CDMA Modems , Routers , Aircard All About CDMA Modems Routers and Aircards |
05-03-2014, 06:26 | #2 (permalink) |
Junior Member Join Date: Mar 2010
Member: 1272691 Status: Offline Thanks Meter: 0 | Have a question on similar lines, i want to use the EC315 tata max wifi on Tata network only, my requirement is to enable the sim slot, i am ok with the same dashboard too. Is it possibile to get the SPC code for EC315 to change the settings from NV to RUIM and get a tata sim to work in the wingle. |
05-04-2014, 17:52 | #3 (permalink) |
Product Manager Join Date: May 2008 Location: Ukraine Age: 45
Member: 772096 Status: Offline Sonork: 100.69222 Thanks Meter: 8,277 | Mkey - Modem Unlock Key can read and zet to zerro SPC , also can write NVM settings on this modem. http://forum.gsmhosting.com/vbb/f695/ |
05-05-2014, 04:27 | #4 (permalink) |
Member: 1272691 Status: Offline Thanks Meter: 0 | Well i have been able to get the SPC and get to the option of saving the settings also, the issue i am facing now is post saving the settings as RUIM it gets reset to NV only whenever the dongle is rebooted. The settings are not sticking and it is jumping back to NV every time, tried a different firmware also but no luck. Tried different softwares like CDMA workshop, different version of DFS also but no go. Any help would be appreciated. |
05-11-2014, 16:33 | #5 (permalink) |
Member: 772096 Status: Offline Sonork: 100.69222 Thanks Meter: 8,277 | Very Easy to do All by MKEY software! Be sure EC315 Mkey can do ALL ! - ESN Repair - Unlock - Flash - Repair Half-dead modems Without Jtag And more! UNLOCK: 18.17.21 : --------------- Read device information ----------------------- 18.17.21 : Model: SCAUTHZ3 18.17.21 : IMEI: 000000-00-000000-0 18.17.21 : Firmware ID: 11.102.53.00.00 18.17.22 : PCB Version: EC315-1CE1EC315M Ver.A 18.17.22 : Firmware upgrade code: 38554571 18.17.22 : Build: MAY 12 201215:23:06MAR 12 201112:00:00* 18.17.22 : ---------------- Scan SPC reset ------------------------------- 18.17.22 : Scanning EFS SPC...Method2 18.17.27 : SPC Found: 000000 18.17.27 : Unlocking MIN-Lock .. Ok 18.17.27 : Write defoult SPC 000000 Ok 18.17.31 : --------------------------- E N D. ---------------------------- ESN REPAIR: 18.18.00 : --------------- Read device information --------------------- 18.18.00 : Current ESN: 00ABCDEF 18.18.00 : Write repaired ESN: 12345678 Ok 18.18.02 : --------------------------- E N D. ---------------------------- FLASHING: 18.22.46 : --------------- Read device information -------------------- 18.22.54 : Model: SCAUTHZ3 18.22.54 : IMEI: 000000-00-000000-0 18.22.54 : Firmware ID: 11.102.53.00.00 18.22.54 : Flash type: MT29F2G16AB ID: ADB1 18.22.54 : PCB Version: EC315-1CE1EC315M Ver.A 18.22.54 : Firmware upgrade code: 38554571 18.22.54 : Build: MAY 12 201215:23:06MAR 12 201112:00:00* 18.22.54 : QCOM CPU - TYPE Identified. 18.23.12 : Open Flashing Protocol OK 18.23.34 : 18.23.41 : --------------- Flash-mode operations ------------------------ 18.23.42 : Verify download mode: Q62XX-OSBL 18.23.44 : Detected: [HUAWEI EC315] 18.23.45 : Server REQ: [Available credits: 492] 18.23.54 : MDM69XX - Router QCOM CPU mode Selected. 18.23.55 : Write Part1...[PARTITION] Ok 18.23.59 : Write Part2...[DBL] Ok 18.24.06 : Write Part3...[OSBL] Ok 18.24.13 : Write Part4...[AMSS] Ok 18.25.39 : Write Part5...[NVINFO] Ok 18.25.45 : Write Part6...[ISOHDR] Ok 18.25.48 : Write Part7...[ISO] Ok 18.26.15 : Write Part8...[WEBAPPHDR] Ok 18.26.18 : Write Part9...[WEBAPP] Ok 18.27.47 : All done ! 18.27.49 : - Flashing Completed! 18.27.51 : --------------------------- E N D. ----------------------------- More info you found here: http://forum.gsmhosting.com/vbb/f695/ |
09-15-2014, 10:57 | #7 (permalink) |
Insane Poster Join Date: Oct 2010 Location: Earth
Member: 1430343 Status: Offline Thanks Meter: 11 | EC315 Unlock Ec306 Unlock 100% Possible EC315 Unlock Ec306 Unlock 100% Possible, But not free. Already unlocked Tested OK Working Reliance/Tata Cdma/ MTS Simcard |
09-20-2014, 18:31 | #13 (permalink) |
Junior Member Join Date: Oct 2011
Member: 1667874 Status: Offline Thanks Meter: 0 | unlocking 100% possible with sms interface with rev b working https://lh6.googleusercontent.com/-n...-h577-no/2.png |
09-25-2014, 02:02 | #15 (permalink) |
Member: 1667874 Status: Offline Thanks Meter: 0 | Bro testbox files not worked for me. We have different methods to unlock these device I had msg also doctor mobile Send log to him . Then he told me he want modem in his hand. And told us that It us not success ful on that. Check his huawei ec1260 and other solutions r like that. Sent from my GT-I8262 using Tapatalk |
