04-16-2020, 03:19 | #1 (permalink) |
Insane Poster Join Date: Dec 2007 Location: MX-KEY is the BEST NOKIA TOOL
Member: 663671 Status: Offline Thanks Meter: 1 | x210ymw remove frp fail software shell this , but phone can't into download mode. https://*********/wJ18Qfu3HBw 1. Disconnect cable and power phone ON. 2. Complete all startup settings. 3. Power phone OFF and put it to Download mode. 4. Connect the cable then press "OK" butto Platform: LG Qualcomm Selected port: COM1163 Selected model: LMX210YMW Reading info... Model ID: LM-X210YMWX210YMW10c IMEI: 353453-09-068777-7 Android version: 7.1.2 Battery level: 86% Mode: Emergency Initializing flash...OK Platform: msm8909 SW version: LMX210YMWAT-00-V10c-AUS-XX-MAR-18-2019+0 Android version: 7.1.2 LAF Version: 1.1 Product ID: IMEI: 353453-09-068777-7 Target operator: LAO Hardware: rev_10 Performed by 3.0.1 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM1163 Selected model: LMX210YMW Please, put the phone into download mode manually (Power phone OFF (reconnect battery), press and hold "Vol+" button and connect the cable (or P999 cable)). Reading info... Model ID: LM-X210YMWX210YMW10c IMEI: 353453-09-068777-7 Android version: 7.1.2 Battery level: 86% Mode: Emergency Initializing flash...OK Platform: msm8909 SW version: LMX210YMWAT-00-V10c-AUS-XX-MAR-18-2019+0 Android version: 7.1.2 LAF Version: 1.1 Product ID: IMEI: 353453-09-068777-7 Target operator: LAO Hardware: rev_10 Reset FRP operation for LMX210YMW will delete all user data on the phone (contacts, pictures and others)! Do You want to continue? Reading partitions...OK Detecting writing method... Trying third method...Failed! Reading partitions...OK Detecting writing method... LAF Error: 80000121. Trying second method... Trying third method...Failed! Connecting to server...OK Octopus smart card is present. Checking smart card...OK Username: Authorizing...Failed! Performed by 3.0.1 Software version. -------------------------------------------------------------------------------- Connecting to server ...OK Username: gss202002020 Authorizing...OK Checking balance...OK Your balance: 400 credits. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM1163 Selected model: LMX210YMW Please, put the phone into download mode manually (Power phone OFF (reconnect battery), press and hold "Vol+" button and connect the cable (or P999 cable)). Reading info... Model ID: LM-X210YMWX210YMW10c IMEI: 353453-09-068777-7 Android version: 7.1.2 Battery level: 86% Mode: Emergency Initializing flash...OK Platform: msm8909 SW version: LMX210YMWAT-00-V10c-AUS-XX-MAR-18-2019+0 Android version: 7.1.2 LAF Version: 1.1 Product ID: IMEI: 353453-09-068777-7 Target operator: LAO Hardware: rev_10 Reset FRP operation for LMX210YMW will delete all user data on the phone (contacts, pictures and others)! Do You want to continue? Reading partitions...OK Detecting writing method... Trying third method...Failed! Reading partitions...OK Detecting writing method... LAF Error: 80000121. Trying second method... Trying third method...Failed! Connecting to server...OK Octopus smart card is present. Checking smart card...OK Username: gss202002020 Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Your balance: 400 credits. To perform "Reset FRP" operation you need to have 100 credits. Backup saved to "LMX210YMW_353453090687777_16-04-2020_ 14-31-54.oct" Removing write protection... Reconnecting phone... Please, perform the following steps: 1. Disconnect cable and power phone ON. 2. Complete all startup settings. 3. Power phone OFF and put it to Download mode. 4. Connect the cable then press "OK" button. Failed! Performed by 3.0.1 Software version. |
04-16-2020, 07:34 | #3 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Hello. Please, download and install the latest test Software version 3.0.1.02 from the Support Area and repeat Reset FRP operation again, after post here full Software log Last edited by Octopus support; 04-16-2020 at 08:00. |
