05-05-2016, 17:49 | #1 (permalink) |
No Life Poster Join Date: May 2014 Location: Nigeria
Member: 2192386 Status: Offline Thanks Meter: 50 | Samsung SM-N920V Reboot Code: #Manual Mode# --Applying Multi-CSC... Applied the CSC-Code : VZW Succesully applied multi-CSC --Wiping data... Formatting /data... Formatting /cache... -- Set Factory Reset done... -- Copying media files... -- preload checking... E:failed to mount /preload (No such file or directory) Data wipe complete. -- Wiping cache... Formatting /cache... Cache wipe complete. -- Wiping data... Formatting /data... Formatting /cache... -- Set Factory Reset done... -- Copying media files... -- preload checking... E:failed to mount /preload (No such file or directory) Data wipe complete. |
05-06-2016, 15:00 | #2 (permalink) |
Junior Member Join Date: May 2016
Member: 2568491 Status: Offline Sonork: markinfiltrado Thanks Meter: 0 | can you help me?? in another forum they told me that download only modem MODEM: N920VVRU2AOGJ MODEM: N920VVRU2AOJ2 You know where I download only the modem ??? I tried modem (CP) only first, then SCS (CS) and didn't workin until I flashed system (AP) too.[/QUOTE] good. who helps me. I have a n920v I get used to me. I put the chip and reconose and gets 4g lte and the internet works perfect. but they do not leave me and go llamandas, when I call 4g falls and rises. note: the imei is clean in Dominican Republic. I can do in that case ??? and you change the SÖFW has 6.0 and 5.1 remains the same |
