06-19-2017, 11:37 | #1 (permalink) |
No Life Poster Join Date: Sep 2007 Location: Canada Toronto
Member: 593920 Status: Offline Sonork: XXXXXX Thanks Meter: 73 | v520 frp remove Error [Solved] -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM45 Selected model: V520 Please, put the phone into download mode manually (Power phone OFF (reconnect battery), press and hold "Vol+" button and connect the cable (or P999 cable)). Reading info... Model ID: LG-V520 IMEI: 356285-07-096758-0 Android version: 7.0 Battery level: 8% SW Version: V52020f Mode: Emergency Initializing flash...OK SW version: LGV520AT-01-V20f-310-410-DEC-21-2016-ARB00+0 Android version: 7.0 LAF Version: 1.1 Product ID: CW85S161011001685 IMEI: 356285-07-096758-0 Target operator: ATT Hardware: rev_10 Reading partitions...OK Resetting FRP Lock...Failed! Error code: MNCAXCALSE Performed by 2.6.8 Software version. Last edited by Octopus box; 06-20-2017 at 08:03. |
06-19-2017, 12:28 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. We have prepared test Software version for You. Please download and install it from the Support Area ("LG/TEST SOFTWARE" folder), then repeat "Reset FRP" operation again and post here the result. Last edited by Octopus box; 06-19-2017 at 12:41. |
06-19-2017, 12:44 | #3 (permalink) |
Member: 593920 Status: Offline Sonork: XXXXXX Thanks Meter: 73 | -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM37 Selected model: V520 Please, put the phone into download mode manually (Power phone OFF (reconnect battery), press and hold "Vol+" button and connect the cable (or P999 cable)). Reading info... Model ID: LG-V520 IMEI: 356285-07-096758-0 Android version: 7.0 Battery level: 10% SW Version: V52020f Mode: Emergency Initializing flash...OK SW version: LGV520AT-01-V20f-310-410-DEC-21-2016-ARB00+0 Android version: 7.0 LAF Version: 1.1 Product ID: CW85S161011001685 IMEI: 356285-07-096758-0 Target operator: ATT Hardware: rev_10 Reset FRP operation for V520 will delete all user data on the phone (contacts, pictures and others)! Do You want to continue? Reading partitions...OK Resetting FRP Lock... Writing loader...Failed! Error code: A09ASDSDAX Performed by 2.6.8.3 Software version. |
06-19-2017, 12:51 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Please perform "Read Full Flash" operation (read at least 7-8 GB), pack it to ZIP or RAR, upload archive somewhere and send us link, we will research it and try to prepare test Software version for You. Last edited by Octopus box; 06-19-2017 at 13:01. |
06-20-2017, 12:21 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | We can't say exactly how long it will take, we will research the file for the solution and write You the result. Last edited by Octopus box; 06-20-2017 at 13:27. |
07-02-2017, 07:30 | #7 (permalink) |
Freak Poster Join Date: May 2015 Location: Mexico
Member: 2398481 Status: Offline Thanks Meter: 16 | Lg v520 frp failed Are we going to have a LG V520 7.0 FRP solution any time soon guys? It worked for 6.0.1 but not for 7.0 Checking data...OK Platform: LG Qualcomm Selected port: COM56 Selected model: MS210 Please, put the phone into download mode manually (Power phone OFF (reconnect battery), press and hold "Vol+" button and connect the cable (or P999 cable)). Reading info... Model ID: LG-V520 Incompatible model ID! IMEI: xxxxxxxxxxxxxxxx Android version: 7.0 Battery level: 39% SW Version: V52020f Mode: Emergency Initializing flash...OK SW version: LGV520AT-01-V20f-310-410-DEC-21-2016-ARB00+0 Android version: 7.0 LAF Version: 1.1 Product ID: CW85S160930003754 IMEI: xxxxxxxxxxxxxxxxxxx Target operator: ATT Hardware: rev_10 Reset FRP operation for MS210 will delete all user data on the phone (contacts, pictures and others)! Do You want to continue? Reading partitions...OK Resetting FRP Lock... Writing loader...OK Writing userdata...Failed! Restoring loader...OK Rebooting phone... Performed by 2.6.9 Software version. |
07-03-2017, 07:46 | #8 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. We work on solution, as soon as solution will be ready, we will release it. Last edited by Octopus box; 11-06-2017 at 07:05. |
11-05-2017, 23:14 | #12 (permalink) |
Freak Poster Join Date: Jul 2008 Location: Redlands Ca Age: 49
Member: 810122 Status: Offline Thanks Meter: 65 | not working i keep getting this Welcome to Octoplus/Octopus Box LG Software version 2.7.7 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM57 Selected model: V521 Please, put the phone into download mode manually (Power phone OFF (reconnect battery), press and hold "Vol+" button and connect the cable (or P999 cable)). Reading info... Model ID: LG-V521 IMEI: 356286-07-318829-9 Android version: 7.0 Battery level: 18% SW Version: V52120f Mode: Emergency Initializing flash...OK SW version: LGV521AT-01-V20f-310-260-DEC-09-2016-ARB01+0 Android version: 7.0 LAF Version: 1.1 Product ID: CW85S161206004076 IMEI: 356286-07-318829-9 Target operator: TMO Hardware: rev_10 Reset FRP operation for V521 will delete all user data on the phone (contacts, pictures and others)! Do You want to continue? Canceled! Performed by 2.7.7 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM57 Selected model: V521 Please, put the phone into download mode manually (Power phone OFF (reconnect battery), press and hold "Vol+" button and connect the cable (or P999 cable)). Reading info... Model ID: LG-V521 IMEI: 356286-07-318829-9 Android version: 7.0 Battery level: 18% SW Version: V52120f Mode: Emergency Initializing flash...OK SW version: LGV521AT-01-V20f-310-260-DEC-09-2016-ARB01+0 Android version: 7.0 LAF Version: 1.1 Product ID: CW85S161206004076 IMEI: 356286-07-318829-9 Target operator: TMO Hardware: rev_10 Reset FRP operation for V521 will delete all user data on the phone (contacts, pictures and others)! Do You want to continue? Reading partitions...OK Resetting FRP Lock... Writing loader... Step 1... Step 2... Step 3... Step 4... Step 5... Step 6... Step 7... Step 8... Step 9... Step 10...OK Writing userdata...Failed! Restoring loader...OK Rebooting phone... Performed by 2.7.7 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM57 Selected model: V520 Please, put the phone into download mode manually (Power phone OFF (reconnect battery), press and hold "Vol+" button and connect the cable (or P999 cable)). Reading info... Model ID: LG-V521 IMEI: 356286-07-318829-9 Android version: 7.0 Battery level: 26% SW Version: V52120f Mode: Emergency Initializing flash...OK SW version: LGV521AT-01-V20f-310-260-DEC-09-2016-ARB01+0 Android version: 7.0 LAF Version: 1.1 Product ID: CW85S161206004076 IMEI: 356286-07-318829-9 Target operator: TMO Hardware: rev_10 Reset FRP operation for V520 will delete all user data on the phone (contacts, pictures and others)! Do You want to continue? Reading partitions...OK Resetting FRP Lock... Writing loader... Step 1... Step 2... Step 3... Step 4... Step 5... Step 6... Step 7... Step 8... Step 9... Step 10...OK Writing userdata...Failed! Restoring loader...OK Rebooting phone... Performed by 2.7.7 Software version. |
