07-09-2018, 15:24 | #1 (permalink) |
No Life Poster Join Date: Dec 2006 Location: GSM WORLD
Member: 412843 Status: Offline Sonork: 100.1604902 Thanks Meter: 497 | X320S Flashing problem [Answered] Its Working Alive Fone Just Tried To Flash Due To Data Auto Enable Problem Code: Welcome to Octoplus/Octopus Box LG Software version 2.8.7 -------------------------------------------------------------------------------- Checking data...OK Platform: LG MTK Selected port: COM1 Selected baudrate: 921600 Selected model: X320S Selected USB connection type Please, disconnect cable, reconnect battery, connect P999 cable (with 910k resistor) or Reconnect battery, press and hold "Vol+" for 10 seconds and connect Micro USB cable. Phone found at port COM66 Mode: Emergency Initializing flash...OK Model ID: LGM-X320S Platform: mt6750 SW version: LGMX320SAT-00-V10p-SKT-KR-FEB-13-2018+0 LAF Version: 1.1 Product ID: CT64S17080500XXXX IMEI: Target operator: SKT Hardware: rev_10 Battery level: 50% Reading partitions...OK Checking security... Checking security passed! -------------------------------------------------------------------------------- IMEI: 357241-08-XXXXXX-X Wi-Fi MAC address: 88:36:5F:F5:D2:00 SPC: 000000 -------------------------------------------------------------------------------- Opening "X320S10P_00_0213.kdz"...OK Firmware version: X320S10p Firmware model: LGM-X320S Sending signature...OK Prepairing firmware...OK Setting options...OK Reading partitions...OK Formating USERDATA...OK Formating ENCRYPT...OK Writing 1/65 preloader_0.bin...OK Writing 2/65 pgpt_0.bin...OK Writing 3/65 lk_98304.bin...OK Writing 4/65 lk2_100352.bin...OK Writing 5/65 laf_102400.bin...OK Writing 6/65 boot_160768.bin...OK Writing 7/65 recovery_196608.bin...OK Writing 8/65 logo_274432.bin...OK Writing 9/65 lo_bak_go_290816.bin...OK Writing 10/65 secro_360448.bin...OK Writing 11/65 tee1_393216.bin...OK Writing 12/65 tee2_403456.bin...OK Writing 13/65 rct_507904.bin...OK Writing 14/65 factory_509952.bin...OK Writing 15/65 efuse_624640.bin...OK Writing 16/65 md1img_884736.bin...Failed! LAF Error: 00000000. Write Firmware operation is currently not supported for your phone's firmware. Error code: ZXLCALSZXC Performed by 2.8.7 Software version. Need Help Plz Thanks Anticipation Last edited by Octopus box; 07-09-2018 at 16:10. |
The Following User Says Thank You to shoaibrao For This Useful Post: |
07-09-2018, 16:09 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Hello. Fully charge device battery, put the device into Download (Emergency) Mode and try to res-flash the device again. |
07-10-2018, 09:12 | #4 (permalink) |
Member: 412843 Status: Offline Sonork: 100.1604902 Thanks Meter: 497 | Battery % Fone Powers On After Factory Reset Button But Flashing Not Completed Yet With Octopus Box |
07-10-2018, 09:32 | #5 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Most likely, the problem is with cable, which You use or with pUSB port, or device has some HW issues. If You can, try to use another cable, connect the device to another PC motherboard USB port (don't use USB hubs, this is important) and try to write firmware again. Post the result. Last edited by Octopus box; 07-10-2018 at 09:43. |
07-10-2018, 09:41 | #6 (permalink) | |
Member: 412843 Status: Offline Sonork: 100.1604902 Thanks Meter: 497 | Quote:
On Three Different Ports But Same With Other Tool Selecting Diffident Model Flashing Completed But After Flash Stuck On Logo | |
07-11-2018, 08:14 | #7 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Check HW, most likely device has HW problem(s). |
