11-29-2018, 13:48 | #1 (permalink) |
Freak Poster Join Date: Feb 2013 Location: pak karachi sadar
Member: 1949466 Status: Offline Sonork: 100.1625935 Thanks Meter: 258 | VS988 8.0.0 t.p frp reset done QH mode only [Solved] Please select Reset FRP Method! Opening "H870_355273083776603_25-11-2018_03-27-12.oct"... Restore device from backup file? Please, connect the phone... Found port COM44 Connecting...OK Sending loader...OK Reconnecting phone...OK Checking request... Request has been successfully sent! Obtaining response...OK Reading partitions...OK Rebooting phone... Performed by 2.8.9 Software version. Last edited by Octopus box; 11-29-2018 at 17:58. |
11-29-2018, 13:50 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Hello. At first post here full Software log with that "Reset FRP" operation, we will check. Then, here is the latest Software version for You (https://drive.google.com/open?id=13u...R7IhULZUM_HqY4). Instal this Software version and repeat "Write Backup" operation. Then do "Reset FRP" again. Post here the result. |
11-29-2018, 14:53 | #3 (permalink) |
Member: 1949466 Status: Offline Sonork: 100.1625935 Thanks Meter: 258 | Welcome to Octoplus/Octopus Box LG Software version 2.9.0 Please, select Reset FRP Method! -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM44 Selected model: H870 Please, put the phone into download mode manually (Power phone OFF, press and hold "Vol+" button and connect the cable). Reading info... Could not detect mode! Performed by 2.9.0 Software version. Please, select Reset FRP Method! Opening "H870_355273083776603_25-11-2018_03-27-12.oct"... Restore device from backup file? Please, connect the phone... Found port COM44 Connecting...Failed! Performed by 2.9.0 Software version. Please, select Reset FRP Method! Opening "H870_355273083776603_25-11-2018_03-27-12.oct"... Restore device from backup file? Please, connect the phone... Found port COM44 Connecting...Failed! Performed by 2.9.0 Software version. Please, select Reset FRP Method! Opening "H870_355273083776603_25-11-2018_03-27-12.oct"... Restore device from backup file? Please, connect the phone... Found port COM44 Connecting...Failed! Performed by 2.9.0 Software version. Please, select Reset FRP Method! Opening "H870_355273083776603_25-11-2018_03-27-12.oct"... Restore device from backup file? Please, connect the phone... Found port COM44 Connecting...Failed! Performed by 2.9.0 Software version. Please, select Reset FRP Method! Opening "H870_355273083776603_25-11-2018_03-27-12.oct"... Restore device from backup file? Please, connect the phone... Found port COM44 Connecting...Failed! Performed by 2.9.0 Software version. Please, select Reset FRP Method! Opening "H870_355273083776603_25-11-2018_03-27-12.oct"... Restore device from backup file? Please, connect the phone... Found port COM44 Connecting...Failed! Performed by 2.9.0 Software version. Please, select Reset FRP Method! Opening "H870_355273083776603_25-11-2018_03-27-12.oct"... Restore device from backup file? Please, connect the phone... Found port COM44 Connecting...Failed! Performed by 2.9.0 Software version. Please, select Reset FRP Method! Opening "H870_355273083776603_25-11-2018_03-27-12.oct"... Restore device from backup file? Please, connect the phone... Found port COM44 Connecting...Failed! Performed by 2.9.0 Software version. Please, select Reset FRP Method! Opening "H870_355273083776603_25-11-2018_03-27-12.oct"... Restore device from backup file? Please, connect the phone... Found port COM44 Connecting...Failed! Performed by 2.9.0 Software version. Please, select Reset FRP Method! Opening "H870_355273083776603_25-11-2018_03-27-12.oct"... Restore device from backup file? Please, connect the phone... Found port COM44 Connecting...Failed! Performed by 2.9.0 Software version. Please, select Reset FRP Method! Opening "H870_355273083776603_25-11-2018_03-27-12.oct"... Restore device from backup file? Please, connect the phone... Found port COM44 Connecting...Failed! Performed by 2.9.0 Software version. Please, select Reset FRP Method! Opening "H870_355273083776603_25-11-2018_03-27-12.oct"... Restore device from backup file? Please, connect the phone... Found port COM44 Connecting...Failed! Performed by 2.9.0 Software version. Please, select Reset FRP Method! Opening "H870_355273083776603_25-11-2018_03-27-12.oct"... Restore device from backup file? Please, connect the phone... Found port COM44 Connecting...Failed! Performed by 2.9.0 Software version. Please, select Reset FRP Method! Opening "H870_355273083776603_25-11-2018_03-27-12.oct"... Restore device from backup file? Please, connect the phone... Found port COM44 Connecting...Failed! Performed by 2.9.0 Software version. Please, select Reset FRP Method! Opening "H870_355273083776603_25-11-2018_03-27-12.oct"... Restore device from backup file? Please, connect the phone... Found port COM44 Connecting...Failed! Performed by 2.9.0 Software version. Please, select Reset FRP Method! Opening "H870_355273083776603_25-11-2018_03-27-12.oct"... Restore device from backup file? Please, connect the phone... Found port COM44 Connecting...Failed! Performed by 2.9.0 Software version. Please, select Reset FRP Method! Opening "H870_355273083776603_25-11-2018_03-27-12.oct"... Restore device from backup file? Please, connect the phone... Found port COM44 Connecting...Failed! Performed by 2.9.0 Software version. Please, select Reset FRP Method! Opening "H870_355273083776603_25-11-2018_03-27-12.oct"... Restore device from backup file? Please, connect the phone... Found port COM44 Connecting...Failed! Performed by 2.9.0 Software version. Please, select Reset FRP Method! Opening "H870_355273083776603_25-11-2018_03-27-12.oct"... Restore device from backup file? Please, connect the phone... Found port COM44 Connecting...Failed! Performed by 2.9.0 Software version. Please, select Reset FRP Method! Opening "H870_355273083776603_25-11-2018_03-27-12.oct"... Restore device from backup file? Please, connect the phone... Found port COM44 Connecting...Failed! Performed by 2.9.0 Software version. Please, select Reset FRP Method! Opening "H870_355273083776603_25-11-2018_03-27-12.oct"... Restore device from backup file? Please, connect the phone... Found port COM1 Connecting...Failed! Performed by 2.9.0 Software version. Please, select Reset FRP Method! Opening "H870_355273083776603_25-11-2018_03-27-12.oct"... Restore device from backup file? Please, connect the phone... Found port COM1 Connecting...Failed! Performed by 2.9.0 Software version. Please, select Reset FRP Method! Opening "H870_355273083776603_25-11-2018_03-27-12.oct"... Restore device from backup file? Please, connect the phone... Found port COM1 Connecting...Failed! Performed by 2.9.0 Software version. Please, select Reset FRP Method! Opening "H870_355273083776603_25-11-2018_03-27-12.oct"... Restore device from backup file? Please, connect the phone... Found port COM44 Connecting...Failed! Performed by 2.9.0 Software version. |
11-29-2018, 16:03 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | You have written, that your device model is VS988, but as I see, try to connect as H870. You can find Software log here: C:\Program Files (x86)\Octoplus\Octoplus_Samsung\LOG folder. And try to re-connect the device (press and hold "Vol-" + "Vol+" + "Power on" keys during 20 seconds) and write backup agin. Try a few times. It is necessary to re-connect device before each attempt. Last edited by Octopus box; 11-29-2018 at 16:13. |
11-29-2018, 16:56 | #7 (permalink) |
Member: 1949466 Status: Offline Sonork: 100.1625935 Thanks Meter: 258 | Performed by 2.9.0 Software version. Please, select Reset FRP Method! Opening "H870_355273083776603_25-11-2018_03-27-12.oct"... Restore device from backup file? Please, connect the phone... Found port COM94 Connecting...OK Sending loader...OK Reconnecting phone...OK Checking request... Request has been successfully sent! Obtaining response...OK Reading partitions...OK Restoring BOOT...OK Rebooting phone... Performed by 2.9.0 Software version. write backup phone power on frp still lock |
11-29-2018, 17:10 | #8 (permalink) |
Member: 1949466 Status: Offline Sonork: 100.1625935 Thanks Meter: 258 | -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM84 Selected model: VS988 Please, put the phone into download mode manually (Power phone OFF, press and hold "Vol+" button and connect the cable). Reading info... Model ID: VS988 IMEI: 355273-08-377660-3 Android version: 8.0.0 Battery level: 4% SW Version: VS98820d Mode: Normal Switching to Download mode...OK Reading partitions... Initializing flash...OKOK Reading BOOT... ID: 0005F0E100310000 Operation is not safe and exist risk to damage the device! Do You want to continue?OK Backup saved to "VS988_355273083776603_29-11-2018_08-04-09.oct" Switching to Qualcomm 9008 mode... Found port COM94 Connecting...OK Sending loader...OK Reconnecting phone...OK Checking request... Request has been successfully sent! Obtaining response...OK Reading partitions...OK Restoring BOOT...OK Searching signatures... Step 1... Step 2... Step 3... Resetting FRP Lock...OK Resetting FRP lock successfully completed! Rebooting phone... Performed by 2.9.0 Software version. thank u Octopus box |
