11-09-2015, 11:38 | #5 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Please fully charge phone's battery and try to reflash the phone again. Try to use different USB ports for connection. If problem will remain the same - try to reflash the phone with original firmware and flashing tool. |
12-23-2015, 23:07 | #6 (permalink) |
Freak Poster Join Date: Jan 2007 Location: <Al hind al Garbiyya> Barbados
Member: 430155 Status: Offline Thanks Meter: 40 | -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM32 Selected model: D852 Reading info... Model ID: LG-D852 IMEI: 354608-06-360989-7 Android version: 5.0.1 Battery level: 45% Trying to enable Diagnostics ports... Initializing ADB...OK ADB Server was found. Trying to kill... Waiting for phone... Please, reconnect phone, enable USB debugging, and try again. To enable USB debugging, please perform the following steps: 1. Disconnect cable 2. Install LG Android ADB drivers 3. Go to "Settings" -> "About phone" -> "Software information" 4. Click on Build number 5 times 5. Enable "Settings" -> "Developer options" -> "USB debugging" option 6. Connect the cable and check, whether ADB interface has appeared in PC Device Manager. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM32 Selected model: D852 Reading info... Model ID: LG-D852 IMEI: 354608-06-360989-7 Android version: 5.0.1 Battery level: 45% Trying to enable Diagnostics ports... Initializing ADB...OK ADB Server was found. Trying to kill... Waiting for phone...Failed! Please, reconnect phone, enable USB debugging, and try again. To enable USB debugging, please perform the following steps: 1. Disconnect cable 2. Install LG Android ADB drivers 3. Go to "Settings" -> "About phone" -> "Software information" 4. Click on Build number 5 times 5. Enable "Settings" -> "Developer options" -> "USB debugging" option 6. Connect the cable and check, whether ADB interface has appeared in PC Device Manager. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM32 Selected model: D852 Reading info... Model ID: LG-D852 IMEI: 354608-06-360989-7 Android version: 5.0.1 Battery level: 46% Trying to enable Diagnostics ports... Initializing ADB...OK Waiting for phone...OK Diagnostics ports are enbled! Switching to Serial Port... Failed! Trying to enable Diagnostics ports... Initializing ADB...OK Waiting for phone...OK Checking root access... Initializing ADB...OK Waiting for phone...OK Phone is not rooted. Sending exploit...OKFailed! Port busy Failed! -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM3 Selected model: D852 Reading info...Failed! Port busy -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM32 Selected model: D852 Reading info... Model ID: LG-D852 IMEI: 354608-06-360989-7 Android version: 5.0.1 Battery level: 46% Mode: Normal Firmware compiled date: Jan 05 2015 Firmware compiled time: 01:00:00 Firmware released date: Aug 23 2015 Firmware released time: 11:33:42 SW Version: MPSS.DI.2.0.1.c1.13-00053-M8974AAAAANPZM-1 IMEI: 354608-06-360989-7 SPC: 000000 Unlocking... Reading QCN... Send SPC...OK Reading Mobile Property...OK Reading Feature Mask...OK Reading Roaming List 0...OK Reading NV_Numbered Items...OK Reading NV_Numbered SIM1 Items...OK Reading NV_Numbered SIM2 Items...OK Reading NV Items...OK Reading EFS...OK Reading Provisioning Items...OK Reading QCN done! Backup saved to "D852_354608063609897_23-12-2015_16-39-43.qcn" Switching to Download mode...OK Initializing flash...OK Reading partition...OK Reading security area...OK Backup saved to "D852_354608063609897_23-12-2015_16-57-52.SEC" Writing security area...OK Switching to Normal mode... Trying to enable Diagnostics ports... Initializing ADB...OK ADB Server was found. Trying to kill... Waiting for phone... Please, reconnect phone, enable USB debugging, and try again. To enable USB debugging, please perform the following steps: 1. Disconnect cable 2. Install LG Android ADB drivers 3. Go to "Settings" -> "About phone" -> "Software information" 4. Click on Build number 5 times 5. Enable "Settings" -> "Developer options" -> "USB debugging" option 6. Connect the cable and check, whether ADB interface has appeared in PC Device Manager.Failed! Please, reconnect phone, enable USB debugging, and try again. To enable USB debugging, please perform the following steps: 1. Disconnect cable 2. Install LG Android ADB drivers 3. Go to "Settings" -> "About phone" -> "Software information" 4. Click on Build number 5 times 5. Enable "Settings" -> "Developer options" -> "USB debugging" option 6. Connect the cable and check, whether ADB interface has appeared in PC Device Manager. Please perform the following steps: 1. Disconnect cable 2. Put phone into Normal mode manually 3. Press "Ok" button Trying to enable Diagnostics ports... Initializing ADB...OK ADB Server was found. Trying to kill... Waiting for phone... Please, reconnect phone, enable USB debugging, and try again. To enable USB debugging, please perform the following steps: 1. Disconnect cable 2. Install LG Android ADB drivers 3. Go to "Settings" -> "About phone" -> "Software information" 4. Click on Build number 5 times 5. Enable "Settings" -> "Developer options" -> "USB debugging" option 6. Connect the cable and check, whether ADB interface has appeared in PC Device Manager.OK Diagnostics ports are enbled! Switching to Serial Port... Found model D852 at port COM32 Send SPC...OK Writing QCN... Writing NV_Numbered Items...OK Writing NV_Numbered SIM1 Items...OK Writing NV_Numbered SIM2 Items...OK Writing QCN done! Phone successfully unlocked! To complete the operation, please make Factory Reset (Go to "Settings" -> "General" -> "Backup & reset" -> "Factory data reset", press "Reset phone" and "Erase everything" buttons). -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM13 Selected model: D852 Reading info... Model ID: LGMS500-00-MS50012b-TMO-US-MAR-24-20140 Incompatible model ID! Please, select correct model! -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM13 Selected model: MS500 Reading info... Model ID: LGMS500-00-MS50012b-TMO-US-MAR-24-20140 IMEI: Android version: Battery level: 48% Mode: Normal Firmware compiled date: Mar 24 2014 Firmware compiled time: 20:58:37 Firmware released date: Mar 24 2014 Firmware released time: 20:58:37 SW Version: LGMS500Z00 SPC: 000000 Unlocking... Initializing ADB...OK ADB Server was found. Trying to kill... Waiting for phone...Failed! Please, reconnect phone, enable USB debugging, and try again. To enable USB debugging, please perform the following steps: 1. Disconnect cable 2. Install LG Android ADB drivers 3. Enable "Settings" -> "Developer options" -> "USB debugging" option 4. Connect cable and check if ADB interface has appeared in PC Device Manager. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM13 Selected model: MS500 Reading info... Model ID: LGMS500-00-MS50012b-TMO-US-MAR-24-20140 IMEI: Android version: Battery level: 48% Mode: Normal Firmware compiled date: Mar 24 2014 Firmware compiled time: 20:58:37 Firmware released date: Mar 24 2014 Firmware released time: 20:58:37 SW Version: LGMS500Z00 SPC: 000000 Unlocking... Initializing ADB...OK Waiting for phone...OK Checking root access... Initializing ADB...OK Waiting for phone...OK Phone is already rooted. Reading QCN... Send SPC...OK Reading Mobile Property...OK Reading Feature Mask...OK Reading Roaming List 0...OK Reading NV_Numbered Items...OK Reading NV_Numbered SIM1 Items...OK Reading NV_Numbered SIM2 Items...OK Reading NV Items...OK Reading EFS...OK Reading Provisioning Items...OK Reading QCN done! Backup saved to "MS500_23-12-2015_17-36-49.qcn" Reading partition...OK Reading security area...OK Backup saved to "MS500_23-12-2015_17-49-15.SEC" Analyzing security...OK Rebooting phone... Found model LGMS500Z: ÿd at port COM13 Send SPC...OK Writing QCN... Writing EFS...OK Writing NV_Numbered Items...OK Writing NV_Numbered SIM1 Items...OK Writing NV_Numbered SIM2 Items...OK Writing Provisioning Items...OK Writing QCN done! Phone successfully unlocked! Rebooting phone... |
