Go Back   GSM-Forum > Other Gsm/Mobile Related Forums > CDMA Modems , Routers , Aircard
CDMA Modems , Routers , Aircard All About CDMA Modems Routers and Aircards
Old 05-20-2018, 15:29   #1 (permalink)
Member: 2543225
Thanks Meter: 12
Need Solution huawei b310s-927 can not enter router settings
huawei b310s-927 router after unlock can not access router setting using lan port but can access using wifi and internet ok
Old 05-21-2018, 14:32   #2 (permalink)
Cheater -Don't Deal with him-
Member: 2469340
Thanks Meter: 1,144
try to hard reset https://www.hardreset99.com/routers/...factory-reset/
Old 05-22-2018, 04:50   #3 (permalink)
Member: 2543225
Thanks Meter: 12
no its not work .... gateway is not showing using land port.. can access wifi
Old 05-22-2018, 08:07   #4 (permalink)
Member: 2469340
Thanks Meter: 1,144
did you unlock via flashing firmware or only unlock thru codes?
if you flash/update you need to reflash to the latest original firmware.
Page generated in 0.12929 seconds with 8 queries
