Go Back   GSM-Forum > Other Gsm/Mobile Related Forums > CDMA Modems , Routers , Aircard
CDMA Modems , Routers , Aircard All About CDMA Modems Routers and Aircards
Old 07-01-2014, 12:56   #1 (permalink)
ch wajid's Avatar
Member: 2203737
Sonork: 1656500
Thanks Meter: 462
Hard reset your Windows Mobile device
Here's how to do it:
Before performing a hard reset, disconnect the device from AC power. Note that whenever
“press the reset button” is stated below,
you must use your stylus in order to do so.
This is done by inserting the stylus into the small reset hole,
which is usually located on the back or on the bottom of the device.
ACER N50
Hold down the Today and the Mail buttons. Simultaneously press the reset button.
ACER N300
Hold down the Home and the Inbox buttons. Simultaneously press the reset button for about 2 seconds.
Asus A632 - A636
Hold down the power button and press in the reset button for about 6 seconds.
BenQ P50 - BenQ/Siemens P51
Hold down the power button and press in the reset button with your stylus for about 6 seconds.
Once the screen fades, press the power button again to activate the unit.
Dell Axim X3 - X3i - X30
Press and hold the power button while you press the reset button for about 6 seconds.
Release both buttons and you will see a confirmation screen asking you if you would like to clear all data in memory.
Then press the Contacts button. To cancel, press the Mail button.
Dell Axim x50 - x50v - x51 - x51v
Turn the device ON. Press and hold the power button while you press the reset button for about 6 seconds.
E-TEN M500
Hold down the power button and then press the reset button for about 6 seconds.
E-TEN M600
Hold down the power button and the (CTRL - ALT!) button simultaneously, and then press the reset button for about 2 seconds.
Then release all buttons at the same time.
HP iPAQ h1900 Series (1910 - 1915 - 1930 - 1935 - 1940 - 1945), HP iPAQ h6300 Series (6310 - 6315)
Hold down the power button and press the reset button for about 6 seconds.
HP iPAQ h2000 Series (2210 - 2215)
Hold down the Calendar and iTask buttons, and then press the reset button for about 6 seconds. After the screen fades,
release all buttons. You can verify the hard reset by pressing the power button. If the device does not power on,
then you have successfully reset you unit. Now you can connect it to AC power or
press the reset button again with your stylus.
HP iPAQ h5000 Series (5450 - 5550 - 5555), HP iPAQ h3800 Series (3830 - 3835 - 3850 - 3855 - 3870 - 3875)
you can verify the hard reset by pressing the power button. If the device does not power on,
then you have successfully reset your unit. Now you can connect the iPAQ to AC power or
HP iPAQ hw6500 Mobile Messenger Series (6510 - 6515), iPAQ hx2000 Series (2410 - 2415 - 2710 - 2715) and HP iPAQ hx4700 -
hx4705
The Pocket PC should reset and power back on. If the device does not power back on,
make sure that the battery lock switch is set to the left.
HP rw6828 - O2 XDA Atom - O2 XDA Atom Pure
Press the reset button with your stylus, then press the power ON/OFF button at the same time.
A confirmation screen should ask you to press the green Call and the red End Call buttons together.
HP iPAQ rz1700 Series (1710 - 1715)
Hold the Mobile Media and the Today buttons, then press reset button for about 4 seconds. To confirm,
press the power button. If the device does not turn on, then you have successfully hard reset your device.
Now you can connect the iPAQ to AC power or press the reset button again with your stylus.
HP iPAQ rx3115 - rx3715
Hold down on the far left (Mobile Media and the iTask buttons) then press the reset button for about 6 seconds.
HTC Apache - Sprint PPC-6700 - Verizon XV6700
Hold both the soft keys (buttons with “-“ on them) and push the reset button once.
Release just the reset button while still holding onto the soft keys.
A confirmation screen should appear asking if you want to reset all data. Press Y to reset, and N to cancel.
HTC Blue Angel - i-mate PDA2K - Siemens SX66 - T-Mobile MDA III
While holding down the power button, press in on the reset button (reset hole) with your stylus for about 6 seconds.
HTC Magician - Dopod 818 - O2 xda II mini - i-mate JAM - QTek S100 - T-Mobile MDA Compact
HTC Universal - T-Mobile MDA IV - Vodafone VDA IV - O2 XDA Exec - i-mate JasJar - QTek 9000 Orange - SPV M5000
Press the two soft keys together, then press the reset button on the back of the unit.
A confirmation screen should appear that reads, “Press 0 to reset to factory defaults or X to exit.
” Press “0” to confirm the factory reset.
HTC Wallaby - O2 XDA - QTek 1010 - Siemens SX56 - T-Mobile MDA
HTC Wizard - Cingular 8125 - i-mate K-JAM - T-Mobile MDA
Hold the Comm manager button and the Voice Command button, then press the reset button once.
Hold the Comm Manager and Voice Command buttons until there is a screen asking if you want to clear all data. To reset,
press the green Send key.
Mitac Mio 168
On the back of the unit, slide the battery switch to OFF. After about 1 minute,
slide the battery switch back to the ON position. The unit will restart with the default settings.
Mitac Mio A201
Remove the battery cover. Use the stylus to slide the battery switch to OFF. After about 1 minute,
slide the battery switch back to the ON position. Install the battery and immediately press the Record Button.
The screen should show “cold boot” and “loading......” Replace the battery cover.
Mitac Mio A701
The device must be turned off. Press and hold the down the volume button and the end button at the same time.
Release both buttons when the device vibrates. The unit will turn on automatically and the Setup Wizard will be displayed.
Follow the instructions to complete the hard reset process.
Palm Treo 700w
Hold the Power-End button and then press the reset button. When the confirmation screen asks you
“Do you want to erase all data?” you can release the Power-End button and press the up button on the
directional pad to confirm the hard reset.
Toshiba e310 - e330 - e335 - e350 - e355 - e400 - e405 - e570 - e740 - e750 - e755 - e800 - e805
The device should be off. Hold the power button and press the reset button, then release the power button.
When the screen appears, release the reset button.
Viewsonic V36 - V37
The device should be off. Slide the grey latch on the right-hand side of the unit to open the battery compartment.
Slide the short grey switch above the battery bay to the OFF position and remove the battery. After a few seconds,
insert the battery. Then slide the short grey switch above the battery bay to the ON position. Now,
replace the cover and slide the grey latch back to the lock position. Turn the unit ON.
The Following User Says Thank You to ch wajid For This Useful Post:
Page generated in 0.16871 seconds with 9 queries
