GSM-Forum (https://forum.gsmhosting.com/vbb/)
-   Octopus LG/Octoplus LG (https://forum.gsmhosting.com/vbb/f799/)
-   -   v520 frp remove Error [Solved] (https://forum.gsmhosting.com/vbb/f799/v520-frp-remove-error-solved-2235832/)
pak555 06-19-2017 11:37
Welcome to Octoplus/Octopus Box LG Software version 2.6.8
Checking data...OK
Platform: LG Qualcomm
Selected port: COM45
Selected model: V520
Please, put the phone into download mode manually (Power phone OFF
(reconnect battery), press and hold "Vol+" button and connect the cable
(or P999 cable)).
Reading info...
Model ID: LG-V520
IMEI: 356285-07-096758-0
Android version: 7.0
Battery level: 8%
SW Version: V52020f
Mode: Emergency
Initializing flash...OK
SW version: LGV520AT-01-V20f-310-410-DEC-21-2016-ARB00+0
LAF Version: 1.1
Product ID: CW85S161011001685
Target operator: ATT
Hardware: rev_10
Reading partitions...OK
Resetting FRP Lock...Failed!
Error code: MNCAXCALSE
Performed by 2.6.8 Software version.
Octopus box 06-19-2017 12:28
Hello.
We have prepared test Software version for You. Please download and install it from the Support Area ("LG/TEST SOFTWARE" folder), then repeat "Reset FRP" operation again and post here the result.
pak555 06-19-2017 12:44
Checking data...OK
Selected port: COM37
(or P999 cable)).
Reading info...
Model ID: LG-V520
Battery level: 10%
SW Version: V52020f
Mode: Emergency
LAF Version: 1.1
Hardware: rev_10
Reset FRP operation for V520 will delete all user data on the phone
(contacts, pictures and others)!
Do You want to continue?
Writing loader...Failed!
Error code: A09ASDSDAX
Performed by 2.6.8.3 Software version.
Octopus box 06-19-2017 12:51
Please perform "Read Full Flash" operation (read at least 7-8 GB), pack it to ZIP or RAR, upload archive somewhere and send us link, we will research it and try to prepare test Software version for You.
pak555 06-20-2017 11:07
https://ufile.io/8lt0m
How much wait for this research???
Octopus box 06-20-2017 12:21
We can't say exactly how long it will take, we will research the file for the solution and write You the result.
rogeliomalpa 07-02-2017 07:30
Lg v520 frp failed
Are we going to have a LG V520 7.0 FRP solution any time soon guys?
It worked for 6.0.1 but not for 7.0
Checking data...OK
Selected port: COM56
Selected model: MS210
Please, put the phone into download mode manually (Power phone OFF (reconnect battery), press and hold "Vol+" button and connect the cable (or P999 cable)).
Reading info...
Model ID: LG-V520
Incompatible model ID!
IMEI: xxxxxxxxxxxxxxxx
Battery level: 39%
SW Version: V52020f
Mode: Emergency
LAF Version: 1.1
Product ID: CW85S160930003754
IMEI: xxxxxxxxxxxxxxxxxxx
Hardware: rev_10
Reset FRP operation for MS210 will delete all user data on the phone (contacts, pictures and others)!
Writing loader...OK
Writing userdata...Failed!
Restoring loader...OK
Rebooting phone...
Performed by 2.6.9 Software version.
Octopus box 07-03-2017 07:46
Hello.
We work on solution, as soon as solution will be ready, we will release it.
abufares 08-19-2017 02:23
Use V521 worked for me Thank you octoplus V520 on 7.0
ocarela 08-25-2017 17:03
How about V521 7.0 ?
Octopus box 08-26-2017 08:11
Operation should work for V521 with Android 7.0 as well. Use the latest Software version.
Fatalfury 11-05-2017 23:14
not working i keep getting this
Welcome to Octoplus/Octopus Box LG Software version 2.7.7
Checking data...OK
Selected port: COM57
Selected model: V521
Reading info...
Model ID: LG-V521
IMEI: 356286-07-318829-9
Battery level: 18%
SW Version: V52120f
Mode: Emergency
SW version: LGV521AT-01-V20f-310-260-DEC-09-2016-ARB01+0
LAF Version: 1.1
Product ID: CW85S161206004076
Target operator: TMO
Hardware: rev_10
Reset FRP operation for V521 will delete all user data on the phone (contacts, pictures and others)!
Canceled!
Performed by 2.7.7 Software version.
Checking data...OK
Reading info...
Model ID: LG-V521
Battery level: 18%
SW Version: V52120f
Mode: Emergency
LAF Version: 1.1
Hardware: rev_10
Writing loader...
Step 1...
Step 2...
Step 3...
Step 4...
Step 5...
Step 6...
Step 7...
Step 8...
Step 9...
Step 10...OK
Rebooting phone...
Checking data...OK
Reading info...
Model ID: LG-V521
Battery level: 26%
SW Version: V52120f
Mode: Emergency
LAF Version: 1.1
Hardware: rev_10
Reset FRP operation for V520 will delete all user data on the phone (contacts, pictures and others)!
Writing loader...
Step 1...
Step 2...
Step 3...
Step 4...
Step 5...
Step 6...
Step 7...
Step 8...
Step 9...
Step 10...OK
Rebooting phone...
samusprime 11-06-2017 00:05
Did you tried to flash before to do frp, that worked for me.
Fatalfury 11-06-2017 01:53
@samsusprime flash what ??? more details please
samusprime 11-07-2017 20:18
Try reflash with the same firmware, LGV521AT-01-V20f-310-260-DEC-09-2016-ARB01+0
Page generated in 0.18789 seconds with 6 queries
