Go Back   GSM-Forum > Other Gsm/Mobile Related Forums > CDMA Modems , Routers , Aircard
CDMA Modems , Routers , Aircard All About CDMA Modems Routers and Aircards
Old 05-04-2014, 11:22   #1 (permalink)
Member: 879967
Thanks Meter: 33
HUWAEI EC315 ESN Repair
Anyone know how to repair Esn Huwaei EC315 ... I Have CDMA WS 3.9.0 ....Please Give Info How To ....
Old 05-04-2014, 17:46   #2 (permalink)
TestBox2's Avatar
Member: 772096
Sonork: 100.69222
Thanks Meter: 8,277
You need use real software , Mkey can do real unlock + repair esn ets ..
http://forum.gsmhosting.com/vbb/f695/
Old 05-06-2014, 08:02   #3 (permalink)
Member: 879967
Thanks Meter: 33
100% Sure repair Esn Huwei Ec315 ZTE ar910b Zte ac27xx series ...how much cost of this Software
Old 05-11-2014, 16:31   #4 (permalink)
TestBox2's Avatar
Member: 772096
Sonork: 100.69222
Thanks Meter: 8,277
Be sure EC315 Mkey can do ALL !
- ESN Repair
- Unlock
- Flash
- Repair Half-dead modems Without Jtag
And more!
UNLOCK:
18.17.21 : --------------- Read device information -----------------------
18.17.21 : Model: SCAUTHZ3
18.17.21 : IMEI: 000000-00-000000-0
18.17.21 : Firmware ID: 11.102.53.00.00
18.17.22 : PCB Version: EC315-1CE1EC315M Ver.A
18.17.22 : Firmware upgrade code: 38554571
18.17.22 : Build: MAY 12 201215:23:06MAR 12 201112:00:00*
18.17.22 : ---------------- Scan SPC reset -------------------------------
18.17.22 : Scanning EFS SPC...Method2
18.17.27 : SPC Found: 000000
18.17.27 : Unlocking MIN-Lock .. Ok
18.17.27 : Write defoult SPC 000000 Ok
18.17.31 : --------------------------- E N D. ----------------------------
ESN REPAIR:
18.18.00 : --------------- Read device information ---------------------
18.18.00 : Current ESN: 00ABCDEF
18.18.00 : Write repaired ESN: 12345678 Ok
18.18.02 : --------------------------- E N D. ----------------------------
FLASHING:
18.22.46 : --------------- Read device information --------------------
18.22.54 : Model: SCAUTHZ3
18.22.54 : IMEI: 000000-00-000000-0
18.22.54 : Firmware ID: 11.102.53.00.00
18.22.54 : Flash type: MT29F2G16AB ID: ADB1
18.22.54 : PCB Version: EC315-1CE1EC315M Ver.A
18.22.54 : Firmware upgrade code: 38554571
18.22.54 : Build: MAY 12 201215:23:06MAR 12 201112:00:00*
18.22.54 : QCOM CPU - TYPE Identified.
18.23.12 : Open Flashing Protocol OK
18.23.34 :
18.23.41 : --------------- Flash-mode operations ------------------------
18.23.42 : Verify download mode: Q62XX-OSBL
18.23.44 : Detected: [HUAWEI EC315]
18.23.45 : Server REQ: [Available credits: 492]
18.23.54 : MDM69XX - Router QCOM CPU mode Selected.
18.23.55 : Write Part1...[PARTITION] Ok
18.23.59 : Write Part2...[DBL] Ok
18.24.06 : Write Part3...[OSBL] Ok
18.24.13 : Write Part4...[AMSS] Ok
18.25.39 : Write Part5...[NVINFO] Ok
18.25.45 : Write Part6...[ISOHDR] Ok
18.25.48 : Write Part7...[ISO] Ok
18.26.15 : Write Part8...[WEBAPPHDR] Ok
18.26.18 : Write Part9...[WEBAPP] Ok
18.27.47 : All done !
18.27.49 : - Flashing Completed!
18.27.51 : --------------------------- E N D. -----------------------------
More info you found here: http://forum.gsmhosting.com/vbb/f695/
Old 08-05-2014, 08:20   #5 (permalink)
Member: 2160845
Thanks Meter: 2
thank you, very helpful info
Old 09-01-2014, 20:55   #6 (permalink)
Member: 2250543
Sir I have bought mkey doungle. I am successfully unlock huawei ec1561. but Huawei ec315 com port not detect. tata docomo photon max wifi ec315. can u help me?
my english is not good so sorry.
Old 09-02-2014, 08:05   #7 (permalink)
Member: 879967
Thanks Meter: 33
http://192.168.1.1/html/switchProjectMode.html
Use this IP......
And show comport
Old 09-09-2014, 18:50   #8 (permalink)
Member: 2250543
Sir i use this ip but not work
Old 09-11-2014, 17:53   #9 (permalink)
Member: 2250543
Sir I unlock my ec315 but network for found. how to enable sim slot?
Old 09-12-2014, 07:46   #10 (permalink)
Member: 879967
Thanks Meter: 33
Write RUIM NVM FILE MKEY DOWNLAOD SECTION....
Old 09-21-2014, 19:43   #11 (permalink)
Member: 2253249
Thanks Meter: 29
Bro any one proof it ec 315.306 unlock posible
Old 11-26-2014, 16:42   #12 (permalink)
Member: 1430343
Thanks Meter: 11
nvm mode not able to change i write ruim file no use tested mts ec315 and tata ec315
Flash done Unlock done Ruim_Only file write done
But can"t changed ruim modem, only nvm mode
This problem latest ec315 models India
Already old ec315 unlock done ruim mode changed
20.21.31 : --------------- Read device information -----------------------
20.21.39 : Model: SCAUTHZ3
20.21.39 : IMEI: 000000-00-000000-0
20.21.39 : Firmware ID: 11.102.53.00.00
20.21.39 : Flash type: MT29F2G16AB ID: ADB1
20.21.39 : MEID: 26843546336841877 : Hex A0000049686615
20.21.39 : PCB Version: EC315-1CE1EC315M Ver.A
20.21.40 : Build: MAY 12 201215:23:06MAR 12 201112:00:00:
20.21.40 : QCOM CPU - TYPE Identified.
20.21.56 : Open Flashing Protocol OK
20.22.18 :
20.22.27 : --------------- Flash-mode operations ------------------------
20.22.29 : Verify download mode: Q62XX-OSBL
20.22.33 : Detected: [HUAWEI EC315]
20.22.44 : MDM69XX - Router QCOM CPU mode Selected.
20.22.46 : Write Part1...[PARTITION] Ok
20.22.53 : Write Part2...[DBL] Ok
20.23.03 : Write Part3...[OSBL] Ok
20.23.14 : Write Part4...[AMSS] Ok
20.25.58 : Write Part5...[NVINFO] Ok
20.26.08 : Write Part6...[ISOHDR] Ok
20.26.13 : Write Part7...[ISO] Ok
20.27.01 : Write Part8...[WEBAPPHDR] Ok
20.27.06 : Write Part9...[WEBAPP] Ok
20.29.05 : All done !
20.29.07 : - Flashing Completed!
20.29.08 : --------------------------- E N D. --------------------------------
20.32.14 : --------------- Read device information -----------------------
20.32.15 : Model: SCAUTHZ3
20.32.15 : IMEI: 000000-00-000000-0
20.32.15 : Firmware ID: 11.102.53.00.00
20.32.15 : MEID: 26843546336841877 : Hex A0000049686615
20.32.15 : PCB Version: EC315-1CE1EC315M Ver.A
20.32.15 : Firmware upgrade code: 44747196
20.32.15 : Build: MAY 12 201215:23:06MAR 12 201112:00:00:
20.32.15 : ---------------- Scan SPC reset ---------------------------------
20.32.16 : Scanning EFS SPC...Method2
20.32.24 : SPC Found: 000000
20.32.24 : Unlocking MIN-Lock .. Ok
20.32.24 : Write defoult SPC 000000 Ok
20.32.27 : --------------------------- E N D. --------------------------------
20.43.01 : --------------- Read device information -----------------------
20.43.03 : Model: SCAUTHZ3
20.43.03 : IMEI: 000000-00-000000-0
20.43.03 : Firmware ID: 11.102.53.00.00
20.43.03 : Flash type: MT29F2G16AB ID: ADB1
20.43.03 : MEID: 26843546336841877 : Hex A0000049686615
20.43.03 : PCB Version: EC315-1CE1EC315M Ver.A
20.43.03 : Build: MAY 12 201215:23:06MAR 12 201112:00:00:
20.43.09 : Loading NV file: CDMA_Ruim_Only.NVM
20.43.11 : --------------------------- E N D. --------------------------------
20.38.18 : --------------- Read device information -----------------------
20.38.20 : Model: SCAUTHZ3
20.38.20 : IMEI: 000000-00-000000-0
20.38.20 : Firmware ID: 11.102.53.00.00
20.38.20 : Flash type: MT29F2G16AB ID: ADB1
20.38.20 : MEID: 26843546336841877 : Hex A0000049686615
20.38.20 : PCB Version: EC315-1CE1EC315M Ver.A
20.38.20 : Build: MAY 12 201215:23:06MAR 12 201112:00:00:
20.38.29 : Loading NV file: CDMA_RUIM_Pref.NVM
20.38.32 : --------------------------- E N D. --------------------------------
Old 12-26-2014, 19:32   #13 (permalink)
Member: 2317479
Huawei Ec315 MIN unlocked
Huawei EC315 how can Min Unlocked MCC MNC ?
what method use for unlocking with Mkey
step by step please .....
Old 05-30-2015, 21:45   #14 (permalink)
Member: 2317479
Huawei EC315 Min unlock
i buy Mkey where from download Flash for Min unlock EC-315
Mkey support web no have any Flash anyone know link for download
Old 06-01-2015, 07:27   #15 (permalink)
Member: 1393148
Sonork: change-the-lifestyle
Yes brother Mkey can repair ESN of Huawei ec315-5 but we are unable to find com port in New ec315 may b lock.
100% teasted Mkey can do this.....
Page generated in 0.23695 seconds with 8 queries
