07-17-2012, 11:46 | #1 (permalink) |
No Life Poster Join Date: May 2009 Location: Srilanka
Member: 1026122 Status: Offline Sonork: 100.1640842 Thanks Meter: 184 | LG KM900 flashing failed....please fix this problem... [Solved] My phone is not power on....always restart...So I try to flash the set.. I use USB and RJ45... also use the following files KM900AT-00-V10b-202-01-MAY-07-2009+0.oct KM900AT-00-V10f-ARB-XXX-JUN-12-2009+0.oct KM900AT-00-V10m-EUR-XXX-APR-27-2009+2.oct KM900AT-00-V10m-EUR-XXX-APR-27-2009+2 LOGS USB Welcome to Octopus Box LG Software version 2.1.4 -------------------------------------------------------------------------------- Platform: LG Infineon Selected port: USB Selected model: KM900 Disconnect battery and connect USB cable to phone... Reading info. Please wait... IMEI: 357366-03-037837-0 Opening "KM900AT-00-V10m-EUR-XXX-APR-27-2009+2.oct"...7/17/2012 OK Will be written 11 zone(s) Writing Firmware... Sending certificate...7/17/2012 12:46:32 AM > OK Writing "psi_large_block_16_bit_paging.flb"...7/17/2012 12:46:32 AM > OK Sending certificate...7/17/2012 12:46:36 AM > OK Writing "slb_large_block_16_bit_paging.flb"...7/17/2012 12:46:37 AM > OK Sending certificate...7/17/2012 12:46:45 AM > OK Writing "MPEH_OPERA_EUROPE_OPEN.fls"...7/17/2012 12:47:11 AM > OK Writing "MPEH_OPERA_EUROPE_OPEN.fls"...7/17/2012 12:47:41 AM > OK Sending certificate...7/17/2012 12:47:45 AM > OK Writing "MPEH_OPERA_EUROPE_OPEN.eep"...7/17/2012 12:47:45 AM > OK Sending certificate...7/17/2012 12:47:49 AM > OK Writing "MPEH_OPERA_EUROPE_OPEN.dsp"...7/17/2012 12:47:50 AM > OK Sending certificate...7/17/2012 12:47:53 AM > OK Writing "ua_large_block_16_bit_paging.flb"...7/17/2012 12:47:54 AM > OK Sending certificate...7/17/2012 12:48:02 AM > OK Writing "OPERA_EUROPE_OPEN-ROOT.dfat"...7/17/2012 12:48:19 AM > OK Sending certificate...7/17/2012 12:48:23 AM > OK Writing "OPERA_EUROPE_OPEN-CUST.dfat"...7/17/2012 12:51:19 AM > OK Sending certificate...7/17/2012 12:51:23 AM > OK Writing "OPERA_EUROPE_OPEN-USER.dfat"...7/17/2012 12:51:23 AM > OK Sending certificate...7/17/2012 12:51:27 AM > OK Writing "a250_single_image.fls"... Error of writing block! Disconnected. RJ45 Welcome to Octopus Box LG Software version 2.1.4 -------------------------------------------------------------------------------- Platform: LG Infineon Selected port: COM6 Selected baudrate: 921600 Selected model: KM900 Please reconnect battery, press and hold power button... Phone found. Release power button. Sending loader...OK Reading info. Please wait... IMEI: 357366-03-037837-0 Please select Fiwmware file! Opening "KM900AT-00-V10m-EUR-XXX-APR-27-2009+2.oct"...OK Will be written 11 zone(s) Writing Firmware... Sending certificate...OK Writing "psi_large_block_16_bit_paging.flb"...OK Sending certificate...OK Writing "slb_large_block_16_bit_paging.flb"...OK Sending certificate...OK Writing "MPEH_OPERA_EUROPE_OPEN.fls"...OK Writing "MPEH_OPERA_EUROPE_OPEN.fls"...OK Sending certificate...OK Writing "MPEH_OPERA_EUROPE_OPEN.eep"...OK Sending certificate...OK Writing "MPEH_OPERA_EUROPE_OPEN.dsp"...OK Sending certificate...OK Writing "ua_large_block_16_bit_paging.flb"...OK Sending certificate...OK Writing "OPERA_EUROPE_OPEN-ROOT.dfat"...OK Sending certificate...OK Writing "OPERA_EUROPE_OPEN-CUST.dfat"...OK Sending certificate...OK Writing "OPERA_EUROPE_OPEN-USER.dfat"...OK Sending certificate... Error of changing certificate! Disconnected. It is not the hardware problem..100% software problem.. Now the condition of the phone is dead...But I can connect it via RJ-45 or USB... There are so many users report this problem...So Please fix this.. Thanks. Last edited by Octopus box; 07-23-2012 at 13:09. |
07-17-2012, 12:41 | #2 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,380 | Hello. What was the firmware version exactly in the phone before You have tried to write wirmare? Please try to write firmware again, a few times. If the problem will be in the same place - most likely this is HW problem. Quote:
07-17-2012, 13:12 | #3 (permalink) | ||
Member: 1026122 Status: Offline Sonork: 100.1640842 Thanks Meter: 184 | Quote:
Also Quote:
You advice for many users as hardware problem... But this is not hardware problem 100%. it is software...Please give any solution for this. | ||
07-17-2012, 13:21 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,380 | Please write firmware using original LG flasher and post here the result. Look for original firmware and flasher in LG section on this forum. |
07-20-2012, 14:53 | #9 (permalink) |
Member: 1026122 Status: Offline Sonork: 100.1640842 Thanks Meter: 184 | Failed Bro..Please check Uploaded with ImageShack.us Uploaded with ImageShack.us May be need to flash the higher version.? Thanks. |
07-20-2012, 15:44 | #11 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,380 | Check Your PM for another firmware. If the problem will be the same - most likely, as I have said, this is HW problem. |
07-23-2012, 10:22 | #15 (permalink) |
Member: 1026122 Status: Offline Sonork: 100.1640842 Thanks Meter: 184 | Dear Bro.. As you told me ....100% right...It is hardware ..not the software... When I check the board..I did not touch the any IC or chips...Insded I clean the board using thinner and give the time to try the board And try to flash using the original flasher with last file you pm me.But I failed on 10/10 27% which last time even did not start 1% on 10/10...So I tried on Octopus with the file of KM900AT-00-V10m-EUR-XXX-APR-27-2009+... Ohhhh??.. I success with the great Octopus Box which gave the live to my km900 set. here is the log.. Welcome to Octopus Box LG Software version 2.1.4 -------------------------------------------------------------------------------- Platform: LG Infineon Selected port: COM6 Selected baudrate: 921600 Selected model: KM900 Please reconnect battery, press and hold power button...Canceled! Disconnected. -------------------------------------------------------------------------------- Platform: LG Infineon Selected port: USB Selected model: KM900 Disconnect battery and connect USB cable to phone... Reading info. Please wait... IMEI: 357366-03-037837-0 Opening "KM900AT-00-V10m-EUR-XXX-APR-27-2009+ 2.oct"...OK Will be written 11 zone(s) Writing Firmware... Sending certificate...OK Writing "psi_large_block_16_bit_paging.flb"...OK Sending certificate...OK Writing "slb_large_block_16_bit_paging.flb"...OK Sending certificate...OK Writing "MPEH_OPERA_EUROPE_OPEN.fls"...OK Writing "MPEH_OPERA_EUROPE_OPEN.fls"...OK Sending certificate...OK Writing "MPEH_OPERA_EUROPE_OPEN.eep"...OK Sending certificate...OK Writing "MPEH_OPERA_EUROPE_OPEN.dsp"...OK Sending certificate...OK Writing "ua_large_block_16_bit_paging.flb"...OK Sending certificate...OK Writing "OPERA_EUROPE_OPEN-ROOT.dfat"...OK Sending certificate...OK Writing "OPERA_EUROPE_OPEN-CUST.dfat"...OK Sending certificate...OK Writing "OPERA_EUROPE_OPEN-USER.dfat"...OK Sending certificate...OK Writing "a250_single_image.fls"...OK Writing Firmware done! Disconnected. Now I have the fully working set. Thanks for the great hardworking Team. |
"Deskey Device driver not found" ?? Please help | DivAdonis | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-08-2017 13:21 |
5110 flash new software , need help | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 01-03-2015 05:41 |
