Huawei CDMA Huawei CDMA Related |
01-07-2017, 06:33 | #18 (permalink) |
Major Poster Join Date: Oct 2012
Member: 1832660 Status: Offline Sonork: [email protected] Thanks Meter: 8 | i want nokia windos phone usb driver needad pls give me brosssssssssss try 100% ok QHSUSB_DLOAD Drivers Download for Windows 10, 8.1, 7, Vista, XP |
08-05-2017, 09:53 | #19 (permalink) |
Freak Poster Join Date: May 2017 Location: georgia Age: 23
Member: 2722292 Status: Offline Thanks Meter: 24 | https://www.4shared.com/file/BeF9Nyv...ier_driver.htm try this version |
05-04-2018, 09:53 | #24 (permalink) |
Major Poster Join Date: Sep 2016 Location: Serbia Age: 26
Member: 2627895 Status: Offline Thanks Meter: 6 | Drivers for both 64 bit and 32 bit You have 2 ways to fix QHUSB_bulk or qualcomm missing drivers. Both method have been tested by me. Method 1: Download the unsinged driver from the link below. (Very IMPORTANT): Make sure you have driver signature enforcement disabled! Here's a guide for Windows 10: https://windowsreport.com/driver-sig...nt-windows-10/ After succsesfuly disabling the driver signature enforcemen, you can manually install your driver. Simply go to device manager, right click on non installed driver and chose "Update Driver Software". Than follow the rest of the process, and manually pick the downloaded driver. You will be given an option of many drivers, but what you want to install is "Qualcomm Hs USB Qdloader 9008" and install it. Unsinged QHSUSB_bulk driver: https://forum.xda-developers.com/sho....php?t=2226445 Method 2: Download the singed driver from below, and install the given program. It will automatically add the necessary drivers. If the issue still remains, than you have to do the following: Go to device manager, right click on non installed driver and chose "Update Driver Software". Than follow the rest of the process, and manually open the following directory [C:\Program Files (x86)\QUALCOMM Incorporated\Qualcomm USB Drivers For Windows\DriverPackage\Qualcomm\Fre\Windows8]. Note that if you installed it on different partition, you will have to find it there and if your using Windows 7 chose it instead. (Windows 8 driver works perfectly on Windows 10) You will be given an option of many drivers, but what you want to install is "Qualcomm Hs USB Qdloader 9008" and install it. Singed QHSUSB_bulk drivers (Works with Windows 10 as well): https://www.androidbrick.com/downloa...rivers-signed/ |
need ericsson 88 cable | migdamas | Old Ericsson Phones & Sony Phones | 2 | 03-24-2017 16:24 |
DES key Driver | black | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 02-08-2014 04:50 |
needed pinout for carkit(N61xx) | mobileinfo | Nokia Hardware & Hardware Repair | 2 | 07-23-2013 02:41 |
need eeprom photo???? | mobileinfo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 05-26-1999 11:35 |
