thanks Meter: 803
kp 500 write arabic language ok!!!!
Log file "C:\Program Files\GsmServer\Octopus\LOG\06-06-2010_05-34-11.log" created.
2010/06/06 05:34:28 ?.? > Welcome to Octopus box software version 1.2.8
2010/06/06 05:35:31 ?.? > ----------------------------------------------------------------------------------
2010/06/06 05:35:31 ?.? > Platform: LG Infineon
2010/06/06 05:35:31 ?.? > Selected port: USB
2010/06/06 05:35:31 ?.? > Selected model: KP500
2010/06/06 05:35:31 ?.? > Disconnect battery and connect USB cable to phone...
2010/06/06 05:35:45 ?.? > Reading info. Please wait...
2010/06/06 05:35:45 ?.? > IMEI: 352317-04-126365-0
2010/06/06 05:35:55 ?.? > Opening "KP500AT-00-V10k-ARB-XXX-APR-24-2009+0.oct"...2010/06/06 05:35:55 ?.? > OK
2010/06/06 05:35:55 ?.? > Writing Firmware...
2010/06/06 05:58:00 ?.? > Writing Firmware done!
2010/06/06 05:58:00 ?.? > Disconnected.
The Following 4 Users Say Thank You to sirnavid2010 For This Useful Post:
Old 06-07-2010, 14:03   #369 (permalink)
trenac's Avatar
Member: 1246981
Sonork: 100.1590424
Thanks Meter: 238
GU230 unlocked by reading codes
THANKS TO OCTOPUS TEAM gu230 unlock ok by reading codes
The Following 3 Users Say Thank You to trenac For This Useful Post:
Old 06-08-2010, 00:35   #370 (permalink)
Little_Master's Avatar
Member: 1205146
Thanks Meter: 873
GD510 Unlock Ok in Seconds..
Welcome to Octopus box software version 1.3.3
Selected port: COM6
Selected model: GD510
Please reconnect battery, press and hold power button...Canceled!
Disconnected.
Selected port: USB
Phone not respond!
Reconnecting in safe mode...
Please reconnect USB cable
This mode only supports firmware writing.
Please use COM Cable for unlocking.
Disconnected.
Selected port: COM39
Phone found.
Release power button.
Sending loader...OK
IMEI: 359929-03-546664-5
Backup saved to
"GD510-359929035466645_08-06-2010_09-31-19.eep"
Unlock code: 7376 1971 8464 5591
MCC: 505 (Australia)
MNC: 03 (Vodafone)
1. Insert the original SIM card and type 2945#*510#
USE GW300 UART CABLE..
otherwise via Test Point
LITTLE MASTER
The Following 3 Users Say Thank You to Little_Master For This Useful Post:
Old 06-09-2010, 19:58   #371 (permalink)
GSM_STREET's Avatar
Member: 1149815
Sonork: N/A for now
Thanks Meter: 217
Selected port: COM10
Selected model: KP100
Disconnected.
Selected port: COM18
Phone found.
Sending loader...Failed!
Disconnected.
Phone found.
Sending loader...OK
Flash ID: 01001A01
Flash type: AMD
IMEI: 358479-02-155937-6
Selecting output file...
Reading EEPROM into file "KP100-358479021559376.EEP"...
Reading EEPROM done!
Unlock code: 6271 1265
The Following 3 Users Say Thank You to GSM_STREET For This Useful Post:
Old 06-10-2010, 09:09   #372 (permalink)
Member: 777729
Sonork: 100.1616470
Thanks Meter: 803
AGAIN KP500 FLASH OK ONLY WITH OCTOPUS BOX.
Selected port: USB
IMEI: 359858-03-746194-2
Opening "KP500AT-00-V10k-ARB-XXX-APR-24-2009+0.oct"...OK
Writing Firmware...
Disconnected.
The Following 3 Users Say Thank You to sirnavid2010 For This Useful Post:
Old 06-10-2010, 18:17   #373 (permalink)
jam_mobile's Avatar
Member: 649578
Sonork: 100.1592568
Thanks Meter: 70
cu720 imei change tested
Platform: LG Qualcomm
Selected port: COM58
Selected model: CU720
Mode: Normal
Phone model: CU720
SW Version: CU720-MSM4090201C-V10l-MAR-26-2008-ATT-US
IMEI: 011783-00-196230-5
Bluetooth adress: 00:21:FB:F5:A6:A2
Fixing IMEI...
New IMEI: 358748-03-834315-0
Prepairing loader...OK
Sending loader...OK
Reading security area...
Backup saved to "CU720-011783001962305_10-06-2010_21-38-
14.sec"
Erasing security area...OK
Writing security area...OK
IMEI successfully fixed!
Rebooting phone...
The Following 4 Users Say Thank You to jam_mobile For This Useful Post:
Old 06-10-2010, 20:22   #374 (permalink)
Member: 1160440
Sonork: 100.1583857
Thanks Meter: 15
kh1200 unlocked
The Following 4 Users Say Thank You to umtraders For This Useful Post:
Old 06-11-2010, 03:56   #375 (permalink)
Member: 1104730
Thanks Meter: 439
kh1200 unsupported/flash/unlock done
Welcome to Octopus box software version 1.3.5
Selected port: COM2
Selected model: KH1200
Mode: Normal
Phone model: KW120612
SW Version: KH1200-M6250D-V10i-AUG-22-2007-KKR
IMEI: 354207-01-635532-6
Bluetooth adress: 00:1C:62:A6:68:96
Firmware compiled date: Aug 14 2006
Firmware compiled time: 11:00:00
Firmware released date: Aug 22 2007
Firmware released time: 12:47:56
User lock code: 7885
Selected port: COM2
Mode: Normal
Unsupported firmware version!
Please, contact to support.
Selected port: COM2
Mode: Normal
Before writing firmware, please fully charge phone battery.
Opening "KW120615_00.oct"...OK
Reading NVM...
Reading NVM done!
Backup saved to "KH1200-354207016355326_11-06-2010_10-36-
13.nvm"
Switching to Download mode...OK
Erasing EFS...OK
Writing Firmware...OK
Phone startup...OK
Writing NVM...
Writing NVM done!
Rebooting phone...
Selected port: COM2
Mode: Normal
Phone model: KW120615
SW Version: KH1200-M6250D-V10l-APR-07-2009-KKR
Firmware released date: Apr 28 2009
Firmware released time: 19:34:16
Selected port: COM2
Mode: Normal
Sending loader...OK
Switching to test mode...
Wait phone startup...OK
Searching signatures...
Signature #1...OK, not patched
Patching...
Signature #1...OK
Phone successfully unlocked!
Rebooting phone...
The Following 4 Users Say Thank You to Babyunlocker For This Useful Post:
Post here successfully unlocked a2 phones 3lsheikh SETool2 10 03-04-2011 01:48
Successfully Unlock Z240 Phone Freeze jhepoy_org UST Pro II 13 12-02-2009 05:03
Successfully unlock BB5 phones with bb5king Mjabbar BB5KING 0 11-29-2008 13:13
Successfully unlock BB5 phones with bb5king Mjabbar BB5KING 2 11-26-2008 10:54
PB2 - Successfully unlocked LG phones CU/KU ... DOUHAL PolarBox 3 72 11-05-2008 17:21
Page generated in 0.45126 seconds with 9 queries
