Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung CDMA
Old 06-20-2015, 02:52   #31 (permalink)
Member: 2413077
First, thanks to AlpineMan (and ecs87) for keeping this topic going! I'm still using my Sprint S4 on an old plan, and it's working well. Recently, I got a phone notification for a Samsung Software Update to "Android v5.0 Lollipop OS." Is it ok to perform this update without messing anything up? I'm currently on Android v 4.4.2 KitKat. Thanks.
Old 06-20-2015, 14:04   #32 (permalink)
Member: 2076039
Thanks Meter: 648
You should be fine. If anything happens you can always update the profile afterwards and itll fix anything that changed (nothing should change).
Old 06-22-2015, 21:39   #33 (permalink)
Member: 554699
Thanks Meter: 52
I guess with this brute force technique and auto generating associated profile 1 info, all you need is a single donor just to pull keys with. This technique can be applied not just on Samsung phones, but any phone in general...as long as you have a method of flashing/setting up profile 1 info, you'll have a fully flashed phone.
The Following User Says Thank You to AlpineMan For This Useful Post:
Old 06-23-2015, 02:51   #34 (permalink)
Member: 2146354
Thanks Meter: 21
pulling aaa keys from s3
Hey guys. Im an experienced flasher. The problem Im having is pulling the aaa keys on profile 1 from a s3. I have both cdma workshop and dfs. I keep getting access denied problem. any help?
THANK YOU!!
Old 06-23-2015, 18:53   #35 (permalink)
Member: 2146354
Thanks Meter: 21
Also the aaa key for profile 0 ( or hdr an long ) is generated by the akey and the esn. If you have the akey to that esn when you do ##RTN# it will calculate the correct 32 bit hdr long an.
I have experimented on a seek to confirm. If you write a new meid on a m350(A) from another m350(B) and do ##786# it will generate the wrong aaa key for profile 0 for m350(A). But if you write the same akey from m350(B) to M350(A) then you do the ##RTN# M350(A) will generate the right AAA key for profile 0
The Following 3 Users Say Thank You to cellularman89 For This Useful Post:
Old 06-23-2015, 19:05   #36 (permalink)
Member: 2146354
Thanks Meter: 21
SO in theory
If you have a akey calculator where you can input the meid and it spits out the correct akey for boost mobile then you could use 1 donor such as a seek m350.
The Following 2 Users Say Thank You to cellularman89 For This Useful Post:
Old 06-23-2015, 20:40   #37 (permalink)
Member: 2076039
Thanks Meter: 648
THANK YOU!!
If youre on anything higher than ICS (i believe) then you wont be able to pull the keys using a CDMA tool. Youre going to need to log them out of the phone.
Old 06-23-2015, 23:25   #38 (permalink)
Member: 2295165
Thanks Meter: 15
yall will get it lol
Old 06-24-2015, 05:21   #39 (permalink)
Member: 554699
Thanks Meter: 52
That's correct. Or you can try a different phone to pull keys from if you want to use QPST, CDMA Workshop, etc. I think an HTC EVO 3D will also work.
A little off topic. Are you guys able to use Tapatalk here?
Old 06-25-2015, 01:46   #40 (permalink)
Member: 2146354
Thanks Meter: 21
Yes im currently using tapatalk
Sent from my SM-G900P using Tapatalk
Old 06-26-2015, 00:16   #41 (permalink)
Member: 2295165
Thanks Meter: 15
Now Flashing the Spint Galaxy S6 / S6 Edge
Old 06-26-2015, 09:20   #42 (permalink)
Member: 554699
Thanks Meter: 52
What version? I'm just getting errors when I attempt to login with Tapatalk .
Nevermind. There's a similarly named forum in Tapatalk that I thought was this. Duh! Damn, I'm getting old.
Old 06-28-2015, 00:22   #43 (permalink)
Member: 2295165
Thanks Meter: 15
Removing post still learning this app
Old 06-28-2015, 01:42   #44 (permalink)
Member: 2295165
Thanks Meter: 15
the verizon note 4 on 5.0 can not be flashed with the meid being changed
Old 06-28-2015, 05:24   #45 (permalink)
Member: 554699
Thanks Meter: 52
What happens when you downgrade the Verizon Note 4 to KitKat? Does the flash work, then?
Sent from my SM-N915V using Tapatalk
Page generated in 0.19791 seconds with 8 queries
