06-20-2015, 02:52 | #31 (permalink) |
Junior Member Join Date: Jun 2015
Member: 2413077 Status: Offline Thanks Meter: 0 | |
06-20-2015, 14:04 | #32 (permalink) | |
Banned Join Date: Nov 2013 Location: Chicago, IL
Member: 2076039 Status: Offline Thanks Meter: 648 | Quote:
06-22-2015, 21:39 | #33 (permalink) |
Freak Poster Join Date: Jul 2007
Member: 554699 Status: Offline Thanks Meter: 52 | I guess with this brute force technique and auto generating associated profile 1 info, all you need is a single donor just to pull keys with. This technique can be applied not just on Samsung phones, but any phone in general...as long as you have a method of flashing/setting up profile 1 info, you'll have a fully flashed phone. |
The Following User Says Thank You to AlpineMan For This Useful Post: |
06-23-2015, 02:51 | #34 (permalink) |
Insane Poster Join Date: Mar 2014
Member: 2146354 Status: Offline Thanks Meter: 21 | pulling aaa keys from s3 Hey guys. Im an experienced flasher. The problem Im having is pulling the aaa keys on profile 1 from a s3. I have both cdma workshop and dfs. I keep getting access denied problem. any help? THANK YOU!! |
06-23-2015, 18:53 | #35 (permalink) |
Member: 2146354 Status: Offline Thanks Meter: 21 | Also the aaa key for profile 0 ( or hdr an long ) is generated by the akey and the esn. If you have the akey to that esn when you do ##RTN# it will calculate the correct 32 bit hdr long an. I have experimented on a seek to confirm. If you write a new meid on a m350(A) from another m350(B) and do ##786# it will generate the wrong aaa key for profile 0 for m350(A). But if you write the same akey from m350(B) to M350(A) then you do the ##RTN# M350(A) will generate the right AAA key for profile 0 |
The Following 3 Users Say Thank You to cellularman89 For This Useful Post: |
06-23-2015, 20:40 | #37 (permalink) |
Member: 2076039 Status: Offline Thanks Meter: 648 | If youre on anything higher than ICS (i believe) then you wont be able to pull the keys using a CDMA tool. Youre going to need to log them out of the phone. |
06-24-2015, 05:21 | #39 (permalink) | |
Member: 554699 Status: Offline Thanks Meter: 52 | Quote:
A little off topic. Are you guys able to use Tapatalk here? | |
