CDMA Modems , Routers , Aircard All About CDMA Modems Routers and Aircards |
05-04-2014, 17:46 | #2 (permalink) | |
Product Manager Join Date: May 2008 Location: Ukraine Age: 45
Member: 772096 Status: Offline Sonork: 100.69222 Thanks Meter: 8,277 | Quote:
You need use real software , Mkey can do real unlock + repair esn ets .. http://forum.gsmhosting.com/vbb/f695/ | |
05-11-2014, 16:31 | #4 (permalink) |
Member: 772096 Status: Offline Sonork: 100.69222 Thanks Meter: 8,277 | Be sure EC315 Mkey can do ALL ! - ESN Repair - Unlock - Flash - Repair Half-dead modems Without Jtag And more! UNLOCK: 18.17.21 : --------------- Read device information ----------------------- 18.17.21 : Model: SCAUTHZ3 18.17.21 : IMEI: 000000-00-000000-0 18.17.21 : Firmware ID: 11.102.53.00.00 18.17.22 : PCB Version: EC315-1CE1EC315M Ver.A 18.17.22 : Firmware upgrade code: 38554571 18.17.22 : Build: MAY 12 201215:23:06MAR 12 201112:00:00* 18.17.22 : ---------------- Scan SPC reset ------------------------------- 18.17.22 : Scanning EFS SPC...Method2 18.17.27 : SPC Found: 000000 18.17.27 : Unlocking MIN-Lock .. Ok 18.17.27 : Write defoult SPC 000000 Ok 18.17.31 : --------------------------- E N D. ---------------------------- ESN REPAIR: 18.18.00 : --------------- Read device information --------------------- 18.18.00 : Current ESN: 00ABCDEF 18.18.00 : Write repaired ESN: 12345678 Ok 18.18.02 : --------------------------- E N D. ---------------------------- FLASHING: 18.22.46 : --------------- Read device information -------------------- 18.22.54 : Model: SCAUTHZ3 18.22.54 : IMEI: 000000-00-000000-0 18.22.54 : Firmware ID: 11.102.53.00.00 18.22.54 : Flash type: MT29F2G16AB ID: ADB1 18.22.54 : PCB Version: EC315-1CE1EC315M Ver.A 18.22.54 : Firmware upgrade code: 38554571 18.22.54 : Build: MAY 12 201215:23:06MAR 12 201112:00:00* 18.22.54 : QCOM CPU - TYPE Identified. 18.23.12 : Open Flashing Protocol OK 18.23.34 : 18.23.41 : --------------- Flash-mode operations ------------------------ 18.23.42 : Verify download mode: Q62XX-OSBL 18.23.44 : Detected: [HUAWEI EC315] 18.23.45 : Server REQ: [Available credits: 492] 18.23.54 : MDM69XX - Router QCOM CPU mode Selected. 18.23.55 : Write Part1...[PARTITION] Ok 18.23.59 : Write Part2...[DBL] Ok 18.24.06 : Write Part3...[OSBL] Ok 18.24.13 : Write Part4...[AMSS] Ok 18.25.39 : Write Part5...[NVINFO] Ok 18.25.45 : Write Part6...[ISOHDR] Ok 18.25.48 : Write Part7...[ISO] Ok 18.26.15 : Write Part8...[WEBAPPHDR] Ok 18.26.18 : Write Part9...[WEBAPP] Ok 18.27.47 : All done ! 18.27.49 : - Flashing Completed! 18.27.51 : --------------------------- E N D. ----------------------------- More info you found here: http://forum.gsmhosting.com/vbb/f695/ |
09-01-2014, 20:55 | #6 (permalink) |
Junior Member Join Date: Sep 2014
Member: 2250543 Status: Offline Thanks Meter: 0 | Sir I have bought mkey doungle. I am successfully unlock huawei ec1561. but Huawei ec315 com port not detect. tata docomo photon max wifi ec315. can u help me? my english is not good so sorry. |
11-26-2014, 16:42 | #12 (permalink) |
Insane Poster Join Date: Oct 2010 Location: Earth
Member: 1430343 Status: Offline Thanks Meter: 11 | nvm mode not able to change i write ruim file no use tested mts ec315 and tata ec315 Flash done Unlock done Ruim_Only file write done But can"t changed ruim modem, only nvm mode nvm mode not able to change i write ruim file no use tested mts ec315 and tata ec315 This problem latest ec315 models India Already old ec315 unlock done ruim mode changed 20.21.31 : --------------- Read device information ----------------------- 20.21.39 : Model: SCAUTHZ3 20.21.39 : IMEI: 000000-00-000000-0 20.21.39 : Firmware ID: 11.102.53.00.00 20.21.39 : Flash type: MT29F2G16AB ID: ADB1 20.21.39 : MEID: 26843546336841877 : Hex A0000049686615 20.21.39 : PCB Version: EC315-1CE1EC315M Ver.A 20.21.40 : Build: MAY 12 201215:23:06MAR 12 201112:00:00: 20.21.40 : QCOM CPU - TYPE Identified. 20.21.56 : Open Flashing Protocol OK 20.22.18 : 20.22.27 : --------------- Flash-mode operations ------------------------ 20.22.29 : Verify download mode: Q62XX-OSBL 20.22.33 : Detected: [HUAWEI EC315] 20.22.44 : MDM69XX - Router QCOM CPU mode Selected. 20.22.46 : Write Part1...[PARTITION] Ok 20.22.53 : Write Part2...[DBL] Ok 20.23.03 : Write Part3...[OSBL] Ok 20.23.14 : Write Part4...[AMSS] Ok 20.25.58 : Write Part5...[NVINFO] Ok 20.26.08 : Write Part6...[ISOHDR] Ok 20.26.13 : Write Part7...[ISO] Ok 20.27.01 : Write Part8...[WEBAPPHDR] Ok 20.27.06 : Write Part9...[WEBAPP] Ok 20.29.05 : All done ! 20.29.07 : - Flashing Completed! 20.29.08 : --------------------------- E N D. -------------------------------- 20.32.14 : --------------- Read device information ----------------------- 20.32.15 : Model: SCAUTHZ3 20.32.15 : IMEI: 000000-00-000000-0 20.32.15 : Firmware ID: 11.102.53.00.00 20.32.15 : MEID: 26843546336841877 : Hex A0000049686615 20.32.15 : PCB Version: EC315-1CE1EC315M Ver.A 20.32.15 : Firmware upgrade code: 44747196 20.32.15 : Build: MAY 12 201215:23:06MAR 12 201112:00:00: 20.32.15 : ---------------- Scan SPC reset --------------------------------- 20.32.16 : Scanning EFS SPC...Method2 20.32.24 : SPC Found: 000000 20.32.24 : Unlocking MIN-Lock .. Ok 20.32.24 : Write defoult SPC 000000 Ok 20.32.27 : --------------------------- E N D. -------------------------------- 20.43.01 : --------------- Read device information ----------------------- 20.43.03 : Model: SCAUTHZ3 20.43.03 : IMEI: 000000-00-000000-0 20.43.03 : Firmware ID: 11.102.53.00.00 20.43.03 : Flash type: MT29F2G16AB ID: ADB1 20.43.03 : MEID: 26843546336841877 : Hex A0000049686615 20.43.03 : PCB Version: EC315-1CE1EC315M Ver.A 20.43.03 : Build: MAY 12 201215:23:06MAR 12 201112:00:00: 20.43.09 : Loading NV file: CDMA_Ruim_Only.NVM 20.43.11 : --------------------------- E N D. -------------------------------- 20.38.18 : --------------- Read device information ----------------------- 20.38.20 : Model: SCAUTHZ3 20.38.20 : IMEI: 000000-00-000000-0 20.38.20 : Firmware ID: 11.102.53.00.00 20.38.20 : Flash type: MT29F2G16AB ID: ADB1 20.38.20 : MEID: 26843546336841877 : Hex A0000049686615 20.38.20 : PCB Version: EC315-1CE1EC315M Ver.A 20.38.20 : Build: MAY 12 201215:23:06MAR 12 201112:00:00: 20.38.29 : Loading NV file: CDMA_RUIM_Pref.NVM 20.38.32 : --------------------------- E N D. -------------------------------- |
06-01-2015, 07:27 | #15 (permalink) |
Banned Join Date: Sep 2010 Location: Lahore Pakistan
Member: 1393148 Status: Offline Sonork: change-the-lifestyle Thanks Meter: 0 | Yes brother Mkey can repair ESN of Huawei ec315-5 but we are unable to find com port in New ec315 may b lock. 100% teasted Mkey can do this..... |
