07-06-2015, 09:11 | #1 (permalink) |
Freak Poster Join Date: May 2007
Member: 517349 Status: Offline Sonork: 100.1667865 Thanks Meter: 52 | want to repair imei of lgl23 [Solved] how sir even i cant connect the phone on usb mode plzz plzz team how i can repair thnx Last edited by Octopus box; 07-07-2015 at 10:39. |
07-06-2015, 10:03 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Hello. To perform "Repair IMEI" operation for LG L23 phone, do the next: 1. Remove SD and SIM cards from the phone; 2. Root device manually; 3. Connect powered-on phone to PC via Micro USB cable; 4. Install necessary driver; 5. Enter correct IMEI; 6. Click "IMEI fix" button; 7. Follow software instructions (prompts). Note: To connect the phone in Normal Mode, do the next: Go to "Settings -> PC connection -> USB connection type -> Select USB Connection method" and select "LG Software" ("PC Software"). |
07-06-2015, 14:31 | #3 (permalink) |
Member: 517349 Status: Offline Sonork: 100.1667865 Thanks Meter: 52 | Welcome to Octoplus/Octopus Box LG Software version 1.9.7 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM17 Selected model: L23 Reading info... Model ID: LGL23 IMEI: 358380-05-063655-8 Android version: 4.2.2 Battery level: 10% Trying to enable Diagnostics ports... Initializing ADB...OK Waiting for phone...OK Checking root access... Phone is not rooted. Please, root the phone manually! -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM17 Selected model: L23 Reading info... Could not detect mode! -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM17 Selected model: L23 Reading info... Model ID: LGL23 IMEI: 358380-05-063655-8 Android version: 4.2.2 Battery level: 11% Trying to enable Diagnostics ports... Initializing ADB...OK ADB Server was found. Trying to kill... Waiting for phone...OK Checking root access... Phone is already rooted. Diagnostics ports are enbled! Switching to Serial Port... Found model AAAAANAZ: ÿh°Á at port COM17 Fixing IMEI... New IMEI: 357632-03-120258-2 Reading QCN... Send SPC...OK Reading Mobile Property...OK Reading Feature Mask...OK Reading Roaming List 0...OK Reading NV_Numbered Items...OK Reading NV_Numbered SIM1 Items...OK Reading NV_Numbered SIM2 Items...OK Reading NV Items...OK Reading EFS...OK Reading Provisioning Items...OK Reading QCN done! Backup saved to "L23_358380050636558_06-07-2015_18-30-36.qcn" Switching to Download mode...OK Initializing flash...OK Reading partition...OK Reading security area...OK Backup saved to "L23_358380050636558_06-07-2015_18-44-57.SEC" Writing security area...OK Switching to Normal mode... Trying to enable Diagnostics ports... Initializing ADB...OK Waiting for phone...OK Checking root access... Phone is already rooted. Diagnostics ports are enbled! Switching to Serial Port... Found model AAAAANAZ* ÿh°¹ at port COM17 Send SPC...OK Writing QCN... Writing NV_Numbered Items...OK Writing NV_Numbered SIM1 Items...OK Writing NV_Numbered SIM2 Items...OK Writing QCN done! IMEI successfully fixed! To complete the operation, please make Factory Reset (Go to "Settings" -> "General" -> "Backup & reset" -> "Factory data reset", press "Reset phone" and "Erase everything" buttons). after fix imei there are no network only emergency what to do team thnx |
07-06-2015, 15:39 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Write backup of phone's original QCN back into the phone, restart the phone, wait 2-5 minutes, then try to find and select Network manually. |
