GSM / HSDPA Modems and Routers GSM , HSDPA , WCDMA, LTE Modems and Routers Unlock And Firmwares |
09-19-2018, 11:53 | #1 (permalink) |
Junior Member Join Date: Apr 2011
Member: 1554401 Status: Offline Thanks Meter: 0 | b310s-927 calling isnt working properly I have B310s-927 unlocked. currently using 21.328.03.00.00 even tried modified firmware from 4pda, calling always been unreliable. sometimes it works fine, sometimes it doesn't. network is good. i did erased firmware via boot points to flash it as stock, but still same. I also tried to keep network to 3g only still its doesn't work perfectly. where as internet works fine. I tried various firmware, modified firmware, web interface but it is same. any help please? I do it for research, or learning purpose, not for monetary gain, please if someone can help i will highly appreciate. |
09-19-2018, 12:06 | #2 (permalink) | |
No Life Poster Join Date: Oct 2016 Location: Developer
Member: 2634133 Status: Offline Thanks Meter: 2,939 | Quote:
which country your b310? are you use usbloader for unlock b310? tell | |
09-19-2018, 15:37 | #4 (permalink) |
Member: 1554401 Status: Offline Thanks Meter: 0 | m from India. I have used usbloader of 315 .. Modified one, normal b310 usbloader didn't work. Mine router came with latest airtel firmware . 328.284 . if I recollected correctly the firmware number. |
09-19-2018, 23:50 | #6 (permalink) | |
Member: 1554401 Status: Offline Thanks Meter: 0 | Quote:
i think i almost fixed it, by only choose band used by vodaphone, 3g band 2100 and 4g band 1800 and disabling 2g band. i will test it for two days, so i can conclude. yes. i thought so, and jio doesnt work in calling anyways. it has network switching problem, 4g to 3g/2g and again back to 3g/2g to 4g .. | |
09-20-2018, 03:15 | #7 (permalink) | |
set modem network settings auto when incoming calls appear then modem switch to 3g after call disconnect modem switch to 4g network | |
The Following User Says Thank You to balwinder27 For This Useful Post: |
01-22-2019, 12:03 | #10 (permalink) |
Junior Member Join Date: Sep 2007
Member: 584899 Status: Offline Thanks Meter: 0 | i have b310s-927 with the last firmware 21.323.03.00.1065 i tried to flash with Balong USB Downloader 1.0.1.10 but i always get this message. 0000: ED 05 FA 53 C0 now the modem is stuck in emergency mode ( no leds working and one COM port working ) and if i reset power form router it starts in emergency mode again with no leds and one COM port working i tried all usbloader but the same result If there is any solution... please help |
