Huawei CDMA Huawei CDMA Related |
07-06-2013, 07:41 | #1 (permalink) |
Junior Member Join Date: Jun 2011 Location: www.*******
Member: 1595542 Status: Offline Thanks Meter: 5 | New huawei m931 metropcs how to enter code I tgink this phone is set on default cdma, no option to change this to lte. I ewven installed phone info but cant find how to enter code. |
12-11-2013, 14:44 | #6 (permalink) |
Junior Member Join Date: Aug 2011 Location: spain
Member: 1628273 Status: Offline Thanks Meter: 4 | How To Unlock Huawei: 1. Turn ON the phone with an Unauthorized Sim Card. 2. Pone will prompt for Unlock Code. 3. Enter Unlock Code. 4. Phone now Unlocked. If Huawei phone ask for a "Simlock Block Unlock Reset Key" after you insert another Network SIM Card, this means your phone is blocked because of too much wrong code. In this case you must enter the 2nd code, 3rd code, and 4th code separately until the phone display “Sim Network Unlock Pin”, and then you enter the 1st code to unlock the phone. 1. Turn ON the phone with an Unauthorized Sim Card. 2. Enter the 2nd code. 3. Enter the 3rd code. 4. Enter the 4th code. 5. Enter the 1st code. 6. Phone now Unblocked and Unlocked. |
12-11-2013, 14:44 | #7 (permalink) |
Member: 1628273 Status: Offline Thanks Meter: 4 | If Huawei phone ask for a "Simlock Block Unlock Reset Key" after you insert another Network SIM Card, this means your phone is blocked because of too much wrong code. In this case you must enter the 2nd code, 3rd code, and 4th code separately until the phone display “Sim Network Unlock Pin”, and then you enter the 1st code to unlock the phone. 1. Turn ON the phone with an Unauthorized Sim Card. 2. Enter the 2nd code. 3. Enter the 3rd code. 4. Enter the 4th code. 5. Enter the 1st code. 6. Phone now Unblocked and Unlocked. |
