08-10-2018, 20:55 | #5506 (permalink) |
No Life Poster Join Date: Mar 2011 Location: dominican republic Age: 45
Member: 1537078 Status: Offline Sonork: celular center Thanks Meter: 573 | MS210 successfully unlocked -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM22 Selected model: MS210 Please, put the phone into download mode manually (Power phone OFF (reconnect battery), press and hold "Vol+" button and connect the cable (or P999 cable)). Reading info... Model ID: LGMS210 IMEI: 000000-00-000000-0 Android version: 7.0 Battery level: 77% SW Version: MS21010f Mode: Emergency Initializing flash...OK SW version: LGMS210AT-02-V10g-310-160-JAN-14-2017-ARB00+3 Android version: 7.0 LAF Version: 1.1 Product ID: CD23S170104003570 IMEI: 353662-08-XXXXXX-1 Target operator: MPCS Hardware: rev_10 Reset FRP operation for MS210 will delete all user data on the phone (contacts, pictures and others)! Do You want to continue? Reading partitions...OK Detecting writing method...OK Resetting FRP Lock... Writing loader... Step 1... Step 2... Step 3... Step 4... Step 5... Step 6... Step 7... Step 8... Step 9... Step 10...OK Writing userdata...OK Formating encrypt...OK Restoring loader...OK Resetting FRP lock successfully completed! Rebooting phone... To complete the operation, please make Factory Reset (Go to "Settings" -> "General" -> "Backup & reset" -> "Factory data reset", press "Reset phone" and "Erase everything" buttons). Performed by 2.8.8 Software version. Last edited by Octopus box; 08-11-2018 at 08:51. |
The Following User Says Thank You to chipscell25 For This Useful Post: |
08-12-2018, 04:59 | #5507 (permalink) |
Freak Poster Join Date: Mar 2015 Location: Bangladesh Age: 32
Member: 2364514 Status: Offline Thanks Meter: 390 | LG-X240K FRP Remove successfully done by Octoplus Checking data...OK Platform: LG MTK Selected port: COM12 Selected baudrate: 0 Selected model: X240K Selected USB connection type Press and hold "Vol-" and connect cable.OK Phone found. CPU name: MT6737M CPU revision: 8A00.CB00.0000.0000 Prepairing loader...OK Sending loader...OK Synchronizing with loader... Detecting flash chip...OK Detecting EMMC flash chip...OK Reading info...OK Reconnecting phone...OK Found model at port COM63 Reading partitions...OK Checking security... Checking security passed! -------------------------------------------------------------------------------- IMEI A: 353745-**************** IMEI B: 353745-**************** Bluetooth address: B8:1D:AA:97:79:BE Wi-Fi MAC address: B8:1D:AA:FB:C0:8E EMMC rpmb size: 4 Mb EMMC boot1 size: 4 Mb EMMC boot2 size: 4 Mb EMMC gp1 size: 0 Mb EMMC gp2 size: 0 Mb EMMC gp3 size: 0 Mb EMMC gp4 size: 0 Mb EMMC user area size: 14910 Mb -------------------------------------------------------------------------------- Reading partitions...OK Resetting FRP Lock...OK Resetting FRP lock successfully completed! Performed by 2.8.0 Software version. Last edited by Octopus box; 08-12-2018 at 12:46. |
The Following User Says Thank You to pranobcox For This Useful Post: |
08-12-2018, 14:34 | #5508 (permalink) |
No Life Poster Join Date: Jan 2015 Location: Narsingdi, Dhaka, Bangladesh Age: 28
Member: 2325851 Status: Offline Sonork: 100.1680491 Thanks Meter: 2,363 | LG G3 D850 download mode is disabled by kill switch remove done LG G3 D850 download mode is disabled by kill switch remove done Welcome to Octoplus/Octopus Box LG Software version 2.8.2.1 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM1 Selected model: D850 To perform Kill Switch operation do the next: 1. Attach testpoint as shown on Figure in manual, and connect phone with Micro USB cable. 2. Check PC Device Manager, a new device should appear "Qualcomm HS-USB QDLoader 9008". 3. Release testpoint.OK Sending loader...OK Connecting to server ...OK Initializing device...OK Deactivating Kill Switch...OK Please, reconnect the battery, put the phone in download mode manually and re-flash the phone. Performed by 2.8.2.1 Software version. Thanks octopus team |
The Following User Says Thank You to pintu_das For This Useful Post: |
08-13-2018, 05:06 | #5509 (permalink) |
Member: 2325851 Status: Offline Sonork: 100.1680491 Thanks Meter: 2,363 | LG G3 D850 Writing firmware done! LG G3 D850 Writing firmware done! Welcome to Octoplus/Octopus Box LG Software version 2.8.2.1 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM197 Selected model: D850 Reading info... Model ID: LG-D850 IMEI: 014065-00-218111-0 Android version: 5.0.1 Battery level: 47% SW Version: D85021r Mode: Emergency Initializing flash...OK SW version: LGD850AT-00-V21r-ATT-US-AUG-17-2015+0 Android version: 5.0.1 LAF Version: 1.1 Product ID: BS03S140813002951 IMEI: 000000-00-000000-0 Target operator: ATT Hardware: rev_10 -------------------------------------------------------------------------------- Writing phone firmware without real necessity is at your own risk. Downgrade may lead to phone damage! Please, make sure the phone's battery is fully charged. Disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Qualcomm-based devices). You should not run any other programs or attach new devices to your computer during the flashing! -------------------------------------------------------------------------------- Opening "LGD850AT-01-V21l-310-410-APR-06-2015+0.oct"...OK Setting options...OK Reading partitions...OK Formating USERDATA...OK Formating ENCRYPT...OK Writing PrimaryGPT...OK Writing modem...OK Writing sbl1...OK Writing dbi...OK Writing aboot...OK Writing rpm...OK Writing tz...OK Writing boot...OK Writing persist...OK Writing recovery...OK Writing laf...OK Writing factory...OK Writing system...OK Writing cache...OK Writing userdata...OK Writing BackupGPT...OK Reading partitions...OK Formating RCT...OK Formating MPT...OK Finalizing...OK Writing firmware done! Performed by 2.8.2.1 Software version. Thanks octopus team |
08-13-2018, 07:31 | #5510 (permalink) |
No Life Poster Join Date: Dec 2009 Location: INDIA Age: 36
Member: 1195083 Status: Offline Sonork: QQ:3208821449 Thanks Meter: 1,348 | LG C395 Unlock Successfully Done LG C395 Unlock Done Checking data...OK Platform: LG Qualcomm Selected port: COM43 Selected model: C395 Reading info...OK Mode: Normal Model ID: LGC395 Firmware compiled date: APR 05 2013 Firmware compiled time: 22:00:00 Firmware released date: Apr 5 2013 Firmware released time: 03:49:46 SW Version: LGC395-QSC6270-V10i-APR-05-2013-ATT-US IMEI: 013502-00-850524-0 Bluetooth address: BC:F5:AC:65:FA:55 Switching to Download mode...OK Unlocking... Sending loader...OK Initializing flash...OK Reading security area...OK Backup saved to "C395_013502008505240_13-08-2018_11-58-29.SEC" Analyzing security...OK IMEI: 013502-00-850524-0 Bluetooth address: BC:F5:AC:65:FA:55 Writing security area...OK Phone successfully unlocked! Please, reboot the phone manually. Performed by 2.8.8 Software version. Last edited by Octopus box; 08-13-2018 at 07:50. |
The Following 4 Users Say Thank You to mr.luckytarun For This Useful Post: |
08-13-2018, 11:44 | #5511 (permalink) |
No Life Poster Join Date: Mar 2008 Location: RMS- CLUB
Member: 723410 Status: Offline Sonork: 📱 100.1592732 Thanks Meter: 3,374 | LG P990 "hang on logo" repair done Lg P990 hang on logo done Lg P990 Flashing done Code: Welcome to Octoplus/Octopus Box LG Software version 2.8.7 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Infineon Connection mode: Tegra Selected model: P990 Opening "LGP990AT-01-V20s-218-90-MAY-21-2012+0_AP.oct"... Please, connect powered OFF phone with P999 (with 910k resistor) cable and press power button...OK Initializing device...OK Writing Firmware... Writing Service data...OK Writing Partition...OK Writing Fastboot...OK Writing System...OK Writing Recovery...OK Writing Boot...OK Writing FAT32...OK Connecting to modem CPU...OK Sending preloader...OK Sending loader...OK Initializing flash...OK Writing psi.fls...OK Writing slb.fls...OK Writing AENEAS_FW.fls...OK Writing R375_SIC.fls...OK Rebooting phone... Disconnected. Performed by 2.8.7 Software version. Last edited by Octopus box; 08-13-2018 at 11:53. |
The Following 4 Users Say Thank You to haji rahim For This Useful Post: |
08-13-2018, 14:08 | #5512 (permalink) |
No Life Poster Join Date: May 2009 Location: USA/NY
Member: 1025079 Status: Offline Thanks Meter: 311 | LG H931 8.0 FRP Removed Successfully Welcome to Octoplus FRP Tool v.1.3.7.1 Platform: LG Selected model: H931 Opening "LG_H931_03-08-2018_12-11-28.dump"... Restore device from backup file? Put the phone into Download Mode: 1. Power phone OFF; 2. Press and hold "Vol+" button and connect USB cable. Searching for a phone. Please wait... Connecting... Reading info... QC HW ID: 0005E0E100310000 QC CPU: Snapdragon 835 MSM8998 Searching loader... Sending loaders... Loader send successfuly. Reconnecting... Checking request.. Checking request.. Reading partition... Reading info... Brand: lge Model: LG-H931 Device: joan Platform: msm8998 Android version: 8.0.0 Display ID: OPR1.170623.026 Restoring BOOT... Rebooting phone Backup saved as LG_H931_13-08-2018_09-03-02.dump file FRP lock is successfully reseted! Performed by 1.3.7.1 Software version. Last edited by Octopus box; 08-13-2018 at 14:34. |
The Following 2 Users Say Thank You to cwcast For This Useful Post: |
08-13-2018, 15:15 | #5513 (permalink) |
Member: 1537078 Status: Offline Sonork: celular center Thanks Meter: 573 | M150 Unlock successfully done Welcome to Octoplus/Octopus Box LG Software version 2.8.8 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM159 Selected model: M150 Please, put the phone into download mode manually (Power phone OFF (reconnect battery), press and hold "Vol+" button and connect the cable (or P999 cable)). Reading info... Model ID: LG-M150 IMEI: 354063-08-807294-7 Android version: 7.0 Battery level: 36% SW Version: M15020d Mode: Emergency Initializing flash...OK SW version: LGM150AT-00-V20d-ATT-US-MAY-02-2017-ARB00+0 Android version: 7.0 LAF Version: 1.1 Product ID: CB41S170726005723 IMEI: 354063-08-807294-7 Target operator: ATT Hardware: rev_10 Reset FRP operation for M150 will delete all user data on the phone (contacts, pictures and others)! Do You want to continue? Reading partitions...OK Detecting writing method...OK Resetting FRP Lock... Writing loader... Step 1... Step 2... Step 3... Step 4... Step 5... Step 6... Step 7... Step 8... Step 9... Step 10...OK Writing userdata...OK Formating encrypt...OK Restoring loader...OK Resetting FRP lock successfully completed! Rebooting phone... To complete the operation, please make Factory Reset (Go to "Settings" -> "General" -> "Backup & reset" -> "Factory data reset", press "Reset phone" and "Erase everything" buttons). Performed by 2.8.8 Software version. Last edited by Octopus box; 08-13-2018 at 15:49. |
The Following 2 Users Say Thank You to chipscell25 For This Useful Post: |
08-13-2018, 15:35 | #5514 (permalink) |
Banned Join Date: Jan 2017 Location: Algeria DZ
Member: 2669781 Status: Offline Thanks Meter: 1,839 | LG-M150 ATT carrier unlock done Log of the operation/ Code: ------------------------------------------------------------------------------ Checking data...OK Platform: LG Qualcomm Selected port: COM53 Selected model: M150 Reading info... Model ID: LG-M150 IMEI: 353712-09-806450-7 Android version: 7.0 Battery level: 52% SW Version: M15020f Mode: Normal Firmware compiled date: Jul 06 2017 Firmware compiled time: 04:00:00 Firmware released date: Oct 4 2017 Firmware released time: 12:07:52 SW Version: MPSS.JO.2.0.c1.2-00020-8909_GEN_PACK-1.92496.1.104247.1 IMEI: 353712-09-806450-7 Bluetooth address: B4:F7:A1:2E:BB:45 Wi-Fi MAC address: B4:F7:A1:DA:04:FA SPC: 000000 Unlocking... Skip Read/Write QCN Switching to Download mode...OK Initializing flash...OK Reading partitions...OK Detecting writing method... LAF Error: 80000121. Trying second method...OK Reading security area...OK Backup saved to "M150_353712098064507_13-08-2018_15-30-41.SEC" Writing security area...OK Switching to Normal mode... Found model LGM150AT* ÿh `n at port COM53 Phone successfully unlocked! Rebooting phone... Performed by 2.8.8 Software version. Last edited by Octopus box; 08-13-2018 at 15:50. |
The Following User Says Thank You to lyes_albert For This Useful Post: |
08-13-2018, 20:34 | #5515 (permalink) |
Member: 1537078 Status: Offline Sonork: celular center Thanks Meter: 573 | LS676 Write Firmware Done Welcome to Octoplus/Octopus Box LG Software version 2.8.8 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM164 Selected model: LS676 Reading info... IMEI: 359842-08-825426-5 Android version: Battery level: 66% SW Version: LS676ZV7 Mode: Emergency Initializing flash...OK SW version: LS676ZV7_09 Android version: 6.0.1 LAF Version: 1.1 Product ID: IMEI: 359842-08-825426-5 Target operator: SPR Hardware: rev_11 Unlock operation is currently not supported for your phone's firmware. Canceled! Performed by 2.8.8 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM164 Selected model: LS676 Reading info... IMEI: 359842-08-825426-5 Android version: Battery level: 66% SW Version: LS676ZV7 Mode: Emergency Initializing flash...OK SW version: LS676ZV7_09 Android version: 6.0.1 LAF Version: 1.1 Product ID: IMEI: 359842-08-825426-5 Target operator: SPR Hardware: rev_11 Opening "LS676ZV6_02.tot"...OK Firmware version: LS676ZV6 Firmware model: LS676 -------------------------------------------------------------------------------- Writing phone firmware without real necessity is at your own risk. Downgrade may lead to phone damage! Please, make sure the phone's battery is fully charged. Disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Qualcomm-based devices). You should not run any other programs or attach new devices to your computer during the flashing! -------------------------------------------------------------------------------- Prepairing firmware...OK Setting options...OK Reading partitions...OK Formating USERDATA...OK Formating ENCRYPT...OK Writing 1/3 PrimaryGPT...OK Writing 2/3 modem...OK Writing 3/3 carrier...OK Reading partitions...OK Formating RCT...OK Formating MPT...OK Finalizing...OK Writing firmware done! Performed by 2.8.8 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM20 Selected model: D415 Reading info... Mode: Emergency Initializing flash...OK SW version: LGD415AT-00-V10e-TMO-US-OCT-29-2014+0 Android version: 4.4.2 LAF Version: 1.0 Product ID: CH32S140401002539 IMEI: 014009-00-066805-8 Target operator: TMO Hardware: rev_10 -------------------------------------------------------------------------------- Writing phone firmware without real necessity is at your own risk. Downgrade may lead to phone damage! Please, make sure the phone's battery is fully charged. Disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Qualcomm-based devices). You should not run any other programs or attach new devices to your computer during the flashing! -------------------------------------------------------------------------------- Opening "D415-00-V10c.oct"...OK Setting options...OK Reading partitions...OK Formating USERDATA...OK Formating ENCRYPT...OK Writing PrimaryGPT...OK Writing modem...OK Writing sbl1...OK Writing rpm...OK Writing tz...OK Writing sdi...OK Writing aboot...OK Writing rpmb...OK Writing tzb...OK Writing abootb...OK Writing persist...OK Writing laf...OK Writing boot...OK Writing recovery...OK Writing factory...OK Writing sbl1b...OK Writing system...OK Writing BackupGPT...OK Reading partitions...OK Formating RCT...OK Formating MPT...OK Finalizing...OK Writing firmware done! Performed by 2.8.8 Software version. Last edited by Octopus box; 08-14-2018 at 05:05. |
08-13-2018, 21:05 | #5516 (permalink) |
Member: 1537078 Status: Offline Sonork: celular center Thanks Meter: 573 | Another one LS676 Write Firmware Done Welcome to Octoplus/Octopus Box LG Software version 2.8.8 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM680 Selected model: LS676 Reading info... IMEI: 358784-07-081109-3 Android version: 6.0.1 Battery level: 3% SW Version: LS676ZV8 Mode: Emergency Initializing flash...OK SW version: LS676ZVA_01 Android version: 6.0.1 LAF Version: 1.1 Product ID: CH31S160912002227 IMEI: 358784-07-081109-3 Target operator: SPR Hardware: rev_11 Unlock operation is currently not supported for your phone's firmware. Canceled! Performed by 2.8.8 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM680 Selected model: LS676 Reading info... IMEI: 358784-07-081109-3 Android version: 6.0.1 Battery level: 3% SW Version: LS676ZV8 Mode: Emergency Initializing flash...OK SW version: LS676ZVA_01 Android version: 6.0.1 LAF Version: 1.1 Product ID: CH31S160912002227 IMEI: 358784-07-081109-3 Target operator: SPR Hardware: rev_11 Opening "LS676ZV6_02.tot"...OK Firmware version: LS676ZV6 Firmware model: LS676 -------------------------------------------------------------------------------- Writing phone firmware without real necessity is at your own risk. Downgrade may lead to phone damage! Please, make sure the phone's battery is fully charged. Disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Qualcomm-based devices). You should not run any other programs or attach new devices to your computer during the flashing! -------------------------------------------------------------------------------- Prepairing firmware...OK Setting options...OK Reading partitions...OK Formating USERDATA...OK Formating ENCRYPT...OK Writing 1/3 PrimaryGPT...OK Writing 2/3 modem...OK Writing 3/3 carrier...OK Reading partitions...OK Formating RCT...OK Formating MPT...OK Finalizing...OK Writing firmware done! Performed by 2.8.8 Software version. Last edited by Octopus box; 08-14-2018 at 05:06. |
08-14-2018, 15:20 | #5517 (permalink) |
No Life Poster Join Date: Nov 2010 Location: RSA-2048 Age: 38
Member: 1444462 Status: Offline Thanks Meter: 1,337 | LG G3 S D722 Repair IMEI successfully done Welcome to Octoplus/Octopus Box LG Software version 2.8.5 -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM177 Selected model: D722 Reading info... Model ID: LG-D722 IMEI: 355403-06-754169-5 Android version: 4.4.2 Battery level: 90% SW Version: D72210c Mode: Normal Firmware compiled date: Jun 19 2014 Firmware compiled time: 10:00:00 Firmware released date: Feb 6 2015 Firmware released time: 11:16:56 SW Version: MPSS.DI.2.0.1.c1.15-00013-M8926DAAAANAZM-1 IMEI: 355403-06-754169-5 SPC: 000000 Performed by 2.8.5 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM177 Selected model: D722 Reading info... Model ID: LG-D722 IMEI: 355403-06-754169-5 Android version: 4.4.2 Battery level: 90% SW Version: D72210c Mode: Normal Firmware compiled date: Jun 19 2014 Firmware compiled time: 10:00:00 Firmware released date: Feb 6 2015 Firmware released time: 11:16:56 SW Version: MPSS.DI.2.0.1.c1.15-00013-M8926DAAAANAZM-1 IMEI: 355403-06-754169-5 SPC: 000000 Fixing IMEI... New IMEI: 355656-56-678800-6 Reading QCN... Send SPC...OK Reading Mobile Property...OK Reading Feature Mask...OK Reading Roaming List 0...OK Reading NV_Numbered Items...OK Reading NV_Numbered SIM1 Items...OK Reading NV_Numbered SIM2 Items...OK Reading NV Items...OK Reading EFS...OK Reading Provisioning Items...OK Reading QCN done! Backup saved to "D722_355403067541695_14-08-2018_12-58-07.qcn" Do you want to create security backup? Switching to Download mode...OK Initializing flash...OK Reading partitions...OK Detecting writing method...OK Reading security area...OK Backup saved to "D722_355403067541695_14-08-2018_13-09-15.SEC" Switching to Normal mode... Found model DAAAANAZ: ÿj¾ at port COM177 Writing security area...OK Rebooting phone... Found model DAAAANAZ: ÿj¾ at port COM177 IMEI successfully fixed! To complete the operation, please make Factory Reset (Go to "Settings" -> "General" -> "Backup & reset" -> "Factory data reset", press "Reset phone" and "Erase everything" buttons). Performed by 2.8.5 Software version. Last edited by Octopus box; 08-14-2018 at 15:48. |
The Following User Says Thank You to ..::GMSR::.. For This Useful Post: |
08-14-2018, 15:27 | #5518 (permalink) |
Member: 1537078 Status: Offline Sonork: celular center Thanks Meter: 573 | K373 Reset FRP successfully done Welcome to Octoplus/Octopus Box LG Software version 2.8.8 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM171 Selected model: K373 Please, put the phone into download mode manually (Power phone OFF (reconnect battery), press and hold "Vol+" button and connect the cable (or P999 cable)). Reading info... Model ID: LG-K373 IMEI: 354887-07-048068-8 Android version: 6.0 Battery level: 25% SW Version: K37310c Mode: Emergency Initializing flash...OK SW version: LGK373AT-00-V10c-CRK-US-JUL-15-2016-ARB01+0 Android version: 6.0 LAF Version: 1.1 Product ID: CY21S160506001313 IMEI: 354887-07-465434-6 Target operator: CRK Hardware: rev_10 Reading partitions...OK Detecting writing method...OK Resetting FRP Lock... Resetting FRP lock successfully completed! Performed by 2.8.8 Software version. Last edited by Octopus box; 08-14-2018 at 15:49. |
08-14-2018, 19:16 | #5519 (permalink) | |
No Life Poster Join Date: Mar 2011 Location: Tadjikistan, Dushanbe Age: 35
Member: 1533366 Status: Offline Thanks Meter: 131 | LG D690 Reset Screen Lock Successfully Done LG D690 Reset Screen Lock Quote:
The Following User Says Thank You to islamic.tj For This Useful Post: |
08-16-2018, 09:13 | #5520 (permalink) |
No Life Poster Join Date: Apr 2011 Location: algerie Age: 54
Member: 1562854 Status: Offline Sonork: 1245 Thanks Meter: 259 | MS550 Reset FRP successfully done Code: Welcome to Octoplus/Octopus Box LG Software version 2.8.8 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM11 Selected model: MS550 Please, put the phone into download mode manually (Power phone OFF (reconnect battery), press and hold "Vol+" button and connect the cable (or P999 cable)). Reading info... Model ID: LGMS550 IMEI: 000000-00-000000-0 Android version: 6.0.1 Battery level: 28% SW Version: MS55010i Mode: Emergency Initializing flash...OK SW version: LGMS550AT-02-V10i-310-160-AUG-25-2016-ARB00+0 Android version: 6.0.1 LAF Version: 1.1 Product ID: VS01S161028001762 IMEI: 358858-07-000000-3 Target operator: MPCS Hardware: rev_10 Reading partitions...OK Detecting writing method...OK Resetting FRP Lock... Resetting FRP lock successfully completed! Performed by 2.8.8 Software version. Last edited by Octopus box; 08-16-2018 at 09:32. |
The Following User Says Thank You to rai14 For This Useful Post: |
Post here successfully unlocked a2 phones | 3lsheikh | SETool2 | 10 | 03-04-2011 02:48 |
Successfully Unlock Z240 Phone Freeze | jhepoy_org | UST Pro II | 13 | 12-02-2009 06:03 |
Successfully unlock BB5 phones with bb5king | Mjabbar | BB5KING | 0 | 11-29-2008 14:13 |
Successfully unlock BB5 phones with bb5king | Mjabbar | BB5KING | 2 | 11-26-2008 11:54 |
PB2 - Successfully unlocked LG phones CU/KU ... | DOUHAL | PolarBox 3 | 72 | 11-05-2008 18:21 |
