Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Octopus/Octoplus > Octopus LG/Octoplus LG
Old 03-02-2011, 10:43   #1066 (permalink)
Member: 353717
Sonork: 1001647526
Thanks Meter: 147
KU 9300 unlock done
Log file "C:\Program Files\GsmServer\Octopus\LOG\02-03-2011_18-14-00.log" created.
3/2/2011 6:14:10 PM > Welcome to Octopus box software version 1.7.2
3/2/2011 6:14:25 PM > ----------------------------------------------------------------------------------
3/2/2011 6:14:25 PM > Platform: LG Qualcomm
3/2/2011 6:14:25 PM > Selected port: COM15
3/2/2011 6:14:25 PM > Selected model: KU9300
3/2/2011 6:14:25 PM > Mode: Normal
3/2/2011 6:14:25 PM > Phone model: KU930004
3/2/2011 6:14:25 PM > SW Version: M6280A-KLRZ-4.0.95T
3/2/2011 6:14:25 PM > IMEI: 352571-04-036799-1
3/2/2011 6:14:25 PM > Bluetooth address: 64:99:5D:16:E70
3/2/2011 6:14:25 PM > Firmware compiled date: Aug 14 2007
3/2/2011 6:14:25 PM > Firmware compiled time: 19:00:00
3/2/2011 6:14:25 PM > Firmware released date: May 24 2010
3/2/2011 6:14:25 PM > Firmware released time: 18:02:51
3/2/2011 6:14:33 PM > ----------------------------------------------------------------------------------
3/2/2011 6:14:33 PM > Platform: LG Qualcomm
3/2/2011 6:14:33 PM > Selected port: COM15
3/2/2011 6:14:33 PM > Selected model: KU9300
3/2/2011 6:14:33 PM > Mode: Normal
3/2/2011 6:14:33 PM > Phone model: KU930004
3/2/2011 6:14:33 PM > SW Version: M6280A-KLRZ-4.0.95T
3/2/2011 6:14:33 PM > IMEI: 352571-04-036799-1
3/2/2011 6:14:33 PM > Bluetooth address: 64:99:5D:16:E70
3/2/2011 6:14:35 PM > Prepairing loader...3/2/2011 6:14:39 PM > OK
3/2/2011 6:14:39 PM > Sending loader...3/2/2011 6:14:39 PM > OK
3/2/2011 6:14:39 PM > Searching signatures...
3/2/2011 6:14:39 PM > Signature #1...3/2/2011 6:14:39 PM > OK, not patched
3/2/2011 6:14:39 PM > Patching...
3/2/2011 6:14:39 PM > Signature #1...3/2/2011 6:14:41 PM > OK
3/2/2011 6:14:41 PM > Phone successfully unlocked!
3/2/2011 6:14:41 PM > Rebooting phone...
The Following 2 Users Say Thank You to sonhuong_dt For This Useful Post:
Old 03-02-2011, 13:18   #1067 (permalink)
champions1's Avatar
Member: 1157490
Sonork: 100.1638346
Thanks Meter: 74
lg kg 290 successfully unlocked
Platform: LG Analog Devices
Selected port: COM85
Selected baudrate: 921600
Selected model: KG290
Please reconnect battery...
Phone found.
Sending loader...OK
Reading info...
Flash ID: 8988
Flash type: Intel
IMEI: 357456-01-267280-7
Backuping Calibration data...OK
Unlocking...
Phone succesfully unlocked!
The Following 2 Users Say Thank You to champions1 For This Useful Post:
Old 03-04-2011, 13:41   #1068 (permalink)
manyosa's Avatar
Member: 271974
Thanks Meter: 97
KG800 Successfull unlocked
Selected port: COM13
Selected baudrate: 115200
Selected model: KG800
Please reconnect battery, press and hold power button...
Phone found.
Sending loader...OK
Reading info...
Flash ID: 9800
Flash type: Toshiba
IMEI: 359105-00-187517-2
Unlocking...
The Following 2 Users Say Thank You to manyosa For This Useful Post:
Old 03-04-2011, 19:12   #1069 (permalink)
unlockmachine44's Avatar
Member: 1350724
Thanks Meter: 168
LG GS290 UNLOCK SUCCESFULLY
Platform: LG Infineon
Selected port: COM8
Selected model: GS290
Detecting phone...
Detected phone in normal mode!
Trying to connect in flash mode..
Phone found.
Sending loader...OK
Reading info. Please wait...
IMEI: 354**********
Reading codes. Please wait...
Backup saved to
"GS290-354963045662377_04-03-2011_19-57-21.eep"
NCK : 1632 5500 6274 8906
NSCK : 4782 7523 9380 5139
SPCK : 3781 2255 3170 2387
CCK : 3568 5480 5952 5410
SIM : 2167 3867 0311 5730
MCC: 214 (Spain)
MNC: 01 (Vodafone)
To finish the operation, please perform the following steps:
1. Insert the original SIM card and type 2945#*290#
2. Go to menu>Settings>Security>SIMLOCK and enter the code.
The Following 2 Users Say Thank You to unlockmachine44 For This Useful Post:
Old 03-05-2011, 07:29   #1070 (permalink)
paffka's Avatar
Member: 212116
Thanks Meter: 177
LG P500 Optimus One has bees successfully flashed. Now it got Froyo 2.2.1
Welcome to Octopus box software version 1.7.5
Selected port: COM14
Selected model: P500
Mode: Normal
Phone model: P500
SW Version: P500-M76XX-V10d-OCT-25-2010-XX
IMEI: 35****-**-******-*
Bluetooth address: **:**:**:**:**:**
Firmware compiled date: Sep 02 2010
Firmware compiled time: 14:00:00
Firmware released date: Oct 25 2010
Firmware released time: 12:47:21
Mode: Normal
Phone model: P500
Opening "LGP500AT-00-V10f-CIS-XXX-DEC-16-2010.oct"...OK
Switching to Download mode...OK
Writing Firmware...
Please, make sure the phone's battery is fully charged.
Disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Qualcomm-based devices). You should not run any other programs or attach new devices to your computer during the flashing!
Please, follow these simple precautions to avoid damaging your phone.
Checking partition...OK
Writing AMSS...OK
Writing Boot image...OK
Writing System...OK
Writing Recovery image...OK
Writing Splash image...OK
Writing Firmware done!
To finish the operation please power on phone and wait 3 minutes
The Following 2 Users Say Thank You to paffka For This Useful Post:
Old 03-05-2011, 10:05   #1071 (permalink)
markrhoden's Avatar
Member: 981198
Sonork: 100.1602386
Thanks Meter: 120
Gu230 unlock by octopus box successfull
lg gu230 unlock procedure.............................
1, open octopus box software and select lg infineon(use AT106 Micro uart cable)
2, select gu230
3, tick connect then insert cable w/o battery
4, read codes then fallow instruction
5, put accepted simcard or test card then enter the codes
The Following 2 Users Say Thank You to markrhoden For This Useful Post:
Old 03-06-2011, 09:36   #1072 (permalink)
Member: 733209
Sonork: 1001620525
Thanks Meter: 426
GD570 flash + unlock OK
The Following 2 Users Say Thank You to hung phong For This Useful Post:
Old 03-07-2011, 05:59   #1073 (permalink)
Member: 1513696
Thanks Meter: 58
lg cyon direct unlock done kh1200
Selected port: COM3
Selected model: KH1200
Phone not detected. Please try again.
Selected port: COM3
Mode: Normal
Phone model: KW120605
SW Version: KH1200-M6250D-V10b-FEB-02-2007-KKR
IMEI: 354207-01-000730-3
Bluetooth address: 00:19:A1:83:F1:F2
Firmware compiled date: Aug 14 2006
Firmware compiled time: 11:00:00
Firmware released date: Feb 02 2007
Firmware released time: 10:13:51
Selected port: COM3
Mode: Normal
Sending loader...OK
Switching to test mode...
Wait phone startup...OK
Signature #1...OK, not patched
Patching...
Signature #1...OK
Rebooting phone...
tnx octupus team...
The Following 2 Users Say Thank You to chongskie7 For This Useful Post:
Old 03-07-2011, 08:11   #1074 (permalink)
Member: 853601
Thanks Meter: 233
Lg cyon kh3900 security code enable done
PROBLEM: CANNOT OPEN SOME APPLICATION BECAUSE SECURITY CODE ENABLE
SOLUTION: FLASHING/REPROGRAM
PROCEDURES:
1. USB METHOD (USE SEARCH BUTTON)
2. BROWSE UNCLE GOOGLE
3. REPROGRAM
4. UNLOCKED
NOTE: CANNOT RESET VIA FACTORY DUE TO NOT YET SUPPORTED BY ANY GADGETS, ONLY REPROGRAM OR FLASHING WITH FIRMWARE IS THE BEST SOLUTION AS OF NOW
DOWNLOAD FIRST FW AT SUPPORT
Selected port: COM18
Selected model: KH3900
Selected port: COM28
Mode: Normal
Phone model: KW390007
SW Version: M6290A-KPRZL-2.4.013511
IMEI: 359846-03-103524-2
Bluetooth address: 8C:54:1D:D9:8A:AF
Firmware compiled date: Dec 29 2009
Firmware compiled time: 16:00:00
Firmware released date: Apr 15 2010
Firmware released time: 11:23:00
Mode: Normal
Repairing NVM...
Repairing NVM complete.
Rebooting phone...
Mode: Normal
Bluetooth address: 64:99:5D:20:D3:F3
Opening "KW390007_00.oct"...OK
Reading NVM...
Reading NVM done!
Backup saved to "KH3900-35984603103delro_07-03-2011_15-39-24.nvm"
Writing Firmware...
Erasing EFS...OK
Writing MIBIB...OK
Writing QCSBL...OK
Writing OEMSBL1...OK
Writing OEMSBL2...OK
Writing AMSS...OK
Writing LGEFAT...OK
Writing EFS2...OK
Phone startup...OK
Writing NVM...
Writing NVM done!
Rebooting phone...
Mode: Normal
IMEI: 359846-03-delro-2
Sending loader...OK
Patching...
Signature #1...OK
Rebooting phone...
The Following 4 Users Say Thank You to DELRO For This Useful Post:
Old 03-07-2011, 14:52   #1075 (permalink)
Member: 370221
Sonork: 1592059
Thanks Meter: 97
Bienvenido en Octopus box software version 1.7.5
Plataforma: LG Infineon
Puerto seleccionado: COM3
Velocidad seleccionada: 115200
Modelo seleccionado: GD510
Por favor vuelva a conectar la batería, pulse y mantenga el botón de
encendido...
Teléfono encontrado.
Suelte el botón de encendido.
Enviando el cargador...OK
Lectura de la información. Por favor, espere...
IMEI: 08-8
Lectura de códigos. Por favor, espere...
Backup reservado en
"GD510_08-03-2011_11-39-13.eep"
NCK : 9540 3912 4315 3823
NSCK : 1923 8988 0267 2997
SPCK : 5371 9911 7196 6851
CCK : 0689 9578 5363 6575
SIM : 6430 8465 9326 2591
MCC: 730 (Chile)
MNC: 01 (Entel Telefonia Movil)
1. Insert the original SIM card and type 2945#*510#
First I conect the phone on and dowload the LG pc suite, because the computer don´t recognize the phone, then I conect and enjoy.
Regards from Chile
The Following 3 Users Say Thank You to crstelefonia For This Useful Post:
Old 03-08-2011, 12:33   #1076 (permalink)
Member: 733835
Thanks Meter: 16
lg p500 unlock ok witth octopus
Welcome to Octopus box software version 1.6.9
Selected port: COM246
Phone model: P500
Mode: Emergency
Opening "Please, select firmware file"...
File does not exists!
Phone model: P500
Mode: Emergency
Opening "LGP500-FOR-UNLOCK.oct"...OK
Writing Firmware...
flashing!
phone.
Writing AMSS...OK
Writing System...OK
Selected port: COM243
Mode: Normal
Phone model: P500
SW Version: P500-M76XX-V10b-OCT-01-2010-XX
IMEI: 354043-04-028056-4
Bluetooth address: 64:99:5D:C4:BC:F0
Firmware released date: Oct 1 2010
Firmware released time: 19:11:06
Mode: Normal
Phone model: P500
Unlocking...
Reading security area...
Backup saved to "P500-354043040280564_08-03-2011_13-36-
26.sec"
Writing security area...OK
Rebooting phone...
The Following 3 Users Say Thank You to abdou-ess For This Useful Post:
Old 03-08-2011, 14:25   #1077 (permalink)
Member: 370221
Sonork: 1592059
Thanks Meter: 97
Plataforma: LG Analog Devices
Velocidad seleccionada: 921600
Modelo seleccionado: GM205
Por favor vuelva a conectar la batería...
Desconectado.
Lectura de la información...
Flash ID: 8988
Tipo de Flash: Intel
IMEI:
Creando copia de seguridad EEPROM...OK
Backup reservado en
"GM205-09-03-2011_11-19-34"
Lectura de la zona de seguridad...OK
Escritura de la zona de seguridad...OK
Desconectado.
The Following 2 Users Say Thank You to crstelefonia For This Useful Post:
Old 03-09-2011, 05:12   #1078 (permalink)
Member: 737818
Thanks Meter: 216
C900 lg windows mobile successfully unlocked...world first!!!
Procedure:
cable used: USB cable(like nokia 5310)
1. Disconnect cable and power phone on
2. In call window input ##634# and click "call" button. After this in list
of application will be avaliable "MFG" application
3. Execute MFG and input password 277634#*# - You will enter into
Engineer menu
4. Go to Engineer menu -> Port settings -> USB switching and select
"QC COMPOSITE"
5. After rebooting, connect cable, install drivers and repeat the
operation
-then press space button and power button together then insert usb then press "UNLOCK BUTTON"
The Following 5 Users Say Thank You to johnric For This Useful Post:
Old 03-09-2011, 05:24   #1079 (permalink)
Member: 737818
Thanks Meter: 216
GU290f lg unlock successfully.....world first again!!
procedure;
cable used: usb cable(like 5310)
-power on the phone
-read info
-press unlock button
The Following 4 Users Say Thank You to johnric For This Useful Post:
Old 03-09-2011, 06:07   #1080 (permalink)
Crazy Poster
Member: 454067
Thanks Meter: 48
LG900GB convert to GW300 Done by Octopus
Tools:
- Octopus Box
- micro usb cable
Procedure:
- open octopus software
- insert usb cable to phone w/out battery
- install usb driver
- select GW300 firmware
- tick write firmware
- wait till finished
- tick read codes
- type 2945#*71001#
- Enter Unlock codes
- Done
Selected port: USB
Selected model: GW300
Disconnect battery and connect USB cable to phone...
Phone found.
Sending preloader...OK
Reconnecting phone...OK
Sending first loader...OK
Sending second loader...OK
Flash ID: ECB1
Flash type: Samsung
Reading info. Please wait...OK
IMEI: 0121xxxxxxxxxxxx
Opening "GW300AT-00-V10a-206-01-SEP-02-2009+1.oct"...OK
Writing Total BIN...
Repair mode: No
Writing Firmware...
Reading codes. Please wait...OK
Unlock code: 7213 3379 2289 7688
1. Insert the original SIM card and type 2945#*71001#
2. Enter the code.
The Following 5 Users Say Thank You to snot522 For This Useful Post:
Post here successfully unlocked a2 phones 3lsheikh SETool2 10 03-04-2011 01:48
Successfully Unlock Z240 Phone Freeze jhepoy_org UST Pro II 13 12-02-2009 05:03
Successfully unlock BB5 phones with bb5king Mjabbar BB5KING 0 11-29-2008 13:13
Successfully unlock BB5 phones with bb5king Mjabbar BB5KING 2 11-26-2008 10:54
PB2 - Successfully unlocked LG phones CU/KU ... DOUHAL PolarBox 3 72 11-05-2008 17:21
Page generated in 0.59163 seconds with 9 queries
