Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Octopus/Octoplus > Octopus LG/Octoplus LG
Old 09-07-2019, 12:52   #6106 (permalink)
GolfGSM's Avatar
Member: 2924041
Thanks Meter: 76
Welcome to Octoplus/Octopus Box LG Software version 2.9.5
Checking data...OK
Platform: LG Qualcomm
Selected port: COM40
Selected model: F500L
Reading info...Failed!
Port busy
Performed by 2.9.5 Software version.
Checking data...OK
Selected port: COM98
Reading info...
Model ID: LG-F500L
IMEI: 357767-06-086730-9
Android version: 6.0
Battery level: 43%
Mode: Emergency
Initializing flash...OK
Platform: msm8992
SW version: LGF500LAT-00-V21a-LGU-KR-DEC-16-2016+0
LAF Version: 1.1
Product ID: YE04S160602003269
Target operator: LGU
Hardware: rev_10
Writing phone firmware without real necessity is at your own risk.
Downgrade may lead to phone damage!
Please, make sure the phone's battery is fully charged.
Disconnect all other devices from the computer (including phones,
modems, etc.) and close all other running programs.
To avoid errors in the flashing process, use a clean PC (without
any installed drivers for other Qualcomm-based devices).
You should not run any other programs or attach new devices to
your computer during the flashing!
Opening "F500L30B_00.oct"...OK
Selecting firmware partitions...OK
Selected default partitions!
Setting options...OK
Do you want to format User Data?
Reading partitions...OK
Formating USERDATA...OK
Formating ENCRYPT...OK
Sending signature...OK
Writing PrimaryGPT...OK
Writing modem...OK
Writing pmic...OK
Writing sbl1...OK
Writing tz...OK
Writing sdi...OK
Writing hyp...OK
Writing rpm...OK
Writing aboot...OK
Writing sbl1bak...OK
Writing pmicbak...OK
Writing tzbak...OK
Writing hypbak...OK
Writing rpmbak...OK
Writing abootbak...OK
Writing sdibak...OK
Writing persist...OK
Writing sec...OK
Writing laf...OK
Writing boot...OK
Writing recovery...OK
Writing raw_resources...OK
Writing raw_resourcesbak...OK
Writing factory...OK
Writing system...OK
Writing BackupGPT...OK
Formating RCT...OK
Formating MPT...OK
Finalizing...OK
Writing firmware done!
Old 09-10-2019, 18:56   #6107 (permalink)
Member: 1608954
Sonork: elmazetaz
Thanks Meter: 19
Welcome to Octoplus/Octopus Box LG Software version 2.9.6
Checking data...OK
Selected port: COM39
Selected model: LMX210CM
Reading info...
Model ID: LM-X210CM
IMEI: 354376-09-843974-4
Android version: 8.1.0
Battery level: 83%
Mode: Normal
Firmware compiled date: May 27 2019
Firmware compiled time: 08:00:00
Firmware released date: May 29 2019
Firmware released time: 17:51:52
SW Version: MPSS.JO.3.0.c12-00015-8937_GENNS_PACK-1.201016.1.205920.1
Performed by 2.9.6 Software version.
Checking data...OK
Reading info...
Model ID: LM-X210CM
Battery level: 83%
Mode: Normal
Checking data...OK
Reading info...
Model ID: LM-X210CM
Battery level: 83%
Mode: Normal
Bluetooth address: 084:6A:85:5B:B6
Wi-Fi MAC address: 38:30:F9:72:20:B9
SPC: 000000
Unlocking...
Initializing ADB...OK
Waiting for phone...OK
Connecting to server...OK
Octopus smart card is present.
Checking smart card...OK
Username: abel0802
Authorizing...OK
Checking balance...OK
Checking operation...OK
Sending device information...OK
Get credits, needed for current operation...OK
Your balance: 50 credits.
To perform "Unlock" operation you need to have 50 credits.
Write security backup function doesn't work for this device with latest firmware versions. If you'll encounter any problem during Unlock operation - you won't be able to restore the phone to it's initial state, so proceed at your own risk.
Continue?
Reading QCN...
Send SPC...OK
Reading Mobile Property...OK
Reading Feature Mask...OK
Reading Roaming List 0...OK
Reading NV_Numbered Items...OK
Reading NV_Numbered SIM1 Items...OK
Reading NV_Numbered SIM2 Items...OK
Reading NV Items...OK
Reading EFS...OK
Reading Provisioning Items...OK
Reading QCN done!
Backup saved to "LMX210CM_354376098439744_10-09-2019_12-26-57.qcn"
Switching to Download mode...OK
Detecting writing method...
LAF Error: 80000121.
Trying second method...
Trying third method...Failed!
Reading security area...Failed!
LAF Error: 80000119.
Writing security area...
Trying second method...Failed!
LAF Error: 00000000.
Unlock operation is currently not supported for your phone's firmware.
Error code: ZXCSIMMISC
Checking data...OK
Reading info...
Model ID: LM-X210CM
Battery level: 83%
Mode: Normal
SPC: 000000
Unlocking...
Username: abel0802
Authorizing...OK
Continue?
Skip Read/Write QCN
it will take a long time to add this device to unlock by server?
Old 09-10-2019, 19:10   #6108 (permalink)
Member: 2122242
Thanks Meter: 47
Originally Posted by elmazetaz View Post
Checking data...OK
Reading info...
Model ID: LM-X210CM
Username: abel0802
Authorizing...OK
Unlock in this Android version isnít impossible
Old 09-11-2019, 04:57   #6109 (permalink)
Member: 1608954
Sonork: elmazetaz
Thanks Meter: 19
The question is when this unlock will be available?
Octoplus is a bit slow in updating and unlocking patches 2019
but we will have to wait Greetings
Old 09-11-2019, 05:00   #6110 (permalink)
Member: 2122242
Thanks Meter: 47
I don't think so, only way is downgrade phone's firmware, but it's a great risk to take
Old 09-16-2019, 06:41   #6111 (permalink)
Member: 1420095
Thanks Meter: 201
LG M430 Unlock Done!
Welcome to Octoplus/Octopus Box LG Software version 2.9.0
Checking data...OK
Selected port: COM852
Selected model: M430
Reading info...
Model ID: LG-M430
IMEI: XXXXX-08-441631-1
Android version: 7.0
Battery level: 41%
SW Version: M43010o
Trying to enable Diagnostics ports...
Found model LGM430AT: ˇh at port COM852
Unlocking...
Reading QCN...
Send SPC...OK
Reading EFS...OK
Reading QCN done!
Backup saved to "M430_XXXXXXX84416311_16-09-2019_15-28-05.qcn"
Trying third method...OK
Reading security area...OK
Backup saved to "M430_XXXXXXX84416311_16-09-2019_15-33-52.SEC"
Writing security area...OK
Switching to Normal mode...
Found model LGM430AT* ˇh at port COM852
Send SPC...OK
Writing QCN...
Writing NV_Numbered Items...OK
Writing NV_Numbered SIM1 Items...OK
Writing NV_Numbered SIM2 Items...OK
Writing QCN done!
Phone successfully unlocked!
Rebooting phone...
Performed by 2.9.0 Software version.
Old 09-16-2019, 10:06   #6112 (permalink)
Crazy Poster
Member: 2860421
Thanks Meter: 4
unlock lg k425 done
Checking data...OK
Selected port: COM110
Selected model: K425
Reading info...
Model ID: LG-K425
IMEI: 000000-00-000000-0
Android version: 6.0.1
Battery level: 72%
Mode: Normal
Firmware compiled date: Sep 28 2016
Firmware compiled time: 01:00:00
Firmware released date: Sep 30 2016
Firmware released time: 10:50:55
SW Version: MPSS.JO.1.0.c5.7-00028-M8909EAAAANVZM-1.71846.2
SPC: 000000
Unlocking...
Reading QCN...
Send SPC...OK
Reading EFS...OK
Reading QCN done!
Backup saved to "K425_000000000000000_16-09-2019_13-27-40.qcn"
Detecting writing method...OK
Backup saved to "K425_000000000000000_16-09-2019_13-31-40.SEC"
Found model at port COM110
Send SPC...OK
Writing QCN...
Writing QCN done!
Rebooting phone...
Old 09-23-2019, 13:23   #6113 (permalink)
Member: 2499103
Thanks Meter: 53
lg x320l frp reset done
Log file "C:\Program Files\Octoplus\Octoplus_LG\LOG\23-09-2019_12-00-16.log" created.
9/23/2019 12:00:20 PM > Searching for server...
9/23/2019 12:00:20 PM > Trying to ping server...9/23/2019 12:00:20 PM > ok
9/23/2019 12:00:20 PM > Trying connect to server...
9/23/2019 12:00:20 PM > Server greeting: Card updates server v.2.2
9/23/2019 12:00:21 PM > Searching installed cards...
9/23/2019 12:00:21 PM > Found card with s/n: ********
9/23/2019 12:00:21 PM > Server check...
9/23/2019 12:00:22 PM > Server Check succesfull!
9/23/2019 12:00:23 PM > Welcome to Octoplus/Octopus Box LG Software version 2.9.6
9/23/2019 12:04:07 PM > --------------------------------------------------------------------------------
9/23/2019 12:04:07 PM > Checking data...9/23/2019 12:04:08 PM > OK
9/23/2019 12:04:08 PM > Platform: LG MTK
9/23/2019 12:04:08 PM > Selected port: COM57
9/23/2019 12:04:08 PM > Selected baudrate: 0
9/23/2019 12:04:08 PM > Selected model: X320L
9/23/2019 12:04:08 PM > Selected USB connection type
9/23/2019 12:04:08 PM > Please, disconnect cable, reconnect battery, connect P999 cable (with 910k resistor)
9/23/2019 12:04:08 PM > or
9/23/2019 12:04:08 PM > Reconnect battery, press and hold "Vol+" for 10 seconds and connect Micro USB cable.
9/23/2019 12:04:41 PM > Phone found at port COM57
9/23/2019 12:04:45 PM > Mode: Emergency
9/23/2019 12:04:45 PM > Initializing flash...9/23/2019 12:04:47 PM > OK
9/23/2019 12:04:48 PM > Model ID: LGM-X320L
9/23/2019 12:04:48 PM > Platform: mt6750
9/23/2019 12:04:48 PM > Android version: 7.0
9/23/2019 12:04:48 PM > SW version: LGMX320LAT-00-V10p-LGU-KR-FEB-13-2018+0
9/23/2019 12:04:48 PM > LAF Version: 1.1
9/23/2019 12:04:48 PM > Product ID: CT01S170729005248
9/23/2019 12:04:48 PM > IMEI:
9/23/2019 12:04:48 PM > Target operator: LGU
9/23/2019 12:04:48 PM > Hardware: rev_10
9/23/2019 12:04:48 PM > Battery level: 50%
9/23/2019 12:04:48 PM > Reading partitions...9/23/2019 12:04:48 PM > OK
9/23/2019 12:04:50 PM > Checking security...
9/23/2019 12:04:50 PM > offs: 00800000
9/23/2019 12:04:50 PM > Read 00800000...
9/23/2019 12:04:50 PM > Checking security passed!
9/23/2019 12:04:50 PM > --------------------------------------------------------------------------------
9/23/2019 12:04:50 PM > IMEI: ****************
9/23/2019 12:04:50 PM > Bluetooth address: 88:36:5F:37:93:9E
9/23/2019 12:04:50 PM > Wi-Fi MAC address: 88:36:5FD4:76
9/23/2019 12:04:50 PM > SPC: 000000
9/23/2019 12:04:50 PM > Detecting writing method...
9/23/2019 12:04:51 PM > LAF Error: 80000121.
9/23/2019 12:04:51 PM > Trying second method...
9/23/2019 12:04:59 PM > Trying third method...
9/23/2019 12:04:59 PM > Reading ramdisk...
9/23/2019 12:05:00 PM > Unpacking...
9/23/2019 12:05:00 PM > Starting MTK decompress...
9/23/2019 12:05:00 PM > Decompressing 0x004FC204
9/23/2019 12:05:00 PM > Decompressing 0x002A3F52
9/23/2019 12:05:00 PM > Set Writing params...
9/23/2019 12:05:00 PM > Set cmdSigData...
9/23/2019 12:05:00 PM > Set corrData...
9/23/2019 12:05:00 PM > Set cSeekData...
9/23/2019 12:05:00 PM > Set cFunc...
9/23/2019 12:05:00 PM > Compose data...
9/23/2019 12:05:00 PM > Testing write method...
9/23/2019 12:05:00 PM > Writing cmd...
9/23/2019 12:05:00 PM > reading cmd...
9/23/2019 12:05:02 PM > reading cmd...
9/23/2019 12:05:05 PM > reading cmd...
9/23/2019 12:05:07 PM > reading cmd...
9/23/2019 12:05:09 PM > reading cmd...
9/23/2019 12:05:11 PM > reading cmd...
9/23/2019 12:05:14 PM > Writing cmd...
9/23/2019 12:05:14 PM > reading cmd...
9/23/2019 12:05:16 PM > reading cmd...
9/23/2019 12:05:18 PM > reading cmd...
9/23/2019 12:05:20 PM > reading cmd...
9/23/2019 12:05:23 PM > reading cmd...
9/23/2019 12:05:25 PM > reading cmd...9/23/2019 12:05:27 PM > OK
9/23/2019 12:05:27 PM > Reset FRP operation for X320L will delete all user data on the phone (contacts, pictures and others)!
Do You want to continue?
9/23/2019 12:05:31 PM > Resetting FRP Lock...
9/23/2019 12:05:31 PM > Writing loader...
9/23/2019 12:05:32 PM > Writing cmd...
9/23/2019 12:05:32 PM > reading cmd...
9/23/2019 12:05:34 PM > reading cmd...
9/23/2019 12:05:37 PM > reading cmd...
9/23/2019 12:05:39 PM > reading cmd...
9/23/2019 12:05:41 PM > reading cmd...
9/23/2019 12:05:43 PM > reading cmd...
9/23/2019 12:05:45 PM > Writing cmd...
9/23/2019 12:05:46 PM > reading cmd...
9/23/2019 12:05:48 PM > reading cmd...
9/23/2019 12:05:50 PM > reading cmd...
9/23/2019 12:05:52 PM > reading cmd...
9/23/2019 12:05:54 PM > reading cmd...
9/23/2019 12:05:57 PM > reading cmd...9/23/2019 12:05:59 PM > OK
9/23/2019 12:05:59 PM > Writing userdata...
9/23/2019 12:06:17 PM > Writing cmd...
9/23/2019 12:06:17 PM > reading cmd...
9/23/2019 12:06:17 PM > Read: EXEC...9/23/2019 12:06:17 PM > OK
9/23/2019 12:06:17 PM > Formating encrypt...9/23/2019 12:06:21 PM > OK
9/23/2019 12:06:21 PM > Restoring loader...
9/23/2019 12:06:21 PM > Writing cmd...
9/23/2019 12:06:21 PM > reading cmd...
9/23/2019 12:06:24 PM > reading cmd...
9/23/2019 12:06:26 PM > reading cmd...
9/23/2019 12:06:28 PM > reading cmd...
9/23/2019 12:06:30 PM > reading cmd...
9/23/2019 12:06:32 PM > reading cmd...
9/23/2019 12:06:35 PM > Writing cmd...
9/23/2019 12:06:35 PM > reading cmd...
9/23/2019 12:06:37 PM > reading cmd...
9/23/2019 12:06:39 PM > reading cmd...
9/23/2019 12:06:41 PM > reading cmd...
9/23/2019 12:06:44 PM > reading cmd...
9/23/2019 12:06:46 PM > reading cmd...9/23/2019 12:06:48 PM > OK
9/23/2019 12:06:48 PM > Resetting FRP lock successfully completed!
9/23/2019 12:06:48 PM > Rebooting phone...
9/23/2019 12:06:48 PM > To complete the operation, please make Factory Reset (Go to "Settings" -> "General" -> "Backup & reset" -> "Factory data reset", press "Reset phone" and "Erase everything" buttons).
9/23/2019 12:06:48 PM > Performed by 2.9.6 Software version.
9/23/2019 12:06:48 PM > Elapsed Time: 12:02:41 AM
Old 09-23-2019, 14:23   #6114 (permalink)
Dr_Wolodya's Avatar
Member: 75408
Thanks Meter: 947
LG H901 (6.0) Unlock from T-Mobile successfully done:
Checking data...OK
Selected port: COM1470
Selected model: H901
Reading info...
Model ID: LG-H901
IMEI: 354017-07-09xxxx
Battery level: 45%
Mode: Normal
Firmware compiled date: May 04 2016
Firmware compiled time: 12:00:00
Firmware released date: Jul 12 2016
Firmware released time: 17:08:27
SW Version: MPSS.BO.2.5.c10.1-00026-M8992FAAAANAZM-1
SPC: 000000
Checking root access...
Phone is already rooted.
Username: Dr_Volodya
Authorizing...OK
Your balance: 251 credits.
To perform "Unlock" operation you need to have 100 credits.
Sending data to server...
Sending exploit...OK
Executing exploit...OK
Calculating. Please Wait...OK
Unlocking...
Rebooting phone...
Old 09-24-2019, 17:54   #6115 (permalink)
Member: 444048
Thanks Meter: 21
j737t1 u5
Platform: Samsung Android
Selected port: COM5
Selected model: SM-J737T1
Operation: Read info
Reading info, please wait...
Please, press "OK" button on the phone to allow USB debugging.
Detected phone model: SM-J737T1
Firmware compiled date: Tue Apr 30 20:38:49 KST 2019
PDA version: J737T1UVS5ASE1
CSC version: J737T1TMK5ASE1
SW version: J737T1UVS5ASE1
Phone SN: Rxxxxxx
Android version: 8.0.0 (R16NW)
Sales code: TMK
Country: USA
HW platform: exynos5
HW Chip: exynos7870
HW Modem: SHANNON315
Security patch level: 2019-05-01
Warranty Void: 0
SIM 1 status: ready
Codename: j7topltemtr
Performed by 2.8.2.3 Software version.
Selected port: COM5
Operation: Unlock
Phone SN: Rxxxxxx
Sales code: TMK
Country: USA
HW Chip: exynos7870
Warranty Void: 0
SIM 1 status: ready
Connecting to modem port...
Found phone on COM786
Reading IMEI...OK
Username: 1
Authorizing...OK
Your balance: 290 credits.
Rebooting phone
Searching for a phone. Please wait...OK
Initializing exploit...OK
Initializing...
Reading HWID...OK
Unlocking phone...OK
Phone is successfully unlocked
To finish the operation, please restart the phone via phone's menu.
Old 09-30-2019, 06:10   #6116 (permalink)
GolfGSM's Avatar
Member: 2924041
Thanks Meter: 76
Checking data...OK
Selected port: COM176
Selected model: D160
Reading info...
Model ID: LG-D160
IMEI: 352934-06-317832-5
Android version: 4.4.2
Battery level: 59%
Mode: Normal
Firmware compiled date: Apr 08 2014
Firmware released date: Apr 22 2016
Firmware released time: 16:59:30
SW Version: M8610B-AAAANAZM-1.0.6047
SPC: 000000
Unlocking...
Reading QCN...
Send SPC...OK
Reading EFS...OK
Reading QCN done!
Backup saved to "D160_352934063178325_30-09-2019_11-00-08.qcn"
Do you want to create security backup?
Backup saved to "D160_352934063178325_30-09-2019_11-07-50.SEC"
Found model WX_PROJE at port COM176
Rebooting phone...
Old 10-04-2019, 11:10   #6117 (permalink)
gunit1's Avatar
Member: 2041210
Thanks Meter: 489
flash LG D125 kz file conver & flash done
Old 10-09-2019, 14:39   #6118 (permalink)
GolfGSM's Avatar
Member: 2924041
Thanks Meter: 76
Selected port: COM1
Selected model: LS775
Reading info...
Waiting for phone...Failed!
Please, reconnect phone, enable USB debugging, and try again.
To enable USB debugging, please perform the following steps:
1. Disconnect cable
2. Install LG Android ADB drivers
3. Go to "Settings" -> "About phone" -> "Software information"
4. Click on Build number 5 times
5. Enable "Settings" -> "Developer options" -> "USB debugging" option
6. Connect the cable and check, whether ADB interface has appeared in PC Device Manager.
Checking data...OK
Selected port: COM118
Reading info...
IMEI: 356304-07-632527-9
Battery level: 77%
Mode: Normal
Firmware compiled date: Aug 01 2017
Firmware compiled time: 03:00:00
Firmware released date: Sep 13 2017
Firmware released time: 16:19:07
SW Version: MPSS.DPM.2.0.c11-00069-M8936FAAAANUZM-1.109817.1
SPC: 114525
MEID: 35630407632527
Mobile ESN: 809906AA
SSD_A: 0000000000000000
SSD_B: 0000000000000000
OTKSL: 218733
NAM Name: Sprint
User Lock Code: 2362
Trying second method...OK
Reading Carrier...OK
Unlocking...OK
Writing Carrier...OK
Old 10-11-2019, 10:15   #6119 (permalink)
..::GMSR::..'s Avatar
Member: 1444462
Thanks Meter: 477
Welcome to Octoplus/Octopus Box LG Software version 2.9.4
Checking data...OK
Selected port: COM781
Selected model: H815P
Reading info...
Model ID: LG-H815P
IMEI: 359871-06-458059-1
Android version: 5.1
Battery level: 9%
Mode: Emergency
Platform: msm8992
SW version: LGH815PAT-00-V10h-ZAF-XX-AUG-25-2015+0
LAF Version: 1.1
Product ID: BS01S151008000935
Target operator: GLOBAL
Hardware: rev_10
Opening "LGH815PAT-00-V20f-ZAF-XX-OCT-19-2016+0.kdz"...OK
Firmware version: LGH815AT-00-V10g-GLOBAL-COM-JUL-27-2015+0
Firmware model: LG-H815
Firmware type: 0100
To avoid errors in the flashing process, use a clean PC (without any
You should not run any other programs or attach new devices to your
Prepairing firmware...OK
Writing 1/68 PrimaryGPT_0.bin...OK
Writing 2/68 modem_32768.bin...OK
Writing 3/68 pmic_229376.bin...OK
Writing 4/68 sbl1_230400.bin...OK
Writing 5/68 tz_232448.bin...OK
Writing 6/68 sdi_234496.bin...OK
Writing 7/68 hyp_235520.bin...OK
Writing 8/68 rpm_236544.bin...OK
Writing 9/68 aboot_237568.bin...OK
Writing 10/68 sbl1bak_241664.bin...OK
Writing 11/68 pmicbak_243712.bin...OK
Writing 12/68 tzbak_244736.bin...OK
Writing 13/68 hypbak_246784.bin...OK
Writing 14/68 rpmbak_247808.bin...OK
Writing 15/68 abootbak_248832.bin...OK
Writing 16/68 sdibak_252928.bin...OK
Writing 17/68 persist_294912.bin...OK
Writing 18/68 sec_376832.bin...OK
Writing 20/68 laf_393216.bin...OK
Writing 21/68 boot_491520.bin...OK
Writing 22/68 recovery_573440.bin...OK
Writing 23/68 factory_753664.bin...OK
Writing 24/68 raw_resources_868352.bin...OK
Writing 25/68 raw_resourcesbak_876544.bin...OK
Writing 26/68 system_884736.bin...OK
Writing 27/68 system_1149000.bin...OK
Writing 28/68 system_1413056.bin...OK
Writing 29/68 system_1673288.bin...OK
Writing 30/68 system_1677320.bin...OK
Writing 31/68 system_1937344.bin...OK
Writing 32/68 system_2197576.bin...OK
Writing 33/68 system_2201608.bin...OK
Writing 34/68 system_2461632.bin...OK
Writing 35/68 system_2721864.bin...OK
Writing 36/68 system_2725896.bin...OK
Writing 37/68 system_2985920.bin...OK
Writing 38/68 system_3246152.bin...OK
Writing 39/68 system_3250184.bin...OK
Writing 40/68 system_3510208.bin...OK
Writing 41/68 system_3772352.bin...OK
Writing 42/68 system_4034496.bin...OK
Writing 43/68 system_4296640.bin...OK
Writing 44/68 system_4558784.bin...OK
Writing 45/68 system_4820928.bin...OK
Writing 46/68 system_5083072.bin...OK
Writing 47/68 system_5345216.bin...OK
Writing 48/68 system_5607360.bin...OK
Writing 49/68 system_5869504.bin...OK
Writing 50/68 system_6131648.bin...OK
Writing 51/68 system_6393792.bin...OK
Writing 52/68 system_6655936.bin...OK
Writing 53/68 system_6918080.bin...OK
Writing 54/68 system_7176192.bin...OK
Writing 55/68 system_7438336.bin...OK
Writing 56/68 system_7440456.bin...OK
Writing 57/68 system_7444488.bin...OK
Writing 58/68 system_7962624.bin...OK
Writing 59/68 system_7964744.bin...OK
Writing 60/68 system_7968776.bin...OK
Writing 61/68 system_8486912.bin...OK
Writing 62/68 system_8749056.bin...OK
Writing 63/68 system_9011200.bin...OK
Writing 64/68 system_9273344.bin...OK
Writing 65/68 system_9276408.bin...OK
Writing 66/68 cust_9363456.bin...OK
Writing 67/68 cust_9625600.bin...OK
Writing 68/68 BackupGPT_61070336.bin...OK
Formating RCT...OK
Formating MPT...OK
Finalizing...OK
Performed by 2.9.4 Software version.
Old 10-11-2019, 22:38   #6120 (permalink)
Member: 2636477
Thanks!
Nice!!! Thnaks for you report!
Post here successfully unlocked a2 phones 3lsheikh SETool2 10 03-04-2011 01:48
Successfully Unlock Z240 Phone Freeze jhepoy_org UST Pro II 13 12-02-2009 05:03
Successfully unlock BB5 phones with bb5king Mjabbar BB5KING 0 11-29-2008 13:13
Successfully unlock BB5 phones with bb5king Mjabbar BB5KING 2 11-26-2008 10:54
PB2 - Successfully unlocked LG phones CU/KU ... DOUHAL PolarBox 3 72 11-05-2008 17:21
Page generated in 0.57509 seconds with 9 queries
