02-19-2017, 14:06 | #1 (permalink) |
Freak Poster Join Date: Aug 2009 Location: Algeria
Member: 1106514 Status: Offline Thanks Meter: 133 | why i could not flash my LG D821 by Octopus ? i tried to flash the LG D821 (16Gb) but there is a problem at the finally ! here is the log : Welcome to Octoplus/Octopus Box LG Software version 2.5.8 Checking data...OK Platform: LG Qualcomm Selected port: COM68 Selected model: D821 Reading info... Model ID: LGD821AT-0LGD821AT-00-V10d-NXS-XX-DEC-11 IMEI: 352136-06-797824-3 Android version: Battery level: 99% SW Version: LGD821AT-00-V10d-NXS-XX-DEC-11 Mode: Emergency Initializing flash...OK SW version: LGD821AT-00-V10d-NXS-XX-DEC-11-2013-KOT49H-USER- 16G+0 Android version: 6.0.1 LAF Version: 1.0 Product ID: HD60S140305003780 IMEI: 352136-06-797824-3 Target operator: ro.build.target_coun Hardware: rev_11 -------------------------------------------------------------------------------- Writing phone firmware without real necessity is at your own risk. Downgrade may lead to phone damage! Please, make sure the phone's battery is fully charged. Disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Qualcomm-based devices). You should not run any other programs or attach new devices to your computer during the flashing! -------------------------------------------------------------------------------- Opening "LGD821AT-00-V10f-NXS-XX-OCT-29-2013-KRT01B-FACTORY- 16G+0.oct"...OK Setting options...OK Reading partitions...OK Formating USERDATA...OK Writing PrimaryGPT...OK Writing modem...OK Writing sbl1...OK Writing rpm...OK Writing tz...OK Writing sdi...OK Writing aboot...OK Writing sbl1b...OK Writing tzb...OK Writing rpmb...OK Writing abootb...OK Writing persist...OK Writing imgdata...OK Writing laf...OK Writing boot...OK Writing recovery...OK Writing system...OK Writing cache...OK Writing BackupGPT...OK Reading partitions...OK Formating RCT...Failed! Formating MPT...Failed! Finalizing...Failed! Writing firmware done! Performed by 2.5.8 Software version. Last edited by Octopus box; 02-20-2017 at 09:01. |
02-20-2017, 09:07 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,409 | Hello. What is exact state of your phone? Why You have decided to re-flash it? |
02-20-2017, 09:58 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,409 | Try to write different firmwares. If the problem is the same, most likely device has HW issues. Also, You can try to write firmware using original flasher. |
02-20-2017, 10:12 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,409 | @soulay You can try to write firmware using original flasher Nexus Root Toolkit. If the problem is the same, check HW. Last edited by Octopus box; 02-20-2017 at 10:31. |
