06-23-2012, 19:10 | #1 (permalink) |
Freak Poster Join Date: Sep 2006 Location: Trust unlocking
Member: 348518 Status: Offline Sonork: 100.1666935 Thanks Meter: 107 | help gt-540 write AMSS failed.. [Solved] help gt-540 write AMSS failed.. Last edited by Octopus box; 12-24-2012 at 08:09. |
06-25-2012, 05:55 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Hello. Please perform the next steps: 1. Put the phone into Emergency Mode manually (disconnect the cable, reconnect the battery, press and hold "Vol-" + "Vol+" + "Power ON" keys and connect USB cable). 2. Select firmware "GT540AT-00-V20b-EUR-XX-DEC-16-2010+0". 3. Select (check) "Write boot loaders" option. 4. Press "Write firmware" button. Note: if there will occurs an error during process of writing firmware, You mandatory should reconnect the battery and put the phone into Emergency Mode manually and repeat the procedure of writing firmware again! Otherwise, phone's boot can be damage! Please uninstall all BB software, modem dashboard software and PC Suite software. Also please don't use USB hubs or PCI USB ports, You need to use motherboard USB ports only! Also please, make sure the phone's battery is fully charged. Disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Qualcomm-based devices). You should not run any other programs or attach new devices to your computer during the flashing! Please, follow these simple precautions to avoid damaging your phone. |
12-22-2012, 17:56 | #3 (permalink) |
Freak Poster Join Date: May 2007 Location: Brazil Age: 45
Member: 508457 Status: Offline Sonork: 100.1602732 Thanks Meter: 59 | sucess , repair boot with jtag medusa, flash with octopus. tks team gsmserver. |
The Following User Says Thank You to andrericardo For This Useful Post: |
