11-12-2018, 18:03 | #1 (permalink) |
Freak Poster Join Date: Jul 2012 Location: brazil
Member: 1789551 Status: Offline Thanks Meter: 90 | M250ds AT-00-V10f FRP problem [Solved] -------------------------------------------------------------------------------- Checking data...OK Plataforma: LG MTK Porto selecionado: COM14 Velocidade selecionada: 0 Modelo selecionado: M250DS Selected USB connection type Please, disconnect cable, reconnect battery, connect P999 cable (with 910k resistor) or Reconnect battery, press and hold "Vol+" for 10 seconds and connect Micro USB cable. Phone found at port COM16 Mode: Emergency Initializing flash...OK Model ID: LG-M250ds Versao de SW: LGM250dsAT-00-V10f-BRA-XXX-AUG-23-2018+0 LAF Version: 1.1 Product ID: BR11S170530003048 IMEI: Target operator: GLOBAL Hardware: rev_10 Battery level: 50% Reading partitions...OK Checking security... Checking security passed! -------------------------------------------------------------------------------- IMEI A: 359173-08-402325-0 IMEI B: 359173-08-402326-8 Endereco de Bluetooth: A8:B8:6E:B8:9D:70 Wi-Fi MAC address: 04:1B:6D:AE:2D:15 SPC: 000000 -------------------------------------------------------------------------------- Detecting writing method... LAF Error: 80000121. Trying second method... Trying third method...OK Reset FRP operation for M250DS will delete all user data on the phone (contacts, pictures and others)! Do You want to continue? Resetting FRP Lock... Escrevendo loader...OK Escrevendo userdata...Error! Restoring loader...OK Rebooting phone... Performed by 2.8.1 Software version. -------------------------------------------------------------------------------- Checking data...OK Plataforma: LG MTK Porto selecionado: COM14 Velocidade selecionada: 0 Modelo selecionado: M250DS Selected USB connection type Please, disconnect cable, reconnect battery, connect P999 cable (with 910k resistor) or Reconnect battery, press and hold "Vol+" for 10 seconds and connect Micro USB cable. Phone found at port COM16 Mode: Emergency Initializing flash...OK Model ID: LG-M250ds Versao de SW: LGM250dsAT-00-V10f-BRA-XXX-AUG-23-2018+0 LAF Version: 1.1 Product ID: BR11S170530003048 IMEI: Target operator: GLOBAL Hardware: rev_10 Battery level: 50% Reading partitions...OK Checking security... Checking security passed! -------------------------------------------------------------------------------- IMEI A: 359173-08-402325-0 IMEI B: 359173-08-402326-8 Endereco de Bluetooth: A8:B8:6E:B8:9D:70 Wi-Fi MAC address: 04:1B:6D:AE:2D:15 SPC: 000000 -------------------------------------------------------------------------------- Detecting writing method... LAF Error: 80000121. Trying second method... Trying third method...OK Reset FRP operation for M250DS will delete all user data on the phone (contacts, pictures and others)! Do You want to continue? Resetting FRP Lock... Escrevendo loader...OK Escrevendo userdata...Error! Restoring loader...OK Rebooting phone... Performed by 2.8.1 Software version. Last edited by Octopus box; 11-12-2018 at 19:07. |
11-12-2018, 18:45 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | You use too old Software version. Please install the latest Software versin (https://octoplusbox.com/en/download/software/) and perform the operation again. Post here the result. |
11-12-2018, 18:45 | #3 (permalink) |
Member: 1789551 Status: Offline Thanks Meter: 90 | Bem-vindo em Octoplus/Octopus Box LG Software version 2.8.9.8 -------------------------------------------------------------------------------- Checking data...OK Plataforma: LG MTK Porto selecionado: COM15 Velocidade selecionada: 0 Modelo selecionado: M250DS Selected USB connection type Please, disconnect cable, reconnect battery, connect P999 cable (with 910k resistor) or Reconnect battery, press and hold "Vol+" for 10 seconds and connect Micro USB cable. Phone found at port COM16 Mode: Emergency Initializing flash...OK Model ID: LG-M250ds Plataforma: mt6750 Android version: 7.0 Versao de SW: LGM250dsAT-00-V10f-BRA-XXX-AUG-23-2018+0 LAF Version: 1.1 Product ID: BR11S170530003048 IMEI: Target operator: GLOBAL Hardware: rev_10 Battery level: 50% Reading partitions...OKOK Checking security... Checking security passed! -------------------------------------------------------------------------------- IMEI A: 359173-08-402325-0 IMEI B: 359173-08-402326-8 Endereco de Bluetooth: A8:B8:6E:B8:9D:70 Wi-Fi MAC address: 04:1B:6D:AE:2D:15 SPC: 000000 -------------------------------------------------------------------------------- Detecting writing method... LAF Error: 80000121. Trying second method... Trying third method...OK Reset FRP operation for M250DS will delete all user data on the phone (contacts, pictures and others)! Do You want to continue? Resetting FRP Lock... Escrevendo loader...OK Escrevendo userdata...OK Formating encrypt...OK Restoring loader...OK Resetting FRP lock successfully completed! Rebooting phone... To complete the operation, please make Factory Reset (Go to "Settings" -> "General" -> "Backup & reset" -> "Factory data reset", press "Reset phone" and "Erase everything" buttons). Performed by 2.8.9.8 Software version. Problem was solved! |
