08-19-2017, 16:22 | #1 (permalink) |
No Life Poster Join Date: Apr 2010 Location: NYC/USA
Member: 1283129 Status: Offline Thanks Meter: 135 | VS987 IMEI Repair question [Solved] Welcome to Octoplus/Octopus Box LG Software version 2.7.4 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM184 Selected model: VS987 Reading info... Model ID: VS987 IMEI: 000000-00-000000-0 Android version: 7.0 Battery level: 100% SW Version: VS98728B Mode: Normal Firmware compiled date: Feb 22 2017 Firmware compiled time: 23:00:00 Firmware released date: Apr 12 2017 Firmware released time: 17:06:43 SW Version: MPSS.TH.2.0.c1.4-00047-M8996FAAAANAZM-1.88674.1 Last edited by Octopus box; 03-01-2018 at 07:03. |
08-21-2017, 07:17 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,409 | Hello. Please, make sure that You perform all the steps, according to the Software manual: To connect the phone in Normal Mode, perform following steps: Type ##7764726987 and press "Call" button; Input Service Code ("000000"); Go to "W2BI - TEST SETTING" and select "W2BI SETTING ENABLE"; Go to "Port check test" and select "Enable". After repeat Repair IMEI operation again. Note: You can use Reset Security operation for resetting phone's security (when phone's Security Area is damaged, IMEI is 0000000000000000 or exist problems with repairing Security Area) to default state. After performing this operation, You should make Repair NVM, then Factory data reset and Repair IMEI. |
01-26-2018, 01:03 | #3 (permalink) |
Junior Member Join Date: Nov 2014 Location: Tampa,FL
Member: 2291138 Status: Offline Thanks Meter: 1 | I have the same problem. The octoplus software freezes after reading info and wont repair imei or wipe security. Welcome to Octoplus/Octopus Box LG Software version 2.7.8 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM13 Selected model: VS987 Reading info... Model ID: VS987 IMEI: 355858-07-595945-4 Android version: 7.0 Battery level: 80% SW Version: VS9872CA Mode: Normal Firmware compiled date: Nov 03 2017 Firmware compiled time: 00:00:00 Firmware released date: Nov 13 2017 Firmware released time: 10:07:24 SW Version: MPSS.TH.2.0.c1.4-00060-M8996FAAAANAZM-1.115439.1.120632.2 IMEI: 355858-07-595945-4 then it sits on that line for as long as you leave software open. Any ideas? Ive already tried the experimental 2.7.8.4 which produces the same issue. |
01-26-2018, 08:40 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,409 | Hello. How your device is detected by PC exactly? Please make photo of Windows Device Managers (with opened Modem section) with connected device and post it here, we will check, probably, You have not installed necessary driver correctly. |
