11-10-2018, 11:42 | #5731 (permalink) |
No Life Poster Join Date: Feb 2008 Location: Bosnia
Member: 698071 Status: Offline Sonork: 100.1622915 Thanks Meter: 283 | LG-M700N downgrade Android 8.x to 7.x and Reset FRP successfully done Welcome to Octoplus/Octopus Box LG Software version 2.8.9.8 -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM20 Selected model: M700N Reading info... Model ID: LG-M700n IMEI: 358729-XXXXXXXX Android version: 8.1.0 Battery level: 49% SW Version: M70020e Mode: Emergency Initializing flash...OK Platform: msm8937 SW version: LGM700nAT-00-V20e-EUR-XX-OCT-01-2018-32G+0 Android version: 8.1.0 LAF Version: 1.1 Product ID: CY19S171111008446 IMEI: 358729-XXXXXXXXX Target operator: GLOBAL Hardware: rev_10 Performed by 2.8.9.8 Software version. Please select Reset FRP Method! -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM20 Selected model: M700N Please, put the phone into download mode manually (Power phone OFF (reconnect battery), press and hold "Vol+" button and connect the cable (or P999 cable)). Reading info... Model ID: LG-M700n IMEI: 358729-XXXXXXXXXX Android version: 8.1.0 Battery level: 51% SW Version: M70020e Mode: Emergency Initializing flash...OK Platform: msm8937 SW version: LGM700nAT-00-V20e-EUR-XX-OCT-01-2018-32G+0 Android version: 8.1.0 LAF Version: 1.1 Product ID: CY19S171111008446 IMEI: 358729-0XXXXXXXX Target operator: GLOBAL Hardware: rev_10 Reset FRP operation for M700N will delete all user data on the phone (contacts, pictures and others)! Do You want to continue? Reading partitions...OK Detecting writing method... Trying third method...Failed! Resetting FRP Lock... Performed by 2.8.9.8 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM20 Selected model: M700N Reading info... Model ID: LG-M700n IMEI: 358729-0XXXXXXXX Android version: 8.1.0 Battery level: 55% SW Version: M70020e Mode: Emergency Initializing flash...OK Platform: msm8937 SW version: LGM700nAT-00-V20e-EUR-XX-OCT-01-2018-32G+0 Android version: 8.1.0 LAF Version: 1.1 Product ID: CY19S171111008446 IMEI: 358729-XXXXXXXXXXX Target operator: GLOBAL Hardware: rev_10 Opening "M700n11d_00_OPEN_EU_OP_0406.kdz"...OK Firmware version: LGM700AT-00-V12m-GLOBAL-COM-APR-06-2018+0 Firmware model: LG-M700 Firmware type: 0100 -------------------------------------------------------------------------------- Writing phone firmware without real necessity is at your own risk. Downgrade may lead to phone damage! Please, make sure the phone's battery is fully charged. Disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Qualcomm-based devices). You should not run any other programs or attach new devices to your computer during the flashing! -------------------------------------------------------------------------------- Prepairing firmware...OK Setting options...OK Reading partitions...OK Formating USERDATA...OK Formating ENCRYPT...OK Sending signature...OK Writing 1/85 PrimaryGPT_0.bin...OK Writing 2/85 modem_16384.bin...OK Writing 3/85 aboot_196608.bin...OK Writing 4/85 abootbak_200704.bin...OK Writing 5/85 tz_204800.bin...OK Writing 6/85 tzbak_208896.bin...OK Writing 7/85 sbl1_212992.bin...OK Writing 8/85 sbl1bak_215040.bin...OK Writing 9/85 rpm_217088.bin...OK Writing 10/85 rpmbak_218112.bin...OK Writing 11/85 devcfg_219136.bin...OK Writing 12/85 devcfgbak_220160.bin...OK Writing 13/85 cmnlib_221184.bin...OK Writing 14/85 cmnlibbak_222208.bin...OK Writing 15/85 cmnlib64_223232.bin...OK Writing 16/85 cmnlib64bak_224256.bin...OK Writing 17/85 keymaster_225280.bin...OK Writing 18/85 keymasterbak_226304.bin...OK Writing 19/85 dsp_278528.bin...OK Writing 20/85 sec_397312.bin...OK Writing 22/85 apdp_402432.bin...OK Writing 23/85 msadp_403456.bin...OK Writing 24/85 boot_409600.bin...OK Writing 25/85 laf_475136.bin...OK Writing 26/85 lafbak_540672.bin...OK Writing 27/85 recovery_606208.bin...OK Writing 28/85 recoverybak_671744.bin...OK Writing 29/85 factory_737280.bin...OK Writing 30/85 raw_resources_851968.bin...OK Writing 31/85 raw_resourcesbak_860160.bin...OK Writing 32/85 persist_868352.bin...OK Writing 33/85 system_1015808.bin...OK Writing 34/85 system_1280520.bin...OK Writing 35/85 system_1284576.bin...OK Writing 36/85 system_1544152.bin...OK Writing 37/85 system_1804808.bin...OK Writing 38/85 system_1808864.bin...OK Writing 39/85 system_2068440.bin...OK Writing 40/85 system_2329096.bin...OK Writing 41/85 system_2333152.bin...OK Writing 42/85 system_2592728.bin...OK Writing 43/85 system_2853384.bin...OK Writing 44/85 system_2857440.bin...OK Writing 45/85 system_3117016.bin...OK Writing 46/85 system_3377672.bin...OK Writing 47/85 system_3381728.bin...OK Writing 48/85 system_3641304.bin...OK Writing 49/85 system_3899392.bin...OK Writing 50/85 system_3903448.bin...OK Writing 51/85 system_4165592.bin...OK Writing 52/85 system_4423680.bin...OK Writing 53/85 system_4427736.bin...OK Writing 54/85 system_4685824.bin...OK Writing 55/85 system_4689880.bin...OK Writing 56/85 system_4952024.bin...OK Writing 57/85 system_5214168.bin...OK Writing 58/85 system_5476312.bin...OK Writing 59/85 system_5738456.bin...OK Writing 60/85 system_6000600.bin...OK Writing 61/85 system_6262744.bin...OK Writing 62/85 system_6524888.bin...OK Writing 63/85 system_6787032.bin...OK Writing 64/85 system_7049176.bin...OK Writing 65/85 system_7311320.bin...OK Writing 66/85 system_7571976.bin...OK Writing 67/85 system_7576032.bin...OK Writing 68/85 system_7835608.bin...OK Writing 69/85 system_8096264.bin...OK Writing 70/85 system_8100320.bin...OK Writing 71/85 system_8359896.bin...OK Writing 72/85 system_8622040.bin...OK Writing 73/85 system_8884184.bin...OK Writing 74/85 system_9146328.bin...OK Writing 75/85 system_9408472.bin...OK Writing 76/85 system_9670616.bin...OK Writing 77/85 system_9932760.bin...OK Writing 78/85 system_10194904.bin...OK Writing 79/85 system_10452992.bin...OK Writing 80/85 system_10715136.bin...OK Writing 81/85 system_10977280.bin...OK Writing 82/85 system_11239424.bin...OK Writing 83/85 system_11242496.bin...OK Writing 84/85 BackupGPT_29359104.bin...OK Writing 85/85 0_OP_OPEN_EU.img...OK Reading partitions...OK Formating RCT...OK Formating MPT...OK Finalizing...OK Writing firmware done! Performed by 2.8.9.8 Software version. -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM20 Selected model: M700N Reading info... Model ID: LG-M700n IMEI: 358729-0XXXXXXXXX Android version: 7.1.1 Battery level: 59% SW Version: M70011d Mode: Emergency Initializing flash...OK Platform: msm8937 SW version: LGM700nAT-00-V11d-EUR-XX-APR-06-2018-32G+0 Android version: 7.1.1 LAF Version: 1.1 Product ID: CY19S171111008446 IMEI: 358729-0XXXXXXXXXXX Target operator: GLOBAL Hardware: rev_10 Performed by 2.8.9.8 Software version. Please select Reset FRP Method! -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM20 Selected model: M700N Please, put the phone into download mode manually (Power phone OFF (reconnect battery), press and hold "Vol+" button and connect the cable (or P999 cable)). Reading info... Model ID: LG-M700n IMEI: 358729-XXXXXXXXXXX Android version: 7.1.1 Battery level: 59% SW Version: M70011d Mode: Emergency Initializing flash...OK Platform: msm8937 SW version: LGM700nAT-00-V11d-EUR-XX-APR-06-2018-32G+0 Android version: 7.1.1 LAF Version: 1.1 Product ID: CY19S171111008446 IMEI: 358729-XXXXXXXXXX Target operator: GLOBAL Hardware: rev_10 Reset FRP operation for M700N will delete all user data on the phone (contacts, pictures and others)! Do You want to continue? Reading partitions...OK Detecting writing method... Trying third method...OK Resetting FRP Lock... Writing loader... Step 1... Step 2... Step 3... Step 6... Step 7... Step 8... Step 9... Step 10...OK Writing userdata...OK Formating encrypt...OK Restoring loader...OK Resetting FRP lock successfully completed! Rebooting phone... To complete the operation, please make Factory Reset (Go to "Settings" -> "General" -> "Backup & reset" -> "Factory data reset", press "Reset phone" and "Erase everything" buttons). Performed by 2.8.9.8 Software version. Last edited by Octopus box; 11-10-2018 at 19:00. |
The Following User Says Thank You to sajohaker For This Useful Post: |
11-10-2018, 12:03 | #5732 (permalink) |
Member: 698071 Status: Offline Sonork: 100.1622915 Thanks Meter: 283 | lg-m700n after downgrade to 7.x for frp back to android 8.x lg-m700n after downgrade to 7.x for frp back to android 8.x -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM20 Selected model: M700N Reading info... Model ID: LG-M700n IMEI: 358729-0xxxxxxxxxxxxxxx Android version: 7.1.1 Battery level: 59% SW Version: M70011d Mode: Emergency Initializing flash...OK Platform: msm8937 SW version: LGM700nAT-00-V11d-EUR-XX-APR-06-2018-32G+0 Android version: 7.1.1 LAF Version: 1.1 Product ID: CY19S171111008446 IMEI: 358729-0xxxxxxxxxxxxxx Target operator: GLOBAL Hardware: rev_10 Performed by 2.8.9.8 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM20 Selected model: M700N Reading info... Model ID: LG-M700n IMEI: 358729-0xxxxxxxxxxxx Android version: 7.1.1 Battery level: 59% SW Version: M70011d Mode: Emergency Initializing flash...OK Platform: msm8937 SW version: LGM700nAT-00-V11d-EUR-XX-APR-06-2018-32G+0 Android version: 7.1.1 LAF Version: 1.1 Product ID: CY19S171111008446 IMEI: 358729-0xxxxxxxxxxxx Target operator: GLOBAL Hardware: rev_10 Opening "M700n20e_00_OPEN_EU_OP_1001.kdz"...OK Firmware version: LGM700AT-00-V20n-GLOBAL-COM-OCT-01-2018+0 Firmware model: LG-M700 Firmware type: 0100 -------------------------------------------------------------------------------- Writing phone firmware without real necessity is at your own risk. Downgrade may lead to phone damage! Please, make sure the phone's battery is fully charged. Disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Qualcomm-based devices). You should not run any other programs or attach new devices to your computer during the flashing! -------------------------------------------------------------------------------- Prepairing firmware...OK Setting options...OK Reading partitions...OK Formating USERDATA...OK Formating ENCRYPT...OK Sending signature...OK Writing 1/83 PrimaryGPT_0.bin...OK Writing 2/83 modem_16384.bin...OK Writing 3/83 aboot_196608.bin...OK Writing 4/83 abootbak_200704.bin...OK Writing 5/83 tz_204800.bin...OK Writing 6/83 tzbak_208896.bin...OK Writing 7/83 sbl1_212992.bin...OK Writing 8/83 sbl1bak_215040.bin...OK Writing 9/83 rpm_217088.bin...OK Writing 10/83 rpmbak_218112.bin...OK Writing 11/83 devcfg_219136.bin...OK Writing 12/83 devcfgbak_220160.bin...OK Writing 13/83 cmnlib_221184.bin...OK Writing 14/83 cmnlibbak_222208.bin...OK Writing 15/83 cmnlib64_223232.bin...OK Writing 16/83 cmnlib64bak_224256.bin...OK Writing 17/83 keymaster_225280.bin...OK Writing 18/83 keymasterbak_226304.bin...OK Writing 19/83 dsp_278528.bin...OK Writing 20/83 sec_397312.bin...OK Writing 22/83 apdp_402432.bin...OK Writing 23/83 msadp_403456.bin...OK Writing 24/83 boot_409600.bin...OK Writing 25/83 laf_475136.bin...OK Writing 26/83 lafbak_540672.bin...OK Writing 27/83 recovery_606208.bin...OK Writing 28/83 recoverybak_671744.bin...OK Writing 29/83 factory_737280.bin...OK Writing 30/83 raw_resources_851968.bin...OK Writing 31/83 raw_resourcesbak_860160.bin...OK Writing 32/83 persist_868352.bin...OK Writing 33/83 system_1015808.bin...OK Writing 34/83 system_1280520.bin...OK Writing 35/83 system_1284576.bin...OK Writing 36/83 system_1544152.bin...OK Writing 37/83 system_1804808.bin...OK Writing 38/83 system_1808864.bin...OK Writing 39/83 system_2068440.bin...OK Writing 40/83 system_2326528.bin...OK Writing 41/83 system_2329096.bin...OK Writing 42/83 system_2333152.bin...OK Writing 43/83 system_2592728.bin...OK Writing 44/83 system_2850816.bin...OK Writing 45/83 system_2853384.bin...OK Writing 46/83 system_2857440.bin...OK Writing 47/83 system_3117016.bin...OK Writing 48/83 system_3377672.bin...OK Writing 49/83 system_3381728.bin...OK Writing 50/83 system_3641304.bin...OK Writing 51/83 system_3903448.bin...OK Writing 52/83 system_4165592.bin...OK Writing 53/83 system_4427736.bin...OK Writing 54/83 system_4689880.bin...OK Writing 55/83 system_4952024.bin...OK Writing 56/83 system_5214168.bin...OK Writing 57/83 system_5476312.bin...OK Writing 58/83 system_5738456.bin...OK Writing 59/83 system_6000600.bin...OK Writing 60/83 system_6262744.bin...OK Writing 61/83 system_6524888.bin...OK Writing 62/83 system_6787032.bin...OK Writing 63/83 system_7049176.bin...OK Writing 64/83 system_7311320.bin...OK Writing 65/83 system_7571976.bin...OK Writing 66/83 system_7576032.bin...OK Writing 67/83 system_8093696.bin...OK Writing 68/83 system_8096264.bin...OK Writing 69/83 system_8100320.bin...OK Writing 70/83 system_8617984.bin...OK Writing 71/83 system_8880128.bin...OK Writing 72/83 system_9142272.bin...OK Writing 73/83 system_9404416.bin...OK Writing 74/83 system_9666560.bin...OK Writing 75/83 system_9928704.bin...OK Writing 76/83 system_10190848.bin...OK Writing 77/83 system_10452992.bin...OK Writing 78/83 system_10715136.bin...OK Writing 79/83 system_10977280.bin...OK Writing 80/83 system_11239424.bin...OK Writing 81/83 system_11242496.bin...OK Writing 82/83 BackupGPT_29359104.bin...OK Writing 83/83 0_OP_OPEN_EU.img...OK Reading partitions...OK Formating RCT...OK Formating MPT...OK Finalizing...OK Writing firmware done! Performed by 2.8.9.8 Software version. Last edited by Octopus box; 11-10-2018 at 19:01. |
11-10-2018, 14:28 | #5733 (permalink) |
No Life Poster Join Date: Jul 2004 Location: Ukraine Age: 44
Member: 75408 Status: Offline Thanks Meter: 1,190 | LG LS996 Unlock successfully done LG LS996 Unlock successfully done: Code: Checking data...OK Platform: LG Qualcomm Selected port: COM736 Selected model: LS996 Reading info... IMEI: 355868-06-046255-4 Android version: 5.1.1 Battery level: 8% SW Version: LS996ZVC Mode: Normal Firmware compiled date: Oct 07 2015 Firmware compiled time: 14:00:00 Firmware released date: Nov 23 2017 Firmware released time: 15:30:09 SW Version: MPSS.BO.2.0.1.c3.2-00027-M8994FAAAANAZM-1.30914.2 IMEI: 355868-06-046255-4 SPC: 241139 MEID: 35586806046255 Mobile ESN: 80033F6F SSD_A: 0000000000000000 SSD_B: 0000000000000000 AKEY: 18423356413948479150 OTKSL: 143357 NAM Name: Sprint User Lock Code: 6495 Initializing ADB...OK Waiting for phone...OK Sending exploit...OK Executing exploit...OK Unlocking... Phone successfully unlocked! Rebooting phone... Performed by 2.8.9.8 Software version. Last edited by Octopus box; 11-10-2018 at 19:03. |
The Following User Says Thank You to Dr_Wolodya For This Useful Post: |
11-10-2018, 16:19 | #5734 (permalink) |
No Life Poster Join Date: Mar 2011 Location: dominican republic Age: 45
Member: 1537078 Status: Offline Sonork: celular center Thanks Meter: 573 | LS676 RESET SCREEN LOCK done USING LS675 LG LS676 RESET SCREEN LOCK done USING LS675 Welcome to Octoplus/Octopus Box LG Software version 2.8.9.8 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM315 Selected model: LS675 Please, put the phone into download mode manually (Power phone OFF (reconnect battery), press and hold "Vol+" button and connect the cable (or P999 cable)). Reading info... IMEI: 350305-26-000000-4 Android version: 6.0.1 Battery level: 73% SW Version: K200F10c Mode: Emergency Initializing flash...OK Platform: msm8909 SW version: K200F10c_02 Android version: 6.0.1 LAF Version: 1.1 Product ID: CH33S160901000490 IMEI: 357269-08-418253-4 Target operator: SPR Hardware: rev_11 Resetting Screen Lock... Reading partitions...OK Detecting writing method...OK Resetting screen lock successfully completed! Performed by 2.8.9.8 Software version. Last edited by Octopus box; 11-10-2018 at 19:07. |
The Following User Says Thank You to chipscell25 For This Useful Post: |
11-10-2018, 21:48 | #5735 (permalink) |
Banned Join Date: Sep 2016 Location: living on the edge
Member: 2620145 Status: Offline Thanks Meter: 319 | LS676 Unlock successfully done 10/11/2018 19:22:32 > Checking data...10/11/2018 19:22:33 > OK 10/11/2018 19:22:33 > Platform: LG Qualcomm 10/11/2018 19:22:33 > Selected port: COM3 10/11/2018 19:22:33 > Selected model: LS676 10/11/2018 19:22:33 > Reading info... 10/11/2018 19:22:45 > Initializing ADB...10/11/2018 19:22:45 > OK 10/11/2018 19:22:45 > ADB Server was found. Trying to kill... 10/11/2018 19:22:45 > Waiting for phone...10/11/2018 19:22:49 > OK 10/11/2018 19:22:50 > Model ID: LGLS676 10/11/2018 19:22:50 > Phone firmware version: LGLS676AT-00-ZVC-SPR-US-AUG-13-2018+02 10/11/2018 19:22:50 > Kernel version: 3.10.49-g0b8e19c (lgmobile@LGEACI5R7) (gcc version 4.8 (GCC) ) #1 SMP PREEMPT Mon Aug 13 17:51:28 KST 201 10/11/2018 19:22:50 > Android version: 6.0.1 10/11/2018 19:22:51 > Hardware: Qualcomm Technologies, Inc MSM8909 0 10/11/2018 19:22:51 > Please, type ##3424# to get SPC / MSL / Service Code...10/11/2018 19:22:54 > OK 10/11/2018 19:22:54 > Go to "Diag" menu and select "Enable" option. 10/11/2018 19:23:46 > Performed by 2.8.6 Software version. 10/11/2018 19:24:41 > -------------------------------------------------------------------------------- 10/11/2018 19:24:41 > Checking data...10/11/2018 19:24:42 > OK 10/11/2018 19:24:42 > Platform: LG Qualcomm 10/11/2018 19:24:42 > Selected port: COM3 10/11/2018 19:24:42 > Selected model: LS676 10/11/2018 19:24:42 > Reading info... 10/11/2018 19:24:54 > Initializing ADB...10/11/2018 19:24:54 > OK 10/11/2018 19:24:54 > ADB Server was found. Trying to kill... 10/11/2018 19:24:54 > Waiting for phone...10/11/2018 19:24:57 > OK 10/11/2018 19:24:58 > Model ID: LGLS676 10/11/2018 19:24:58 > Phone firmware version: LGLS676AT-00-ZVC-SPR-US-AUG-13-2018+02 10/11/2018 19:24:58 > Kernel version: 3.10.49-g0b8e19c (lgmobile@LGEACI5R7) (gcc version 4.8 (GCC) ) #1 SMP PREEMPT Mon Aug 13 17:51:28 KST 201 10/11/2018 19:24:58 > Android version: 6.0.1 10/11/2018 19:24:59 > Hardware: Qualcomm Technologies, Inc MSM8909 0 10/11/2018 19:24:59 > Please, type ##3424# to get SPC / MSL / Service Code...10/11/2018 19:25:02 > OK 10/11/2018 19:25:02 > Go to "Diag" menu and select "Enable" option. 10/11/2018 19:25:55 > Performed by 2.8.6 Software version. 10/11/2018 19:31:34 > -------------------------------------------------------------------------------- 10/11/2018 19:31:34 > Checking data...10/11/2018 19:31:34 > OK 10/11/2018 19:31:34 > Platform: LG Qualcomm 10/11/2018 19:31:34 > Selected port: COM93 10/11/2018 19:31:34 > Selected model: LS676 10/11/2018 19:31:34 > Reading info... 10/11/2018 19:31:37 > IMEI: 350305-26-000000-4 10/11/2018 19:31:37 > Android version: 6.0.1 10/11/2018 19:31:37 > Battery level: 22% 10/11/2018 19:31:37 > SW Version: 10/11/2018 19:31:37 > LS676ZV3 10/11/2018 19:31:39 > Mode: Emergency 10/11/2018 19:31:39 > Initializing flash...10/11/2018 19:31:40 > OK 10/11/2018 19:31:41 > SW version: 10/11/2018 19:31:41 > LS676ZVC_02 10/11/2018 19:31:41 > Android version: 6.0.1 10/11/2018 19:31:41 > LAF Version: 1.1 10/11/2018 19:31:41 > Product ID: CH32S161125006685 10/11/2018 19:31:41 > IMEI: 358784-07-644190-3 10/11/2018 19:31:41 > Target operator: SPR 10/11/2018 19:31:41 > Hardware: rev_11 10/11/2018 19:31:41 > Unlock operation is currently not supported for your phone's firmware. 10/11/2018 19:31:47 > Reading partitions...10/11/2018 19:31:48 > OK 10/11/2018 19:31:48 > Reading Carrier...10/11/2018 19:31:53 > OK 10/11/2018 19:31:53 > Unlocking...10/11/2018 19:31:53 > OK 10/11/2018 19:31:53 > Writing Carrier...10/11/2018 19:32:06 > OK 10/11/2018 19:32:06 > Phone successfully unlocked! 10/11/2018 19:32:06 > Performed by 2.8.6 Software version. Last edited by Octopus box; 11-11-2018 at 10:23. |
The Following User Says Thank You to khalidsuper For This Useful Post: |
11-12-2018, 14:40 | #5736 (permalink) | |
Banned Join Date: Jan 2017 Location: Algeria DZ
Member: 2669781 Status: Offline Thanks Meter: 1,839 | LG-E410_{Network Lock}_successfully removed... Full logs of the operation/ Old But Gold Quote:
The Following User Says Thank You to lyes_albert For This Useful Post: |
11-12-2018, 14:53 | #5737 (permalink) |
No Life Poster Join Date: Feb 2016 Location: GREAT Country Pakistan
Member: 2537939 Status: Offline Sonork: 100.1670350 Thanks Meter: 708 | LG F740L screen lock remove done without data lost select k120 and click on reset screen lock /2018 6:18:16 AM > Checking data...11/12/2018 6:18:18 AM > OK 11/12/2018 6:18:18 AM > Platform: LG Qualcomm 11/12/2018 6:18:18 AM > Selected port: COM2399 11/12/2018 6:18:18 AM > Selected model: K120 11/12/2018 6:18:18 AM > Please, put the phone into download mode manually (Power phone OFF (reconnect battery), press and hold "Vol+" button and connect the cable (or P999 cable)). 11/12/2018 6:18:18 AM > Reading info... 11/12/2018 6:18:19 AM > Model ID: LG-F740L 11/12/2018 6:18:19 AM > Incompatible model ID! 11/12/2018 6:18:21 AM > IMEI: 358963-********** 11/12/2018 6:18:21 AM > Android version: 6.0.1 11/12/2018 6:18:21 AM > Battery level: 91% 11/12/2018 6:18:21 AM > SW Version: 11/12/2018 6:18:21 AM > F740L10i 11/12/2018 6:18:31 AM > Mode: Normal 11/12/2018 6:18:31 AM > Switching to Download mode...11/12/2018 6:18:57 AM > OK 11/12/2018 6:19:00 AM > Initializing flash...11/12/2018 6:19:01 AM > OK 11/12/2018 6:19:01 AM > Resetting Screen Lock... 11/12/2018 6:19:04 AM > Reading partitions...11/12/2018 6:19:04 AM > OK 11/12/2018 6:19:04 AM > Detecting writing method...11/12/2018 6:19:04 AM > OK 11/12/2018 6:19:05 AM > Resetting screen lock successfully completed! 11/12/2018 6:19:05 AM > Performed by 2.8.8 Software version. 11/12/2018 6:19:05 AM > Elapsed Time: 12:00:51 AM Last edited by Octopus box; 11-12-2018 at 15:19. |
The Following User Says Thank You to lerner_ For This Useful Post: |
11-13-2018, 00:20 | #5738 (permalink) |
Freak Poster Join Date: Aug 2015 Location: Jamaica
Member: 2450214 Status: Offline Thanks Meter: 106 | H932 (V30) unlock successfully done Checking data...OK Platform: LG Qualcomm Selected port: COM441 Selected model: H932 Reading info... Mode: Normal Firmware compiled date: Sep 14 2017 Firmware compiled time: 04:00:00 Firmware released date: Jan 11 2018 Firmware released time: 13:13:40 SW Version: MPSS.AT.2.5.c1.2-00017-8998_GEN_PACK-1.112143.14 IMEI: 358165-08-218514-0 Checking root access... Initializing ADB...OK Waiting for phone... Phone is already rooted. -------------------------------------------------------------------------------- Connecting to server...OK Octopus smart card is present. Checking smart card...OK Username: dwanexxxxxx Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Your balance: 100 credits. To perform "Unlock" operation you need to have 100 credits. Sending exploit...OK Executing exploit...OK Sending data to server...OK Calculating. Please Wait...OK Unlocking... Phone successfully unlocked! Rebooting phone... Performed by 2.8.9.8 Software version. Last edited by Octopus box; 11-13-2018 at 06:06. |
The Following User Says Thank You to lilshane For This Useful Post: |
11-13-2018, 16:25 | #5739 (permalink) |
Freak Poster Join Date: Jan 2008 Location: HH +4940
Member: 686560 Status: Offline Thanks Meter: 68 | LG Q6 M700n Reset FRP Successfully Done LG Q6 M700n Reset FRP Successfully Done: Detected phone model: LG-M700n Mode: Emergency Initializing.. SW version: LGM700nAT-00-V10k-EUR-XX-AUG-30-2017-32G+0 Android version: 7.1.1 Platform: msm8937 Performed by 1.4.9.0 Software version. Platform: LG Selected model: M700DSK Put the phone into EDL mode: 1. Attach testpoint as shown in Help manual; 2. Connect USB cable; 3. Release testpoint after 3-5 seconds. Searching for a phone. Please wait... Found phone on COM83 Reading info... Detected phone model: LG-M700n Mode: Emergency Initializing.. SW version: LGM700nAT-00-V10k-EUR-XX-AUG-30-2017-32G+0 Android version: 7.1.1 Platform: msm8937 Reset FRP operation for M700DSK will delete all user data on the phone (contacts, pictures and others)! Do You want to continue? Reading partition... Detecting writing method... Trying to repeat.. Resetting FRP lock.. Writing loader... Writing userdata... Formating encrypt section Restoring loader... Perform factory reset to complete operation! FRP lock is successfully reseted! Performed by 1.4.9.0 Software version. Last edited by Octopus box; 11-13-2018 at 18:49. |
The Following User Says Thank You to serpas007 For This Useful Post: |
11-13-2018, 20:03 | #5740 (permalink) |
No Life Poster Join Date: Apr 2015 Location: Dominican Republic
Member: 2382052 Status: Offline Thanks Meter: 1,511 | M153 Reset FRP successfully done -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM75 Selected model: M153 Reading info...Failed! Could not detect mode. Performed by 2.8.9.5 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM75 Selected model: M153 Please, put the phone into download mode manually (Power phone OFF (reconnect battery), press and hold "Vol+" button and connect the cable (or P999 cable)). Reading info... Model ID: LG-M153 IMEI: 354064-08-772789-5 Android version: 6.0.1 Battery level: 91% SW Version: M15311g Mode: Emergency Initializing flash...OK Platform: msm8909 SW version: LGM153AT-01-V11g-310-150-AUG-10-2018-ARB00+0 Android version: 6.0.1 LAF Version: 1.1 Product ID: CB47S170809000421 IMEI: 354064-08-772789-5 Target operator: GLOBAL Hardware: rev_10 Reading partitions...OK Detecting writing method... LAF Error: 80000121. Trying second method...OK Resetting FRP Lock...OK Resetting FRP lock successfully completed! If the phone hang on logo or is restarting afetr performing the operation, please re-flash it using the same or higher version of firmware Performed by 2.8.9.5 Software version. Last edited by Octopus box; 11-13-2018 at 20:22. |
The Following User Says Thank You to maxpatri9 For This Useful Post: |
11-14-2018, 11:28 | #5741 (permalink) |
No Life Poster Join Date: Jul 2009 Location: CHENNAI
Member: 1079392 Status: Offline Thanks Meter: 444 | LS676 network unlock (invalid SIM) success without root Welcome to Octoplus/Octopus Box LG Software version 2.7.6 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM78 Selected model: LS676 Reading info...Failed! Port busy Initializing ADB...OK Waiting for phone...OK Model ID: Incompatible model ID! Phone firmware version: Kernel version: 3.10.49-g9c553a6 (lgmobile@LGEACI8R10) (gcc version 4.8 (GCC) ) #1 SMP PREEMPT Thu Aug 11 16:18:11 KST 201 Android version: Hardware: Qualcomm Technologies, Inc MSM8909 0 Please, type ##3424# to get SPC / MSL / Service Code...OK Go to "Diag" menu and select "Enable" option. Performed by 2.7.6 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM78 Selected model: LS676 Reading info...Failed! Port busy Initializing ADB...OK Waiting for phone...OK Model ID: Incompatible model ID! Phone firmware version: Kernel version: 3.10.49-g9c553a6 (lgmobile@LGEACI8R10) (gcc version 4.8 (GCC) ) #1 SMP PREEMPT Thu Aug 11 16:18:11 KST 201 Android version: Hardware: Qualcomm Technologies, Inc MSM8909 0 Please, type ##3424# to get SPC / MSL / Service Code...OK Input 278067, go to "Diag" menu and select "Enable" option. Performed by 2.7.6 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM78 Selected model: LS676 Reading info...Failed! Port busy Initializing ADB...OK Waiting for phone...OK Model ID: Incompatible model ID! Phone firmware version: Kernel version: 3.10.49-g9c553a6 (lgmobile@LGEACI8R10) (gcc version 4.8 (GCC) ) #1 SMP PREEMPT Thu Aug 11 16:18:11 KST 201 Android version: Hardware: Qualcomm Technologies, Inc MSM8909 0 Please, type ##3424# to get SPC / MSL / Service Code...OK Input 278067, go to "Diag" menu and select "Enable" option. Performed by 2.7.6 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM29 Selected model: LS676 Reading info... IMEI: 358784-07-129194-9 Android version: 6.0.1 Battery level: 78% SW Version: LS676ZV3 Mode: Normal Firmware compiled date: Jun 10 2016 Firmware compiled time: 00:00:00 Firmware released date: Aug 11 2016 Firmware released time: 16:17:14 SW Version: MPSS.JO.1.0.c5.7-00028-M8909EAAAANVZM-1.59782.1 IMEI: 358784-07-129194-9 SPC: 278067 MEID: 35878407129194 Mobile ESN: 80B7A8B1 SSD_A: 0000000000000000 SSD_B: 0000000000000000 OTKSL: 372285 NAM Name: Sprint User Lock Code: 9921 Switching to Download mode...OK Initializing flash...OK Reading partitions...OK Reading Carrier...OK Unlocking...OK Writing Carrier...OK Phone successfully unlocked! Performed by 2.7.6 Software version. Last edited by Octopus box; 11-14-2018 at 15:12. |
The Following User Says Thank You to mmurugan1978 For This Useful Post: |
11-14-2018, 14:22 | #5742 (permalink) |
No Life Poster Join Date: Sep 2016 Location: IN THIS WORLD Age: 33
Member: 2621892 Status: Offline Sonork: 1677742 Thanks Meter: 456 | LG-M700n Resetting FRP lock Done Welcome to Octoplus/Octopus Box LG Software version 2.8.8 Please select Reset FRP Method! -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM361 Selected model: M700Y Please, put the phone into download mode manually (Power phone OFF (reconnect battery), press and hold "Vol+" button and connect the cable (or P999 cable)). Reading info... Model ID: LG-M700n IMEI: 358729-08-070372-3 Android version: 7.1.1 Battery level: 88% SW Version: M70011d Mode: Emergency Initializing flash...OK SW version: LGM700nAT-00-V11d-EUR-XX-APR-06-2018-32G+0 Android version: 7.1.1 LAF Version: 1.1 Product ID: CY22S170805000374 IMEI: 358729-xx-xxxxxx-x Target operator: GLOBAL Hardware: rev_10 Reset FRP operation for M700Y will delete all user data on the phone (contacts, pictures and others)! Do You want to continue? Reading partitions...OK Detecting writing method... Trying third method...OK Resetting FRP Lock... Writing loader... Step 1... Step 2... Step 3... Step 6... Step 7... Step 8... Step 9... Step 10...OK Writing userdata...OK Formating encrypt...OK Restoring loader...OK Resetting FRP lock successfully completed! Rebooting phone... To complete the operation, please make Factory Reset (Go to "Settings" -> "General" -> "Backup & reset" -> "Factory data reset", press "Reset phone" and "Erase everything" buttons). Performed by 2.8.8 Software version. |
The Following User Says Thank You to orhan5 For This Useful Post: |
11-15-2018, 14:39 | #5743 (permalink) | |
Member: 2669781 Status: Offline Thanks Meter: 1,839 | LG Xpower Boost {Carrier Restriction} Successfully removed LG Xpower Boost {Carrier Restriction} Successfully removed.... Quote:
11-16-2018, 17:02 | #5744 (permalink) | |
Member: 2669781 Status: Offline Thanks Meter: 1,839 | LG-X210DS with Hidden APN settings, successfully solved by direct unlocking Full logs of the operation/ Quote:
11-17-2018, 12:37 | #5745 (permalink) |
No Life Poster Join Date: Sep 2008 Location: FMI OF Age: 52
Member: 866455 Status: Offline Sonork: SAMSUNG CPID ONLINE Thanks Meter: 577 | H820 ds - convert firmware and flesh successfully done H820 ds - convert firmware and flesh successfully done: Code: Welcome to Octoplus/Octopus Box LG Software version 2.8.9.8 Converting files... Unpacking "C:\Users\Unlocker\Downloads\H870DSU20a_00 _OPEN_HK_DS_OP_0518.kdz"...OK Opening "C:\Users\Unlocker\AppData\Local\Temp\H870DSU20a_00 _OPEN_HK_DS_OP_0518\H87020a_00.dz"...OK Unpacking "PrimaryGPT_0.bin"...OK Unpacking "laf_6.bin"...OK Unpacking "lafbak_12294.bin"...OK Unpacking "factory_45062.bin"...OK Unpacking "rct_62214.bin"...OK Unpacking "persist_62598.bin"...OK Unpacking "system_70790.bin"...OK Unpacking "system_103911.bin"...OK Unpacking "system_136829.bin"...OK Unpacking "system_169447.bin"...OK Unpacking "system_169950.bin"...OK Unpacking "system_202365.bin"...OK Unpacking "system_234983.bin"...OK Unpacking "system_235486.bin"...OK Unpacking "system_267901.bin"...OK Unpacking "system_300166.bin"...OK Unpacking "system_300519.bin"...OK Unpacking "system_301022.bin"...OK Unpacking "system_333437.bin"...OK Unpacking "system_365702.bin"...OK Unpacking "system_366055.bin"...OK Unpacking "system_366558.bin"...OK Unpacking "system_398973.bin"...OK Unpacking "system_431741.bin"...OK Unpacking "system_464509.bin"...OK Unpacking "system_496774.bin"...OK Unpacking "system_497277.bin"...OK Unpacking "system_529542.bin"...OK Unpacking "system_530045.bin"...OK Unpacking "system_562813.bin"...OK Unpacking "system_595581.bin"...OK Unpacking "system_628349.bin"...OK Unpacking "system_661117.bin"...OK Unpacking "system_693885.bin"...OK Unpacking "system_726653.bin"...OK Unpacking "system_759421.bin"...OK Unpacking "system_792189.bin"...OK Unpacking "system_824957.bin"...OK Unpacking "system_857725.bin"...OK Unpacking "system_890343.bin"...OK Unpacking "system_890846.bin"...OK Unpacking "system_923261.bin"...OK Unpacking "system_955879.bin"...OK Unpacking "system_956382.bin"...OK Unpacking "system_988797.bin"...OK Unpacking "system_1021565.bin"...OK Unpacking "system_1054333.bin"...OK Unpacking "system_1087101.bin"...OK Unpacking "system_1119869.bin"...OK Unpacking "system_1152637.bin"...OK Unpacking "system_1185405.bin"...OK Unpacking "system_1218173.bin"...OK Unpacking "system_1250941.bin"...OK Unpacking "system_1283709.bin"...OK Unpacking "system_1316477.bin"...OK Unpacking "system_1348742.bin"...OK Unpacking "system_1381510.bin"...OK Unpacking "system_1414278.bin"...OK Unpacking "system_1447046.bin"...OK Unpacking "system_1480007.bin"...OK Unpacking "BackupGPT_7728123.bin"...OK Unpacking "PrimaryGPT_0.bin"...OK Unpacking "xbl_6.bin"...OK Unpacking "xblbak_774.bin"...OK Unpacking "BackupGPT_8187.bin"...OK Unpacking "PrimaryGPT_0.bin"...OK Unpacking "xbl2_6.bin"...OK Unpacking "xbl2bak_774.bin"...OK Unpacking "BackupGPT_2043.bin"...OK Unpacking "PrimaryGPT_0.bin"...OK Unpacking "BackupGPT_2043.bin"...OK Unpacking "PrimaryGPT_0.bin"...OK Unpacking "boot_6.bin"...OK Unpacking "recovery_10246.bin"...OK Unpacking "recoverybak_20614.bin"...OK Unpacking "tz_30982.bin"...OK Unpacking "tzbak_31494.bin"...OK Unpacking "aboot_32006.bin"...OK Unpacking "abootbak_32518.bin"...OK Unpacking "raw_resources_33030.bin"...OK Unpacking "raw_resourcesbak_34054.bin"...OK Unpacking "rpm_35078.bin"...OK Unpacking "rpmbak_35206.bin"...OK Unpacking "hyp_35334.bin"...OK Unpacking "hypbak_35462.bin"...OK Unpacking "pmic_35590.bin"...OK Unpacking "pmicbak_35718.bin"...OK Unpacking "devcfg_35846.bin"...OK Unpacking "devcfgbak_35878.bin"...OK Unpacking "modem_35910.bin"...OK Unpacking "sec_57926.bin"...OK Unpacking "keymaster_58054.bin"...OK Unpacking "keymasterbak_58182.bin"...OK Unpacking "cmnlib_58310.bin"...OK Unpacking "cmnlibbak_58438.bin"...OK Unpacking "cmnlib64_58566.bin"...OK Unpacking "cmnlib64bak_58694.bin"...OK Unpacking "apdp_58822.bin"...OK Unpacking "msadp_58950.bin"...OK Unpacking "BackupGPT_59387.bin"...OK Unpacking "PrimaryGPT_0.bin"...OK Unpacking "BackupGPT_2043.bin"...OK Unpacking "PrimaryGPT_0.bin"...OK Unpacking "BackupGPT_2043.bin"...OK Unpacking "0_OP_OPEN_HK_DS.img"...OK Unpacking "1_OP_OPEN_HK_DS.img"...OK Unpacking "2_OP_OPEN_HK_DS.img"...OK Unpacking done. Processing files... Creating destination file...OK Deleting temporary files... Deleting directory "C:\Users\Unlocker\AppData\Local\Temp\H870DSU20a_ 00_OPEN_HK_DS_OP_0518\"... Deleting file "C:\Users\Unlocker\AppData\Local\Temp\H870DSU20a_00 _OPEN_HK_DS_OP_0518\0_BackupGPT"...OK Deleting file "C:\Users\Unlocker\AppData\Local\Temp\H870DSU20a_00 _OPEN_HK_DS_OP_0518\0_factory"...OK Deleting file "C:\Users\Unlocker\AppData\Local\Temp\H870DSU20a_00 _OPEN_HK_DS_OP_0518\0_laf"...OK Deleting file "C:\Users\Unlocker\AppData\Local\Temp\H870DSU20a_00 _OPEN_HK_DS_OP_0518\0_lafbak"...OK Deleting file "C:\Users\Unlocker\AppData\Local\Temp\H870DSU20a_00 _OPEN_HK_DS_OP_0518\0_OP_T"...OK Deleting file "C:\Users\Unlocker\AppData\Local\Temp\H870DSU20a_00 _OPEN_HK_DS_OP_0518\0_partsv2.bin"...OK Deleting file "C:\Users\Unlocker\AppData\Local\Temp\H870DSU20a_00 _OPEN_HK_DS_OP_0518\0_persist"...OK Deleting file "C:\Users\Unlocker\AppData\Local\Temp\H870DSU20a_00 _OPEN_HK_DS_OP_0518\0_PrimaryGPT"...OK Deleting file "C:\Users\Unlocker\AppData\Local\Temp\H870DSU20a_00 _OPEN_HK_DS_OP_0518\0_rct"...OK Deleting file "C:\Users\Unlocker\AppData\Local\Temp\H870DSU20a_00 _OPEN_HK_DS_OP_0518\0_SIGN"...OK Deleting file "C:\Users\Unlocker\AppData\Local\Temp\H870DSU20a_00 _OPEN_HK_DS_OP_0518\0_system"...OK Deleting file "C:\Users\Unlocker\AppData\Local\Temp\H870DSU20a_00 _OPEN_HK_DS_OP_0518\1_BackupGPT"...OK Deleting file "C:\Users\Unlocker\AppData\Local\Temp\H870DSU20a_00 _OPEN_HK_DS_OP_0518\1_PrimaryGPT"...OK Deleting file "C:\Users\Unlocker\AppData\Local\Temp\H870DSU20a_00 _OPEN_HK_DS_OP_0518\1_xbl"...OK Deleting file "C:\Users\Unlocker\AppData\Local\Temp\H870DSU20a_00 _OPEN_HK_DS_OP_0518\1_xblbak"...OK Deleting file "C:\Users\Unlocker\AppData\Local\Temp\H870DSU20a_00 _OPEN_HK_DS_OP_0518\2_BackupGPT"...OK Deleting file "C:\Users\Unlocker\AppData\Local\Temp\H870DSU20a_00 _OPEN_HK_DS_OP_0518\2_PrimaryGPT"...OK Deleting file "C:\Users\Unlocker\AppData\Local\Temp\H870DSU20a_00 _OPEN_HK_DS_OP_0518\2_xbl2"...OK Deleting file "C:\Users\Unlocker\AppData\Local\Temp\H870DSU20a_00 _OPEN_HK_DS_OP_0518\2_xbl2bak"...OK Deleting file "C:\Users\Unlocker\AppData\Local\Temp\H870DSU20a_00 _OPEN_HK_DS_OP_0518\3_BackupGPT"...OK Deleting file "C:\Users\Unlocker\AppData\Local\Temp\H870DSU20a_00 _OPEN_HK_DS_OP_0518\3_PrimaryGPT"...OK Deleting file "C:\Users\Unlocker\AppData\Local\Temp\H870DSU20a_00 _OPEN_HK_DS_OP_0518\4_aboot"...OK Deleting file "C:\Users\Unlocker\AppData\Local\Temp\H870DSU20a_00 _OPEN_HK_DS_OP_0518\4_abootbak"...OK Deleting file "C:\Users\Unlocker\AppData\Local\Temp\H870DSU20a_00 _OPEN_HK_DS_OP_0518\4_apdp"...OK Deleting file "C:\Users\Unlocker\AppData\Local\Temp\H870DSU20a_00 _OPEN_HK_DS_OP_0518\4_BackupGPT"...OK Deleting file "C:\Users\Unlocker\AppData\Local\Temp\H870DSU20a_00 _OPEN_HK_DS_OP_0518\4_boot"...OK Deleting file "C:\Users\Unlocker\AppData\Local\Temp\H870DSU20a_00 _OPEN_HK_DS_OP_0518\4_cmnlib"...OK Deleting file "C:\Users\Unlocker\AppData\Local\Temp\H870DSU20a_00 _OPEN_HK_DS_OP_0518\4_cmnlib64"...OK Deleting file "C:\Users\Unlocker\AppData\Local\Temp\H870DSU20a_00 _OPEN_HK_DS_OP_0518\4_cmnlib64bak"...OK Deleting file "C:\Users\Unlocker\AppData\Local\Temp\H870DSU20a_00 _OPEN_HK_DS_OP_0518\4_cmnlibbak"...OK Deleting file "C:\Users\Unlocker\AppData\Local\Temp\H870DSU20a_00 _OPEN_HK_DS_OP_0518\4_devcfg"...OK Deleting file "C:\Users\Unlocker\AppData\Local\Temp\H870DSU20a_00 _OPEN_HK_DS_OP_0518\4_devcfgbak"...OK Deleting file "C:\Users\Unlocker\AppData\Local\Temp\H870DSU20a_00 _OPEN_HK_DS_OP_0518\4_hyp"...OK Deleting file "C:\Users\Unlocker\AppData\Local\Temp\H870DSU20a_00 _OPEN_HK_DS_OP_0518\4_hypbak"...OK Deleting file "C:\Users\Unlocker\AppData\Local\Temp\H870DSU20a_00 _OPEN_HK_DS_OP_0518\4_keymaster"...OK Deleting file "C:\Users\Unlocker\AppData\Local\Temp\H870DSU20a_00 _OPEN_HK_DS_OP_0518\4_keymasterbak"...OK Deleting file "C:\Users\Unlocker\AppData\Local\Temp\H870DSU20a_00 _OPEN_HK_DS_OP_0518\4_modem"...OK Deleting file "C:\Users\Unlocker\AppData\Local\Temp\H870DSU20a_00 _OPEN_HK_DS_OP_0518\4_msadp"...OK Deleting file "C:\Users\Unlocker\AppData\Local\Temp\H870DSU20a_00 _OPEN_HK_DS_OP_0518\4_pmic"...OK Deleting file "C:\Users\Unlocker\AppData\Local\Temp\H870DSU20a_00 _OPEN_HK_DS_OP_0518\4_pmicbak"...OK Deleting file "C:\Users\Unlocker\AppData\Local\Temp\H870DSU20a_00 _OPEN_HK_DS_OP_0518\4_PrimaryGPT"...OK Deleting file "C:\Users\Unlocker\AppData\Local\Temp\H870DSU20a_00 _OPEN_HK_DS_OP_0518\4_raw_resources"...OK Deleting file "C:\Users\Unlocker\AppData\Local\Temp\H870DSU20a_00 _OPEN_HK_DS_OP_0518\4_raw_resourcesbak"...OK Deleting file "C:\Users\Unlocker\AppData\Local\Temp\H870DSU20a_00 _OPEN_HK_DS_OP_0518\4_recovery"...OK Deleting file "C:\Users\Unlocker\AppData\Local\Temp\H870DSU20a_00 _OPEN_HK_DS_OP_0518\4_recoverybak"...OK Deleting file "C:\Users\Unlocker\AppData\Local\Temp\H870DSU20a_00 _OPEN_HK_DS_OP_0518\4_rpm"...OK Deleting file "C:\Users\Unlocker\AppData\Local\Temp\H870DSU20a_00 _OPEN_HK_DS_OP_0518\4_rpmbak"...OK Deleting file "C:\Users\Unlocker\AppData\Local\Temp\H870DSU20a_00 _OPEN_HK_DS_OP_0518\4_sec"...OK Deleting file "C:\Users\Unlocker\AppData\Local\Temp\H870DSU20a_00 _OPEN_HK_DS_OP_0518\4_tz"...OK Deleting file "C:\Users\Unlocker\AppData\Local\Temp\H870DSU20a_00 _OPEN_HK_DS_OP_0518\4_tzbak"...OK Deleting file "C:\Users\Unlocker\AppData\Local\Temp\H870DSU20a_00 _OPEN_HK_DS_OP_0518\5_BackupGPT"...OK Deleting file "C:\Users\Unlocker\AppData\Local\Temp\H870DSU20a_00 _OPEN_HK_DS_OP_0518\5_PrimaryGPT"...OK Deleting file "C:\Users\Unlocker\AppData\Local\Temp\H870DSU20a_00 _OPEN_HK_DS_OP_0518\6_BackupGPT"...OK Deleting file "C:\Users\Unlocker\AppData\Local\Temp\H870DSU20a_00 _OPEN_HK_DS_OP_0518\6_PrimaryGPT"...OK Deleting file "C:\Users\Unlocker\AppData\Local\Temp\H870DSU20a_00 _OPEN_HK_DS_OP_0518\H87020a_00.dz"...OK Directory "C:\Users\Unlocker\AppData\Local\Temp\H870DSU20a_00 _OPEN_HK_DS_OP_0518\" succesfully deleted! Firmware convert done! -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM201 Selected model: H870DS Reading info... Model ID: LG-H870DS IMEI: 356145-08-397171-6 Android version: 7.0 Battery level: 73% SW Version: H87010b Mode: Emergency Initializing flash...OK Platform: msm8996 SW version: LGH870DSAT-00-V10b-DS2-YT-APR-06-2017+0 Android version: 7.0 LAF Version: 1.1 Product ID: HD60S170824001482 IMEI: 356145-08-397171-6 Target operator: GLOBAL Hardware: rev_10 Writing phone firmware without real necessity is at your own risk. Downgrade may lead to phone damage! Please, make sure the phone's battery is fully charged. Disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Qualcomm-based devices). You should not run any other programs or attach new devices to your computer during the flashing! Opening "H870DSU20a_00_OPEN_HK_DS_OP_0518.oct"...OK Setting options...OK Reading partitions...OK Formating USERDATA...OK Formating ENCRYPT...OK Sending signature...OK Writing PrimaryGPT...OK Writing laf...OK Writing lafbak...OK Writing factory...OK Writing persist...OK Writing system...OK Writing BackupGPT...OK Writing PrimaryGPT...OK Writing xbl...OK Writing xblbak...OK Writing BackupGPT...OK Writing PrimaryGPT...OK Writing xbl2...OK Writing xbl2bak...OK Writing BackupGPT...OK Writing PrimaryGPT...OK Writing BackupGPT...OK Writing PrimaryGPT...OK Writing boot...OK Writing recovery...OK Writing recoverybak...OK Writing tz...OK Writing tzbak...OK Writing aboot...OK Writing abootbak...OK Writing raw_resources...OK Writing raw_resourcesbak...OK Writing rpm...OK Writing rpmbak...OK Writing hyp...OK Writing hypbak...OK Writing pmic...OK Writing pmicbak...OK Writing devcfg...OK Writing devcfgbak...OK Writing modem...OK Writing sec...OK Writing keymaster...OK Writing keymasterbak...OK Writing cmnlib...OK Writing cmnlibbak...OK Writing cmnlib64...OK Writing cmnlib64bak...OK Writing apdp...OK Writing msadp...OK Writing BackupGPT...OK Writing PrimaryGPT...OK Writing BackupGPT...OK Writing PrimaryGPT...OK Writing BackupGPT...OK Writing OP_T...OK Finalizing...OK Writing firmware done! Performed by 2.8.9.8 Software version. Last edited by Octopus box; 11-18-2018 at 11:17. |
The Following User Says Thank You to AgicAga For This Useful Post: |
Post here successfully unlocked a2 phones | 3lsheikh | SETool2 | 10 | 03-04-2011 02:48 |
Successfully Unlock Z240 Phone Freeze | jhepoy_org | UST Pro II | 13 | 12-02-2009 06:03 |
Successfully unlock BB5 phones with bb5king | Mjabbar | BB5KING | 0 | 11-29-2008 14:13 |
Successfully unlock BB5 phones with bb5king | Mjabbar | BB5KING | 2 | 11-26-2008 11:54 |
PB2 - Successfully unlocked LG phones CU/KU ... | DOUHAL | PolarBox 3 | 72 | 11-05-2008 18:21 |
