Go Back   GSM-Forum > Other Gsm/Mobile Related Forums > CDMA Modems , Routers , Aircard
CDMA Modems , Routers , Aircard All About CDMA Modems Routers and Aircards
Old 01-30-2014, 05:40   #1 (permalink)
gsmsikar's Avatar
Member: 28004
Sonork: 100.1601142
Thanks Meter: 770
ec315 huawei data card unlock ?
is it possible to make RUIM of Huawei ec315 data card given by MTS ?
Old 05-03-2014, 06:26   #2 (permalink)
Member: 1272691
Have a question on similar lines, i want to use the EC315 tata max wifi on Tata network only, my requirement is to enable the sim slot, i am ok with the same dashboard too.
Is it possibile to get the SPC code for EC315 to change the settings from NV to RUIM and get a tata sim to work in the wingle.
Old 05-04-2014, 17:52   #3 (permalink)
TestBox2's Avatar
Member: 772096
Sonork: 100.69222
Thanks Meter: 8,277
Mkey - Modem Unlock Key can read and zet to zerro SPC , also can write NVM settings on this modem.
http://forum.gsmhosting.com/vbb/f695/
Old 05-05-2014, 04:27   #4 (permalink)
Member: 1272691
Well i have been able to get the SPC and get to the option of saving the settings also, the issue i am facing now is post saving the settings as RUIM it gets reset to NV only whenever the dongle is rebooted. The settings are not sticking and it is jumping back to NV every time, tried a different firmware also but no luck. Tried different softwares like CDMA workshop, different version of DFS also but no go.
Any help would be appreciated.
Old 05-11-2014, 16:33   #5 (permalink)
TestBox2's Avatar
Member: 772096
Sonork: 100.69222
Thanks Meter: 8,277
Very Easy to do All by MKEY software!
Be sure EC315 Mkey can do ALL !
- ESN Repair
- Unlock
- Flash
- Repair Half-dead modems Without Jtag
And more!
UNLOCK:
18.17.21 : --------------- Read device information -----------------------
18.17.21 : Model: SCAUTHZ3
18.17.21 : IMEI: 000000-00-000000-0
18.17.21 : Firmware ID: 11.102.53.00.00
18.17.22 : PCB Version: EC315-1CE1EC315M Ver.A
18.17.22 : Firmware upgrade code: 38554571
18.17.22 : Build: MAY 12 201215:23:06MAR 12 201112:00:00*
18.17.22 : ---------------- Scan SPC reset -------------------------------
18.17.22 : Scanning EFS SPC...Method2
18.17.27 : SPC Found: 000000
18.17.27 : Unlocking MIN-Lock .. Ok
18.17.27 : Write defoult SPC 000000 Ok
18.17.31 : --------------------------- E N D. ----------------------------
ESN REPAIR:
18.18.00 : --------------- Read device information ---------------------
18.18.00 : Current ESN: 00ABCDEF
18.18.00 : Write repaired ESN: 12345678 Ok
18.18.02 : --------------------------- E N D. ----------------------------
FLASHING:
18.22.46 : --------------- Read device information --------------------
18.22.54 : Model: SCAUTHZ3
18.22.54 : IMEI: 000000-00-000000-0
18.22.54 : Firmware ID: 11.102.53.00.00
18.22.54 : Flash type: MT29F2G16AB ID: ADB1
18.22.54 : PCB Version: EC315-1CE1EC315M Ver.A
18.22.54 : Firmware upgrade code: 38554571
18.22.54 : Build: MAY 12 201215:23:06MAR 12 201112:00:00*
18.22.54 : QCOM CPU - TYPE Identified.
18.23.12 : Open Flashing Protocol OK
18.23.34 :
18.23.41 : --------------- Flash-mode operations ------------------------
18.23.42 : Verify download mode: Q62XX-OSBL
18.23.44 : Detected: [HUAWEI EC315]
18.23.45 : Server REQ: [Available credits: 492]
18.23.54 : MDM69XX - Router QCOM CPU mode Selected.
18.23.55 : Write Part1...[PARTITION] Ok
18.23.59 : Write Part2...[DBL] Ok
18.24.06 : Write Part3...[OSBL] Ok
18.24.13 : Write Part4...[AMSS] Ok
18.25.39 : Write Part5...[NVINFO] Ok
18.25.45 : Write Part6...[ISOHDR] Ok
18.25.48 : Write Part7...[ISO] Ok
18.26.15 : Write Part8...[WEBAPPHDR] Ok
18.26.18 : Write Part9...[WEBAPP] Ok
18.27.47 : All done !
18.27.49 : - Flashing Completed!
18.27.51 : --------------------------- E N D. -----------------------------
More info you found here: http://forum.gsmhosting.com/vbb/f695/
Old 09-10-2014, 09:00   #6 (permalink)
Member: 2250543
how to unlock huawei ec315
i have mkey dongle.
com port not detect
Old 09-15-2014, 10:57   #7 (permalink)
Member: 1430343
Thanks Meter: 11
EC315 Unlock Ec306 Unlock 100% Possible
EC315 Unlock Ec306 Unlock 100% Possible, But not free.
Already unlocked Tested OK
Working Reliance/Tata Cdma/ MTS Simcard
Old 09-19-2014, 12:59   #8 (permalink)
Member: 1667874
unlocking poassible 100%
Old 09-19-2014, 13:09   #9 (permalink)
Member: 2253249
Thanks Meter: 29
bro 100% tested u r con no plz ur send logs
Old 09-19-2014, 16:24   #10 (permalink)
satyanyadav's Avatar
Member: 1777416
Sonork: 100.1647840
Thanks Meter: 129
Ec 315 unlock
unlock via mkey bro
Old 09-20-2014, 04:56   #11 (permalink)
Member: 1667874
Mkey can not do all....
Sent from my GT-I8262 using Tapatalk
Old 09-20-2014, 04:57   #12 (permalink)
Member: 1667874
We have customized filea to flash via another tools not mkey
Old 09-20-2014, 18:31   #13 (permalink)
Member: 1667874
unlocking 100% possible with sms interface with rev b working
https://lh6.googleusercontent.com/-n...-h577-no/2.png
Old 09-24-2014, 19:51   #14 (permalink)
mediapeople's Avatar
Member: 759477
Sonork: 100.1618763
Thanks Meter: 111
TEST BOX in you shows flashing logs also so where is flash file downloading link
Old 09-25-2014, 02:02   #15 (permalink)
Member: 1667874
Bro testbox files not worked for me.
We have different methods to unlock these device
I had msg also doctor mobile
Send log to him .
Then he told me he want modem in his hand.
And told us that
It us not success ful on that.
Check his huawei ec1260 and other solutions r like that.
Page generated in 0.28715 seconds with 9 queries
